2010 Audi Q7 3.0 TDI - P0087
jmjq7tdi
Lidingö, Sweden
C?ID=205446
Hello all,
I'm hoping you can help me avoid an expensive trip to the repair shop. Huge thanks in advance. Beginning yesterday, the flashing glow-plug light started coming on and putting the Q7 in limp mode. It did this for the first three consecutive trips yesterday morning. It ran fine otherwise during those trips, even though it was in limp mode, limiting me to about 80km/hr. The next three trips later that day, it ran normally, no glow plug light came on at all. One of those trips was to the auto parts store, because I knew that three of the glow plugs were already throwing error codes regularly and I had the same issue with my previous Q7. Then, last night (before I had a chance to install the glow plugs), my wife took it out, and both the check engine and the flashing glow plug light came on, so she returned home and took a different vehicle.
Today, before even scanning for codes, I took it for a long drive to warm it up, but never drove too fast. The flashing glow plug light eventually came on again, but no check engine light. It ran remarkably smooth and well. I took it home, replaced all six glow plugs, and also, since I was working on it anyway I also replaced the fuel filter.
The old fuel filter looked very good, the fuel inside the fuel filter canister was remarkably clean, and there was no grime or deposits in the bottom of the canister.
I ran VCDS to collect a new log and to clear the codes. I didn't pay much attention to the codes that were coming up because the first three codes were all old glow plug codes and I thought this work would clear them. I cleared all the codes, and proceeded to take it out for the verification test drive. Within one block, the flashing glow plug light came back on again (but no check engine light). I ran the codes again, checked with the previous codes before clearing it, and saw that a low fuel pressure failure P0087 appeared in both the before and after. But at least the glow plug errors are gone.
I've been doing a lot of research, and it seems that there are many possible culprits. Worst case scenario would be the HPFP, but as clean as the fuel filter canister was (I rechecked the filter and don't see any specs of metal at all), it didn't seem as if the HPFP was self-destructing or anything. I removed the pressure control valve from the top of the HPFP because I saw several pictures that showed metal underneath it when an HPFP fails, but it was perfectly clean inside, and surprisingly this valve already has the strainer mounted on it, so another good sign that the HPFP is probably not eating itself as I've seen in so many of the pictures online - but I understand that doesn't mean I can rule it out.
Other possible culprits would seem to be the high pressure sensor or the fuel pump(s) in the tank. Maybe the fuel pump pressure control valve mounted on the HPFP? I don't know, but I haven't found any other examples of that being the problem.
How should I approach this diagnostic - without a mechanical fuel pressure gauge?
Here's the latest scan. Thanks in advance for your help!
Thursday,09,April,2020,17:30:33:49964
VCDS Version: 19.6.2.2 (x64)
VIN: WAUZZZ4L3AD0#####   License Plate:
Mileage: 158560km-98524mi   Repair Order:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 28 34 36 3C 42 46 47
          4F 52 55 56 5F 62 69 6C 6D 6F 72 76
VIN: WAUZZZ4L3AD0#####   Mileage: 158560km-98524miles
Address 01: Engine (CAS)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 4L1 910 401 D    HW: 4L0 907 401 A
   Component: 3.0TDI EDC17A104AG  0080
   Revision: --H02---    Serial number:
   Coding: 0121002C191F0A68
   Shop #: WSC 40970 222 94360
   VCID: 2447ED83E718D36FE1-8070
000135 - Fuel Rail/System Pressure
               P0087 - 003 - Too Low
                    Fault Status: 01100011
                    Mileage: 158567 km
                    Date: 2020.04.09
                    Time: 17:21:32
                    RPM: 1575 /min
                    Speed: 3.4 km/h
                    Mass Air / Rev.: 36.0 mg/str
                    Temperature: 48.6°C
                    Pressure: 795.2 bar
                    (no units): 5.0
                    Bin. Bits: 00110100
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 KC    HW: 09D 927 750 KC
   Component: AL 750 6A           1470
   Revision: 00H78000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 79F9ECF7301A7E87E2-802C
   Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
   Revision: 00H30001
   Coding: 0627841
   VCID: 326B1BDBADEC4DDF63-8066
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601405096
   Coding: 0000135
   VCID: 2541F087EC222A67F6-8070
   Subsystem 1 - Part No: 4F0 910 132 G
