Inactivate (disable) Daylight Running Lights (DRL) When Light Switch in Off Pos.
coar
C?ID=394727
First I want to thank the Ross-Tech crew for making a great product. I attempted to use the OBDEleven app/reader previously, and it was garbage compared to VCDS. Anyways, my VCDS reader arrived yesterday and I made some much awaited tweaks to the car.
However one thing is still eluding me. I want the option to turn off all the exterior lights. Really what I'm looking for is the option to inactive the DRL LEDs when the headlight switch is either off, or not in the auto position. I got the DRLs to disable when the parking brake is on, but I can't figure how to disable them via the headlight switch. I looked through every byte in Central Electronics (09), twice, and couldn't find anything specifically referencing the headlight switch inactivating DRLs. I believe it's possible as I've seen a number of references to that online, but not sure if said references were for my specific chassis.
The car is a 2014 Audi A4 allroad (8k). Any guidance would be much appreciated!
Windows Based VAG/VAS Emulator Running on Windows 10 x64
 VCDS Version: Release 20.4.0(x64) Data version: 20200331 DS317.0
 Dealer/Shop Name:
 Workshop Code: 000 00000 000000
 Self-Diagnosis Log
 Saturday,11,April,2020,17:04:02:63077
 VIN: WA1UFAFL8EA004204 License Plate: DDL-501
 Mileage: 117550km-73042mi Repair Order:
 Chassis Type: FL-AU48 (8R0)
 Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
 62 6C 6D 72
 VIN: WA1UFAFL8EA004204 Mileage: 117550km-73042miles
10425 - Fuel Pressure too Low during Cold Start
Self-Diagnosis Log
 Page 2
 Address 01: Engine (DET-CPMB) Labels:. 06H-907-115-CDN.clb
 PartNoSW:8K5907115N HW:8K2907115L
 Component: 2.0l R4/4V TF H09 0005
 Revision: ECH09---
 Coding: 722A0013242600062000
 Shop #: WSC 44646 001 1048576
 ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
 ROD: EV_ECM20TFS0118K5907115N.rod
 VCID: 3D273FB6EDFEC8B3784-8068
   P053F 00 [096] - -
 2837 - Fuel Rail/System Pressure
 P0088 00 [096] - Too High
 Mileage: 112665 km
 Date: 2020.02.03
 Time: 07:29:33
 Engine speed: 2492.00 /min
 Normed load value: 55.7 %
 Vehicle speed: 67 km/h
 Coolant temperature: 39 °C
 Intake air temperature: 1 °C
 Ambient air pressure: 830 mbar
 Voltage terminal 30: 14.182 V
 Unlearning counter according OBD: 15
 Engine status: COENG_RUNNING
 4201 - Fuel Level too Low
 P1250 00 [047] - -
 Mileage: 116419 km
 Date: 2020.03.21
 Time: 09:25:57
 Engine speed: 2497.00 /min
 Normed load value: 52.5 %
 Vehicle speed: 68 km/h
 Coolant temperature: 39 C
Page 3
 Voltage terminal 30: 14.206 V
 Unlearning counter according OBD: 0
 Part No SW: 8K1 927 158 HW: 0BK 927 156 AL
 Component: 0BK 20TFSIUSA H16 1003
 Revision: --H16---
 Coding: 000002
 ASAM Dataset: EV_TCMAL551211 002020
 VCID: 74B1DA929E3449FB47A-8020
Address 03: ABS Brakes (J104) Labels: None
 PartNoSW:8K9907379K HW:8K9907379K
 Component: ESP8 quattro H09 0050
 Coding: 0E1D1801
 Shop #: WSC 06335 000 00000
 VCID: 4ACD646AACB06F0BCD6-801E
 Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
 Component: BCM2 2.0 H12 0633
 Coding: 0D824040000000000000
 VCID: 04518A52CE14797B77A-8050
 Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
 Serial number: 2313000082264009
Self-Diagnosis Log
PartNoSW:8K1820043T HW:8K1820043T
Serial number: 13050807054250
Self-Diagnosis Log
 Revision: C1000000 Serial number: 01270520130519
 Coding: 6480208000
 VCID: 392F2BA6F956F49354C-806C
Page 4
 Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
 Component: BCM1 1.0 H16 0103
