DSG issue
tautvydasv
Lithuania
C?ID=360923
Dear Colleagues,
I have changed DSG transmission, but have left old mechatronic. Did all resets + adaptation. These went fine. However, car shift upto 2nd gear and does not go above. All goes smooth in first gears. I get error below. What could I do to trouble shoot current situation?
South Molton, UK
First step - post a full VCDS Auto-Scan - see my sig for a How-To.
tautvydasv
Lithuania
C?ID=360923
Tuesday,14,April,2020,11:15:27:44594
VIN: WVWZZZAUZGW083158   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 47 52 55 5F
          A5 A9
VIN: WVWZZZAUZGW083158   Mileage: 66050km-41041miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00122426050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259F.rod
   VCID: 313F1721E1A3B9A3ECC-8064
15329 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [047] - -
                    Mileage: 66049 km
                    Date: 2020.04.10
                    Time: 19:03:41
                    Engine speed: 4939.50 /min
                    Normed load value: 11.4 %
                    Vehicle speed: 63 km/h
                    Coolant temperature: 97 °C
                    Intake air temperature: 17 °C
                    Ambient air pressure: 1060 mbar
                    Voltage terminal 30: 14.687 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 16 s
                    MAP_MES_SAE: 44 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.934 V
                    FAC_TPS_1_SAE: 19.921875 %
                    FUP_H_SAE: 15500.0 kPa
Readiness: 1010 0001
   Part No SW: 0D9 300 043 T    HW: 02E 927 770 AQ
   Component: DQ250-6A TVS  H53 9699
   Revision: 06253104    Serial number: TFK01507210021
   ROD: EV_TCMDQ250021.rod
   VCID: 2B030549C38FD373D60-807E
21180 - Unexpected / Implausible Mechanical Gear Disengagement
          P2711 00 [200] - -
                    Mileage: 66049 km
                    Date: 2020.04.10
                    Time: 19:02:55
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62085000004497
   Coding: 01FA6BA15428296F0778070541CB6980D62A94E0E08296F7004200F8C208
   VCID: 79AFEF017953B1E314C-802C
   Revision: 00021000    Serial number: 0375512940
   Coding: 030C0C
   VCID: 3A2D300D3CD57AFB5D6-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004200100011105000000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6A8DC04D0CF50A7BED6-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061520800883
   Coding: 00011E46C24122F30BA44080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9FC129B3A16304C-805C
   Component: WWS    150715  043 0551
   Serial number:         150718084443
   Component: RLHS  037 0059
   Serial number: S4Y15M08D05H08M41S27
   Coding: 90A8DD
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY151753E6Z
   Serial number: 00000000000033028610
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Reset counter: 93
                    Mileage: 66047 km
                    Date: 2020.04.06
                    Time: 01:46:22
   Revision: --------    Serial number: 39331521102895
   Coding: 0031051011
   VCID: 43D34DE94B1F3B330E0-8016
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 15071541350657
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 372B29390FC76793A28-8062
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR034HBN
   Coding: 98FCC0C0000000005C5400CF004800000065
   VCID: 005982E51A89E02B532-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 002 707 15
   Serial number: 357670000007E10DB51.
   Subsystem 2 - Part No SW: -----------    HW: 480 002 707 15
   Serial number: 3586700000045685B51V
   Subsystem 3 - Part No SW: -----------    HW: 480 402 107 15
   Serial number: 3516502BD1C2F03401A8
   Subsystem 4 - Part No SW: -----------    HW: 480 402 207 15
   Serial number: 3526502C31C2F030518%
   Subsystem 5 - Part No SW: -----------    HW: 480 402 907 15
   Serial number: 3556502C51B7E8E4639Y
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 31071504221452
   Coding: 0410
   VCID: 074B99F93FA7D713128-8052
   Part No SW: 5G1 920 758 A    HW: 5G1 920 758 A
   Component: KOMBI         302 6420
   Coding: 07AD08183B80000801086A001400000000000000
   VCID: 2D070B51FD9BDD43C84-8078
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1224
   Revision: --------    Serial number: 0003808209
   Coding: 030100043F085900FB00026A9C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75B7E331554BD583704-8020
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150001452560035291
   Coding: 29FFFF
   Serial number: 7957297303
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00020.05.15
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 46D554FD782D0E1B29E-8012
   Revision: 00000000    Serial number: 15000179147005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311E351EB18C8B87A-8060
   Serial number: 110715BG700057
   Coding: 003E12208000040000001000
   Serial number: 00000000000006831335
   Coding: 110000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   VCID: 392F2F0139D371E354C-806C
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA00N92/
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 6D87CB513D1B1D43884-8038
   Serial number: 240715BGN03403
   Coding: 003E10208E00040000801000
   VCID: 42DD48ED5405323B056-8016
   Serial number: 00000000000006894686
   Coding: 090000
   Coding: 02A203104F010200
   VCID: 40D942E55A09202B132-8014
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Part No SW: 3G0 035 043 B    HW: 3G0 035 043
   Component: MU-H-N-EU     H42 0317
   Serial number: A599G0F7534015
   Coding: 027300010000000051110002000908001F0207E401200100DF
   VCID: 1B63D589932F23F3A60-804E
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU302M33
   Subsystem 2 - Part No SW: V03 959 800 QT    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Compact Disc Database:
   Component: Gracenote2  --- 1011
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 00000374487
   Coding: 0000020000020308000400000000000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C21361536E144CB4FA-8068
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 150706200929
   VCID: 2F3B1159F797AF53FA8-807A
End----------(Elapsed Time: 01:51, VBatt start/end: 12.2V/12.2V)-----------
Moving to Car Repair Support.
DrPeter
16.4905° S, 151.7375° W
Hello and thanks for post the Auto-Scan,
Simply put, the fault code in the [02-Auto Trans], below, would be an indication that the transmission was NOT expecting the "Gear Disengagement" on your test drive.
We have a Ross-Tech wiki page for this fault code that may help,
P2711 - Unexpected / Implausible Mechanical Gear Disengagement
Sounds like this replacement transmission might not be in the best condition.
Hope that helps,
drpeter
