2018 Audi S5 - Multiple fault codes after tire change/alignment
Uptime
C?ID=184877
I brought my car to Firestone to switch from my winter tires to summer sport tires and for an alignment. When they handed me the keys back they told me there were some fault codes but that the car was drivable. Upon starting the car, a barrage of malfunction messages appeared: Distance warning, Stabilization Control Malfunction, Audi Adaptive Light Malfunction, Sport Differential Malfunction, Suspension Malfunction, and several steering and safety system related messages. I ran VCDS and saved the results then cleared DTCs hoping the simplest solution would remedy the problem. Unfortunately the malfunction messages persist. Help! Am I stuck with going to my Audi service shop for them to resolved the problem?
Any assistance would be appreciated! Thanks, Mike
Monday,13,April,2020,12:50:32:35744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.2.0 (x64)
VIN: WAUC4CF53JA016644   License Plate:
Gateway Installation List:  8W8 907 468 E
13-Auto Dist. Reg -- Status: Malfunction 0110
1B-Active Steering -- Status: Malfunction 0110
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
32-Differential Locks -- Status: Cannot be reached 0100
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0110
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0110
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
HERE'S THE FULL SCAN RESULTS:
Monday,13,April,2020,12:37:01:35744
VIN: WAUC4CF53JA016644   License Plate: UPTIME
Mileage: 36959km-22965mi   Repair Order:
Chassis Type  F5-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 1B 29 32 36 39 3C 42 44 46 47
          52 5F 6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
VIN: WAUC4CF53JA016644   Mileage: 36959km-22965miles
1B-Active Steering -- Status: Malfunction 0010
32-Differential Locks -- Status: Malfunction 0010
Address 01: Engine (J623-CWGD)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8W0 907 559 H    HW: 06M 907 309 D
   Component: V6 3.0l TFSI  H21 0005
   Revision: B2H21000
   Coding: 1A2A00322366010E34280000000000000000000000000000
   Shop #: WSC 06334 790 00001
   ASAM Dataset: EV_ECM30TFS0118W0907559H 001006
   ROD: EV_ECM30TFS0118W0907559H.rod
   VCID: 4A9BBF8EED34A91F39-801F
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:26:33
                    Engine speed: 793.00 /min
                    Normed load value: 1.6 %
                    Coolant temperature: 101 °C
                    Intake air temperature: 53 °C
                    Voltage terminal 30: 11.940 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
Readiness: 0110 0101
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 8W0 927 158 C    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H05 1003
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 428B97AED504715FF1-8017
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 M    HW: 8W0 907 379 D
   Component: ESP9 Premium  H13 0767
   Coding: 1CAA149A30A30A9C11A44895408158A2E4259A38280C508812021A4527A459
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 4FADAE9A16568C376E-801B
12851462 - Implausible Data Received from Steering Effort Control Module
          U0419 00 [175] - -
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:14:53
                    7B 00 82 00 C2 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H55 0205
   Coding: 1608050D5544010D10020100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 448791B6CF107F6FC3-8011
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001603260
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: 16915CA880PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07500363E0691CCD050D511918AC9CB9110B3D040000000000000000200016010A69012B825709
   VCID: 020B57AE9584B15FB1-8057
   Subsystem 1 - Part No SW: 8W6 955 119     HW: 8W6 955 119   Labels: 1KX-955-119.CLB
   Component: 494 LL 050417  036 0471
   Serial number: 00000001704030303602
   Coding: 5FC7F7
   Serial number: 20455999X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 T    HW: 4M0 941 531 T
   Component: E1 - LDS  H06 0008
   Serial number: 24 02 2017  00793706
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z0CQ602
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170427095627 00273
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE123031723610109
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 CS    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00291848
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000031920006
   Valve Block 1 In Driver Side Front Seat:
   Subsystem 9 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J873 MKS_FSv  H03 0033
   Serial number: 7008174235B171434596
   Coding: BF0500
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 10 - Part No SW: 8W0 907 182     HW: 8W0 907 182
   Component: J872 MKS_BFSv  H03 0033
