Newbie: SRI Reset
CrazeUK
Hey All.
So far i have just used my VCDS to read error codes on the car - which is just the once.
It is now time to reset a service light. The last Full service i did was back in June 2019, ifi recall, they did reset the servie light. Which has come on again.
So, how do i find out why?
Also how do tell if my car is on flexible or fixed service?
Finally, do the results below look okay?
Monday,06,April,2020,20:36:28:04239
VCDS Version: 20.4.0.1 (x64)
VIN: License Plate: **** *****
Mileage: ###### Repair Order:
VCDS Release 20.4.0: SRI Reset
Control Module Part Number: 8T0 920 983 M Labels: .8T0-920-xxx-17.clb
Component:KOMBIINSTR. H35 0556, Coding:33A7300002012600010000
Channel Description Unit Current val. New val.
02 Service Reminder Status 2 ---
40 Distance since Service km x100 145 ---
41 Time since Service Days 159 ---
42 Minimum Distance to Service km x100 300 ---
43 Maximum Distance to Service km x100 300 ---
44 Maximum Time to Service Days 730 ---
45 Oil Quality 1 ---
47 Soot Quantity DIST x100 329 ---
48 Thermal Load DIST x100 136 ---
49 Minimum Time to Service Days 730 ---
50 Basic Distance Value for Oil Change km x100 145 ---
51 Basic Time Value for Oil Change Days 365 ---
52 Basic Distance Value for Inspection km x100 190 ---
53 Distance since Inspection km x100 56 ---
54 Basic Time Value for Inspection Days 730 ---
55 Time since Inspection Days 307 ---
56 Day Counter Days 2598 ---
Thanks in advance
Craze: hmmm...... that's a unique and an very interesting way to introduce the vehicle for your question. Notwithstanding my assumption that you want to not disclose the VIN, please include a full (meaning, unedited) current auto-scan from the car - so we can see a total list of the equipment installed as context for the CAN Gateway module (the VIN can be blanked on your scan report before posting -if you want)
Thank you
PS: Or, as a relatively obscure forum member so eloquently said recently: HERE
CrazeUK
Hi Don.
Thanks for the response and apologies for missing the information
I didn't know you needed that.
Do I need to start a new thread with a scan of the car?
I assume you mean this:
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 19.6.2(x64) Data version: 20190930 DS308.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Sunday,19,January,2020,12:42:54:04239
VIN: License Plate:
Mileage: 231010km-143542mi Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 0E 0F 15 16 17 19 37 42 44 46 52 53 56 5F
62 72
VIN: Mileage: 231010km-143542miles
0F-Digital Radio -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
Self-Diagnosis Log
Page 2
VIN: License Plate:
Address 01: Engine (J623-CJCA) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 HT HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9977
Revision: 45H25---
Coding: 0A034012232401080000
Shop #: WSC 46703 001 1048576
ASAM Dataset: EV ECM20TDI01103L906018HT 003008
ROD: EV ECM20TDI01103L906018HT.rod
VCID: 03022E508A059757BA-8056
4807 - EGR System
P0401 00 [104] - Insufficient Flow
Fault Frequency: 18
Mileage: 230023 km
Date: 2020.01.04
Time: 21:44:03
Engine speed: 1162.00 /min
Normed load value: 27.1 %
Vehicle speed: 46 km/h
Coolant temperature: 80 °C
Intake air temperature: 13 °C
Voltage terminal 30: 14.640 V
Air mass: specified value: 283.2 mg/stroke
Air mass: actual value (mg/stroke): 415.9 mg/stroke
EGR Solen.val.: actual value: 15.92 %
Throttle valve adapter: actual value: 26.62 %
Charge air pressure specified value: 1042 hPa
Charge air pressure: actual value: 1140 hPa
Mean injection quantity: 8.20 mg/stroke
Readiness: 0 1 0 0 0
Self-Diagnosis Log
Page 3
VIN: License Plate:
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K9 927 155 A HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H05 0001
Revision: --H05--- Serial number: 0000001585
Coding: 000002
Shop #: WSC 06325 000 00000
ASAM Dataset: EV TCMVL381 A02432
ROD: EV TCMVL381.rod
VCID: 3A7C93B4BD4F169FA9-806E
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Coding: 171544
VCID: 0008215C93138C4FA7-8054
Part No SW: 8K0 907 064 GB HW: 8K0 907 064 FB
Component: BCM2 2.0 H12 0633
Coding: 01B44040000000000000
VCID: 76E44784C1D7B2FF8D-8022
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Serial number: 0513000010155010
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000021399005
