I have got 6R polo,the ABS has been replaced by other garage to second hand.
The guy gave me the old original ABS unit,
The original has AB letters but the "new" has S letter.
The coding string copy does not work. Even I can see the HW are the same only the SW level is different.
Thank you.
Tuesday,07,April,2020,13:12:32:17963
VCDS Version: 20.4.0.1 (x64)
VIN: WVWZZZ6RZAU010372 License Plate: 10MO 448 ORI
Mileage: 268640km-166925mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 09 15 17 19 25 44 56
VIN: WVWZZZ6RZAU010372 Mileage: 268640km-166925miles
Address 01: Engine (CGP) Labels: 03E-906-033-AZQ.lbl
Part No SW: 03E 906 023 AL HW: 03E 906 023 L
Component: SIMOS91 1.2l 4V 4523
Revision: --H04--- Serial number:
Coding: 0000031
Shop #: WSC 00000 000 31414
VCID: 69D3D4F2433FC9CEB5-5120
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AB HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 200200E3006E00B2042800E900D300000000
Shop #: WSC 31414 790 31414
VCID: 7EF997AEEDB15E7670-802A
01201 - ABS Pump Supply Voltage
Fault Status: 11100000
Reset counter: 41
Mileage: 268615 km
Date: 2014.08.26
Time: 00:02:05
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x32A0
Hex Value: 0x05B5
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Reset counter: 83
Mileage: 268615 km
Date: 2014.08.29
Time: 00:14:42
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x33A0
Hex Value: 0x1398
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 086 B HW: 6R0 937 086 B
Component: PQ25 BCM H09 0025
Revision: BD009001 Serial number: 9953A236090484
Coding: 24B02BBF08A10000002000003D2B0CD00040410F600400002000
VCID: 3B7F5EBABA238B5E17-806E
Subsystem 1 - Part No SW: 6R0 959 802 H HW: 6R0 959 802 H Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0803
Serial number: KU0-KU020.08.0911349
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 K HW: 6R0 959 801 K Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 0803
Serial number: KU0-KU014.08.0911506
Coding: 08BC30
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00E H09 0018
Revision: -------- Serial number: 003DW0061BK0
Coding: 003045
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4281235ED5C9FA9654-8016
Serial number: 3572SRB400009A11035U
Serial number: 3582SRB40000993D2A27
Serial number: 3516GRB402F9BPVMOCCL
Serial number: 3526GRB401N9NI6CVBPI
Part No SW: 6R0 920 860 A HW: 6R0 920 860 A
Component: KOMBI H23 0110
Coding: 140200
Shop #: WSC 31414 790 50316
VCID: 3261739E65694A16C4-8066
Part No SW: 6N0 909 901 HW: 6R0 937 086 B
Component: GW-K-CAN TP20 0025
Coding: 002300
VCID: 70E5B996A3E53806F2-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H23 0110
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 31414
VCID: 2E5967EEED516EF6A0-807A
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 013 0036
Revision: 01000000 Serial number: VWZ1Z2I6819507
Coding: 0500040002
VCID: 6BDFAEFA8AC3DBDEC7-803E
00856 - Radio Antenna
007 - Short to Ground
Fault Status: 01100111
Reset counter: 43
Mileage: 268645 km
Date: 2014.08.29
Time: 00:03:40
End-------------------------(Elapsed Time: 01:56)--------------------------
Tuesday,07,April,2020,12:49:46:17963
VIN: WVWZZZ6RZAU010372 License Plate: 10M0448
Coding: 0000031
Readiness: N/A
Part No SW: 6R0 907 379 S HW: 6R0 907 379 AB
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 13765 790 00017
VCID: 4E99076E1D910EF6C0-801A
Reset counter: 43
Mileage: 268644 km
Date: 2014.08.29
Time: 19:28:17
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3213
Hex Value: 0x148D
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 43
Mileage: 268644 km
Date: 2014.08.29
Time: 19:33:07
Hex Value: 0x0005
Hex Value: 0x0001
Hex Value: 0x3224
Hex Value: 0x0371
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Coding: 08BC30
Coding: 08BC30
Coding: 003045
Coding: 140200
Coding: 002300
Coding: 10150
Shop #: WSC 31414
Address 56: Radio Labels: None
VCID: 55ABE802BC477D2E01-FFFE
No Faults Found
End-------------------------(Elapsed Time: 05:47)--------------------------
