2015 Caddy Maxi Start/Stop
Rhodesian75
Perth, Western Australia
C?ID=221953 (NRRT)
G'Day all fellow Ross-Techians.
I was wandering if some of those out there that hold vastly more knowledge than I have if you could help me figure out an issue I have with my Start/Stop system on my van.
Basically the Start/Stop system very intermittently works. After I got the van in October last year the Start/Stop system has not worked. So after about a week of using it I thought I would disconnect the battery and charge it slowly as it may need a trickle charge having been sat at the dealers for who knows how long. When I reconnected I had all the usual errors associated with a disconnected battery which I cleared and rectified. Took the van for a drive. Came to my first stop and hey presto van shuts off, lights change and I released brake pedal and all I hear in several loud clicks from what seemed to be behind the fuse box (RHD) and display says "Manual restart". Ok so manual restart and off I go, come to the next stop and it turns off as expected, but this time I touch the throttle to see if it will restart, but again several loud clicks and manual restart required. Then decided to go home and check codes. Several stops on the way home and engine did not turn off once and get the capital "A" with a line through it saying Start/Stop inactive.
So I do a full scan and get this.
VIN: WV1ZZZ2KZFX138364   License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 61 77
VIN: WV1ZZZ2KZFX138364   Mileage: 110780km-68835miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TL    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9977
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254014032501080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TL 003001
   ROD: EV_ECM16TDI02103L997557R.rod
   VCID: 032B663A8A7F4E57BA-8056
   Part No SW: 0AM 300 062 Q    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6201
   Revision: 00043014    Serial number: CU501503317186
   Shop #: WSC 35110 377 00141
   VCID: 3A55DBDE7535CF9FA9-806E
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: 633C400D09250302C60E02EA901DC091A1000020
   VCID: 042965268771496F83-8050
                    Reset counter: 208
                    Mileage: 110781 km
                    Date: 2020.01.11
                    Time: 00:23:53
                    Count: 14
                    Count: 12800
                    Count: 294
                    Count: 49664
   Part No SW: 7N0 907 426 CM    HW: 7N0 907 426 CM
   Component: AC Manuell    H20 0707
   Revision: 00001002
   Coding: 0010002003
   VCID: 01276C3290635C47A8-8054
   Part No SW: 5K0 937 085 AA    HW: 5K0 937 085 AA
   Component: BCM PQ35 B+   122 0174
   Revision: BB122001
   Coding: 671A58388025186F08880082940000C403617288424F8160648087000041
   VCID: 72C533FEADC577DFA1-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 16031  26  0512
   Coding: 009F95
   Component: VW10Airbag02D H07 0013
   Revision: --------    Serial number: 003HL00WFF6N
   Coding: 000000000000000000000000000000003244
   VCID: 354FC8E2942B20E744-8060
   Part No SW: 5K0 953 521 DD    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150401300011
   Coding: 1882160000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 71C73CF2A0C34CC758-8024
   Serial number: 0796776
   Coding: 820000
   Part No SW: 2K0 920 876 F    HW: 2K0 920 876 F
   Component: KOMBI         H04 0905
   Coding: 180A00
   VCID: 334BF6FA9A5F3ED76A-8066
   Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1653
   Revision:   H58       Serial number: 050415F1000108
   Coding: 357401
   VCID: 7F23EACAEE972AB7DE-802A
   Component: IMMO          H04 0905
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AF52B9E8D15BF1F19-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0132656
   VCID: 48B1B1163BD9AD0F2F-801C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 3957C4D27033C487A0-806C
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 208
                    Mileage: 110781 km
                    Date: 2020.01.11
                    Time: 00:23:52
                    Battery Volts: 13.4 V
                        DU
                    Temperature: 59.0∞C
                    Count: 5
                    Steering Angle: -30.45∞
                    Count: 1
                        SteerAng n.Init
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 110781 km
                    Date: 2020.01.11
                    Time: 00:23:52
                    Battery Volts: 13.2 V
                        DU
                    Temperature: 59.0∞C
                    Count: 7
                    Steering Angle: 0.00∞
                    Count: 1
                        SteerAng n.Init
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0132656
   VCID: 47B3B22A36C7A27726-8012
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
   Component: Radio RCD510  052 0208
   Revision: 00000001    Serial number: VWZ1Z3L1612482
   Coding: 01000200010005
   VCID: 236B06BA22BFAE579A-8076
   Component: Batt.regelung H58 1653
   Coding: 030F1859
   VCID: 71C73CF2A8C34CC758-8024
   Component: J367-BDM  H07 0180
   Serial number: 42091111141491789413
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007670326545
   Coding: 0A01010000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C59DDC6B701F1AFBB-8068
End-------------------------(Elapsed Time: 01:55)--------------------------
So I clear codes, and carry out the steering angle calibration. Take the van for a drive around the block and as soon as I come to a stop the engine shuts down, but when I release the brake again all i hear is several clicks then manual restart required.
