I'm looking to turn off the instrument cluster SERVICE indicator in my recently acquired 2003 A4 3.0L Sedan. From the on-line RT manual, I found ...
Home >Products >VCDS >Support >Car Info & Procedures >Audi Service Interval Reminders
This looks to be a straight forward procedure using my VCDS-Lite, but I would like to verify that it is correct for my 03 A4. I'm guessing the "and" between 1998 and 2008 is a typo and should read "through".
Additionally, I'm also guessing that the indicator trigger is a fixed mileage (or time) value that is stored elsewhere. Is there a procedure for changing this value?
Thanks for your help.
1998 and 2008 (for 2009+ you will need to use the SRI Reset button):
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter channel 02
[Read]
The "Stored Value" is the current value for that channel.
Enter the "New" value of 0 (zero)
[Test]
[Save]
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter channel 02
[Read]
[Test]
[Save]