   Serial number: 7008174235B171433231
   Coding: B30500
131945 - Databus
                    Fault Frequency: 15
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:03
                    average_Voltage_terminals: 12.30 V
                    Outside air temperature sensor-Outside air temperature on CAN: 14.50 °C
                    interior_temperature: 22.50 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
196758 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:04
196761 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:04
   Part No SW: 8W0 907 561 C    HW: 8W0 907 561
   Component: LRR4          H10 0330
   Coding: B4779FF258FFEC05757A61A1
   ASAM Dataset: EV_ACCBOSCHAU49X 003022
   ROD: EV_ACCBOSCHAU49X.rod
   VCID: 3E73E35EA1FC15BF95-806B
9 Faults Found:
2179 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:18:19
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 11.8 V
2106 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:18:18
0852 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:07
                    Control Module temperature: 36 °C
                    Voltage terminal 15: 12.3 V
2101 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:07
2153 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:07
2115 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:07
1392 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:07
0800 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:07
2068 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:07
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 J    HW: 8W0 959 655 J
   Component: Airbag10.44   H09 0104
   Serial number: 003US0006CPI
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005015
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 50AFADE60B6893CF77-8005
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705G0149R00679
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706J0144R01614
   Coding: 80000D
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J170007BBLG0A
   Subsystem 4 - Part No SW: -----------    HW: 442 061 305 17
   Serial number: 3577Y009F2414141236M
   Subsystem 5 - Part No SW: -----------    HW: 442 061 305 17
   Serial number: 3587Y009F2414143218P
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 305 17
   Serial number: 3517700A52674E13E09C
   Subsystem 7 - Part No SW: -----------    HW: 442 0B1 305 17
   Serial number: 35277009B2674E142334
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 105 17
   Serial number: 3557500AB22BF493612F
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 105 17
   Serial number: 3567500AB22BF495909R
          B13BC F2 [137] - No function
                    Reset counter: 39
                    Mileage: 36952 km
                    Date: 2020.04.13
                    Time: 10:39:04
1061893 - Databus
                    Fault Frequency: 14
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:15
1060613 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:15
1060614 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:15
1060615 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:15
1060617 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:15
   Part No SW: 4M0 907 129 GG    HW: 4M0 907 129 GG
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7BF52A4AF26EC097F2-802F
   Part No SW: 8W5 920 890 D    HW: 8W5 920 890 D
   Component: FBenUSA       H18 0371
   Coding: 09CF49CB7CA8CF0502B3E9601800400008000000
   Part No SW: 8W8 907 468 E    HW: 8W8 907 468 E
   Component: Gateway       H42 0116
   Revision: 6D020002    Serial number: 0286D045917531
   Coding: 03010001000006405407000000590010FC980007920000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   VCID: 4E93B39E115C853F65-801B
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20170526005031 20075
   Serial number: 4775024004
   Part No SW: 8W0 907 144 E    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0706
   Coding: 40
   ASAM Dataset: EV_SCUZFLSAU49X 002014
   ROD: EV_SCUZFLSAU49X_002.rod
   VCID: 3D71E452ACFA0EA78C-8069
18432 - Control Module for Active Steering
          C115C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:20
Address 29: Left Light
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H07 0040
   Revision: 5WK12700    Serial number: 605721701252007
   Coding: 0001
   ASAM Dataset: EV_TVDCQSP22 001007
   ROD: EV_TVDCQSP22.rod
   VCID: 79F93042F852F287E0-802D
33263 - Databus
                    Fault Frequency: 12
                    Reset counter: 79
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:26:32
                    Active Backup Function: TEMPORARY SHUTDOWN 20
                    Status of QSP: Temp_Shutdown
                    Program Counter: 00 00 00 00
                    Reset Fault Code: SCM_E_NONE
                    Number of resets: 0
                    Active fault: SCM_E_NONE