Self-Diagnosis Log
Page 4
VIN: License Plate:
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AJ HW: 8K2 820 043 AJ
Revision: D1000000 Serial number: 01150220130789
Coding: 342402E000
VCID: 71EE7498A8B995C758-8024
Part No SW: 8K0 907 063 DD HW: 8K0 907 063 DD
Component: BCM1 1.0 H16 0103
Revision: 04016001 Serial number: 00000549150902
Coding: 290000308034A7E01E81000300001F1F009D420827080201000008004000020000000024000000
Shop #: WSC 06325 123 12345
VCID: 74E07D8CD7ABA0EFB3-8020
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 140213 H13 0080
Serial number: SWF13020145100
Coding: 00FD11
Component: G397 RLFS H06 0002
Serial number: 20993713
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000802130845
Component: AQ Hum Sensor H03 0003
Serial number: ED380296000000000001
00471 - Control Module for Elect. Regulated Dampers (J250)
Reset counter: 88
Mileage: 229799 km
Date: 2020.01.01
Time: 14:06:03
Self-Diagnosis Log
Page 5
VIN: License Plate:
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000008
VCID: 2D56A8E87401B1273C-8078
Address 0F: Digital Radio
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD989TDX
Coding: 30533938363030303030554A305238543053
ASAM Dataset: EV AirbaECUVWAUDI010 003010
ROD: EV AirbaECUVWAUDI010 003_AU48.rod
VCID: 4898F97CF3A3740F2F-801C
Serial number: 6334MSME7665266DO
Serial number: 6344MSME78655546K
Serial number: 6352QSME3E2C1574P
Serial number: 6362QSME712B0456E
Serial number: 63732SME49292962%
Serial number: 63832SME5C2B20560
Self-Diagnosis Log
Page 6
VIN: License Plate:
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130215000428
Coding: 000036
VCID: 4FAAD2601ECDA3376E-801A
Part No SW: 8T0 920 983 M HW: 8T0 920 983 M
Component: KOMBIINSTR. H35 0556
Revision: 00100000 Serial number: UUW323G2E
Coding: 33A7300002012600010000
VCID: 4898F97CFBA3740F2F-801C
Self-Diagnosis Log
Page 7
VIN: License Plate:
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y131290170
Coding: 80CF07FF00
VCID: 4A9CC374E5AF861F39-801E
Serial number: 6754938901
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532 DCDCStab H17 0042
Serial number: 13042001600021200181
02230 - Digital Radio (DAB) (R147)
Reset counter: 88
Mileage: 229799 km
Date: 2020.01.01
Time: 14:06:08
Bin. Bits: 11111
Voltage: 14.50 V
Count: 6
Bin. Bits: 10000
Reset counter: 88
Mileage: 229799 km
Date: 2020.01.01
Time: 14:06:08
Bin. Bits: 11111
Voltage: 14.50 V
Count: 6
Bin. Bits: 10000
Self-Diagnosis Log
Page 8
VIN: License Plate:
Address 37: Navigation
Part No SW: 8T0 959 793 Q HW: 8T0 959 793 F
Component: TSG FA H09 0304
Coding: 011002624001450005
VCID: 57BA2A00261DEBF7B6-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0026221517
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV RCEPSAU48X 008014
ROD: EV RCEPSAU48X 008.rod
VCID: 3460BD8C9F2BE0EF73-8060
Revision: 00002001 Serial number: 0300863779
Coding: 013B062220B90000802004368000000F
Self-Diagnosis Log
Page 9
VIN: License Plate:
Part No SW: 8T0 959 792 Q HW: 8T0 959 792 H
Component: TSG BF H08 0304
Coding: 011002224C01450005
Shop #: WSC 12345 123 61029
VCID: 56A427042117D2FFAD-8002
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 30000000011898
ASAM Dataset: EV ParkiBrake 001027
ROD: EV ParkiBrake AU48.rod
VCID: 387889BC8343048F5F-806C
Part No SW: 4G0 035 056 G HW: 4G0 035 056
Component: Radio U STD H60 0121
Revision: AB001007 Serial number: 230BY0D7583564
Coding: 010003020100000001
VCID: 254650C82CF18967F4-8070
Self-Diagnosis Log
Page 10
VIN: License Plate:
Part No SW: 8R2 035 666 B HW: 8R2 035 666 C
Component: H-BN-EU H45 0639
Revision: -------- Serial number: 206B/0D7518686
Coding: 13010104000681ED07808F5E00000403E40000020200000000
VCID: 387889BC8B43048F5F-806C
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Component: DU7 High H42 0104
Serial number: A130BP0D2655633
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000001414782
Component: CD-Database 4949
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010002224001450005
VCID: 59BE2C385009FD8780-800C
Component: TSG HR H07 0304
End-------------------------(Elapsed Time: 03:55)--------------------------
That's better than nothing, but it's certainly not ideal. Please don't use the [Print] function in VCDS to post data here. Please just post the native text VCDS produces. You can grab it from your Scans sub-folder.
