Golf 7 tsi 1.0
automania
South Africa
C?ID=316086
golf 7 tsi came in with no start issue i run a test with my vcds i found 3 fault code i found the following fault code u0151 p1429 but the car is not starting i ask the customer what happen to the car he said the car go through the water i decide to check the fuse box i found out that the ecu relay is rust from the water i clean the fuse box and i replace the relay and the car start but misfaring on cylider 1 and i off the car to start again but not starting again
Thursday,16,April,2020,15:41:17:56244
Dealer/Shop Name: automania standerton
VIN: WVWZZZAUZJP127430   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 20 42 44 52 5F
VIN: WVWZZZAUZJP127430   Mileage: 26288km-16334miles
15-Airbags -- Status: Cannot be reached 0100
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CHZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BH    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H26 5152
   Revision: W1H26---
   Coding: 01190032232415082000
   Shop #: WSC 00028 028 00071
   ASAM Dataset: EV_ECM10TFS01104C906026BH 002004
   ROD: EV_ECM10TFS01104C906026BH.rod
   VCID: 6888434EA2FE600BFB2-803C
   CAN Converter 01:
          U0428 00 [039] - -
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 01:34:20
                    Engine speed: 0.00 /min
                    Coolant temperature: 25 °C
                    Intake air temperature: 24 °C
                    Ambient air pressure: 840 mbar
                    Voltage terminal 30: 12.533 V
                    Outside air temperature: 21 °C
                    Absolute intake pressure: 85 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 3.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 15.9998
                    Engine operating condition: Idling
4710 - No Communications with Airbag Control Module
          U0151 00 [039] - -
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 01:34:19
                    Fuel level: 3.00 l
4360 - Circuit for Brake Vacuum Pump
          P1429 00 [039] - Open Circuit
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 01:34:20
                    Fuel level: 3.00 l
Readiness: 1110 0001
   Part No SW: 5Q0 614 517 CT    HW: 5Q0 614 517 AG
   Component: ESC           H62 0653
   Revision: 00000000    Serial number: 60758000002234
   Coding: 01FA8AA114222173477B060360C32580512884E26006A4732020F038C002430B00000012121212B835351919323200
   Shop #: WSC 00028 028 00069
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 05566AFAB5AC9D63604-8050
17 Faults Found:
0297 - Steering Angle Sensor
          B1168 F2 [137] - Not Initialized
                    Fault Frequency: 25
                    Reset counter: 99
                    Mileage: 26286 km
                    Date: 2019.12.23
                    Time: 00:00:14
4337 - Brake Boost Vacuum System
          P1479 00 [008] - Mechanical Failure
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.23
                    Time: 01:23:45
8200 - Databus
          [FCAN: Airbag_01 message is not received]
                    Reset counter: 98
                    Mileage: 26286 km
                    Date: 2019.12.23
                    Time: 00:52:57
8204 - Databus
          [FCAN: Airbag_02 message is not received]
                    Reset counter: 98
                    Mileage: 26286 km
                    Date: 2019.12.23
                    Time: 00:53:01
8206 - Databus
          [FCAN: Airbag_03 message is not received]
                    Reset counter: 98
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:31
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:31
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:31
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:27
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:27
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:27
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:27
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:27
8291 - Databus
          [FCAN: MO_QBit_Motormomente signal is invalid]
                    Reset counter: 138
                    Mileage: 26288 km
                    Date: 2019.12.23
                    Time: 00:17:16
8351 - Databus
          [FCAN: Motor_17_alt veraltet bit is set]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:29
16409 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:36
16410 - Display for Tire Pressure Monitoring
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:36
16416 - Display for Tire Pressure Monitoring
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:36
   Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
   Component: AC Manuell    H03 1801
   Revision: 00001K06
   Coding: 00120003200100001000000000000002
   VCID: 7AAC0906CC52E29B1D6-802E
7 Faults Found:
459009 - Databus
          [Airbagsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:27:16
459023 - Databus
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 03:12:28
393479 - Air Blower
          B10BE 31 [009] - No Signal
          [ZSB Gebläse/Regler (LIN) - kein Signal/Kommunikation]
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 05:13:20
                    Voltage terminal 30: 10.8 V
                    Outside air temperature: 13.5 °C
393473 - Air Blower
          B10BE 96 [009] - Component internal failure
          [ZSB Gebläse/Regler (LIN) - Gebläsereglerstatus - interner Fehler]
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:29:17
                    Voltage terminal 30: 11.5 V
                    Outside air temperature: 22.5 °C
393474 - Air Blower
          B10BE 1D [008] - Current Implausible
          [ZSB Gebläse/Regler (LIN) - Gebläsereglerstatus - Kurzschluss oder blockiert]
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 00:07:42
                    Voltage terminal 30: 11.2 V
393475 - Air Blower
          B10BE 4B [009] - Over temperature
          [ZSB Gebläse/Regler (LIN) - Gebläsereglerstatus - Übertemperaturbegrenzung]
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 02:59:22
                    Voltage terminal 30: 10.6 V
                    Outside air temperature: 15.0 °C
          B10CD 00 [008] - -
                    Fault Frequency: 24
                    Reset counter: 138
                    Mileage: 26282 km
                    Date: 2019.12.04
