20.4.0 output tests refused by control module
willmtl
Canada
C?ID=305896
Long time VCDS user. I mainly use my cable to do retrofits. I was trying to troubleshoot an issue with the Dynaudio system on a MK6 GTI but can't get any of the output tests to work on the amplifier with the latest version. I have done this several times in the past with 19.6 and it always worked, I was able to get test tones to come out of the selected speaker in the output tests. With the latest version, I cannot get any to work. Not sure what is going on. I am using a Hex-V2 cable. When I hit start, I get "Refused by control Module" and "Message 7F 2F 13".
Any input would be appreciated. Thanks.
We've got one or two other reports like that. We're looking into it.
willmtl
Canada
C?ID=305896
Too easy. Thanks!
ch1z64
C?ID=316572
Funnily enough i get the same message in certain modules but my last 2 numbers are different ( Refused by control Module" and "Message 7F 2F 22" ) plus when i go into module 9 vcds always wants to shut down.:(
VWT6
Finland
C?ID=295527
The same here: "Refused by control Module", "Message 7F 2F 13" :confused:
Hi guys,
We currently have a Release Candidate to address the UDS protocol SOT problem. If anyone desperately needs to run SOTs before RC 20.4.1.0 has been thoroughly tested and is available from the Download page please ping Support via e-mail with a link to this thread.
bigbigblue
C?ID=508110
I'm aware this is an old thread, but I have the same problem with my newly purchased VCDS. On attempting output test on control module 69 (Trailer) I receive the message 'Refused by control module' with error code 7F 2F 13. My OBDEleven can successfully perform the output tests rejected by VCDS, so I believe it is a VCDS problem. I am using the current version of VCDS (22.3) with a brand new interface with the latest firmware.
All help appreciated.
  • Informative
Reactions: JMR
bigbigblue
C?ID=508110
Please see autoscan below:
Sunday,17,July,2022,12:07:14:40058
Mileage: 104502km-64934mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 34 36 42 46 52 53 55
          56 5F 62 65 69 6C 6D 72
VIN: xxxxxxxxxxxxx   Mileage: xxxxxxxxxx
Address 01: Engine (J623-CVVA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 E    HW: 7P0 907 401 K
   Component: 3.0TDI EDC17  H21 0003
   Revision: 56H21---    CVN: 7960E67C92F1EF3C92F1EF3C
   Coding: 292A4012A33E01030000
   Shop #: WSC 00126 210 00000
   ASAM Dataset: EV_ECM30TDI0117P1907401E 001003
   ROD: EV_ECM30TDI0117P1907311.rod
   VCID: 323D150C34A6A63B09B-8066
   VINID: 9E65EAAAA1E0A975000020891852696A25
Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
   Part No SW: 0C8 927 755 C    HW: 0C8 927 755
   Component: AL1000 AISIN  130 2881
   CVN: C2781931
   Coding: 010100011C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 313F1A0031A09D23701-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 40445439037407
   Coding: 5B6B13C30B242555DAF6C89CD0D8A470F701
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4CC16BF4B642D0CB637-8018
   Part No SW: 4H0 907 064 GH    HW: 4H0 907 064 GH
   Component: BCM2 2.0      H37 0572
   Coding: 05B60016000000000000
   VCID: 75B7EE1085C8F103EC9-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3215000096842007
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CK    HW: 7P6 907 040 CK
   Component: Klima 4 Zonen H23 1507
   Coding: 36F600BA70
   Shop #: WSC 12345 123 61029
   VCID: 7F5B0C38B774BB53B65-802A
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 22020001    Serial number: 00001089103402
   Coding: 26000015D13C5F010029400300005D4C431D67082701C241000000000040110000000000000000
   VCID: 6A8DCD6CDC762EFB71B-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    150516  033 0021
   Serial number: 90243401150521191833
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20570341
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002005150127
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28231514203588
   Coding: 318504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44D143D49E12188BAB7-8010
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag037 H10 0043
   Revision: --------    Serial number: 003NK003UR4O
   Coding: 000000000000000000000000000000003337
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   VCID: 43D340C89B1C1FB392D-8016
   Serial number: 3575LRB405J3A178A1Q1
   Serial number: 3585LRB405937T8ACP7R
   Serial number: 3517ARB401654R14OJPC
   Serial number: 3527ARB401454R155JDO
   Serial number: 3557BRB405T3CGVEHOEN
   Serial number: 3567BRB405T3CGVEKPCQ
   Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AC
   Component: Lenks.Modul   H06 0005
   Revision: --------    Serial number: 01374OF20007L
   Coding: 000C35
   VCID: 3D273630FD786943E49-8068
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0092014 TRW 20150520
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 983 G    HW: 7P6 920 983 G
   Component: Kombi         H13 0515
   Revision: 13240302    Serial number: 658020615592018
   Coding: 333733003B00260001000C
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526.rod
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 7P0 963 272 E    HW: 7P0 963 272 E
   Component: Standheizung  H23 0247
   Revision: 56005006    Serial number: 20141004102913
   Coding: 114200
   VCID: 392F2220E9505563C81-806C
   Part No SW: 7P6 907 530 M    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6042
   Revision: --------    Serial number: 00000001869159
   Coding: 000D07AD00
   GVL: FB4FC4C51D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 42DD45CC840616BB99B-8016
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 42139G53205701046374
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 15147001834011200181