                    Active extended fault: SCM_E_EXTENT_NONE
                    SCM_E_PFM_NOK: inactive
                    SCM_E_ASIL_RAM_PROT: inactive
                    SCM_E_ASIL_RAM_DEFECT: inactive
                    SCM_E_ASIL_ROM: inactive
                    SCM_E_MC_SUPPLIES: inactive
                    SCM_E_HW_TSBC_RST_UNLIMITED: inactive
                    SCM_E_MPT_AUDI: inactive
                    SCM_E_BSW: inactive
                    SCM_E_TRAP_X2: inactive
                    SCM_E_TRAP_X3: inactive
                    SCM_E_TRAP_NMI: inactive
                    SCM_E_TRAP_ECC_FLASH: inactive
                    SCM_E_TRAP_UNKNOWN: inactive
                    SCM_E_PCP: inactive
                    SCM_E_HW_MU_RST: inactive
                    SCM_E_OS_TASK_NOK: inactive
                    SCM_E_HW_BIST: inactive
                    SCM_E_HW_MU_CFG: inactive
                    SCM_E_HW_MU_INVALID_QUESTION: inactive
                    SCM_E_HW_MU_WRONG_BEHAVIOR: inactive
                    SCM_E_INT_RST: inactive
                    SCM_E_HW_TSBC_RST: inactive
                    SCM_E_LVL2: inactive
                    SCM_E_TRAP_X1: inactive
                    Reserved: inactive
                    SCM_E_SW_RESTART: inactive
                    SCM_E_SOPC: inactive
                    SCM_E_VSOUTx: inactive
                    SCM_E_ADC_REF: inactive
                    SCM_E_ADC_STUCK_AT__MULTIPLEX: inactive
                    SCM_E_VDD5: inactive
                    SCM_E_HW_DEV_ID: inactive
                    Occurrence_counter_over_length_of_life: 22
                    FR_ESP_VL_VR_HL_HR_FR_QBit: 0
                    Front left wheel speed: 0.0 km/h
                    Front right wheel speed: 0.0 km/h
                    Left rear wheel speed: 0.0 km/h
                    Right rear wheel speed: 0.0 km/h
                    State EFP: 5
                    FR_FDR_TV_SollRadDiff_Moment: 0.0 Nm
                    FR_KBI_Standzeit_02: 173 s
                    Engine speed: 1159.50 /min
                    Lateral acceleration sensor 1: -0.04000 m/s²
                    Lateral acceleration sensor 1: status: 0
                    Lateral acceleration sensor 2: -0.02000 m/s²
                    Lateral acceleration sensor 2: status: 0
                    FR_KBI_Reifenumfang: 2003 mm
                    FR_Motor_Code_01: 2
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-FS        008 0031
   Serial number: 00000259079390
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   VCID: 76E33B7EC94C9DFF8D-8023
Address 39: Right Light
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 3663FB7E89CCDDFF4D-8063
1192224 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:27
                    Control Module temperature: 41 °C
                    Voltage terminal 30: 12.20 V
                    Terminal 15 status: On
                    Voltage terminal 15: Measured value not available
1192210 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:27
267010 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:27
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0125
   Serial number: 0000260007158
   Coding: 005D5B625E001080000104B2
   VCID: 438592AACA1E7857FA-8017
   Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0409
   Coding: 85008380008080
   ASAM Dataset: EV_EPSZFAU49X 003018
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 418998A2D0026A47E8-8015
26112 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:34
                    Expanded ambient data 1-Engine running: Engine_not_running
                    Expanded ambient data 1-Supply voltage: 0.00 V
                    Expanded ambient data 1-Temperature: -70 °C
                    Expanded ambient data 1-System status: 4
                    Expanded ambient data 1: 00
                    Expanded ambient data 1-driving_direction: 0
                    Expanded ambient data 1-KFA: 0
                    Expanded ambient data 1-KFC: 102
                    Expanded ambient data 1-Ready_To_Drive_Bit: 0
                    Expanded ambient data 1-StartStop Info: 0
                    Expanded ambient data 1-Steering_Angle_Calculated: 0 °
                    Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
                    Expanded ambient data 1-Steering_torque: 0.00 Nm
                    Expanded ambient data 1-Steering_Torque_Sign: 1
                    Expanded ambient data 14-KFA_FAST_RESET: 0
                    Expanded ambient data 14-KFC_FAST_RESET: 0
                    Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 12.23 V
                    Expanded ambient data 14-Voltage_terminal_30_unfiltered: 12.39 V
17664 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:34
                    Expanded ambient data 1-KFC: 69
Address 46: Central Conv.
