P0106 Fault Code Help
Mark.wilbur23
C?ID=401199
My 2009 Q5 is throwing a engine check light at start up every time i drive it
Tried resetting the fault but it always comes back the next time I start the engine after it’s been driven
It’s running fine no noticeable changes other than the constant check engine light
here is the VAG dump
6010 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [237] - Implausible Signal
Mileage: 197881 km
Engine speed: 0.00 /min
Coolant temperature: 44 °C
Intake air temperature: 27 °C
Ambient air pressure: 910 mbar
Voltage terminal 30: 12.390 V
Engine speed: actual: 0 /min
MAF_ENVD: 397.63528 mg/stroke
Coolant temperature (unfiltered): 96.0 °C
Engine: operating status: ES
Battery voltage: 12.492188 V
Vehicle speed: actual: 0 km/h
i replaced the MAP sensor (03C906051F) with a Bosch 261230234 , Confirmed no Vacuum leaks (propane tank and hose) ,
cleaned the throttle body (it was dirty) , Ran the TBA with the engine at temp Adapt moved from 6 to 2
Still getting the same error at engine start up after a drive but not if I just start and stop the engine
noticed my accelerator sensor values were a bit strange but I’m guessing this is just a new rabbit hole I should avoid
Any one able to confirm the values below are normal
Engine OFF Key ON Accelerator pedal not depressed
IDE00025 Coolant temperature 76 °C
IDE00078 Time since engine start 689 s
IDE00083 Throttle valve position (absolute) 11.8 %
IDE00086 Accelerator position 15 %
IDE00349 Throttle valve position: normed 2 %
ENG102297 Accelerator Pedal Position E 14.5 %
ENG103226 Accelerator pedal sender 1: voltage ratio 0.752 V
ENG103029 Accelerator pedal sender 2: voltage ratio 0.381 V
ENG103042 Accelerator pedal sender: learned end stop 4.126 V
ENG103719 Accelerator position 0.00 %
is it normal for the ENG and IDE values to be so far apart 0 vs 15%
Any ideas or suggestions would be welcome
thanks in advance
Mark
NostraJackAss
Welcome OP
It's an incomplete movement.
http://wiki.ross-tech.com/wiki/index.php/16490/P0106/000262
JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Mark.wilbur23
C?ID=401199
Here is the full scan per your request
thanks again for an and all suggestions and help resolving this error
all the best
Mark
Wednesday,01,April,2020,19:51:52:14281
VIN: WA1KK78R19A055752   License Plate:
Mileage: 197880km-122956mi   Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62
          65 6C 6D 72
VIN: WA1KK78R19A055752   Mileage: 197880km-122956miles
Address 01: Engine (J623-CALB)       Labels:| 06E-907-559-CAL.clb
   Part No SW: 8R0 907 559 A    HW: 8T0 907 559 B
   Component: 3.2 SIMOS8.2  H04 0006
   Revision: --------
   Coding: 0121000A190F0121
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM32FSI8R0907559A A01012
   ROD: EV_ECM32FSI8R0907559A.rod
   VCID: 3E253818C0F4C96B61E-806A
                    Mileage: 197731 km
                    Coolant temperature: 43 °C
                    Intake air temperature: 25 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 12.187 V
                    Coolant temperature (unfiltered): 91.5 °C
                    Battery voltage: 12.085938 V
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8R0 927 158     HW: 0B6 927 156
   Component: 0B6 32FSIUSA  H05 0010
   Revision: --H05---
   Coding: 001002
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 7AADF4089C5C254B1D6-802E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 C    HW: 8R0 907 379 C
   Component: ESP8 quattro  H06 0230
   Coding: 041500
   VCID: 40D946E0BA80BF9B132-8014
   Part No SW: 8K0 907 064 AS    HW: 8K0 907 064 AS
   Component: BCM2 1.1      H80 0145
   Coding: 090500
   VCID: 015F83E4F10A76935CC-8054
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000018021013
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000029169002
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01080520091645
   Coding: 46112000
   VCID: 72BDDC28C4AC5D0B556-8026
   Component: BCM1 1.0      H26 0253
   Revision: 05026001    Serial number: 00000000262096
   Coding: 26001091063CAF010000080300001D0D0F1C460800010161000000
   VCID: 303916200A202F1BE32-8064
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 090429  H10 0041
   Serial number: 90243014090423195000
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10465913
   Coding: 024D25
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000000405090268
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 G    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0040
   Revision: 11001001    Serial number: 40040912800653