                    Time: 17:10:25
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 3
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 084 CN    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H36 0253
   Serial number: 01001807800391
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06546DF688AA967B69E-8052
   Component: WWS    180222  042 0551
   Serial number:         180302091539
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S6Y18M03D20H20M03S35
   Coding: 00A8DD
   Serial number: 000000000ZY180502T1M
   Serial number: 00000000000099982393
16 Faults Found:
12298 - License Plate Light
          B12CA 15 [008] - Open or Short to Plus
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 00:10:49
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:16:33
19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:16:28
66314 - Positioning Motors for Headlight Range
          B1528 F1 [008] - Control Voltage Implausible
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:25:15
197132 - Lock Module for Central Locking; Rear Left
          B12DB 01 [009] - Electrical Failure
                    Reset counter: 98
197388 - Lock Module for Central Locking; Rear Right
          B12DC 01 [009] - Electrical Failure
                    Reset counter: 98
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
                    Reset counter: 136
                    Mileage: 26008 km
                    Date: 2019.11.25
                    Time: 20:28:34
395273 - Control Circuit for Signal Horn
          B1344 14 [008] - Open or Short to Ground
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.12.11
                    Time: 00:01:00
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:27:15
541973 - Databus
          [Motor_04 Datenbus fehlende Botschaft]
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 03:12:27
542229 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 03:12:27
542485 - Databus
          [Motor_18 Datenbus fehlende Botschaft]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:29
545300 - Databus
          [Gateway_78 Datenbus empfangener Fehlerwert EPS_Lastinfo]
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 03:04:42
555541 - Databus
          [Motor_12_alt aktiv]
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 03:12:27
558101 - Databus
          [Airbag_02 Datenbus fehlende Botschaft]
                    Fault Frequency: 28
                    Reset counter: 99
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:27:16
559125 - Databus
          [Motor_07 Datenbus fehlende Botschaft]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:29
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018076
   Coding: 0471051001
   VCID: 4BC29CC2D348AB13F60-801E
12648465 - Databus
          [Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:26
13637426 - Databus
                    Fault Frequency: 42
                    Reset counter: 99
                    Mileage: 26286 km
                    Date: 2019.12.23
                    Time: 00:00:15
12648468 - Databus
          [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:26
Address 15: Airbags
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 21031804400845
   Coding: 0400
   VCID: 0D4652DAEDDCE523284-8058
   Part No SW: 5G1 920 740 C    HW: 5G1 920 740 C
   Component: KOMBI         202 0310
   Coding: 27A42A002380000801082A001401000000000000
   VCID: 26140D76686AB67B09E-8072
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Fault Frequency: 16
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.23
                    Time: 01:03:18
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:27:16
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 03:12:28
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 00:09:51
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 03:12:14
   Component: GW MQB High   518 5323
   Serial number: 13031810802576
   Coding: 030100047F085700FA000048080F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3828D30EB2DE308BAB2-806C
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29180000431190118101
   Coding: 28FFFF
   Serial number: 1864107204
8 Faults Found:
131594 - Parallel Parking Assistance Control Module
          U104E 00 [008] - No communication
          [Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 00:09:53
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
131605 - No Communications with Airbag Control Module
          U0151 00 [009] - -
          [Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
                    Fault Frequency: 71
                    Reset counter: 99
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:27:18
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:00:14
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: On
66049 - Powertrain Databus
          U0002 00 [008] - No Communications
          [Globaler Timeout CAN-Antrieb]
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.12.11
                    Time: 00:00:36
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: OFF
197149 - Generator
          U1052 00 [008] - No Communication
          [Generator (LIN#1) Timeout]
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.12.11
                    Time: 00:00:02
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
8526353 - Generator
          P1B00 00 [008] - Mechanical Malfunction
                    Fault Frequency: 8
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.12.11
                    Time: 00:35:25
                    Supply voltage: Terminal 30: 11.7 V
                    Terminal 15: OFF
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 12:04:56
                    Terminal 15: OFF
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Fault Frequency: 84
                    Reset counter: 138
                    Mileage: 26282 km
                    Date: 2019.12.04
                    Time: 17:14:29
                    Supply voltage: Terminal 30: 11.0 V
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 BD    HW: 3G0 857 511 BD
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0101010000000100000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B823C42B3084B13960-803E
13238275 - Databus
          [ECU for engine: no signal/no communication]
                    Reset counter: 139