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAHJA01L3XH
   Coding: 0194030800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0125
   Serial number: 0000259889911
   Coding: 005D5B225E001080000104B0
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 A    HW: 8W5 035 880
   Component: MU-P-LNS-US   034 1118
   Serial number: A798E0HB032395
   Coding: 019453020000000053220002041A00102F0012E501700904BE
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0160
   Serial number: TPO00124041700820201
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK127041700020808
   Compact Disc Database:
   Component: Gracenote2  --- 3012
          B11CF 53 [009] - Deactivated
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:26:51
                    Voltage terminal 30: 14.8 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG017333
   Coding: 02940302BA0FA10008404000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 3467C1769FB0CFEF73-8061
13705996 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 12:26:45
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 31391870800000
   Coding: 0630
   VCID: 489F8586F3385B0F2F-801D
Address 74: Chassis Control
   Part No SW: 8W1 713 041 F    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 20170529000543
   ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 8W6 919 617     HW: 8W6 919 617
   Component: HeadUpDisplay H09 1640
   Coding: 4F01E0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736.rod
   VCID: 06034BBEB9AC8D7F9D-8053
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 C    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 003022
   ROD: EV_ACC2BOSCHAU49X.rod
   VCID: 3C77E956B7E007AFBB-8069
0852 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:51
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 12.2 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W6 907 217 A    HW: 8W6 907 217 A
   Component: BVS           H15 0050
   Coding: 0404090300000204012023A6AD0000FCB0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 408F9DA6DB08634FE7-8015
7 Faults Found:
1123714 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:16:00
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 12.20 V
1123157 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:56
                    Voltage terminal 15: 12.30 V
1123159 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:56
1123173 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:56
1123733 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:56
4195330 - Databus
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:15:56
4195335 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36954 km
                    Date: 2020.04.13
                    Time: 11:18:19
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 12.00 V
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8W0 907 159 E    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 170503201061
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0125
   Serial number: 0000259679280
   Coding: 000D5B2200001080400000A0
   VCID: 45818CB2C42A4667D4-8011
Address BC: Door Rear Pass
Address CA: Sunroof
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 08:28)--------------------------
Uptime
C?ID=184877
Thanks for the reply MYOUNUS and sharing the link to the steering angle sensor calibration process. I think you are leading me in a good direction, but I ran into some issues with the procedure. First, there is no "Group 001" in 04-Basic Settings for my car. Instead, there is a dropdown menu with 3 different codes starting with "IDE" that can be chosen:
1) IDE02284 Steering angle sensor: carry out zero calibration
2) IDE02285 Steering angle sensor: reset zero calibration
3) IDE03192-ENG136915- Steering angle sensor : zero calibration w/ steer. wheel scale
I tried IDE02284 and select [Go!]. The response is immediate and reports "Not Running". I watched for a couple of minutes and selected [Done] to exit out. So I'm stuck with how to get past this issue since it never indicates that it ran and completed before reporting the "not running" status.
I looked at the Advanced Measuring Values for all of the variables that begin with "Steering angle sensor" and one struck me as a problem: "Steering wheel angle sensor status" showed a value of "not initialized". All other values seemed OK-- Calibration status=calibrated, Steering wheel angle:internal value =4.9 deg, malfunction status=no error, steering wheel angle=0.0 deg, etc.
