2017 NAR Jetta disable traction control (ESC)
gokarty
C?ID=401142
Hi,
Is it possible to use VCDS to disable traction control/ESC on a NAR 2017 Jetta 1.8t ?
I know some kits are available to install a button to turn off ESC but can VCDS turn off traction control (without a button or wire)?
Thanks!
Auto-Scan:
Saturday,04,April,2020,23:53:03:39190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
VIN: 3VWL17AJ2HM299863   License Plate: REFRENCE_SCAN
Mileage: 61170km-38009mi   Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 02 03 04 05 08 09 13 15 17 19 25 2B 3C 44 5F 61 75
VIN: 3VWL17AJ2HM299863   Mileage: 61170km-38009miles
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BE    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 4889
   Revision: --H13---
   Coding: 001A0092244400175000
   Shop #: WSC 00066 790 00015
   ASAM Dataset: EV_ECM18TFS02006K906071BE 001009
   ROD: EV_ECM18TFS02006K906071BE.rod
   VCID: 6FBBD54837149D13BA8-803B
Readiness: 1110 1101
   Part No SW: 09G 927 158 BC    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3114
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW26.rod
   VCID: 75B7E7205548A7C3704-8021
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B400C492B0003851302EA921C004100F0F01A
   Shop #: WSC 00066 790 00295
   VCID: 75B7E72055C8A7C3704-8021
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0418626241
   Coding: 032C0C
   Shop #: WSC 12345 123 61029
   VCID: 392F2B1039D003A354C-806D
   Part No SW: 1K8 907 044 CL    HW: 1K8 907 044 CL
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 0050019002
   VCID: 7BA3F118736CF1B3060-802F
   Part No SW: 7E0 937 190 B    HW: 7E0 937 190
   Component: BCM PQ25 Max3 H81 0744
   Revision: B8081001    Serial number: 88003324160043
   Coding: 7B994B9A08AB0B000939268024C886C54BC6720E60A571F0B0A050032844
   VCID: 2B030158C30CA133D60-807F
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 051016 04  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  022 1467
   Serial number: 14102743161111040253
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  022 1467
   Serial number: 14102742161107144632
   Coding: 820000
   Subsystem 4 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST00183XGP00000
   Coding: 180000
   Subsystem 5 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B
   Serial number: 2771623205202400AF1B
   Coding: 2C0000
   Subsystem 6 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14102745161111130501
   Subsystem 7 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14202744161107074551
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 24111604380638
   Coding: 01005002FE0779
   ROD: EV_ACCBEGVW361.rod
   VCID: 3635202C08CEECDBB9E-8063
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM09RC9D
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 6393A978EBDC29732E0-8037
   Serial number: IBH0000000000063C6NA
   Coding: 303146
   Subsystem 2 - Part No SW: -----------    HW: 480 002 510 16
   Serial number: 3570000000075D84DE1.
   Subsystem 3 - Part No SW: -----------    HW: 480 002 510 16
   Serial number: 3580000000094784DE1X
   Subsystem 4 - Part No SW: -----------    HW: 480 020 810 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B72303C93847-
   Subsystem 5 - Part No SW: -----------    HW: 480 020 810 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001B72303C93883.
   Subsystem 6 - Part No SW: -----------    HW: 480 022 710 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001C1223536345FW
   Subsystem 7 - Part No SW: -----------    HW: 480 022 710 16
   Component: FrontSensor_P  000 0189
   Serial number: 35600019D22AFFC6626R
   Part No SW: 5C6 920 976 D    HW: 5C6 920 976 D
   Component: KOMBI         H02 1104
   Coding: 221A010000
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 333319381BBCF9F39E0-8067
   Part No SW: 7E0 909 901     HW: 7E0 937 190
   Component: GW-K-CAN TP20 H81 0744
   Revision: B8081001
   Coding: 102203
   VCID: 6889BE54127A4A2BFB2-803D
   Component: IMMO          H02 1104
   Coding: 000007
   Shop #: WSC 00066 790 00318
   VCID: 6A8DC45C0CF6783BED6-803F
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000164262007
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW31.rod
   VCID: 313F1330E1A0CBE3ECC-8065
   Serial number: 0419928869
   Coding: 01011101
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C21320436E2368B4FA-8069
   Lane Change Assistant 2:
   Serial number: 0417102021
   Coding: 010111
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F2B10355003A354C-806D
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H31 0359
   Serial number: VWZAZ2S0626354
   Coding: 02630102BE00000051220001001808009F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2411EA64AE526E4B17A-8071
   Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
   Part No SW: 7E0 907 534     HW: 7E0 937 190
   Component: Batt.regelung H81 0744
   Coding: 01240859
   Shop #: WSC 45359 001 1048576
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0160
   Serial number: 000003554140557
   Coding: 02630102C24232107F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 1471BAA47EF21ECBE7A-8041
End----------(Elapsed Time: 01:39, VBatt start/end: 13.9V/13.9V)-----------
TBAx
C?ID=287144
Uhm, I don't think this is possible. There are tweaks to disable the ESC upon long-pressing the according button. But I don't see any way to disable the ESC without said button.
gokarty
C?ID=401142
Jetta,97
Thanks for the video however disabling ESC via the gas pedal only allows you to drive a few feet before it reengages. According to some sources online, VW gives that "feature" so that you can disable traction control if you're stuck in snow but it automatically re-enables after 5 feet of movement
I was looking more for a longer lasting solution (without a traction control button retrofit)
However, thanks for the help!
Regards,
gokarty
gokarty
C?ID=401142
TBAx,
There are videos online that show recoding the ABS control unit when retrofitting the traction control button. Is it possible that there could be a coding that allows for traction control to be disabled?
Some people are indicating that pulling the ABS fuse is an option but that's not what I would want to drive around with