   Coding: 300105
   VCID: 3D273F14CD72D273784-8068
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 A    HW: 8R0 959 655 A
   Component: AirbagVW-AU10 H13 0320
   Serial number: 003BRD053NWV
   Coding: 303633313432303030304A55304C38523053
   ASAM Dataset: EV_AirbaAU10SMEAU416 001001
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 42DD4CE8B40CAD8B056-8016
   Subsystem 1 - Part No SW: 8R0 959 339     HW: 8R0 959 339
   Serial number: 5810000R0900004703
   Serial number: 6334MSME474123093
   Serial number: 6344MSME470555459
   Serial number: 6352QSME2B28242CK
   Serial number: 6362QSME372C4314E
   Serial number: 63732SME0E270634Z
   Serial number: 63832SME36274E2C7
   Revision: --------    Serial number: 90319IE4000F7
   Coding: 000017
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 A    HW: 8R0 920 980 A
   Component: KOMBIINSTR.   H08 0224
   Revision: 00200000    Serial number: 9EP532A59
   Coding: 8B1622000300D705020000
   VCID: 372B2D3CEF4EF823A28-8062
   Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0095
   Revision: EB500046    Serial number: 4600E094238123
   Coding: 000303
   VCID: 4EC568D870D459EB91E-801A
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140509680
   Part No SW: 8R0 959 760     HW: 8R0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001272358
   Coding: 00581300000044440000
   VCID: 7EA5F81880F4096B21E-802A
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008837890
   Coding: 011D03205E00440004
   VCID: 41DF43E4B18AB6931CC-8014
                    Reset counter: 213
                    Mileage: 194456 km
                    Date: 2020.01.17
                    Time: 12:49:25
   Revision: 00002001    Serial number: 0118393261
   Coding: 0126023A207A749404B005
   Component: GTO BF  H06 0050
   Serial number: 00000000000000132507
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE19SKB12  H01 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE19SKB12  H01 0220
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008886195
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000364206
   VCID: 3333192CFB3614039E0-8066
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 34311A30F238133B87A-8060
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335DX097512919
   Coding: 020000020100000001
   VCID: 1D67DF946DB2B273584-8048
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664
   Component: H-BN-NA       H63 0042
   Revision: --------    Serial number: 328EX097511908
   Coding: 010200060005A1EF41000B0E000000030000
   VCID: 36352038E844012BB9E-8062
   Subsystem 1 - Part No: 8R0 060 884 A
   Component: NAR 2008  5203
   Component: DU7 High  H43 0306
   Serial number: 9356D-091093966
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000280884
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000101063834
   Coding: 010C03204000240004
   VCID: 43D349ECAB96A4830E0-8016
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13374790430563
   Coding: 0CD153
02214 - Tire Pressure Warning
                    Reset counter: 222
                    Mileage: 196595 km
                    Date: 2020.03.04
                    Time: 17:47:13
                    Bin. Bits: 00000000 00100011
                    Voltage: 14.50 V
                    Text:  16,0°C; -0,45bar;3444547831;00h; 14°C
   Part No SW: 8R0 907 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J93A0L3
   Coding: 1020010
   VCID: 73B3D92CB7B654035E0-8026
   Part No SW: 8R0 827 851 A    HW: 8R0 827 851
   Component: J605  Master  H27 0290
   Revision: --------    Serial number: 8R0827851
   VCID: 3A2D3408DC5CE54B5D6-806E
   Subsystem 1 - Part No SW: 8R0 827 852 A    HW: 8R0 827 852
   Component: J756  Slave  H27 0290
   Serial number: 8R0827852
   Revision:             Serial number: 0000101063811
End----(Elapsed Time: 01:55, VBatt start/end: 11.5V/11.7V. VIgn 11.8V)-----
NostraJackAss
all the best
Mark
Thank you for posting the auto-scan.......
In addition to aforementioned link.
Why not have a look at battery, freewheel pulley/alternator and belt plus charging system as a whole for connections & function yet?
Terrible........
DrPeter
16.4905° S, 151.7375° W
I would suggest to check the Advanced Measuring Values for the F96 and the G31(G71) pressures with the key on and the engine off.
These values should be equal or very close.
[*ENG99319*],083,,Ambient pressure,LINEAR,hPa
[*ENG101388*],336,,Intake manifold pressure: absolute,LINEAR,hPa
The fault will set when there is a difference of about 210-230 hPa (+/-), according to some of the Audi repair information.