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Subsystem 3 - Part No: 4F0 910 220 K
   Component: FBSAUDIC6 IDG   H01 0040
   Part No SW: 4L0 910 043 C    HW: 4L0 820 043 AB
   Component: KLIMA 4 ZONEN H12 0030
   Revision: 00---017    Serial number: 00000000212367
   Coding: 040816
   VCID: 2447ED832718D36FE1-8070
   Part No SW: 4F0 910 279 R    HW: 4F0 907 279
   Component: ILM Fahrer      H25 0330
   Coding: 0033221
   VCID: 387F29F34B90A78F5D-806C
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4L0 910 561 A    HW: 4L0 907 561
   Component: ABSTANDSREGELUNGH06 0160
   Revision: --------    Serial number: 00000000000000
   Coding: 0031161
   VCID: 275DFA8F962E3877C4-8072
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D065B3G
   Coding: 0014128
   VCID: 2E530FABB9D4693F07-807A
   Subsystem 1 - Serial number: 6332QSME623A191AH
   Subsystem 2 - Serial number: 6342QSME703A32067
   Subsystem 3 - Serial number: 6352QSME4338322CE
   Subsystem 4 - Serial number: 6362QSME623A143AH
   Subsystem 5 - Serial number: 63734SME3136050EX
   Subsystem 6 - Serial number: 63834SME2F364400-
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026092380094
   Coding: 0002052
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 931 J    HW: 4L0 920 931 J
   Component: KOMBIINSTR.   H08 0144
   Revision: 00000000    Serial number: CNN432799
   Coding: 0F5E63040C010008000000
   VCID: 326B1BDB6DEC4DDF63-8066
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 265 105 M
   Component: Heizgeraet      H08 0120
   Revision: 0000000E    Serial number: 00000009014264
   Coding: 0000101
   VCID: 60CFA193B3808F4FC5-8034
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M098308025
   Coding: 000303
   VCID: 3A7B33FBB59CB59FAB-806E
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140159397
                    Reset counter: 110
                    Mileage: 158567 km
                    Date: 2020.04.09
                    Time: 17:03:54
                    Bin. Bits:    11111
                    Voltage: 14.60 V
                    Count: 7
                    Bin. Bits:    10011
   Part No SW: 4F0 857 511 J    HW: 4F0 857 511 G
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02019064747464545425363E
   VCID: 2F6D12AF7EDE60370C-807A
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000000352325
   Coding: 0000006
   VCID: 68DFB9B35BB0F70F0D-803C
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 H    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7870
   Revision: --H03001    Serial number: 15.1528-0123.2
   Coding: 0015520
   VCID: 2F6D12AFBEDE60370C-807A
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001001346979
   Coding: 00581B00000011110000
   VCID: 316914D768EA76C71A-8064
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010101
   Component: J0770_SWA_Slave_H01 0040
   Subsystem 3 - Serial number: 5F21.07.0900H010003C910745ÿ
   Subsystem 4 - Serial number: 910745ÿ
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000101820752
   Coding: 011F52205E40440004
   VCID: 4683570BF164C17FDF-8012
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H09 0100
   Revision: 0100 ---    Serial number: 01219373360000
   Coding: 3549361
   VCID: 356120C75C825AE746-8060
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 035 223 E    HW: 4L0 035 223 E
   Component: BOSE G3 AU716 H01 0100
   Revision: AH001500    Serial number: 00000000008395
   Coding: 0D000000
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000139275
   Coding: 0011101
   VCID: 5EB39F6B89F4B9BFF7-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000101847220
   VCID: 45815007CC62CA67D6-8010
                    Fault Status: 01101000
                    Reset counter: 110
                    Mileage: 158567 km
                    Date: 2020.04.09
                    Time: 17:05:00
   Part No SW: 4L0 910 357 A    HW: 4L0 907 357 A
   Component: AFS 1           H01 0030
   Coding: 0000032
   VCID: 2A5B03BB853C051FDB-807E
   Part No SW: 4F0 035 053 K    HW: 4F0 035 053
   Component: Radio U Basic H45 0074
   Revision: AB001007    Serial number: 341IZ097634851
   Coding: 010003010000000000
   VCID: 2541F0872C222A67F6-8070
   Part No SW: 4L0 035 670 H    HW: 4L0 035 670
   Component: H-BNT-EU      H41 0187
   Revision: --------    Serial number: 474I6097515869
   Coding: 010100060004DBEF71000715EF6300030000
   VCID: 2D5108A774D212273E-8078
   Subsystem 1 - Part No: 8R0 060 884 ED
   Component: EUR 2017  2402
   Component: DU7 High  H43 0306
   Serial number: 9356IZ091064728
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 C
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001400099
   Component: CD-Database  1293
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000101862201