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 03:12:27
                    Communication status of data bus 1-Brake control module: No communication
                    Communication status of data bus 1-Diagnostic interface for data bus: Communications link
                    Communication status of data bus 1-Engine Control Module (ECM): No communication
                    Communication status of data bus 1-Vehicle Electrical System Control Module: Communications link
                    Communication status of data bus 1-Steering column electronics control module: Communications link
   Serial number: 0000310852353
   Coding: 00310220D001020000001000
   VCID: 47CAA0F2CF204F73D28-8012
   Serial number: 00000000000008441696
   Coding: 0D0000
7 Faults Found:
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.12.11
65592 - Interior Switch for Central Locking
          B1230 29 [008] - Signal Implausible
65593 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 00:07:36
458752 - Databus
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:27:20
458803 - Databus
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:30
589827 - Window Regulator; Rear Driver Side
          B131F 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 98
                    Mileage: 26286 km
                    Date: 2019.12.23
                    Time: 00:37:56
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Reset counter: 138
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:15:48
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B22422EB3893D35E0-8026
8 Faults Found:
16275 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 99
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 11.75 V
                    Temperature: 23.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 11.80 V
                    uAdSensI_SwitchedKl30_xdu16: 11.72 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 C0
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
19460 - Databus
          [ESP_05 Botschaft - SNA-Check]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:00:14
                    Motor status: 03
                    System status: Driving mode
                    Supply voltage: 12.50 V
                    Temperature: 22.0 °C
                    KFC: 4C
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.52 V
                    uAdSensI_SwitchedKl30_xdu16: 12.44 V
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_UNDERVOLT: not activated
28672 - Databus
          [MOTOR_07 Botschaft - CAN-Timeout]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:00:16
                    Motor status: 03
                    KFC: 70
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.67 V
                    uAdSensI_SwitchedKl30_xdu16: 12.59 V
26885 - Comfort limitation
          C10D7 00 [008] - -
          [Speicherinkonsistenz im Errorhandler]
                    Reset counter: 138
                    Motor status: 00
                    Supply voltage: 0.00 V
                    Temperature: 80.0 °C
                    KFC: 69
                    KFA: 00 05
22272 - Databus
          [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.23
                    Time: 01:03:39
                    Motor status: 01
                    Supply voltage: 12.25 V
                    Temperature: 20.0 °C
                    KFC: 57
                    KFA: 00 00
                    Environmental conditions: 20
22528 - Databus
          [MOTOR_12 Botschaft - CAN-Timeout]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:00:12
                    Motor status: 03
                    KFC: 58
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.70 V
                    uAdSensI_SwitchedKl30_xdu16: 12.64 V
23040 - Databus
          [MOTOR_20 Botschaft - CAN-Timeout]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:00:12
                    Motor status: 03
                    KFC: 5A
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.55 V
                    uAdSensI_SwitchedKl30_xdu16: 12.46 V
22784 - Databus
          [MOTOR_14-Botschaft - CAN-Timeout]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:00:12
                    Motor status: 03
                    KFC: 59
                    KFA: 00 00
   Serial number: 0000310406567
   Coding: 00310020DE01020000801000
   VCID: 46D4ADF6C82A567B29E-8012
   Serial number: 00000000000008467395
   Coding: 050000
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.12.11
458752 - Databus
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:27:20
458803 - Databus
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:30
589843 - Window Regulator; Front Passenger Side
          B1320 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 98
                    Mileage: 26286 km
                    Date: 2019.12.23
                    Time: 00:37:56
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 138
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:15:48
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      722 0867
   Coding: 02731000FF00000051110001000918001F0500C60120010003
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D06F25A4D9C8523C84-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H51 8130
   Serial number: VWZ6ZJV0725406
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 96
                    Mileage: 26282 km
                    Date: 2019.11.29
                    Time: 23:27:21
                    Voltage terminal 30: 12.1 V
                    Network diagnosis-Status: Enabled
6708 - Databus
          [Engine: no communication]
                    Reset counter: 139
                    Mileage: 26288 km
                    Date: 2019.12.29
                    Time: 00:03:35
                    Voltage terminal 30: 12.5 V
6922 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 00:09:55
                    Voltage terminal 30: 11.9 V
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 136
                    Mileage: 26282 km
                    Date: 2019.11.30
                    Time: 00:09:58
                    BAP-BAP_Function_ID: 02
End----------(Elapsed Time: 01:16, VBatt start/end: 12.5V/12.5V)-----------
Pinpointdiag
Scotland
C?ID=90374
Is it short of fuel, spark or compression? Is it cranking over?
