Hello all,
it's good to finally be here! I've been pining over VCDS since I had my first VW, and finally was able to purchase my own dongle.
My test subject is a 2004 VW Jetta wagon, used for autocross primarily. It is equipped with the 2.0 8v BEV engine code and 5-speed manual transmission.
Over the last few days I've been hunting for a way to disable ESP without losing ABS, and where possible keeping EDL as well, and information seems to be sparse.
One suggestion I had found in my search was to access 03-ABS Brakes, in the Coding module. My VAG number is 1C0 907 397 M, and the component is listed as ESP FRONT MK60 0102.
I subtracted 2048 from my existing coding (0019458 original, 0017410 after) and ESP appears to have completely disappeared -- the car no longer tries to take over when it feels something is awry, and there is no dash light. Also the ESP button on the dash does not enable ESP or seem to change behavior at all.
I'm posting not only because I've seen others request information on a similar modification, but also because I'm hoping to find more information where possible about the possibilities for the MK60 controller.
I know this is probably older news, but hopefully it helps someone else out, and maybe we can also gather more information on these modules.
Edit: I am aware of this article in the wiki, however I found it to be a bit difficult to follow/understand -- I'm somewhat technically savy, but this is all new ground for me. Hopefully I can dig up more information to get to the bottom of how the MK60 operates in terms of coding.
