Audi A4 2008 1.8T service due
mohamed
Egypt
C?ID=211960
I cant remove the message of service due in this car
i have reset the oil interval service through SRI and i tried to remove the message of the service due but i cant
i tried through insturment adaption and try the differnets channel , but nothing happened
DrPeter
16.4905° S, 151.7375° W
A 2008 A4 is not a UDS cluster.
But it does have the other two counters (time based inspection and mileage based inspection) in addition to the normal oil service.
mohamed
Egypt
C?ID=211960
I saw the links but nothing changes
what should be the number in the time based inspection ?
GaryM
Oxford, UK
C?ID=226919
This works on some of the VWs and SEATs of the same era. Not sure it works on an Audi A4 but no harm in giving it a try...
  1. Press and hold the odometer reset knob in.
  2. Turn the ignition on but do not start the car.
  3. Turn the odometer reset knob to the right and hold for ~5 seconds.
  4. Release the odometer reset knob and then switch the ignition off.
  5. Start the car and the service indicator should now be gone.
Please let us know if this works on your car or not.
Please post up the values in all your SRI-related channels. The easiest way to do that is to click [SRI Reset], wait for VCDS to read all the channels, then [Save to logfile]. The log will be in your Logs sub-folder, typically C:\Ross-Tech\VCDS\Logs\
A screen-shot won't do because the screen isn't big enough to show all the channels.
mohamed
Egypt
C?ID=211960
GaryM
it not work but thanks for your help
okay i will post the file of of SRI