I take it home and leave it for a few weeks as it's due its first service since I got it and would get dealer to look into it. Get it back after service and dealer says I require a new battery. So I say to the dealer if fault still occurs after battery is replaced will I be reimbursed for the battery as it was not the fault. Silence. I ask again and get told technician said it needs new battery.
I will get battery replaced at a later date as they are pretty expensive in Australia, about $475 fitted.
Anyways, Monday I was driving to work and the first set of lights I come to and come to a full stop, engine shuts down. Weird as I thought the battery was faulty, so lights change and I take my foot off the brake and again hear the clicks and manual restart required. This is starting to get really frustrating. It seems that when I disconnect the battery and reconnect it the engine will stop, but not restart twice and then not turn off for weeks, but the like Monday turn off once and not again since.
Today I scanned again and this is what I get (Nothing).
VIN: WV1ZZZ2KZFX138364   Mileage: 117340km-72911miles
   VCID: 032B663A8A7F4E57B8-8056
   VCID: 3A55DBDE7535CF9FAB-806E
   Revision: 00H46001
   VCID: 042965268771496F81-8050
   Revision: 00001002
   Coding: 0010002003
   VCID: 01276C3290635C47AA-8054
   Revision: BB122001
   VCID: 72C533FEADC577DFA3-8026
   Coding: 009F95
   VCID: 354FC8E2942B20E746-8060
   Coding: 1882160000
   VCID: 71C73CF2A0C34CC75A-8024
   Coding: 820000
   Coding: 780A00
   VCID: 334BF6FA9A5F3ED768-8066
   Coding: 357401
   VCID: 7F23EACAEE972AB7DC-802A
   VCID: 6AF52B9E8D15BF1F1B-803E
   Coding: 0132656
   VCID: 48B1B1163BD9AD0F2D-801C
   Revision: 00H22000
   VCID: 3957C4D27033C487A2-806C
   Coding: 0132656
   VCID: 47B3B22A36C7A27724-8012
   VCID: 236B06BA22BFAE5798-8076
   Coding: 030F1859
   VCID: 71C73CF2A8C34CC75A-8024
   VCID: 3C59DDC6B701F1AFB9-8068
Any help would be greatly appreciated.
Finally can anyone tell me what the temperature "Temperature: 59.0∞C" under steering assist freeze frame relates to as it's too low for coolant temp and too high for ambient?
:banghead:
NostraJackAss
Not sure how it is in Australia, however, here the start/stop is an AECD and under useful life warranty for anywhere depending on how certified for 10/120 or 15/150 in the USA, did you look into such certifications or process the OEM is responsible for by contacting Government responsible for enforcement if such possible regulations exist there in your region?
Sure does sound like a wiring or faulty relay, possible had BCM?
Get RTFB and WD and trace check all with DVOM and decade box, it maybe something as simple as a brake light switch, no?
Rhodesian75
C?ID=221953 (NRRT)
I believe it's a faulty relay, but have no idea which relay it is.
I'm fairly new to VW. What is RTFB & WD?
Cheers.
Rhodesian75
C?ID=221953 (NRRT)
See how RTFB and WD are bold green underlined? Hover your mouse over them and a pop-up explanation will appear :thanks:
Ah, ok.
which one is right for a Varta battery?
Number 1
068 VA0 250330U0JK
or
Number 2
068 VAO 250330U0JK
VAO is Varta.