Also worth noting, my car has the steering assist option, the module 1B-Steering Assist shows 2 faults:
1) Implausible data received from steering angle sensor module (G85)
2) Position Sensor for Active Steering C129E F0 [009] - Not Adapted
Here's the output from VCDS during my session:
Tuesday,14,April,2020,13:34:43:35744
VCDS Version 20.4.0.1 (x64)
Mileage: 22975   Repair Order:
VIN: WAUC4CF53JA016644   Mileage: 36976km-22975miles
   Component: V6 3.0l TFSI  H21 V6 H21 00050005
   Revision: B2H
   Coding: 1A2A00000000000000000000000000000000000000000000
   ROD: N/A
   VCID: 4A9BBF8EED34A9D69C-801F
17158 - Databus
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 17:56:09
                    Engine speed: 1280.00 /min
                    Normed load value: 5.9 %
                    Coolant temperature: 45 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 11.440 V
                    Drivetrain coordinator: brake function status-Bits 0-7: 1
Readiness: 0010 0101
   VCID: 4FADAE9A16568CFECB-801B
          U0419 00 [175] - -
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:51:27
                    7F 00 02 00 CA 24 00 00 00 00
   VCID: 448791B6CF107FA666-8011
   Component: BCM1 MLBevH13 0267
   VCID: 020B57AE9584B19614-8057
   Coding: 5FC7F7
   Coding: 02005D
   Coding: 350000
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Coding: BF0500
   Coding: B30500
131945 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
                    average_Voltage_terminals: 12.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: 14.00 °C
                    interior_temperature: 29.00 °C
196758 - Databus
                    Fault Frequency: 14
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
196761 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
   ROD: EV_ACCBOSCHAU49X_003_AU49.rod
   VCID: 3E73E35EA1FC157630-FFFF
9 Faults Found:
2179 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
                    Control Module temperature: 45 °C
                    Voltage terminal 15: 12.8 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
2106 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
0852 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
2101 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
2153 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
2115 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
1392 - Databus
                    Fault Frequency: 11
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
0800 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
                    Voltage terminal 15: 12.7 V
2068 - Databus
   Component: Airbag10.44   H09 Airbag10.44   H09 01040104
   ROD: N/A
   VCID: 50AFADE60B689306D2-8005
   Coding: 80000D
   Component: Bel  306 2033
   Coding: 80000D
   Occupant Detection:
                    Reset counter: 39
                    Mileage: 36952 km
                    Date: 2020.04.13
                    Time: 10:39:04
1061893 - Databus
                    Fault Frequency: 14
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:39
1060613 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:39
1060614 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:39
1060615 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:39
1060617 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:39
   VCID: 7BF52A4AF26EC05E57-802F
   VCID: 4E93B39E115C85F6C0-801B
   Coding: 40
   VCID: 3D71E452ACFA0E6E29-8069
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:01:35
19968 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 79
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 12:01:03
19712 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [009] - -
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 12:01:03
   Coding: 0001
   VCID: 79F93042F852F24E45-802D
33263 - Databus
                    Fault Frequency: 13
                    Reset counter: 79
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:59
                    Number of resets: 0
                    SCM_E_BSW: inactive
                    SCM_E_PCP: inactive
                    Reserved: inactive
                    Occurrence_counter_over_length_of_life: 38
                    State EFP: 5
                    FR_KBI_Standzeit_02: 4 s
                    Engine speed: 1162.00 /min
                    Lateral acceleration sensor 1: 0.22000 m/s²
                    Lateral acceleration sensor 2: 0.20000 m/s²
                    FR_Motor_Code_01: 2
   VCID: 76E33B7EC94C9D3628-8023
   Revision: --------
   Coding: 0EC002
   VCID: 3663FB7E89CCDD36E8-8063
1192224 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
                    Voltage terminal 30: 12.80 V
1192210 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
267010 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
   VCID: 418998A2D0026A8E4D-8015
26112 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
                    Expanded ambient data 1-Engine running: Engine_Running_Stable
                    Expanded ambient data 1-System status: 5
                    Expanded ambient data 14-Register_seg_flag: 0
                    Expanded ambient data 14-Rom_ram_ecc_adr_1: 0
