Start no run very well. T5 Transporter engine code BNZ 2.5 five cylinder
johne
Southampton, UK
C?ID=380307
Hi All. Symptoms starts fine from cold and revs up fine but when warm you have to keep the key on until it catches very sluggish from rest, you have to wait for the turbo to spool up and off we go runs ok.
Did have a 000833 - Camshaft Position Sensor (G40) P0341 - 000 - Implausible Signal.. before i striped and retimeed the cam. any idea what 48.0 Start Synchronisation means ??
so far.
new moo valve
rebuild turbo {not by me}
Many thanks for sharing my problems. john {jack iam ok for soup}
Address 01: Engine  (070 906 016 DS)
11:18:51 Group 004: Unit Injector
  798 /min  Engine Speed (G28)
  3.1 °BTDC  Injection Start (specified)
  7.7°KW  Injection Duration (specified)
  -6.9°KW  Torsion Value
11:18:51 Group 013: Idle Stabilization (Injection Quantity Deviation - Cylinder 1-4)
  2.16 mg/str  Injection Quantity Deviation Cyl. 1
  0.92 mg/str  Injection Quantity Deviation Cyl. 2
  -0.31 mg/str  Injection Quantity Deviation Cyl. 3
  -0.64 mg/str  Injection Quantity Deviation Cyl. 4
11:18:51 Group 051: Speed Recording
  399 /min  Camshaft Speed
  00010000  Inject. Sequence Shut-Off Status
Wednesday,08,April,2020,11:54:18:62543
VIN: WV2ZZZ7HZ8H015277   License Plate: HKOI
Mileage: 496720km-308647mi   Repair Order: 8/5/20
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ8H015277   Mileage: 496720km-308647miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 DS    HW: 070 906 016 DS
   Component: R5 2,5L EDC  000SG  1585
   Revision: --H05---    Serial number: VWZ7Z0G5463049
   Coding: 0001072
   Shop #: WSC 80093 222 69422
   VCID: 6491AC44A244FBDBD7A-5184
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 000 - Signal too High
                    Mileage: 496720 km
                    RPM: 777 /min
                    Voltage: 14.36 V
                    Bin. Bits: 00000000
                    Temperature: 66.6°C
                    Temperature: 55.8°C
Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
   Component: (M)ABS MK25E        0103
   Revision: 00H21001
   Coding: 0000552
   Shop #: WSC 02756 790 00000
   VCID: 45D751C009BEA2D3204-5160
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 AL
   Component: CLIMA/AC            0303
   VCID: 6FBBD3687B824883BA8-5160
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 T
   Component: BORDNETZ SGVER 1.0  2001
   Coding: 0000101
   VCID: 43D34FD8078A9CE30E0-513C
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0010
   Coding: 13123
   Shop #: WSC 02756
   VCID: 221DEA5CFDD0B5EB656-513C
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 951 T
   Coding: 00413
   Shop #: WSC 77824
   VCID: 3D273920646EEA13784-513C
   WV2ZZZ7HZ8H015277     VWZ7Z0G5463049
01304 - Radio
            49-00 - No Communications
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 815 071 F
   Component: Standheizung        0209
   VCID: 2B0307788F1A74A3D60-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02756
   VCID: 70B9D01463BC577BA32-513C
01304 - Radio
Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
   Part No: 7H0 951 171 B
   Component: Innenraumueberw.    2920
   Coding: 0000022
   Shop #: WSC 02757 790 00000
   VCID: 290FFD7085E666B324C-51CE
   Subsystem 1 - Part No: 7H5 951 178
   Component: Innenraumueberw.    1607
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C11 Komfortgerát     0004
   Coding: 00030
   Shop #: WSC 02756
   VCID: 323D1A1CAD30256B956-4B1E
End----------(Elapsed Time: 05:48, VBatt start/end: 14.5V/12.4V)-----------
NostraJackAss
The RTFB will tell you and how to check belt timing since appears out is that right?
Pardon me retarded........
NostraJackAss
This engine is gear driven ....so you saying its retarded ?
Compound run on sentence questions away, with self evident answers okay? :rolleyes:
All depends on you and your observations compared to RTFB, huh?
Don't you see what I'm asking in general, is that you should query the RTFB and check timing, since that is recent work history right and torsion value is what it is & yes it's gear driven, "gear chain belt" same crap different shovel for cam position & that vehicle isn't in the USA, so criticizing me for information you should already have a baseline on and choose not too, isn't wise when seeking a hand out, well is it?
You say no free soup needed, well no crackers either........ :p
The forum is not a substitute for VCDS or RTFB procedures, it is to elaborate on it based on test data, anything contrary in this section would be considered reckless and unqualified as a repair process.
What are conditions of PD and cam lifters + mechanical's for leak down and lash settings of injector train?
johne
Southampton, UK
C?ID=380307
...i only meant it being gear driven moving the gear one tooth would i think be more then 6 degrees .
NostraJackAss
Sorry man I cant guess what you did or didn't do but I can advise that you get the RTFB.
