20.4.0 output tests refused by control module
   #21
Masi
Finland
C?ID=344856
I have a 2018 VW Golf GTE. I did an output test for the ABS unit with VCDS. Front and rear inlet valves. VCDS did not drive the valves. VCDS message was:
This output is not supported by control module. Message 7F 2F 31.
The same message for all valves, including the parking brake light.
The same test was tried in the 2016 Passat Variant Motion. Didn't work, same message: This output is not supported by control module. Message 7F 2F 31.
I have VCDS release 22.3.1. We also tried beta versions of the page, but the results were the same.
Where's the problem? How to make the output test work. Help is needed.
   #22
Westbury, UK
We need to know the details of how your Golf GTE is equipped and configured, so please post an Auto-Scan.
   #23
Masi
Finland
C?ID=344856
Here is Auto-Scan
Monday,01,August,2022,21:20:18:49227
VIN: WVWZZZAUZJW808186   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 23 29 2B 39 3C 42 44
          4B 51 52 5F 75 8C A5 A9 C6 D6 D7
VIN: WVWZZZAUZJW808186   Mileage: 55013km-34183miles
Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 BN    HW: 04E 907 309 F
   Component: 1.4l TFSI hy  H22 4518
   Revision: X3H22---    CVN: 5F3A7D93
   Coding: 011D001A636405083008
   ASAM Dataset: EV_ECM14TFS01104E906023BN 008006
   ROD: EV_ECM14TFS01104E906023BN.rod
   VCID: 6D87CAED6D1DFAD3149-8038
   VINID: 9E69EAAAA465A9A9C80080481827CA7C79
Readiness: 1110 0001
   Part No SW: 0DD 300 046 F    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1601
   Revision: 00032056    Serial number: TFK01712080228 CVN: 8E28300F
   ROD: EV_TCMDQ400021.rod
   VCID: 2B0304F5938934E34AD-807E
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 DB    HW: 5Q0 614 517 AH
   Component: ESC           H62 0856
   Revision: 00000000    Serial number: 60068000000464 CVN: D163C072
   Coding: 01FA40A1382021744778060861C92980021C84E26086947338B15078C2A203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
   VCID: 74B1DF890E372B1BDB7-8020
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0469892238
   Coding: 032C0C
   VCID: 3C2137A966E7A35BD37-8068
   Part No SW: 5GE 907 044 AP    HW: 5GE 907 044 AP
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0002100420011101050500000010102A
   VCID: 0A4DA1717CB34DEB91B-805E
   Subsystem 3 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00100.4V.6B20340333
   Air quality sensor:
   A/C compressor sub:
H02
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001803200760
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08499B7962BF3FFB87F-805C
   Component: WWS    180103  043 0551
   Serial number:         180111012758
   Component: RLHS  047 0105
   Serial number: S5Y18M02D05H04M59S46
   Coding: 00A8DD
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018026
   Coding: 1471155811
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4BC36475334914E36AD-801E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 550067C15DFFC728949C810580400600000000000000000000
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR03WARA
   Coding: 98CCC000002000005C0000CF004800000065
   VCID: 50F97319DA6F373B1FF-8004
   Subsystem 1 - Part No SW: -----------    HW: 480 003 001 18
   Serial number: 3570000000004DA4CB2S
   Subsystem 2 - Part No SW: -----------    HW: 480 003 001 18
   Serial number: 3580000000010B307B28
   Subsystem 3 - Part No SW: -----------    HW: 480 400 102 18
   Serial number: 3510001B928C22E5521/
   Subsystem 4 - Part No SW: -----------    HW: 480 400 102 18
   Serial number: 35200019F281A435C22+
   Subsystem 5 - Part No SW: -----------    HW: 480 402 701 18
   Serial number: 3550001AD28C22E2D7DQ
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 31011808490880
   Coding: 0C10
   VCID: 094F9E7D79B546F3981-805C
   Part No SW: 5G1 920 794 A    HW: 5G1 920 794 A
   Component: KOMBI         408 3195
   Coding: 07AC7B186FCC000801886B1B5601000000000000
   VCID: 2D070AEDAD9D3AD3549-8078
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 K
   Component: STH-MQB       008 0080
   Coding: 13C1
   VCID: 3E253DA170FBB14BFD3-806A
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0402
   Serial number: 00000000000000388687
   Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6322
   Serial number: 03011810524049
   Coding: 020100176EF11000FB00527A5C1D00000001070100010000000300000000
   GVL: 01563C100000060850CC80008004C81800000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 392F2EBD69D59673C81-806C
   Subsystem 1 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170002809500107495
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 6080945904
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460010978
   Coding: 02720100331900000002060500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   VCID: 52FD7911D463452B29B-8006
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861180118091054
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47CB58452F21F0834E5-8012
   Revision: 00000000    Serial number: 18000021903009
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311F894EB76B1B1B7-8060
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Component: HRE_Master    H12 0080
   Serial number: 0468381633
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273AAD7DFDAA53E49-8068
   Component: HRE_Slave  H12 0080
   Serial number: 0468862052
   Coding: 020111
   Serial number: 190118EAI04689
   Coding: 003F1720D000040000001000
