Make interior lights less bright
kronner2
C?ID=391832
Hey,
I tried adjusting in 09-cent elect
"helligkeit" of various sorts without noticable change.
What am I doing wrong?
The two lights on the ceiling for passenger and driver are very bright and I want to dim them. Is that possible? What adaptation is needed?
Thanks.
Saturday,04,April,2020,18:53:44:28172
Chassis Type: UY-VN54 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 3C 42 44 52 5F 65 69 6C A5 BB
          BC
VIN: XXXXXXXXXXXXXX   Mileage: 1267km-787miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DAVA)       Labels: None
   Part No SW: 04L 906 056 SH    HW: 04L 907 445 P
   Component: R4 2.0l BTD   H01 9795
   Revision: 23203001
   Coding: 002A40346374050800000000000000000000000000000000
   Shop #: WSC 00000 000 00019
   ASAM Dataset: EV_ECM20BTD03004L906056SH 006003
   ROD: EV_ECM20BTD03004L906056SE.rod
   VCID: 05566BD545A7C6E3604-8050
Readiness: N/A
   Part No SW: 09G 927 158 ED    HW: 09G 927 158
   Component: AISIN AQ8     206 3548
   Coding: 0000000100000000010000000000000000000000
   ROD: EV_TCMAQ450031_VN54.rod
   VCID: 79AE1725395FB20314C-802C
   Part No SW: 2N0 907 379 D    HW: 2N0 907 379 C
   Component: ESC_base      H02 0860
   Serial number: 08503098200109
   Coding: 25AA2477483DB68AA44F246012476D763CF740BA
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701030
   ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
   VCID: 372AD11D4FCB6473A28-8062
Address 08: Auto HVAC (J301)       Labels:* None
   Part No SW: 7C0 907 426 AF    HW: 7C0 907 426 AF
   Component: AC Manuell    H01 0401
   Coding: A07010000800000001000820500101000000000000001000000000000000
   Shop #: WSC 00000 000 00012
   ASAM Dataset: EV_AirCondiBHTCVN54X 003020
   ROD: EV_AirCondiBHTCVN54X_VN54.rod
   VCID: 6D8633757D171EA3884-8038
   Part No SW: 5Q0 937 084 DG    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H42 0312
   Serial number: 02002000302433
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 00587AC15A85E3CB532-8054
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050  0105
   Serial number: S4Y20M01D03H15M26S38
   Coding: 0038DD
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 CR    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23  0170
   Serial number: 0100021220190C107357
Address 10: Park/Steer Assist (J791)       Labels:* None
   Part No SW: 2N0 919 300 C    HW: 2N0 919 300
   Component: aFLS 16KH06 0205
   Serial number: 000310350619346
   Coding: 0A7116F971
   ASAM Dataset: EV_EPHVA2FVN54X0000 009035
   ROD: EV_EPHVA2FVN54X0000.rod
   VCID: 290E0765897FC28324C-807C
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 30095F4B44EFC448949C818F20308500000000000000000004
   Shop #: WSC 12345 123 00019
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D2B5CD0B1338D30E0-8016
   Part No SW: 3Q0 959 655 CR    HW: 3Q0 959 655 CR
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z6PQJ9FAJ
   Coding: 88CCC00000000000400000CF000800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 10784A810AE5934BC32-8044
   Subsystem 1 - Part No SW: -----------    HW: 454 001 911 19
   Serial number: 35700000000DA8DCF246
   Subsystem 2 - Part No SW: -----------    HW: 454 001 911 19
   Serial number: 3580000000094DFCF244
   Subsystem 3 - Part No SW: -----------    HW: 454 801 210 19
   Component: SideSensor_Dr  305 0109
   Serial number: 35100FC2E1E1A000000Z
   Subsystem 4 - Part No SW: -----------    HW: 454 801 210 19
   Component: SideSensor_Pr  305 0109
   Serial number: 3520054321E1A0000007
   Subsystem 5 - Part No SW: -----------    HW: 454 802 811 19
   Component: FrontSensor_D  305 0109
   Serial number: 35500C003831A0000007
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 454 802 811 19
   Component: FrontSensor_P  305 0109
   Serial number: 356005C05831A000000F
   Part No SW: 7C0 920 741 C    HW: 7C0 920 741 C
   Component: KOMBI         204 6700
   Coding: 07A41188648C0008008A6A0F7401000000000000
   Shop #: WSC 12345 123 00012
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 24101651EE5D1FEB17A-8070
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000450399
   Coding: 030100344F05730000000000000F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 70B82A016A25F34BA32-8024
   Component: 4-00-11-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190003514400029495
   Coding: 2EFFFF
   Subsystem 3 - Part No SW: 2N0 915 181     HW: 2N0 915 181
   Serial number: 758849020020011102FF
   Serial number: 0534673535
   Coding: 02012103
   ROD: EV_HREntryHella_SE27.rod
   VCID: 3D26C3356DF74E23784-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0535337818
   Coding: 020121
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000399001040
   Coding: 00300B20D000020100001000
   VCID: 4DC693F5DD57FEA3E84-8018
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 2N0 909 143 G    HW: 2N0 909 143 C
   Component: EPS_MQB_ZFLS  701 7031
   Coding: 1307
   ASAM Dataset: EV_SteerAssisMNB 002009
   ROD: EV_SteerAssisMNB_VN54.rod
   VCID: 313EEF05A1AFBA43ECC-8064
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000401256452
   VCID: 4CC09EF1264DF7ABFFA-8018
   Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
   Component: MU-S-N-ER     H42 0475
   Serial number: VWZAZ2X0804958
   Coding: 084500013C00000051110001000808001F060BD401200500C7
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 3038EA01AAA5B34BE32-8064
   Component: ABT_High  H64 0032
   Serial number: VWZ8Z9W4P011R9
   Subsystem 2 - Part No SW: 7CE 919 866 AK    HW: -----------
   Component: ECE3 2020  --- 1310
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H05 0010
   Serial number: 30000000371633
   ROD: EV_RDKBERU30_VW41.rod
   VCID: 3634DC1948C19D7BB9E-8062
   Part No SW: 6C0 907 383 G    HW: 6C0 907 383 G
   Component: Anhaenger     H27 0260
   Revision: 8D001004    Serial number: 0538232307
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 2E04F479B091A5BBF1E-807A
   Part No SW: 5Q0 980 568 B    HW: 5Q0 980 568 B
   Component: RVC Compact+  H09 0250
   Coding: 0155000101002000000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
   ROD: EV_CamSysRVRVCARPANAMQBAB_007.rod
   VCID: 3C20CE3176ED472B4FA-8068
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 11012012K21553
   Coding: 010504000000040100221355C14685009A000E00002000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D8BAC11A0523CB132-8014
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----(Elapsed Time: 01:11, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
TBAx
C?ID=287144
I never checked these myself, but I've read that the Innenbeleuchtung Parameter-p_adaption_kundenwunsch_cockpit adaptions in the BCM could do the trick.
IDE11477-ENG128587-Innenbeleuchtung Parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Innenbeleuchtung Parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Innenbeleuchtung Parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128571-Innenbeleuchtung Parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Innenbeleuchtung Parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Innenbeleuchtung Parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Innenbeleuchtung Parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Innenbeleuchtung Parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
kronner2
C?ID=391832
Thanks!
I tried setting
to 0.20
but I did not see any effect.