Based on "Oil Quality" being set to 1, it appears your car is set to Fixed intervals. But the rest of the values don't match that; for example both Minimum and Maximum Distance to Service are set to 30,000 km, which strikes me as implausibly long for fixed intervals. 30,000 km is the maximum allowed on flexible intervals, but even then the minimum should should 15,000.
How long have you owned this car? It seems someone has buggered up these settings, as well as the coding. Byte 9 of the cluster's coding indicates it's set to "Germany (D) / Left-Hand-Drive (LHD) OR Not Specified". That doesn't seem correct. Is this really a LHD car? Because some of the other coding bits seem to show it set up for the UK.
PS: Please Get Verified.
CrazeUK
Hey Don.
Thanks for the quick reply.
Thanks for pointing the scans folder - duly noted.
Does the below work better - or do you need the file attached?
Also, is below the ideal of what you need - or is there something else? - I appreciate your assistance, so would like to make it as easy as possible for you.
I have had the car just coming up to 1 year from Last April. January was the first time I looked into scanning the codes after it got a Fault (on the EGR valve if I recall).
The car is certainly a UK spec right-hand drive Auto.
How do I correct the coding info?
Thanks again.
Sunday,19,January,2020,12:41:23:04239
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8###########   License Plate:
          62 72
VIN: WAUZZZ8###########   Mileage: 231010km-143542miles
   Revision: 45H25---
   ASAM Dataset: EV_ECM20TDI01103L906018HT 003008
   ROD: EV_ECM20TDI01103L906018HT.rod
4807 - EGR System
                    Fault Frequency: 18
                    Mileage: 230023 km
                    Date: 2020.01.04
                    Time: 21:44:03
   Coding: 000002
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   Coding: 171544
   Coding: 342402E000
   Coding: 00FD11
   Coding: 02005D
                    Reset counter: 88
                    Mileage: 229799 km
                    Date: 2020.01.01
                    Time: 14:06:03
   Revision: 00000008
   Coding: 000036
   Coding: 80CF07FF00
                    Reset counter: 88
                    Mileage: 229799 km
                    Date: 2020.01.01
                    Time: 14:06:08
                    Bin. Bits:    11111
                    Voltage: 14.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 88
                    Mileage: 229799 km
                    Date: 2020.01.01
                    Time: 14:06:08
                    Bin. Bits:    11111
                    Voltage: 14.50 V
                    Count: 6
                    Bin. Bits:    10000
   ROD: EV_RCEPSAU48X_008.rod
   ROD: EV_ParkiBrake_AU48.rod
p.s. Will work on getting verified asap. My paperwork is at my flat in Leeds and I am stuck down in Hertfordshire due to Covid.
Yes, much better, thank you.
OK, I located two other scans of cars with the exact same Instrument Cluster. Both seem to be UK cars, and both have the same 00 value in Byte 9. So it's possible that the documentation we have for that byte is no applicable to this particular cluster, and I'm going to recommend against messing with it.
Now regarding the Service Reminder, here's what I would do if this car were mine: Wait 5,000 more km, because then it's due for an oil change anyway. Once that has been done, I would do the following:
[SRI Reset]
Wait for VCDS to read the channels again.
From the Operation drop-down, choose "Change to fixed Intervals (Rest of World)" (*)
[Perform SRI]
Wait for VCDS to modify the channels.
[Done, Go Back]
Cycle the ignition.
[SRI Reset]
From the Operation drop-down, choose "Fixed Oil Service Reset (Rest of World)"
[Perform SRI]
[Done, Go Back]
(*) I would not use "Change to fixed Intervals (Great Britain)" because that assumes the values are in miles and yours aren't.
You shouldn't need any paperwork. There should be a "short" serial number that starts with HC7 and is followed by five more numbers on the interface itself. That and the "long" serial number from the About screen in VCDS (plus your contact info) are all that's required.
