MK6 GTI GOLF RANDOM ROUGH IDLE AND CEL..
BOBSER1
Ireland
C?ID=275670
hey folks , i am having some trouble narrowing a fault down with this car as the problem is very intermittent.
the car will run fine with no problems for up to two weeks then put on an engine light and idle rough and even
one time cut out .only seems to happen at idle when up to running temp (80) and above .i checked hpfp readings
at constant 40bar and sat with ignition on and it climbs up to high 50bar,so dont suspect fuel leak ,oil level perfect,
no smell of fuel off oil and cant seem to find any air leaks .possible pcv valve setup maybe.....
Sunday,12,April,2020,21:44:01:65251
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZBW340733   License Plate: 11LK3137
Mileage: 115780km-71942mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 47 52 55 56
          62 72 77
VIN: WVWZZZ1KZBW340733   Mileage: 115780km-71942miles
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115 N    HW: 1K0 907 115 AA
   Revision: AAH18---    Serial number:
   Coding: 0403000C1C070160
   Shop #: WSC 27156 001 1048576
   VCID: 3522E8BB5CBF952EE1-8060
               P0300 - 000 -  - Intermittent
                    Mileage: 115540 km
                    Date: 2014.08.29
                    Time: 20:57:31
                    RPM: 749 /min
                    Load: 24.7 %
                    Temperature: 96.0°C
                    Temperature: 84.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.462 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Mileage: 115540 km
                    Date: 2014.08.29
                    Time: 20:57:31
                    RPM: 749 /min
                    Load: 24.7 %
                    Temperature: 96.0°C
                    Temperature: 84.0°C
                    Voltage: 13.462 V
008825 - Leak in Air Intake System
               P2279 - 000 -  - Intermittent
                    Mileage: 115540 km
                    Date: 2014.08.29
                    Time: 23:07:16
                    RPM: 808 /min
                    Load: 18.8 %
                    Temperature: 96.0°C
                    Temperature: 72.0°C
                    Voltage: 13.716 V
008584 - Bank 1; System too Rich at Idle
               P2188 - 000 -  - Intermittent
                    Mileage: 115611 km
                    Date: 2014.09.01
                    Time: 09:51:52
                    RPM: 767 /min
                    Load: 26.7 %
                    Speed: 6.0 km/h
                    Temperature: 102.0°C
                    Temperature: 61.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.589 V
   Part No SW: 02E 300 054 L    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2604
   Revision: 05351113    Serial number: 00001105010026
   VCID: 1F0E2A13CE433F7E1B-804A
   Revision: 00H31001
   Coding: 163B600D092600FA681206E7901C0081310800
   VCID: 76A02FB7C139DE3628-8022
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00001003
   Coding: 0000000002
   VCID: 6E9007D7B169E6F6E0-803A
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AE
   Coding: 48180A3A8825F1C040880080340009E443550088736D8D60E48000240040
   VCID: 383CE18F8BAD6846FA-806C
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 27041  26  0512
   Coding: 009795
   Component: RLS 140511 05  54  0403
   Coding: 0330AD
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12501112401187
   Coding: 308103
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA52WCQ
   Coding: 00003958
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 312ADCAB60D7B90EBD-8064
   Serial number: 3572MSME7D183460ZZZZ
   Serial number: 3582MSME2F55525FZZZ5
   Serial number: 3512QSME44430669ZZZR
   Serial number: 3522QSME542B0110ZZZG
   Revision: --------    Serial number:  90422KE900084
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76A02FB7C939DE3628-8022
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Serial number: 0030853
   Coding: 830000
147462 - Terminal 15
          B1148 12 [008] - Short to Plus
                    Reset counter: 63
                    Mileage: 114205 km
                    Date: 2020.03.19
                    Time: 16:06:02
226057 - Ignition Starter Switch; Terminal S
          B1147 F1 [008] - Open or Short to GND
                    Fault Frequency: 211
                    Reset counter: 62
                    Mileage: 114205 km
                    Date: 2020.03.19
                    Time: 16:10:52
   Part No SW: 5K6 920 971     HW: 5K6 920 971
   Coding: 470F00
   VCID: 72A813A7A551C21604-8026
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 140511F1002403
   Coding: 350003
   VCID: 302CD9AF63DDB006B2-8064
   Component: IMMO          H20 0420
   VCID: 6A980BC78D810AD6BC-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669967262
   VCID: 281C31CF5B0DF8C66A-807C
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H52 2840
   Revision: AB001001    Serial number: VWZ6Z7L7132026
   Coding: 040700420100009000
   VCID: 2E10C7D779E9A6F6A0-807A
                    Fault Frequency: 25
                    Reset counter: 22
                    Mileage: 114320 km
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2120
   Coding: 0004790
   VCID: 3228D3A7ADD18216C4-8066
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 3424D5BF57C58C26D6-8060
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218109123868
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 679E72F39E9337BEA3-8032
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0005046
   VCID: 3326D6A352CB8B1ECF-8066
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
   Coding: 1443164
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
                    Fault Frequency: 25
                    Reset counter: 22
                    Mileage: 114320 km
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Coding: 0000144
   VCID: 3620EFB741B99E36E8-8062
   Part No SW: 5K0 035 730 J    HW: 5K0 035 730 J
   Component: TELEFON       H09 1031
   Revision: 1B001001    Serial number: 00007661951993
   Coding: 0A01000000010101
   Shop #: WSC 35406 002 1048576
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 2C14CDDF47F5D4E68E-8078
End----------(Elapsed Time: 01:27, VBatt start/end: 12.5V/12.4V)-----------
Moving to Car Repair Support.
United States
Adding to that (PCV/rear main seal and Evap system), Basic Settings 107 may help determine if the PCV or RMS are responsible. BS 070 and 071 might help rule out the Evap components.
You might also want to see if the cause of the misfire and rich DTC could be an injector that's leaking intermittently. When those injectors fail they typically fail in a non-intermittent way .. buy you could have one that does so intermittently. Monitoring the residual fuel pressure the next time it happens may help rule that out. Although high pressure fuel pumps can dump fuel straight into the crankcase resulting in rich and misfire faults VW pumps aren't noted for that.
BOBSER1
Ireland
C?ID=275670
the next time it is acting up i will check the injectors see what they are reading. it has a new hpfp maybe some stuff got into injector . but it shoud misfire most the time should
it not