   Coding: 010E50204040230004
   VCID: 43854E1FC256F457F8-8016
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00008200327685
   Coding: 0100000000000000
   Shop #: WSC 80093 222 69422
   Revision: --H03---    Serial number: 525PA8-J9940CA
   Coding: 1021001
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 D
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: 8K9827852  B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7C5A34F48DB2F69-8038
   Subsystem 3 - Serial number: RD16.09.09--H29001001A0322ÿ
   Subsystem 4 - Serial number: 1A0322ÿ
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003881240-----
   Coding: 0003587
   VCID: 2643F78B9124217FFF-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE16_SKB09H10 0200
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE16_SKB09H10 0200
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE16_SKB09H10 0200
   Revision:             Serial number: 0000101862200
                    Reset counter: 110
                    Mileage: 158567 km
                    Date: 2020.04.09
                    Time: 17:06:36
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H02 0100
   Revision: 00H02000    Serial number: 85130925303084
   Coding: 0231166
   VCID: 2C5705A38FC81B2F29-8078
End-------------------------(Elapsed Time: 03:50)--------------------------
I guess I would try to see what's going on in MVB Group 020, where you should find:
Engine Speed
Specified Pressure
Actual Pressure
Pressure Control Valve duty cycle
MVBs 018, 019, and 021 all have pressure-related info as well.
There are also some tips here:
http://wiki.ross-tech.com/wiki/index.php/16471/P0087/000135
jmjq7tdi
Lidingö, Sweden
C?ID=205446
I've taken a brief look at the pressures in those MVB's, but not while driving around, just idling and revving the engine. In those cases, the specified pressure and actual pressure were always in sync. How should I go about getting useful information from these? I saw another post about low fuel pressure where he did some type of logging in VCDS, but I haven't tried that yet. Do I need to start logging and drive around?
NostraJackAss
Did you know you should not attempt such an approach with exception of rail isolation caps & while logging with VCDS to manage injector zones for comparison of actual PSI reported or a fuel filter changed?
RTFB should be observed for safe testing procedures fuel system and mechanicals cross referenced to log data.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
That's what I'm concerned about - not being able to do much without any mechanical testing tools. I saw another post of yours where you posted a pic of these isolation caps. I don't even have a mechanical gauge for these kinds of pressures, so if it gets to a point where the diagnostics require that, I'm going to have to take it in to a shop. I'm hoping we can collect enough clues to narrow down the culprit.
NostraJackAss
Did you know caps can be installed and PSI compared in logs of rail and if DTC goes away for PSI after cleared and PSI jumps up, than you know that's the respective problem injector like leaking down now don't you?
I suspect so. No-load conditions simply don't use much fuel.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
Okay, I hear you. We need to add the possibility of a leaky injector to the list of potential problems. Short of capping-off the supply lines for injectors, is there another way to determine if 'any' of the injectors are leaking? Since it's CR, if just one is leaking, the entire system should depressurize, right? I saw a diagnostic test where you monitor fuel pressure in VCDS after engine cutoff, and due to heat soak, it should theoretically rise a little bit. Would that same type of test apply to the 3.0 TDI?
Also, if I had an injector that was leaking that badly, i.e. exhibiting low fuel pressure by 2k RPM's, wouldn't I see smoke out of one side from the extra fuel? At least a little bit?
If 'any' of the injectors are leaking, is there any value in determining exactly which one, i.e. is it okay to only replace a single injector in a car with 98k miles and leave the rest alone, or should they all be removed and sent off?
About to head out now to start logging fuel pressures.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
When starting it this morning for the first time, it seemed to have to crank over longer than unusual, maybe 5-6 seconds instead of the normal ~2 seconds of cranking before start. Every start after that, it starts right up. There was a slight hint of smoke from the right side exhaust of the car, but it was very, very light, probably just morning condensation burning off. It really didn't seem to be excess fuel.