 Revision: 08016001 Serial number: 00000047933201
 Coding: 26000091863CAFC00000480300003D0D0F1C4708A2090221000008004000030100000030000000
 VCID: 78A9EEA282DC2D9B6B2-802C
 Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B Labels: 1KX-955-119.CLB
 Component: MITSUBA100513 H18 0461
  Coding: 004577
 Component: G397_RLFS H06 0002
 Serial number: 21323938
 Coding: 02005D
 Component: E1 - LDS H03 0031
 Serial number: 00000000001105130939
 Component: USHL4.2 H30 0030
 Serial number: 0000002274555R5XT402
 Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
 Serial number: CD094CA6000000000001
Self-Diagnosis Log
 Page 5
 PartNoSW:8K0959655M HW:8K0959655M
 Component: AirbagVW-AU10 H46 0610
 Serial number: 003KEDA074C/
 Coding: 303844354A32303030304A55304C384B3053
 Shop #: WSC 25663 002 1048576
 VCID: 47CB5D5EBF229263D28-8012
 Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
 Component: BF-Gewichtss. H02 0040
 Serial number: 5810000R130000D11Q
 Serial number: 6334MSME79635861I
 Serial number: 6344MSME79645918N
 Serial number: 6352QSME643032601
 Serial number: 6362QSME2F340B44L
 Serial number: 63732SME3732277E1
 Serial number: 63832SME65311B60X
 PartNoSW:8R0953568Q HW:8R0953568Q
 Component: Lenks.Modul H02 0171
 Revision: 00000000 Serial number: 20130521000559
 Coding: 000037
 VCID: 4FFB757E57D24A239A8-801A
 Component: E221 - MFL H03 0004 No fault code found.
 PartNoSW:8K0920983F HW:8K0920983F
 Component: KOMBIINSTR. H35 0563
 Revision: 00400000 Serial number: WWC61065E
 Coding: 8BB729020300D705020000
 Shop #: WSC 12345 123 61029
 VCID: 38292EA2C25CED9BAB2-806C
Self-Diagnosis Log
 Page 6
 Reset counter: 90
 Mileage: 112153 km
 Date: 2020.01.27
 Time: 16:53:35
 PartNoSW:8R0907468P HW:8R0907468D
 Component: GW-BEM 5CAN-M H11 0056
 Revision: 1Z110028 Serial number: 2841Z1342901A4
 Coding: 80C303FF00
 VCID: 4CC16272A6C4713BFFA-8018
 Serial number: 8180810503
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
 PartNoSW:8K0959760D HW:8K0959760D
 Component: MEM-FS H06 0076
 Revision: AA000000 Serial number: 00000060190642
 Coding: 00581B00000000000000
 VCID: 3B2331AEF36AC683460-806E
 PartNoSW:8T0907566B HW:8T0907566B
 Component: SWA Master H04 0060
 Serial number: 0306339337
 Coding: 010211
 Shop #: WSC 06334 000 00000
 VCID: 3FDB45BEE7F2DAA36A8-806A
 Lane Change Assistant 2:
 Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
 Component: SWA Slave H04 0060
 Serial number: 0306684341
 Coding: 000102
 733696 - Control Module 2 for Lane-Change Assist
 C1115 F5 [008] - Limited Visibility
 Reset counter: 237
 Mileage: 113007 km
 Date: 2020.02.07
 Time: 19:46:42
 PartNoSW:8K0959793R HW:8K0959793P
 Component: TSG FA H02 0508
 Revision: Serial number: 0000062443912
 Coding: 011C13205E00410001
Self-Diagnosis Log
 Page 7
Self-Diagnosis Log
 Saturday,11,April,2020,17:04:03:63077
 Page 8
 PartNoSW:8K0909144F HW:8K0909144B
 Component: RCEPS H37 0507
 Revision: 00001000 Serial number: 0011483523
 Coding: 100000000001
 ROD: EV_RCEPSAU48X_008.rod
 VCID: 34311A92DEB409FB87A-8060
 Revision: 00002001 Serial number: 0307434757
 Coding: 0126023A20BA709580B0023200000000
 Component: GTO BF H01 0080
 Serial number: 00000000000000673843
 Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
 Component: J245 PS150 H08 0043
 Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
 Component: J394 PS240 H08 0043
 01503 - Bulb for 3rd Brake Light (M25)
 Fault Status: 00101100
 Reset counter: 236
 Mileage: 115906 km
 Date: 2020.03.08
 Time: 18:55:22
Component: DSP Prem H05 0030
Page 9
 PartNoSW:8T1035223A HW:8T1035223A