We do have a Ross-Tech wiki page for the fault code page, P0106 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
Hope this helps,
drpeter
MartinsX
Riga, Latvia
C?ID=268515
6010 - [COLOR="#00FF00"]Manifold[/COLOR] / [COLOR="#0000FF"]Barometric Pressure Sensor[/COLOR] [COLOR="#0000FF"][COLOR="#00FF00"](G71)[/COLOR][/COLOR] / [COLOR="#0000FF"](F96)[/COLOR]
Mileage: 197731 km
Ambient air pressure: [COLOR="#0000FF"]920 mbar[/COLOR]
I think fault code and FF data together are self-explaining.
Use RTFB and WD, find where F96 barometric pressure sensor is located and find out why it is measuring incorrectly.
Of course, if You are not high above sea level. At sea level barometric pressure 920 mbar is not correct measurement.
P.S. Dr Peter was faster with the same suggestions ;)
Mark.wilbur23
C?ID=401199
Thanks for all the tips and suggestions
I replaced the MAP sensor mounted right behind and above the TB
Anyone have any ideas where the second MAP sensor is physically located
I’ll look into the battery and the charging system ASAP didn’t notice that one
I’ll post the MAP sensor deltas from the advanced measurement values ASAP
hopefully that’s the issue causing the P0106 fault code
Mark
Mark.wilbur23
C?ID=401199
Did I misunderstand DrPeters suggestion to compare the sensor data readings Don his post ?
Dr Peters post follows
DrPeter
Sorry for any confusion....
So in the quote below, I was making mention of two (2) sensors:
1) F96-arometric Pressure (BARO) Sensor = "Ambient pressure"
2) G71-Manifold Absolute Pressure Sensor = "Intake manifold pressure: absolute"
The G31-Charge Air Pressure Sensor is for forced induction engines...
Hope that clears things up,
drpeter
NostraJackAss
This is why the forum is not a substitute for the RTFB and observation of SSP design and function & to familiarize yourself with circuits or operation of components/locations.
Mark.wilbur23
C?ID=401199
Sensors appear to be reading about the same pressure any ideas on where to go from here would be very welcome
Address 01: Engine (8R0 907 559 A)
11:33:54
IDE00190-ENG103225 Charge air pressure specified value-MAP_SP 118.99 hPa
IDE00474 Ambient air pressure 90 kPa abs
IDE00594 Absolute intake pressure 97 kPa abs
ENG99319 Ambient pressure 908.44 hPa
ENG101388 Intake manifold pressure: absolute 979.92 hPa
Mark.wilbur23
C?ID=401199
Do you have a RTFB and WD so you can observe it because that is what you need?
Not sure what these items are or how to use them
is there a wiki or other document i should spend some time with
to learn what they are and how to use them ?
again very grateful to everyone here for all of the advice and help so far
i understand that is difficult (and frustrating) to get everyone up to speed on some of the common procedures
but i am a fast learner and m sure with your help we can resolve this fault code
Mark
NostraJackAss
Mark
No sweat.
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
https://procarmanuals.com/vag-ssp-657-audi-q5-type-fy/
https://procarmanuals.com/vag-ssp-433-audi-q5/
DrPeter
Well.. there is only a 70 hPa difference in your values at the time the were being observed. So the code should not set .. technically, according to some information I had found in the repair manuals, however I do recall some documents wanting less than 100? I could be wrong..
You could do a 'wiggle' test of the harness, connectors, ecm, grounds, etc while observing these values live with the key on/engine off. Be sure to maintain battery voltage.
Maybe an ECM concern... hard to be sure.. You can use VCDS to clear fault codes three (3) times in a row in less than 30-sconds in the [01-Engine], then cycle the ignition off/on after about a 10 second wait... or You can disconnect the battery for 30 min and see if the code clears?
drpeter
Mark.wilbur23
C?ID=401199
I’ll give it a try
Anything I need to run after I reconnect the battery ?
Seen lots of suggestions on running TBA after battery disconnect
Thanks for the help
Mark
DrPeter
Seen lots of suggestions on running TBA after battery disconnect ....
It would not hurt to use the Basic Settings for the Throttle Body Alignment, then run an Auto-Scan, clear all DTC's and see what comes back..
drpeter
Mark.wilbur23
C?ID=401199
I’m going to purchase another different manufacturer MAP sensor and see if it gets closer
To the intake manifold sensor values I found several other vehicle scans on other sites
And all of the scans I reviewed were almost identical readings with in 1-2 MBar
Hope that works
Thanks again for 5he help
NostraJackAss
Hope that works
Think you would mine more GOLD checking and qualifying the harness or tracks shared versus changing out parts?
Ever consider a tester such as a decade box and load lights?
Have you read the entire JPPSG thread yet?