                    Expanded ambient data 14-Rom_ram_ecc_eipc: 0
                    Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 12.83 V
                    Expanded ambient data 14-Voltage_terminal_30_unfiltered: 12.97 V
17664 - Databus
                    Fault Frequency: 15
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
27136 - Databus
                    Reset counter: 79
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 12:01:03
                    Expanded ambient data 1-KFC: 106
                    Expanded ambient data 1-Steering_torque: 0.10 Nm
                    Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 14.75 V
                    Expanded ambient data 14-Voltage_terminal_30_unfiltered: 14.89 V
   VCID: 428B97AED504719654-8017
   Component: MU-P-LNS-US   034 MU-P-LNS-US   034 11181118
   Coding: 01945300000000000000000000000000000000000000000000
   ROD: N/A
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 17:53:57
                    Voltage terminal 30: 12.6 V
   VCID: 3467C1769FB0CF26D6-8061
13705996 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:38
   Coding: 0630
   VCID: 489F8586F3385BC68A-801D
   Coding: 4F01E0
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 06034BBEB9AC8DB638-8053
   ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
   VCID: 3C77E956B7E007661E-8069
0852 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
                    Control Module temperature: 53 °C
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
   VCID: 408F9DA6DB08638642-8015
7 Faults Found:
1123714 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:42
                    Control Module temperature: 43 °C
                    Voltage terminal 15: 12.80 V
1123157 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
1123159 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
1123173 - Databus
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
1123733 - Databus
                    Fault Frequency: 11
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
4195330 - Databus
                    Fault Frequency: 11
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
4195335 - Databus
                    Fault Frequency: 13
                    Reset counter: 39
                    Mileage: 36959 km
                    Date: 2020.04.13
                    Time: 14:48:37
   VCID: 438592AACA1E789E5F-8017
   VCID: 45818CB2C42A46AE71-8011
   Component: TSG HBFS      005 0125
   Serial number: 0000259678567
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address CA: Sunroof
End-------------------------(Elapsed Time: 11:30)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 13: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 1B: DTCs cleared
Address 32: DTCs cleared
   Revision: B2H21000
Readiness: 1110 0101
   Revision: --H05---
   Coding: 100000
   ROD: EV_TCMALX52011_AU49.rod
          U0419 00 [167] - -
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 13:49:58
                    93 00 02 00 CA 24 00 00 00 00
   Coding: 5FC7F7
   Coding: 02005D
   Coding: 350000
   Subsystem 6 - Part No: 8W0 857 511 B
   Component: Y7_Innenspieg  8W0857511B  0002
   Coding: BF0500
   Coding: B30500
   Component: LRR4
   VCID: 55A15CF2348AF62E01-FFFF
9 Faults Found:
2179 - Databus
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 13:51:42
                    Control Module temperature: 40 °C
                    Voltage terminal 15: 14.7 V
2106 - Databus
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 13:51:42
0852 - Databus
2101 - Databus
2153 - Databus
2115 - Databus
1392 - Databus
0800 - Databus
2068 - Databus
   Component: Airbag10.44   0104
   Coding: 80000D
   Coding: 80000D
   Occupant Detection:
                    Reset counter: 39
                    Mileage: 36952 km
                    Date: 2020.04.13
                    Time: 10:39:04
1061893 - Databus
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 13:52:20
1060613 - Databus
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 13:52:21
1060614 - Databus
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 13:52:21
1060615 - Databus
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 13:52:21
1060617 - Databus
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 13:52:21
Address 1B: Active Steering        Labels:
   ROD: N/A
   VCID: 3D71E4522CFA0E6E29-8069
   Coding: 0001
36-Seat Mem. Drvr -- Status: Cannot be reached 0100
myounus
Northwest UK
C?ID=321059
Try them all. I’d try reset zero calibration first.
I located a phone ticket that I recorded from a 2017 A5 S-line involved in a very light (no frame damage) crash. The replacement control arms were installed and the alignment was completed by another shop before the technician and I spoke on the phone about the issues. The steps we completed were similar to my suggestions to you yesterday:
  • Address 16 SA code 40168 followed by BS: [*IDE02284*] Steering angle sensor: carry out zero calibration
  • Address 1B SA code 20103 followed by BS: [*IDE06140-ENG114972*] Basic setting of active steering - Routine Control Option
There were several Function Restriction due to Implausible Message(s) DTCs but all warnings went off after a drive.