So, I drove around for a while and logged 018, 019 and 020. Here's the logging info for MVB 020 at the specific point of failure. Not too surprising. When RPM's start to rise above 2000, fuel pressure can't keep up. At over 2500, the computer catches it and puts it in limp mode.
https://www.dropbox.com/s/tu2w632um9j4yqv/FocusedData.jpg?dl=0
Here's the graph for the entire drive. It seems that the fuel pressure generally keeps up with all demands except when RPM's go above 2000, or fuel pressure above 1250 bar.
https://www.dropbox.com/s/16j83maqcpefu95/EntireDrive.jpg?dl=0
Using the gas Fuel Rail Pressure Test testing/logging method can be applied to a TDI however the failed part would need to be bad enough that you saw a complete leakdown under key on, engine off conditions. Since yours runs and just can't keep up under high RPM I'm not sure it will reveal problems. If this was a no-start or constant long-crank on startup that would be easier to spot.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
Thanks. I told my wife something similar this morning - 'it's failing, but it hasn't failed badly enough to be able to figure out where the problem is'.
But it has me wondering which parts would fail with this type of failure mode? It seems much more like a problem in the tank - either the pump, or a clogged screen. I have the time to remove and inspect them, so I think that's the next step. Is anyone aware of a procedure for that? I've seen a video of someone replacing the fuel pump on the driver's side tank on a gasoline Q7, but didn't see any type of screen or pickup, only a few hoses connected to the pump. Not much else out there, so I guess this doesn't fail often, and Audi was covering a bunch of these under a recall anyway.
Exactly, the problem may need to get worse before the cause is entirely obvious.
In my experience Low-side (in-tank and in-line to the engine) TDI issues aren't extremely common and when they happen it is often due to metal/debris that have circulated through the system and back into the tank and electric pumps. You already inspected for metal and replaced the fuel filter so there shouldn't be metal/debris in the system. Please don't let that discourage you from checking the low-side because it wouldn't be unheard of for an issue at 158,560km/98,524miles and you don't need highly specialized tools.
Do check your repair manual to see if a volume specification is listed for the electric pump(s). I believe the pressure is roughly 5 bar based on memory. You should be able to use VCDS to activate the pump(s) using this procedure (which you likely used when replacing the filter).
jmjq7tdi
Lidingö, Sweden
C?ID=205446
Okay, now I see that the Q7 TDI has the following:
1) two in-tank fuel pumps
2) a fuel pump in the engine compartment before the filter: https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/fuel-pump/1k0906089c/
So far, a failure of one of these seems to make the most sense. It seems that we would see these symptoms if any one of those is having a problem, i.e., enough fuel for low loads, but not higher loads.
Do you know if I can run all three of these independently via VCDS to do a flow/volume-based diagnostic?
No, you will be limited to the single Basic Settings - 04 > Group to "035" operation with VCDS. If you want to run them independently I would firstly check the wiring diagram and then jump power and ground directly .. but make sure not to starve the under-hood pump for fuel if the ones back in the tank aren't running. I'm pretty sure that's why there aren't individual pump test provisions in the EDC.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
Either one should be fine as long as you only intend on using it for low-side testing.
You likely know this but fuel pumps shouldn't be dead headed for any extended time, and you don't want to crank or start a CR-TDI without fuel, so make sure the fittings you connect are T'd into the low side lines since I doubt you'll have an actual service port that any of those car specific fittings are going to connect to. Hopefully you can fit the one that looks like a universal T into a flexible hose that already exists on the vehicle.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
Thank you, I will use the T-adaptor to keep fuel flowing through the system.
Just to consider all the possibilities, I saw that there is also a pressure relief valve on the back of one of the fuel rails. Ever hear of this failing in this way, i.e. not holding more than a certain pressure (1250 in my case)?
jmjq7tdi
Lidingö, Sweden
C?ID=205446
I don't have my fuel pressure testing tool yet, but I have been reading about the 3.0 TDI fueling system used in VW/Audi and have a very simple test in mind that wouldn't require a fuel gauge, and would like to know what you guys think. Would this tell me anything conclusive, and do you see any dangers with the steps I've proposed?
Theory: The secondary in-tank fuel pump has failed or is very weak.
Rationale: The car runs perfectly fine (manages high pressure in the rail quite well) until it reaches an RPM level requiring more fuel flow and pressure. The Audi Q7 has two lift (in-tank) fuel pumps, and both run continuously. If one of them is bad, then alternately disconnecting each pump should isolate the one that has the problem.
Of course, there are several other possible reasons that the fuel system can't generate enough pressure, but none that seem as simple and easy to test as this theory.
