Problem with HEX-NET Pro
MIMODIAG
Algeria
C?ID=377398
HELLO HOW I SAID IN TITLE MY PROBLEM AND THAT MY INTERFACE NO LONGER WANTS TO CONNECT THROUGH WIFI WHEN I DO DETECTION KNOW GOOD TEST INTERFACE FROM TIME TO TIME OK THEN THE SOFT VCDS BUG IT LEAVES ME NOT SAVE BUT BY USB NO PROBLEM:furieux:
What happens when you run VCIConfig, click on the WiFi tab, and then the [Scan for Networks] button?
Shaun
Also post a screenshot from the main screen of VCIConfig please.
MIMODIAG
Algeria
C?ID=377398
MY INTERFACE IS RECOGNIZED AND WHEN I TEST THE INTERFACE IT SAYS OK WELL VCDS BUG AND IT STAYS BUG 2 PC SAME THING 32BIT AND 64BIT
MIMODIAG
Algeria
C?ID=377398
I AM NOT AT THE WORKSHOP CONTAINMENT TOMORROW I WILL TRY TO PRODUCE SCREEN CAPTURE
Mari
C?ID=150535
Posting to a forum using only capital letters is considered screaming!
Or is your keyboard defective ;)
MIMODIAG
Algeria
C?ID=377398
MR MARI I scream on perssone but quite simply I did not pay attention thank you for the remark
MIMODIAG
Algeria
C?ID=377398
help
hello I can't figure out how to add but screenshot
Shaun
That picture shows that the interface is in AP mode, where it broadcasts it's own network. Is your computer connected to the interfaces's wifi network?
MIMODIAG
Algeria
C?ID=377398
yes my micro computer connects to wifi without any problem but with interface it connect but when I want to save with the soft vcds it bug
Please show us what WiFi network your computer is connected to.
South Molton, UK
I wonder if OP has the same problem I had several years ago - which is that my WiFi was transmitting on a channel not used in the US so the HEX-NET was unable to connect?
MIMODIAG
Algeria
C?ID=377398
hello I worked with this interface every day on wifi and I never had a problem then it started to cut from tempt to tempt then nothing https://imgur.com/a/xi3nbGu
The video was very helpful. In summary:
  • FRM VCDS freezes when you attempt to [Save] after testing in AP mode via NET.
  • FRM VCDS does NOT freeze when you [Save] after testing via USB.
  • 32 and 64 Bit versions have the same results.
I would try English VCDS on that PC to see if the results are the same:
https://www.ross-tech.com/vcds/download/current.php
Depending on the results you might want to disable non-essential start-up programs, disable Anti-Virus software, check task manager system resources on the PC while using WiFi and verify Windows isn't attempting to download or install updates.
It may be best to try VCDS on an entirely different PC at some point as well.
MIMODIAG
Algeria
C?ID=377398
https://imgur.com/a/z88FMKZ THANKS FOR YOUR HELP I tried on 32 64 BIT but it is the same problem even with English version I just tried in infrastructure mode I managed to connect once and then nothing ??? I think it is my interface that is bug for time I am buying it the month of September 2019 I get an original pay 650 EURO
Did VCDS prevent you from Testing and Saving when Infrastructure mode stopped working?
Did you try using another PC yet?
MIMODIAG
Algeria
C?ID=377398
yes always the same problem even with Infrastructure mode on pc computer problem