Jef in our tech support team sent the following to a customer via e-mail. This was likely based on my notes:
Start engine, let idle.
Rotate steering wheel full lock left, hold for +10 seconds.
Rotate steering wheel full lock right, hold for +10 seconds.
Center steering wheel, front wheel straight ahead.
[Select]
[16-Steering Wheel]
[Security Access - 16]
Submit the value 40168
[Do it!]
[Basic Settings - 04]
[IDE02284] Steering angle sensor: carry out zero calibration
[Go!]
We suspect you will get a message of "Finished Correctly"
[Stop]
[Done, Go Back]
[1B-Active Steering]
Submit the value of 20103
[IDE06140-ENG114972] Basic setting of active steering - Routine Control
Option
[Go!]
[Stop]
[Done, Go Back]
Shut the car down and lock it up for 60 seconds, then restart, go in and
clear codes and see what comes back.​
Based on that feedback more than one ignition cycle, lock-to-lock cycle and test drive were needed before all of the warnings on-dash cleared and DTCs could be erased but it was also successful. That one began due to aftermarket lowering springs and an alignment and it was a 2018 S4.
Moving forward, I'm slightly concerned about the Steering wheel angle: internal value = 4.9 deg you mentioned. Most modern vehicles won't even calibrate G85 if the readings are outside of +/- 1.5°. For that reason you might want to verify the wheel is actually straight when watching [*IDE08696-MAS02406*] Steerg. wheel angle sens. - Steering wheel angle: internal value in address 16 prior to using the text steps in Jef's email list above. However, if the steering wheel isn't close to straight when that internal value is ... my fear is that the alignment may need readjusted.
Next, I wouldn't worry about that B13BC DTC in 15-Airbags until the other systems are in a better way but this may be helpful: https://forums.ross-tech.com/showth...dy-B13BC-Multiple-collision-brake-No-function
Internal ref to ST?ID=93066
Uptime
C?ID=184877
Problem resolved! Thanks for your help, Dana and Jef!
Here are some additional observations on the procedure you shared:
1) There is no feedback (i.e. no beep noise as I've read about in some posts) from the vehicle when going through the steps in the procedure involving the manipulation of the steering wheel to the end points left and right and bringing back to center.
2) When in the [16-Steering Wheel] part of the procedure, I displayed and saved the variables that had the word "steering" in them and noticed IDE08696-MAS02126 showed a status of "not initialized". Under these conditions carrying out the zero calibration did NOT ever display the "Finished Correctly" message. My car always displayed the message "Not Running" immediately after hitting [Go!]. I proceeded as if the procedure worked into the [1B-Active Steering] area and upon completing the specified steps, still had the malfunctions. I cleared the DTCs and drove the car for about 0.5 mile and continued to have all of the malfunction indicators alarming.