Test 1: Determine if the secondary pump flows any fuel at all
Step 1 - Disconnect the wiring connector (or is there a dedicated relay?) from the primary in-tank fuel pump
Step 2 - Disconnect the wiring connector from the in-line fuel pump in the engine compartment.
Now, only the secondary in-tank fuel pump is connected to power.
Step 2 - Remove the fuel line from the input side of the fuel pump in the engine compartment and route a temporary connection to a gas can.
Step 3 - Turn on the key. Activate VCDS to run the fuel pumps. If I don't see any fuel, bingo, I've found a problem with the secondary fuel pump (either the pump itself, a relay, wiring, etc.), and I need to test power to pump (and possibly work my way back). If I do get fuel, then measure the volume of fuel that was pumped and repeat this test with only the primary fuel pump connected and compare the volumes (I assume that both fuel pumps have the same specs for flow rate - if that is wrong, please let me know).
Step 4 - Put everything back together and use VCDS to prime the fuel system.
If the secondary fuel pump is only partially failing/weakening, this test might not be very conclusive. But I think it's worth a shot. Do you see any potential problems?
jmjq7tdi
Lidingö, Sweden
C?ID=205446
I found some interesting info from SSP 351 (which is for the Toureg/Phaeton 3.0 TDI):
When the ignition is switched on and the engine speed exceeds 40 rpm, the two electric fuel pumps are initialised
by the diesel direct injection system control unit J248 via the fuel pump relay J17, and build up pilot pressure.
As soon as the engine is running, both pumps continuously pump fuel into the fuel supply system.
The right-hand chamber's suction jet pump pumps the fuel into the pre-delivery tank for the fuel system
pressurisation pump G6, and the left-hand chamber's suction jet pump pumps fuel into the pre-delivery tank for the
fuel pump G23. Both suction jet pumps are driven by the electric fuel pumps.
Effects in the event of failure
In the event of pump failure, a lack of fuel may lead to deviations in fuel pressure in the high-pressure accumulator
(rail) in combination with a fault memory entry. The engine's output is reduced.
The good thing is that the 'Effects...' description matches exactly what's happening to me, so it seems that I'm on the right track.
I finally broke down and bought an hour of ERWIN so I could get correct documentation for my car, so hopefully I can figure out the best way to electrically isolate and test the pumps without trying to run the vehicle at all. Apparently starving the HPFP is extremely bad.
jmjq7tdi
Lidingö, Sweden
C?ID=205446
I gathered all the material I could find in Erwin that seemed to be applicable. One thing I could not find is a specific diagnosis checklist of all the test procedures for code P0087. Is there supposed to be such a thing in Erwin, or is this only available through Audi's maintenance computers?
In the absence of this checklist, I'm following my initial theories, so I've run the test "Checking fuel system pressurisation pump -G6-/fuel pump -G23-, vehicles with 3.0 ltr. (V6) or 4.2 ltr. (V8) engine up to 05.2010". The result was very surprising, but inconclusive.
I don't have VAG tool 1348 to independently power the rear pumps, but I thought I should be able to use VCDS to duplicate it. When running the pump using group 035, VCDS powers both rear pumps (G6 and G23) AND supplementary front fuel pump V393. I wasn't sure how this would affect the test since the VAG tool says it only powers the rear pumps, so I ran it both ways - with V393 connected and running, and with the wiring at V393 disconnected so that only both rear pumps were running. The fuel cap was off as prescribed. The engine (and all pumps) were cold, so if the problem is only affecting the car when the pumps warm up, this test wouldn't confirm that. According to the procedure, I should get a minimum of 550 cubic centimeters (mL) after 15 seconds of pumping. We used the on/off button in VCDS to limit the pump run time to 15 seconds in each test. I got exactly 1100 ml in both tests, whether V393 was connected or not. This seems to eliminate the possibility of clogged strainers in the tank (which is not surprising given how clean the fuel filter was) and a failure of either of the tank pumps.
Any comments on this test?
Since I don't have a checklist, my next guess is to run the diagnostic test for the fuel pressure regulator valve, N276, mounted to the back of the fuel rail. In some applications such as US trucks, this component has as high a rate of failure as anything else for my symptoms (it's not particularly high, but it is one of the more common culprits). I really, really hope that's the problem, because if it's not, then we're looking at the likelihood of an HPFP failure, or a failure of the flow metering valve on the pump (which doesn't have its own diagnostic procedure).