  Revision: 00005001 Serial number: 94813014844602
 VCID: 2D070FF63D1E5833C84-8078
 PartNoSW:8K0959792R HW:8K0959792P
 Component: TSG BF H02 0508
 Revision: Serial number: 0000061846167
 VCID: 4EC5687A50D8432B91E-801A
 PartNoSW:8K0907801M HW:8K0907801J
 Component: EPB-4 H01 0004
 Revision: -------- Serial number: 00000001308572
 ROD: EV_ParkiBrake_AU48.rod
 VCID: 392F2BA6F9D6F49354C-806C
 Revision: AB001007 Serial number: 156EV0D7801054
 Coding: 020007010000000001
 VCID: 2411EAD26ED4997B17A-8070
Self-Diagnosis Log
Component: NAR 2013/2014 0802
 PartNoSW:8R1035746D HW:8R1035746D
 Component: H-BNT-NA H40 0738
 Revision: -------- Serial number: 204ET0DB001584
 Coding: 010200050006A1EF51028B4E00000403140000000000000000
 Component: DU7 High H42 0104
 Serial number: A130EP0D2727531
 Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
 Serial number: 00000001509939
 Component: CD-Database 5298
 PartNoSW:8K0959795G HW:8K0959795D
 Component: TSG HL H01 0506
 Revision: Serial number: 0000061847129
 Coding: 010C13204000210001
 VCID: 46D5505AB8A88B6B29E-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
 PartNoSW:8T0907441C HW:4L0907441B
 Revision: --H07--- Serial number: 525PA8-J3293MC
 Coding: 1000007
 VCID: 38292EA2CE5CED9BAB2-806C
Self-Diagnosis Log
Page 10
 Subsystem 1 - Part No: 8R0 060 884 BD
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
 PartNoSW:8K9827851A HW:8K9827851A
 Component: J605 Master H52 0330
 Revision: -------- Serial number: 8K9827851A
 VCID: 3C2132B2F664C1BB4FA-8068
 Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
 Component: J756 Slave H52 0330
 Serial number: 8K9827852A
Self-Diagnosis Log
 Page 11
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
 Component: TSG HR H01 0506
 Revision: Serial number: 0000061847711
End----------(Elapsed Time: 02:03, VBatt start/end: 12.2V/12.2V)-----------
Hi and welcome.
Admin request: Please don't use the [Print] function in VCDS to post data here. The formatting that produces is much harder to read here than the native text that VCDS produces. You will find a backup of that text in your Scans sub-folder.
TBAx
DE
C?ID=287144
If I am not mistaken Byte 3 Bit 0 in the BCM allows activation of an option inside the MMI.
coar
C?ID=394727
Hi and welcome.
Noted, I'll use the native text next time.
Thanks, I'll check that out.
United States
I agree and believe both of these may need to be enabled:
Address 09: Byte 03, Bit 0 DRL (Daytime running lights) selectable via MMI / Car Menu
Address 5F: Byte 06, Bit 7 Menu Exterior Lights active
I don't recall if the MMI needs a reboot after those changes.
coar
C?ID=394727
Long time, no update, but unfortunately that didn't create an option in the MMI.
Address 09: Byte 03, Bit 0 5F was already enabled from previous experimenting, and I think Address 5F: Byte 06, Bit 7 was enabled from the factory - I've always had the exterior light menu in the MMI.
Thanks for the help, but I think I'm done pursuing this - having DRLs disable with the parking brake is good enough for me.
coar
C?ID=394727
Just to give this thread closure, all my lights will now turn off in the 0 position. I didn't do anything different from what was mentioned above except turning DRLs to Off then back to On in the MMI. I'm not sure why the changes didn't take effect immediately before, but it's possible a MMI reboot or engine restart was needed. I keep the headlight switch in Auto 99.9% of the time so it's possible the DRL inactivation was working soon after I enabling, but I just didn't notice it.
