2004 Touareg - KESSY module replacement
KraftwerkTurbo
Brighton, MI
C?ID=102239
My KESSY module failed due to corrosion.
I bought a good used one with matching numbers.
Before swapping the modules: do I need to adapt the new module to the car?
If so, link to the procedure?
Scan from old module:
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 P HW: 5WK 470 25
Component: Kessy 6610
Revision: 66105312 Serial number: VWZ3Z0D5286731
Coding: 0000161
Shop #: WSC 31414 000 00000
VCID: 326A972FAE21D0DF57-5140
New module is 3D0 909 135 P and 5WK47025 and H12 S6610
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
You want be able to adopt it just like that , Some data has to be swap manually then you would need both SKC (Pin) form Used and original one .VCDS can not do any of those .
KraftwerkTurbo
Brighton, MI
C?ID=102239
What hardware/software is needed?
m3nt4l
C?ID=348982
You could also read the EEPROM from the old one and transfer the data to the replacement module.
