2005 Transporter T5 AC not working
Cargeorge
Australia
C?ID=192289
Hi all,
new member has problems with a T5
History is that the cluster (immobilizer) died and has been replaced with a used part along with ECU, Key Barrel and BCM from the same donor.
Now that the van is running again the AC is not working anymore (clutch does not engage).
As I can not even get into the AC control module (08 on VCDS main menu not responding) my uneducated guess is that the donor van had an automatic AC as my problem van has only manual AC.
I tried to recode as explained in the Ross Tech "Recode Tour" but there was no balloon popping up with the ECU coding options.
The code is 0000031 and I tried anyway to change to 0100031 but the ECU did not accept.
What else could I try or am I completely on the wrong track?
Any suggestions are very welcome.
Thanks Cargeorge
Thursday,09,April,2020,09:46:03:42134
VCDS Version: 20.4.0.1 (x64)
VIN: WV1ZZZ7HZ5H011843   License Plate: 000MAD
Mileage: 222810km-138447mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ5H011843   Mileage: 222810km-138447miles
   Part No: 06A 906 032 DB
   Component: 2.0l R4/2V HS M5    5852
   Coding: 0000031
   Shop #: WSC 02756 785 00200
   VCID: 61C94D63BBED3C8E6D-5124
17850 - Potentiometer for EGR (G212)
            P1442 - 001 - Signal too High
Readiness: 1110 1101
Address 03: ABS Brakes        Labels: 7H0-907-37x-ASR-F.lbl
   Part No: 7H0 907 379 G
   Component: ASR FRONT MK25      0103
   Coding: 0007206
   VCID: 3979C50373FD044E05-5124
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 K
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0001125
   Shop #: WSC 02760 785 00200
   VCID: 3A7BDA0F76FB0F560C-5124
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0008
   Coding: 13122
   Shop #: WSC 02756
   VCID: 224B026FAE6B679634-5124
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 851
   Coding: 03701
   Shop #: WSC 43039
   VCID: 68DF504708D74DC6AA-5106
   WV1ZZZ7HZ5H011843     VWZ7Z0D0086131
            80-10 - Single-Wire Operation - Intermittent
01322 - Control Module for Multi-Function Unit (MFA) (J501)
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02760
   VCID: 70EF382730078506F2-5124
            49-00 - No Communications
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C2B Komfortgerát     0004
   Coding: 00069
   Shop #: WSC 02756
   VCID: 326BF22FFE8BF716C4-4B06
   Subsystem 1 - Part No: Steuerger
   Component: t Fahr. antwortet nicht
   Subsystem 2 - Part No: Steuerger
   Component: t Beif. antwortet nicht
End-------------------------(Elapsed Time: 06:22)--------------------------
myounus
Northwest UK
C?ID=321059
Have you got a scan from your original setup to compare? Please post, thanks.
Cargeorge
Australia
C?ID=192289
Hi myounus,
thanks for coming back to me.
Unfortunately I did not scan it before but I try to get hold of the old parts, put them back in and re scan it.
myounus
Northwest UK
C?ID=321059
Ah ok. Try your last original BCM
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, please check communication in control unit 19 in the measuring blocks, block 132,3 as shown:
132,0,CAN-Databus Comfort (Communication)
132,2,Steering Wheel,Electronics (J527),Range: St. Wheel 1/St. Wheel 0\nSpecification: St. Wheel 1
132,3,Heating/Air,Condition (J255),Range: A/C 1/A/C 0\nSpecification: A/C 1
If communication is error-free, you have to see a "1" at A/C.
Cargeorge
Australia
C?ID=192289
Hi there,
sorry for the delay, had to deal with more urgent problems.
@myounus: Unfortunately I can't access the old parts anymore, so no scan of the original setup available :cry:
@Ingo: Measuring block 132 in control unit 19 does not have any entries - all fields are blank. What could that mean to my problem?
Thanks Cargeorge
NostraJackAss
Does the new cluster report ambient temp proper or is it running interference possibly?
Cargeorge
Australia
C?ID=192289
Hi Jack,
thanks for your reply.
The ambient temp comes up properly, see attached log.
Tuesday,28,April,2020,13:25:22:42134
VIN:    License Plate: 000MAD
                Address 17: Instruments  (7H0 920 851 )
13:25:10 Group 001: General
  0.0 km/h  Vehicle Speed
  0 /min  Engine Speed
  Oil Pr. 2 <min  Oil Pressure Switch 2
  13:26  Time
13:25:10 Group 002: General
  222840 km  Odometer
  29.0 l  Fuel Level
  197 ohms  Fuel Sender Resistance
  27.0°C  Ambient Temperature
13:25:10 Group 003: General
  29.0°C  Coolant Temperature
     Oil Level
     Oil Temperature
  N/A
Address 09: DTCs cleared
Address 19: DTCs cleared
United States
I would re-code 19 back to the same value of 00006
Coding: 00006
Doing so will refresh the internal installation list.