Record then clear all codes and see what comes back.
And I don’t know about VAG group vehicles. But on many cars these days the airbag module will stop it running. After an impact.
And so if the module has crash data or fails completely you’ll get a no start.
automania
South Africa
C?ID=316086
there is no burning on piston 1 and 2 and i also clear the code but still coming back
Jef
HQ
Address 15: Airbags
Fuse SC33 good?
automania
South Africa
C?ID=316086
the fuse box are clean from the water rust and all damage fuse and relay are replace still promising to start but not starting.
Jef
HQ
It would appear that fuse SC33 is for the airbag module, so if that fuse is good... why no airbag module? I've found that often (but not always) that sorting out an easy issue can help resolve the more difficult issues.
@automania: is there any evidence of water ingress into the cabin floor pan - particularly the foot-well area, perhaps underneath the back of the center console (up against the fire-wall)?
This is where the hex15 module is located on a mk7. Given your confirmation to Jeff's suggestion that SC33 is OK, I wonder whether there is a problem at 12Volt supply pins on the connector for J234 (pin #31 and/or pin #61) - maybe? Or maybe j234 is "cactus" (Aussie slang for "cactus-f#cktus") due to water inundation of the module
NostraJackAss
I have to ask .........
Is the 0x15 bolted tight to chassis completing its ground of case?
automania
South Africa
C?ID=316086
yes the ecu relay is rusted and the customer also confirm that the car is deep in the flood and the car stay with the insurance for sometime without draining out the water.
automania
South Africa
C?ID=316086
you did not think the ecu is affected
automania: Of course anything is possible - but just based on your autoscan (which is really all we know about the car - other than it has been baptized at some point in its history) it appears that the hex01 module is complaining about the data that it's not receiving from other modules.
The "No Communication with Engine Control Module" DTC on the Gateway module is concerning, but this error has a date-stamp in late December 2019 and the fault frequency=1 - which means that the DTC has not reappeared on any subsequent ignition cycle. Now, I don't know how long the car has been sitting in the "insurance yard" - but generally a low fault frequency on an "aged" DTC is a good sign.
So, on the plus side - at least from a CAN perspective, the ecu appears to be communicating correctly and it isn't reporting any internal errors at the autoscan date. At face value (and assuming that the car has been operational since late December 2019), this suggests that the ecu might be OK. But mine is simply a deduction that is predicated on a single piece of information (i.e the initial auto-scan) - further work is needed to confirm what is my flaky speculation starting with a re-post of the auto-scan after clearing the DTCs.
However the primary DTCs (like bringing the air-bag module on-line) need to be addressed first to ensure that they are not masking other errors!
automania
South Africa
C?ID=316086
thanks i found the problem it was the bcm that was faulty i want to know does bcm need programing
automania: Hi again.
I'm ecstatic to read that the problem was found (and I'm delighted that the ECU is OK). However, without intending any offense - there is disturbing economy of information in your latest revelation!
Faulty BCM-what does this mean? How was the BCM faulty? What precisely was the nature of the module failure (most DTCs in your auto-scan could be explained by dubious peripherals)?
automania
South Africa
C?ID=316086
sorry about that it is hex01 module it is burn so i am buying new one i just want to know if i need to program the part number on the module is 5Q0937084CN
South Molton, UK
So if the engine ECU is faulty (#01) and will be replaced then why are you asking about changing the part number to that of the BCM (#09)?
:confused: :confused: :confused:
automania
South Africa
C?ID=316086
i got second hand ecu for my golf 7 and i hard that it is online programming i want to know if my vcds can do the online programming
darkchina811
ITALY
C?ID=333184
no it cannot. you need ODIS with dealer level Geko account.
automania
South Africa
C?ID=316086
i have odis interface but the sorftware they give me not working i dont know if i can find some help with working software i dont mind to pay for it
