Have code; (00332 - Control Circuit for Tank Flap 007 - Short to Ground) on Golf MK6
jedred1
C?ID=399849
This is reg. Cent. Elect. -- Status: Malfunction code 00332. I didn't think I had a problem as I had no CEL on the dash but upon testing my tank flap door I found it will not lock along with all of the other doors. Also when locking all of the doors with the key I do not hear any sound from above the flap door only the sound of the the other 4 doors. So I'm thinking I have a problem with the Fuel Door Actuator (the rod which moves up and down like a bolt lock to lock the fuel door flap). I've purchased this part and plan on switching out this weekend. But before I go tearing everything apart I wanted to research things a bit more. So my questions are 1.) is there a fuse I should check first? 2.) it says 007 - Short to Ground. I have checked the general condition of the wires in the area and see nothing loose any ideas? Well that's all I can think of. I just was wondering if I was going down the wrong road and wanted to see if any one else has dealt with this.
Thanks, Justin (My 3rd scan and 1st post)
here is the whole scan
Thursday,02,April,2020,11:59:12:03423
VIN: WVWHD7AJ1CW239582   License Plate: MJOLNER
Mileage: 124250km-77205mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHD7AJ1CW239582   Mileage: 124250km-77205miles
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 040301081C070160
   VCID: 78A9EE508ED39E3B6B2-802C
001056 - Catalyst System; Bank 1
               P0420 - 000 - Efficiency Below Threshold
                    Mileage: 123904 km
                    Date: 2014.08.17
                    Time: 09:06:02
                    RPM: 2632 /min
                    Load: 34.1 %
                    Speed: 106.0 km/h
                    Temperature: 91.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 850.0 mbar
                    Voltage: 13.843 V
Readiness: 0000 0001
   Part No SW: 02E 300 057 R    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3115
   Revision: 05551213    Serial number: 00001112060407
   VCID: 2809FE101EF3CEBB3B2-807C
   Revision: 00H31001
   Coding: 114B600C49250003881006EC921B0041B70800
   VCID: 7BA3F15CB3E5B523060-802E
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001016
   Coding: 0000001002
   VCID: 005986B0DA83D6FB532-8054
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 6F180A3A90272AC4008800C1700001444E611F86434D8D60648020200040
   VCID: 3D273F44ED717B13784-8068
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 16011  26  0512
   Coding: 009795
                    Fault Status: 01100111
                    Reset counter: 233
                    Mileage: 123719 km
                    Date: 2014.08.13
                    Time: 12:49:52
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Fault Frequency: 13
                    Mileage: 123744 km
                    Date: 2014.08.14
                    Time: 05:42:12
                    Voltage: 14.30 V
                        Term 50 On
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA1BU55
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FDB454CE7FD69036A8-806A
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00002VGL00
   Serial number: 3572MSME3247016BZZZR
   Serial number: 3582MSME17156369ZZZW
   Serial number: 3512QSME6C1B6366ZZZ%
   Serial number: 3522QSME7A28676FZZZA
   Serial number: 35527SME49464229ZZZG
   Serial number: 35627SME51534229ZZZ8
   Revision: --------    Serial number:  90440LA5000ST
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B5E0688847E84B79E-8022
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H08 0010
   Serial number: 0147111
   Coding: 830000
   Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
   Coding: 270F01
   VCID: 36352068C8C7A84BB9E-8062
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 120112F2001542
   Coding: 350002
   VCID: 3A2D3458FC5F4C2B5D6-806E
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223RG7M206
   Coding: 0000002
   VCID: 7EA5F848ACF7A00B21E-802A
   VCID: 6A8DC418CCFF3CABED6-803E
   Revision: A1001003    Serial number: 7661679221
   VCID: 290FFB1409F9F7B324C-807C
03138 - Input AUX IN
                    Fault Status: 00101001
                    Reset counter: 42
                    Mileage: 123662 km
                    Date: 2014.08.13
                    Time: 10:00:11
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0001204
   VCID: 313F13742D298F73ECC-8064
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: 372B2D6CC34D5143A28-8062
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 323D1C78282FB46B956-8066
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7M1101250
   Coding: 01000400040005
   VCID: 6393A93C2B556DE32E0-8036
                    Reset counter: 236
                    Mileage: 123662 km
                    Date: 2014.08.13
                    Time: 09:40:39
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 35372764D941A353B04-8060
   Coding: 0001168
   VCID: 36352068C447A84BB9E-8062
00108 - Signal Central Locking SAVE/LOCK Rear Right
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H12 2902
   Revision: 1B001001    Serial number: 00007661711382
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270BFD2C1F6DC1C3328-8072
End----------(Elapsed Time: 01:06, VBatt start/end: 12.5V/12.4V)-----------
Hi and welcome.
Check wiring diagrams to see how that actuator works. If it has switched power on one side and the BCM pulls the other side to ground to turn it on, then not having the +12 on the other side will throw a "Short to GND" fault.
NostraJackAss
So will insufficient current not just voltage so verify the available output current OP.