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 7P6 907 049 S    HW: 7P6 907 049 S
   Component: Klima Fond    H16 1406
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001007
   ROD: EV_AirCondiHeck.rod
   VCID: 4DC766F04D58D9C3749-8018
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AF    HW: 7P0 907 553 AF
   Component: PASM          H05 0750
   Revision: 00000000    Serial number: 00000151480363
   Coding: 15210000
   ASAM Dataset: EV_PASMConti 001005
   ROD: EV_PASMConti.rod
   VCID: 7BA3F828A36CA7739AD-802E
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000150420241
   Coding: 00781B0000004001000001010101202020202121202020
   VCID: 34311314CE32A80B1B7-8060
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000151172320
   Coding: 011F1620DE01451005080002
   VCID: 7AADFD2CACD69E7B81B-802E
   Revision: 00002001    Serial number: 0370359944
   Coding: 019B1122A899109583200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 172
   Component: Sensor, DWA  005 0502
   Subsystem 3 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS30.408  H03 0004
   Serial number: 0000FST000A4PQT00000
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
   Component: J394 PS30.408  H03 0004
   Serial number: 0000CGQ0004C2JJ00000
   Coding: 191100
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000151552958
   Coding: 011F1620DE01451005080000
   VCID: 48C957E4A2BA3CEB47F-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1552400824
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3635291CD8CEBA1B253-8062
   Slave 3:
   Component: AFS-ECU       H01 0110
   Coding: 01A602000B000200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDB4C38F7F47B53F65-806A
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B00000
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109F30F8039478
   Coding: 010105020100000003
   VCID: 2B030868130CF7F34AD-807E
   Part No SW: 7P6 035 670 K    HW: 7P6 035 670 A
   Component: H-BNT-EU      H41 0934
   Revision: --------    Serial number: 603FV0FB006341
   Coding: 010101050040E1ED41002B8E00000003500401030000000000
   Subsystem 1 - Part No: 7P6 060 884 A
   Component: EUR 2015  2102
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9RGF0003D
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: CD-Database  6208
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000152332496
   Coding: 011E14200001251005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 30000000017081
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   VCID: 45D75ED095282183BC9-8010
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 N    HW: 4H0 907 383 L
   Component: Anhaenger     H14 0137
   Revision: 7A001001    Serial number: 0349431355
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW52.rod
   VCID: 38292724D2DA4C6B37F-806C
Address 6C: Back-up Cam.
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 142501670
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000150693035
End----------(Elapsed Time: 02:10, VBatt start/end: 14.5V/14.6V)-----------
NEtech
Denmark
C?ID=56995
Which Output test do you try?
bigbigblue
C?ID=508110
It rejects every output test ! I tried them all.
NEtech
Denmark
C?ID=56995
And you are sure, all of them show exactly "7F 2F 13" in return?
That is not normal.
bigbigblue
C?ID=508110
No I am not sure. I will check tomorrow.
bigbigblue
C?ID=508110
I have just checked and all but 3 or 4 are refused with "7F 2F 13", the other 3 or 4 are 'not supported by module' with code '7F 2F 31'. Outputs work OK with my OBDEleven.
Eric
HC800000
bigbigblue
C?ID=508110
Apologies for delay in replying- I have been on vacation. Anyway - debug file sent to support@ross-tech.com and Autoscan is below. Note that the output tests worked as expected on the 22.5.0 beta :-)
Autoscan -
Wednesday,27,July,2022,17:35:24:40058
VCDS Version: 22.5.0.0 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220530 DS340.0
VIN: xxxxxxxxxxxxxxxx   License Plate:
VIN: xxxxxxxxxxxxxxx   Mileage: 104840km-65144miles
   VCID: 323D150C34A6A63B117-8066
   CVN: C2781931
   VCID: 313F1A0031A09D2368D-8064
   VCID: 4CC16BF4B642D0CB7BB-8018
   VCID: 75B7EE1085C8F103F45-8020
   Coding: 36F600BA70
   VCID: 7F5B0C38B774BB53AE9-802A
0254 - Rear Air Blower
          B10BF 12 [008] - Short to Plus
                    Reset counter: 13
                    Mileage: 104692 km
                    Date: 2022.07.24
                    Time: 16:45:42
   VCID: 6A8DCD6CDC762EFB697-803E
   Coding: 004DBD
   Coding: 025223
   Coding: 318504
   VCID: 44D143D49E12188BB3B-8010
   VCID: 43D340C89B1C1FB38A1-8016
   Coding: 000C35
   VCID: 3D273630FD786943FC5-8068
   Coding: 114200
   VCID: 392F2220E9505563D0D-806C
   Coding: 000D07AD00
   VCID: 42DD45CC840616BB817-8016
   Voltage stabilizer:
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschraenkung Pausenempfehlung]
                    Reset counter: 14
                    Mileage: 104603 km
                    Date: 2022.07.24
                    Time: 13:12:47
                    Voltage terminal 30: 14.6 V
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 33 0C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Coding: 0000000000
   VCID: 4DC766F04D58D9C36C5-8018
   Coding: 15210000
   VCID: 7BA3F828A36CA773821-802E
   VCID: 34311314CE32A80B03B-8060
   VCID: 7AADFD2CACD69E7B997-802E
   Coding: 191100
   Coding: 191100
   VCID: 48C957E4A2BA3CEB5F3-801C
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3635291CD8CEBA1B3DF-8062
   Slave 3:
   ROD: EV_HeadlRegulAFSMQBMLB_VW51.rod
   VCID: 3FDB4C38F7F47B53EE9-806A
   Coding: B00000
   Coding: B00000
   VCID: 2B030868130CF7F3521-807E
   VCID: 45D75ED095282183A45-8010
   VCID: 38292724D2DA4C6B2F3-806C
   Coding: 0533314003
End----------(Elapsed Time: 02:17, VBatt start/end: 13.3V/14.3V)-----------
Eric
HC800000
