I watched this youtube video trying to set the auto window close for some reason it didn't work. I must be missing something can anyone point me in the right direction
https://youtu.be/AASygQQA39k
i have a 2015 gti autobahn with a lighting package as well as the PP. the wipers have the ability to be auto.
here is a scan of the car
Friday,10,April,2020,16:28:05:34708
VCDS Version: 20.4.0.1 HEX-NET CB: 0.4508.4
VIN: 3VW447AU7FM093635 License Plate: 4.10.2020
Mileage: 89063km-55341mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 32 42 44 52 55 5F 75 A9
VIN: 3VW447AU7FM093635 Mileage: 89063km-55341miles
Address 01: Engine (J623-CXCB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0006
Revision: --H13---
Coding: 091D00124424002F1000
Shop #: WSC 00066 790 00202
ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C14F5E5478CA3E68E-8078
Readiness: 1110 1101
Part No SW: 0D9 300 020 G HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4523
Revision: 05853104 Serial number: TFK01503190805
ROD: EV_TCMDQ250021.rod
VCID: 197A3C31181E264EE5-804C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 51055000000757
Coding: 01FA6BA15429096F007D020341C86880D62A9000408216B600430051C006
Shop #: WSC 01383 790 50316
VCID: 47DEAA49FE2A60BE83-8012
Revision: 00021000 Serial number: 0363885276
Coding: 030C0C
VCID: 3A38C3BDBDD80D560C-806E
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020014200100000005000012111400
VCID: 42C8BB5DD508459654-8016
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
Air quality sensor:
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Revision: -------- Serial number: 86582503150084
Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00144
ROD: EV_BCMBOSCH_014.rod
VCID: 4AD8937DED389DD69C-801E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150411 043 0581
Serial number: 150503085733
Component: RLHS 037 0059
Serial number: S5Y15M03D23H03M25S44
Coding: 06A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03690800532712141958
Coding: 181803
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM024K8C
VCID: 51EA8411006EAE0EDD-8004
Occupant Detection:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002MSWO07
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 000 903 15
Serial number: 35700000000C581D531K
Subsystem 3 - Part No SW: ----------- HW: 480 000 903 15
Serial number: 35800000000E07FC531U
Subsystem 4 - Part No SW: ----------- HW: 480 401 003 15
Serial number: 35100029919EFD24F1FW
Subsystem 5 - Part No SW: ----------- HW: 480 401 003 15
Serial number: 3520002B119DB8B52389
Subsystem 6 - Part No SW: ----------- HW: 480 402 003 15
Serial number: 3550002BD19DB894328L
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 003 15
Component: FrontSensor_P 001 6149
Serial number: 3560002BD19DB891C37S
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150331500408
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 04447D458F9C8BA626-8050
Part No SW: 5G1 920 856 HW: 5G1 920 856
Component: KOMBI 342 4270
Coding: 0BAD091A2980CF0502086A001000000000000000
VCID: 6B9636F9820264DEC7-803E
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 10041510000982
Coding: 0101000820085900EF00022B1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07027
ROD: EV_GatewConti_011.rod
VCID: 72A82B9DA528B51604-8026
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29150000515380085133
Coding: 31FFFF
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000069765004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3424ED859FBCFB26D6-8060
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8040
Serial number: HA1-00006.02.15
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001001
ROD: EV_LockElectHA1VW37X.rod
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 250415060501DU
Coding: 003E13200000040000000000
VCID: 40CCB155DB04578642-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001067636
Coding: 011000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8102
VCID: 373EDA898ECA103EF3-8062
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 250415060504Z6
Coding: 003E13200C00040000000000
VCID: 3FCEB2A9A6FA287E3B-806A
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001087444
Coding: 091000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A01000B000400
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 0655
Serial number: V7B02304152544
Coding: 027300020000000021220002001800001F0203340100010546
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 699A4CF188FE76CEB5-803C
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9RS600L7Q
Subsystem 2 - Part No SW: 5G0 919 866 H HW: -----------
Component: NAR 2014/15 --- 0020
B11CF 53 [009] - Deactivated
Reset counter: 134
Mileage: 89063 km
Date: 2020.04.10
Time: 15:58:32
Voltage terminal 30: 12.3 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Shop #: WSC 00066 790 00322
ROD: EV_OCULowMQB.rod
VCID: 43C6BE59CA124C9E5F-8016
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150303201119
End------(Elapsed Time: 01:34, VBatt start/end: 12.3V/12.3V, udsna)--------