   VCID: 43D34C551B19DCA392D-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000018974880
   Coding: 110000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: D10A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B3DC950B392C23C2D-8026
24321 - Steering
          C10AC 07 [009] - Mechanical Failure
          [Belastungszähler hat 99% überschritten Belastungszähler hat 99% erreicht]
                    Reset counter: 110
                    Mileage: 55013 km
                    Date: 2022.08.01
                    Time: 21:18:46
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 12.00 V
                    Temperature: 32.0 °C
                    KFC: 5F
                    KFA: 00 01
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 12.22 V
                    uAdSensI_SwitchedKl30_xdu16: 12.24 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 21011810800556
   Coding: 000000050100164A00604F01020000000000000000000000000000000000
   VCID: 72BDD9917423252BC9B-8026
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H15 1032
   Revision: 00H15000    CVN: 0C4EF12C
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: 290FFEFD997526F3B81-807C
   Serial number: 210118EAL14904
   Coding: 003F1120DE00040000801000
   VCID: 42DD49510403D5AB99B-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000019022014
   Coding: 090000
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     851 0867
   Coding: 02731001FF0000005111000100080A001F0509F4012000008E
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313F169DB1A55E33701-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHV0092545
   Subsystem 2 - Part No SW: V03 825 254 AA    HW: -----------
   Component: ECE DL3 2022  --- 1730
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------
   Coding: 02739001EA42980D3FFCBE000045400382E708
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW25.rod
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
   Component: BECM          H05 0921
   Serial number: V8090070 CVN: B5428CFDC05121EDB797EC16B797EC16B797EC16B797EC16B797EC16B797EC16
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006041
   ROD: EV_BECM06020115C6915182_AU37.rod
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell module control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D1  H14 0481
   Serial number: V013C17B1620096
   Cell module control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D2  H14 0481
   Serial number: V013C17B1620097
   Cell module control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D3  H14 0481
   Serial number: V013C17B1620091
   Cell module control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D4  H14 0481
   Serial number: V013C17B1620094
   Cell module control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D5  H14 0481
   Serial number: V013C17B1620092
   Cell module control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D6  H14 0481
   Serial number: V013C17B1620093
   Cell module control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D7  H14 0481
   Serial number: V013C17B1620087
   Cell module control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D8  H14 0481
   Serial number: V013C17B1620090
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 16011812P13276
   Coding: 0003070000000401002213548150A90098000E300040
   Part No SW: 5G0 907 159 C    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0017
   Serial number: 171110201646
   VCID: 2E050DE1A09B41CB6D3-807A
   Part No SW: 5QE 915 682 AF    HW: 5QE 915 682 AF
   Component: OBC KOSTAL    H40 4013
   Revision: --------    Serial number: 2212170L7000J6
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 117FB61D11E57E33501-8044
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:12, VBatt start/end: 12.2V/12.2V)-----------
   #24
Eric
HC800000
Make a debug 1024 with the current beta, please.
   #25
Masi
Finland
C?ID=344856
Eric did you answer me. ”I don't understand debug 1024 with the current beta”. What do I have to do? Thanks.
   #26
Bruce
Near Philadelphia, PA, USA
Eric is asking you to go to the Options Screen, set the debug level to 1024. See this page in the manual: https://www.ross-tech.com/vcds/tour/option_screen.php
He is also that you do this using the current Beta release which you can download and have present next to the Current Release 22.3
Post the result here.
   #27
Masi
Finland
C?ID=344856
Debug value changed to 1024. Nothing changed. Same messages with release 22.3.1 and beta 22.6 programs. Does not work.
   #28
Eric
HC800000
Try this:
This is the same error you were getting with 22.6.0 (even though you only sent the debug from 22.3) on a '19 Alltrack:
This is the new version:
   #31
Masi
Finland
C?ID=344856
I installed the new beta update, but the program does not start. I get the message:
VCDS: Interface check.
Failure to communicate (0). Please use (Options) (Test) for further.
Usb port tested and saved. but in config all values are 0.0
Check for uptadets gives the correct values.
I exit the settings and go back, all values are 0.0 again.
I uninstalled the old program, it didn't help.
How do I get the program to work? What have to do?
   #32
Eric
HC800000
So I guess reports that
had been greatly exaggerated? :)
I can see in your 22.3.1 debug from yesterday that your codeblock is still at 4615. You need to update your codeblock to 4622 after setting the channel in VCIConfig to Beta, just like VCDS' Options->Test is telling you.
