Heated Steering Wheel - Security Access Code.
Emmett03
Voorheesville, NY, USA
C?ID=353548
2008 Q7 4.2L I’m trying to change the temperature setting on the heated steering wheel but I cant get into the adaptive setting. Does anyone have the security access code? When I hover over the field I don’t get the code as I do with the other modules. Any help would be appreciated. Thank you.
South Molton, UK
The security code may be dependent on the hardware and software versions fitted to your Q7, so we'll need to see a full unedited VCDS Auto-Scan - see my sig for a How-To.
Emmett03
C?ID=353548
Thank you.
Sunday,12,April,2020,08:31:21:43894
VIN: WA1BV74L88D061845   License Plate:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 34 36 37 3C 42
          46 47 4F 52 55 56 5C 61 62 65 67 69 6C 6D 6F 72 76 77 7F
VIN: WA1BV74L88D061845   Mileage: 185740km-115413miles
0E-Media Player 1 -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
7F-Inform. Electr. II -- Status: Cannot be reached 1100
Address 01: Engine        Labels:. 079-907-560-BAR.clb
   Part No SW: 4L0 910 560 G    HW: 4L0 907 560 B
   Component: 4.2l V8/4V          0020
   Revision: 78H02---    Serial number:
   Coding: 01210009190F0560
   Shop #: WSC 31414 790 00001
   VCID: 2C01069F8A01800BDFA-8078
005241 - Brake Boost Vacuum System
               P1479 - 008 - Mechanical Failure
                    Fault Status: 01101000
                    Mileage: 185357 km
                    Date: 2020.03.23
                    Time: 05:55:47
                    RPM: 2091 /min
                    Load: 58.4 %
                    Speed: 23.0 km/h
                    Temperature: 14.0°C
                    Temperature: 6.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.843 V
Readiness: 0010 0000
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 JH    HW: 09D 927 750 JH
   Component: AL 750 6A           1166
   Revision: 00H78000    Serial number:
   Coding: 0000504
   VCID: 7DA7FBDB21FBD983384-8028
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0087073
   Shop #: WSC 08701 444 00001
   VCID: 290FFF8B85F3952324C-807C
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601501041320
   Coding: 0000135
   VCID: 6393ADA3A75F0F732E0-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H46 0080
   Component: FBSAUDIC6 KSG   H27 0080
   Component: FBSAUDIC6 IDG   H01 0060
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 253
                    Mileage: 185370 km
                    Date: 2020.03.23
                    Time: 08:34:20
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Reset counter: 253
                    Mileage: 185370 km
                    Date: 2020.03.23
                    Time: 08:34:20
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 253
                    Mileage: 185370 km
                    Date: 2020.03.23
                    Time: 08:34:20
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 354DJ087537100
   Coding: 0002003
   VCID: 353723FB594BC1C3B04-8060
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001418939
   Subsystem 3 - Serial number: 0114.10.090000000100010899ÿ
   Subsystem 4 - Serial number: 010899ÿ
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
   Component: KLIMABETAETIGUNGH07 0030
   Revision: 00---013    Serial number: 00000000161930
   Coding: 0786472
   VCID: 2313EDA3E7DF4F736E0-8076
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 68
                    Mileage: 176341 km
                    Date: 2019.01.06
                    Time: 15:24:07
                    Temperature: 22.0°C
02380 - Positioning Motor for Right Side Vent (V300)
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 25
                    Mileage: 176341 km
                    Date: 2019.01.06
                    Time: 15:24:08
                    Voltage: 14.00 V
                    Temperature: 27.0°C
                    (no units): 203.0
                    (no units): 103.0
                    Temperature: 18.0°C
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Component: ILM Fahrer      H18 0250
   Coding: 0114123
   VCID: 303912EFA629E4EBE32-8064
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H15 0100
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00152619
   Shop #: WSC 31414
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H45 0350
   Revision: 00045007    Serial number: AUZ5ZBH8365440
   VCID: 1D67DB5BC1BB7983584-8048
02446 - Disk Drive Mechanical Malfunction
                    Fault Status: 00101110
                    Reset counter: 63
                    Mileage: 185728 km
                    Date: 2020.04.10
                    Time: 17:32:39
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7H0296952
   Coding: 0000100
   VCID: 2F3B1193BB17FB13FA8-807A
                    Reset counter: 252
                    Mileage: 185356 km
                    Date: 2020.03.21
                    Time: 13:51:29
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH42 0230
   Revision: 06H42000    Serial number: 0038QD07ESBO
   Coding: 0014131
   VCID: 2B0305838F0F8733D60-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME5A422349E
   Subsystem 3 - Serial number: 6342QSME546C3367M
   Subsystem 4 - Serial number: 6352QSME5C21253BI
   Subsystem 5 - Serial number: 6362QSME5878444BT
   Subsystem 6 - Serial number: 63734SME542C3C411
   Subsystem 7 - Serial number: 63834SME54311079W
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0410
   Revision: 00H04000    Serial number: 90054080720626
   Coding: 0032242
   VCID: 270BF9B393E7A353328-8072
   Component: E0221           H01 0030
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 981
   Component: KOMBIINSTR. M73 H23 0240
   Revision: 00000000    Serial number: 73K597148
   Coding: 3697288
   Shop #: WSC 08902 444 56823
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 C
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1000D0812881D8
   Coding: F7F7FE7F767A0201
   Shop #: WSC 08902 444 12161
   VCID: 2D070B9BB11B8903C84-8078
03163 - Control Module for Information Electronics 2
                    Reset counter: 68
                    Mileage: 150580 km
                    Date: 2016.06.07
                    Time: 16:45:08
Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 270BF9B39FE7A353328-8072
   Part No SW: 4L0 910 158     HW: 4L0 919 158 D
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---009    Serial number: 00000030087398
   Coding: 0000006
   VCID: 6889BA8F5E796C2BFB2-803C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 252
                    Mileage: 185356 km
                    Date: 2020.03.21
                    Time: 14:08:33
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 C    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7660
   Revision: --H03001    Serial number: 15.1528-0096.2
   Coding: 0015520
   Shop #: WSC 08701 444 54431
   VCID: 2A0D008780F59E3B2D6-807E
00139 - Left Front Body Acceleration Sensor (G341)
                    Fault Status: 00101001
                    Fault Frequency: 22
                    Reset counter: 49
                    Mileage: 185356 km
                    Date: 2020.03.21
                    Time: 13:55:15
                    Error Code: 193
01577 - Turn-Off due to Over-Temp
                    Fault Status: 00100001
                    Fault Frequency: 18
                    Reset counter: 64
                    Mileage: 185364 km
                    Date: 2020.03.23
                    Time: 06:00:46
                    Error Code: 68
01772 - Signal from Level Control Pressure Sensor (G291)
                    Fault Frequency: 21
                    Reset counter: 62
                    Mileage: 185383 km
                    Date: 2020.03.23
                    Time: 14:42:44
                    Error Code: 78
                    Reset counter: 63
                    Mileage: 185728 km
                    Date: 2020.04.10
                    Time: 18:38:03
                    Error Code: 13
01400 - Suspension Level Control
                    Reset counter: 62
                    Mileage: 185726 km
                    Date: 2020.04.09
                    Time: 17:53:51
                    Error Code: 66
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082954
   VCID: 619FA7ABBD431D633CC-8034
   Part No SW: 4E0 910 888 F    HW: 4E0 919 887 M
   Component: MNS US          H51 0990
   Revision: 00000000    Serial number: 313CI087534315
   Shop #: WSC 08252 444 69879
   VCID: 313F17EBAD23EDE3ECC-8064
02927 - DVD Read Error
                    Reset counter: 43
                    Mileage: 185408 km
                    Date: 2020.03.24
                    Time: 17:33:07
                    Hex Value: 0x5E7A
                    Hex Value: 0x448D
                    Hex Value: 0x0401
                    Hex Value: 0x0000
   Part No SW: 4L0 910 566 B    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH10 0130
   Revision: 00H10000    Serial number: 6PZ 009 014-00
   Coding: 0000001
   Subsystem 1 - Part No: 4L0 910 568 B
   Component: J0770_SWA_Slave_H08 0130
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F10.03.0800H0800000010034ÿ
   Subsystem 4 - Serial number: 010034ÿ
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00-00000
   Coding: 0051915
                    Reset counter: 13
                    Mileage: 185569 km
                    Date: 2020.03.27
                    Time: 15:32:43
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H08 0060
   Revision: 0060 ---    Serial number: 01105067690000
   Coding: 7632925
   VCID: 33331DE3573FDFF39E0-8066
03073 - Rear Lid Closed Sensor 1
                    Reset counter: 58
                    Mileage: 185569 km
                    Date: 2020.03.27
                    Time: 15:34:18
02956 - Lamp in Trunk/Hatch Lid; Left
                    Fault Frequency: 8
                    Reset counter: 61
                    Mileage: 185648 km
                    Date: 2020.04.06
                    Time: 19:16:02
                    Bin. Bits:  001 000
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H03 0150
   Revision: PROD_01     Serial number: 00000000061602
   Coding: 0000026
   VCID: 2809FA8F9EF9AC2B3B2-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000031365
   Coding: 0012001
   VCID: 5EE59C578C3D229B01E-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0051915
                    Fault Frequency: 62
                    Reset counter: 87
                    Mileage: 181977 km
                    Date: 2019.11.30
                    Time: 17:35:14
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0040
   Coding: 0000022
   VCID: 698FBF8B45735523E4C-803C
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 388CY087681433
   Coding: 0000002
   VCID: 2E050C97BC1DF21BF1E-807A
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 4E0 910 217 C    HW: 4E0 907 217 C
   Component: J759  LDW       H07 0070
   Revision: 00H07018    Serial number: 80020832000009
   Coding: 0001101
   VCID: 2019E2AFF6C9546B732-8074
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000014211
   VCID: 2517F3BBE9EBB143004-8070
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2803181777
   Coding: 344630393135313035442056413032383033313831373737
                    Mileage: 185740 km
                    Date: 2020.04.11
                    Time: 19:44:50
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0051722
                    Fault Frequency: 13
                    Reset counter: 239
                    Mileage: 184785 km
                    Date: 2020.02.22
                    Time: 12:29:54
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700069886
   Coding: 0062424
   VCID: 221DE8A7F8C5467B656-8076
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000803190077
   Shop #: WSC 12336 024 394758
   VCID: 34311EFF5231D8CB87A-8060
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000152268559
   Coding: 0100000000000000
   VCID: 313F17EBA123EDE3ECC-8064
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J8342NB
   Coding: 1021001
   VCID: 2411EEBFE2D1484B17A-8070
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C69F4A81400B9FA-8038
   Subsystem 3 - Serial number: RD19.11.07--H25001001B0062ÿ
   Subsystem 4 - Serial number: 1B0062ÿ
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003596579-----
   Coding: 0003595
   VCID: 2615F4B794EDBA5B09E-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE16_SKB09H10 0200
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE16_SKB09H10 0200
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE16_SKB09H10 0200
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Fault Status: 00101010
                    Fault Frequency: 27
                    Reset counter: 61
                    Mileage: 185569 km
                    Date: 2020.03.27
                    Time: 15:26:17
                    Reset counter: 63
                    Mileage: 185728 km
                    Date: 2020.04.10
                    Time: 14:17:47
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0051722
                    Reset counter: 82
                    Mileage: 177411 km
                    Date: 2019.02.03
                    Time: 10:45:09
   Part No SW: 4F0 910 283 K    HW: 4F0 919 283 K
   Component: Parkhilfe 8-Kan H12 0100
   Revision: 00H12000    Serial number: 69820807500852
   Coding: 0231246
01548 - Sensor for Parking Aid; Rear Right (G206)
                    Fault Status: 01101001
                    Reset counter: 236
                    Mileage: 179632 km
                    Date: 2019.08.03
                    Time: 09:38:11
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
                    Reset counter: 229
                    Mileage: 174136 km
                    Date: 2018.11.15
                    Time: 12:12:32
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                    Reset counter: 4
                    Mileage: 174838 km
                    Date: 2018.11.28
                    Time: 18:24:31
01549 - Supply Voltage for Parking-Aid Sensor
                    Reset counter: 237
                    Mileage: 179636 km
                    Date: 2019.08.03
                    Time: 12:45:52
01629 - Sensor for Parking-Aid; Front Left (G255)
                    Reset counter: 236
                    Mileage: 179634 km
                    Date: 2019.08.03
                    Time: 09:50:19
                    Fault Status: 01100010
                    Reset counter: 237
                    Mileage: 179636 km
                    Date: 2019.08.03
                    Time: 12:46:01
   Part No SW: 4F0 910 336 E    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005028489
   Coding: 0010900
Address 7F: Inform. Electr. II
End----------(Elapsed Time: 02:51, VBatt start/end: 13.8V/13.9V)-----------