 Thursday,16,April,2020,18:10:02:35744
Mileage: 23109   Repair Order:
                Address 16: Steering wheel  (4M0 907 129 GG)
18:09:44
  IDE08696-MAS02125   Steerg. wheel angle sens.-Steering wheel angle speed 0 °/s
  IDE08696-MAS02126   Steerg. wheel angle sens.-Steering angle sensor: status not initialized
  IDE08696-MAS02128   Steerg. wheel angle sens.-Q bit: steering wheel angle valid
  IDE08696-MAS02406   Steerg. wheel angle sens.-Steering wheel angle: internal value 0.2 °
  IDE08696-MAS02453   Steerg. wheel angle sens.-Steering wheel angle offset 0.8 °
  IDE08696-MAS02983   Steerg. wheel angle sens.-Steering wheel angle 0.6 °
  IDE08696-MAS07727   Steerg. wheel angle sens.-Steering wheel angle: prefix internal value Positive
  IDE08696-MAS07728   Steerg. wheel angle sens.-Steering wheel angle offset: prefix Positive
  IDE08696-MAS07729   Steerg. wheel angle sens.-Steering wheel speed: prefix N/A
  IDE09381-IDE02219   Steering angle sensor calibration status-Steering wheel angle: sign Negative
  IDE09381-MAS00037   Steering angle sensor calibration status-Calibration status calibrated
Thursday,16,April,2020,18:23:22:35744
                Address 1B: Active Steering  (8W0 907 144 E)
18:23:14
  IDE05817-MAS04337   Motor for active steering-Engine current 1.20 A
  IDE05817-MAS04456   Motor for active steering-Angular speed 0 °/s
  IDE05817-MAS04457   Motor for active steering-PWM pulse duty factor 0.00 %
  IDE05817-MAS13401   Motor for active steering-Resistance phase 1-2 66 mOhm
  IDE05817-MAS13402   Motor for active steering-Resistance phase 2-3 66 mOhm
  IDE05817-MAS13403   Motor for active steering-Resistance phase 3-1 67 mOhm
  IDE05818-MAS02998   Active steering initialization sensor-Angle value offset 0.00 °
  IDE05818-MAS02999   Active steering initialization sensor-Correction value -1 °
  IDE05818-MAS04458   Active steering initialization sensor-Validity for newly adapted value invalid
18:23:43
  IDE05818-MAS04459   Active steering initialization sensor-Progress of index position adaptation 0.00 %
  IDE05818-MAS04470   Active steering initialization sensor-Progress of correction value adaptation 100.00 %
  IDE05818-MAS10225   Active steering initialization sensor-Signal level up
                Address 1B: Active Steering       Labels: NONE
Control Module Part Number: 8W0 907 144 E    HW: 8W0 907 144 C
  Component and/or Version: SCU_MLBevo    H03 0706
           Software Coding: 40
            Work Shop Code: WSC 06335 790 00001
              ASAM Dataset: EV_SCUZFLSAU49X 002014 (AU49)
          U0428 00 [009] - -
                    Reset counter: 43
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 14:04:25
50176 - Position Sensor for Active Steering
          C129E F0 [008] - Not Adapted
                    Reset counter: 79
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 14:06:10
                    Reset counter: 43
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 14:12:52
                    Reset counter: 39
                    Mileage: 36976 km
                    Date: 2020.04.14
                    Time: 14:12:52
           Software Coding: 40
Fault Codes have been Erased
                    Reset counter: 43
                    Mileage: 37191 km
                    Date: 2020.04.16
                    Time: 18:28:31
                    Reset counter: 43
                    Mileage: 37191 km
                    Date: 2020.04.16
                    Time: 18:28:31
3) Re-running through all of the steps a second time turned out to be productive. I didn't save all of the steering variables to prove it, but I think that on the 2nd run through the procedure, IDE08696-MAS02126 changed to "initialized". I still got the "Not Running" message instead of the "Finished Correctly" message while in the [16-Steering Wheel] section. BUT, when I completed the [1B-Active Steering] steps, I did get the "Finished Correctly" message which I was very happy to see. When I cleared DTCs, most faults except one in [1B-Active Steering] cleared! The one remaining fault was "50176 - Position Sensor for Active Steering C129E F0 [009] - Not Adapted". All of the dashboard malfunction warnings disappeared and I went for a test drive to see if that would help with the final malfunction. The code below was gathered before the test drive.
Thursday,16,April,2020,18:49:37:35744
Mileage: 23110   Repair Order:
           Software Coding: 40
                    Reset counter: 43
                    Mileage: 37192 km
                    Date: 2020.04.16
                    Time: 18:46:07
Thursday,16,April,2020,18:51:57:35744
                Address 1B: Active Steering       Labels: None
           Software Coding: 40
                    Reset counter: 43
                    Mileage: 37192 km
                    Date: 2020.04.16
                    Time: 18:46:07
4) After taking the car on test drive and returning home, I cleared the DTCs and that took care of that lingering [1B-Steering Assist] malfunction!
 Thursday,16,April,2020,18:59:46:35744
Mileage: 23112   Repair Order:
