I have been able to get
"Streckenverlauf berücksichtigen"
to show in the menu (ACC should slow down in curves)
But it's unchecked and when I try to check it, I get "This function is currently not available."
So I guess I either missed some coding or it's not possible with this vehicle and VCDS.
Has anyone activated Curve Assist successfully on another vehicle?
Saturday,04,April,2020,18:53:44:28172
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
Chassis Type: UY-VN54 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 3C 42 44 52 5F 65 69 6C A5 BB
BC
VIN: XXXXXXXXXXXXXX Mileage: 1267km-787miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DAVA) Labels: None
Part No SW: 04L 906 056 SH HW: 04L 907 445 P
Component: R4 2.0l BTD H01 9795
Revision: 23203001
Coding: 002A40346374050800000000000000000000000000000000
Shop #: WSC 00000 000 00019
ASAM Dataset: EV_ECM20BTD03004L906056SH 006003
ROD: EV_ECM20BTD03004L906056SE.rod
VCID: 05566BD545A7C6E3604-8050
Readiness: N/A
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 ED HW: 09G 927 158
Component: AISIN AQ8 206 3548
Coding: 0000000100000000010000000000000000000000
ROD: EV_TCMAQ450031_VN54.rod
VCID: 79AE1725395FB20314C-802C
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 2N0 907 379 D HW: 2N0 907 379 C
Component: ESC_base H02 0860
Serial number: 08503098200109
Coding: 25AA2477483DB68AA44F246012476D763CF740BA
ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701030
ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
VCID: 372AD11D4FCB6473A28-8062
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7C0 907 426 AF HW: 7C0 907 426 AF
Component: AC Manuell H01 0401
Coding: A07010000800000001000820500101000000000000001000000000000000
Shop #: WSC 00000 000 00012
ASAM Dataset: EV_AirCondiBHTCVN54X 003020
ROD: EV_AirCondiBHTCVN54X_VN54.rod
VCID: 6D8633757D171EA3884-8038
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DG HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H42 0312
Serial number: 02002000302433
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 00587AC15A85E3CB532-8054
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S4Y20M01D03H15M26S38
Coding: 0038DD
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 CR HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0100021220190C107357
Address 10: Park/Steer Assist (J791) Labels:* None
Part No SW: 2N0 919 300 C HW: 2N0 919 300
Component: aFLS 16KH06 0205
Serial number: 000310350619346
Coding: 0A7116F971
ASAM Dataset: EV_EPHVA2FVN54X0000 009035
ROD: EV_EPHVA2FVN54X0000.rod
VCID: 290E0765897FC28324C-807C
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 30095F4B44EFC448949C818F20308500000000000000000004
Shop #: WSC 12345 123 00019
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D2B5CD0B1338D30E0-8016
Part No SW: 3Q0 959 655 CR HW: 3Q0 959 655 CR
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z6PQJ9FAJ
Coding: 88CCC00000000000400000CF000800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 10784A810AE5934BC32-8044
Subsystem 1 - Part No SW: ----------- HW: 454 001 911 19
Serial number: 35700000000DA8DCF246
Subsystem 2 - Part No SW: ----------- HW: 454 001 911 19
Serial number: 3580000000094DFCF244
Subsystem 3 - Part No SW: ----------- HW: 454 801 210 19
Component: SideSensor_Dr 305 0109
Serial number: 35100FC2E1E1A000000Z
Subsystem 4 - Part No SW: ----------- HW: 454 801 210 19
Component: SideSensor_Pr 305 0109
Serial number: 3520054321E1A0000007
Subsystem 5 - Part No SW: ----------- HW: 454 802 811 19
Component: FrontSensor_D 305 0109
Serial number: 35500C003831A0000007
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 454 802 811 19
Component: FrontSensor_P 305 0109
Serial number: 356005C05831A000000F
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 7C0 920 741 C HW: 7C0 920 741 C
Component: KOMBI 204 6700
Coding: 07A41188648C0008008A6A0F7401000000000000
Shop #: WSC 12345 123 00012
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 24101651EE5D1FEB17A-8070
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000450399
Coding: 030100344F05730000000000000F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 70B82A016A25F34BA32-8024
Component: 4-00-11-01-04
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H18 0052
Serial number: 39190003514400029495
Coding: 2EFFFF
Subsystem 3 - Part No SW: 2N0 915 181 HW: 2N0 915 181
Component: J367-BDMConti H03 1051
Serial number: 758849020020011102FF
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0534673535
Coding: 02012103
ROD: EV_HREntryHella_SE27.rod
VCID: 3D26C3356DF74E23784-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0535337818
Coding: 020121
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000399001040
Coding: 00300B20D000020100001000
VCID: 4DC693F5DD57FEA3E84-8018
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 2N0 909 143 G HW: 2N0 909 143 C
Component: EPS_MQB_ZFLS 701 7031
Coding: 1307
ASAM Dataset: EV_SteerAssisMNB 002009
ROD: EV_SteerAssisMNB_VN54.rod
VCID: 313EEF05A1AFBA43ECC-8064
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000401256452
VCID: 4CC09EF1264DF7ABFFA-8018
Part No SW: 3Q0 035 846 B HW: 3Q0 035 846 B
Component: MU-S-N-ER H42 0475
Serial number: VWZAZ2X0804958
Coding: 084500013C00000051110001000808001F060BD401200500C7
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 3038EA01AAA5B34BE32-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H64 0032
Serial number: VWZ8Z9W4P011R9
Subsystem 2 - Part No SW: 7CE 919 866 AK HW: -----------
Component: ECE3 2020 --- 1310
Part No SW: 5Q0 907 273 D HW: 5Q0 907 273
Component: RDKBERU30 H05 0010
Serial number: 30000000371633
ROD: EV_RDKBERU30_VW41.rod
VCID: 3634DC1948C19D7BB9E-8062
Part No SW: 6C0 907 383 G HW: 6C0 907 383 G
Component: Anhaenger H27 0260
Revision: 8D001004 Serial number: 0538232307
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 2E04F479B091A5BBF1E-807A
Part No SW: 5Q0 980 568 B HW: 5Q0 980 568 B
Component: RVC Compact+ H09 0250
Coding: 0155000101002000000048
ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
ROD: EV_CamSysRVRVCARPANAMQBAB_007.rod
VCID: 3C20CE3176ED472B4FA-8068
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 11012012K21553
Coding: 010504000000040100221355C14685009A000E00002000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D8BAC11A0523CB132-8014
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----(Elapsed Time: 01:11, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
### Adaptation Camera:
;SW:3Q0-980-654-L HW:3Q0-980-654-A --- Frt Sens. Drv. Assist
;Component:MQB_B_MFK H12 0610, Coding:010504000000040100221355C14085009A000E00002000
;EV_MFKBoschMQBB,002041,EV_MFKBoschMQBB_002.rod
;Friday,03,April,2020,21:47:49:28172
;VCDS Version: Release 20.4.0 (x64) Data version: 20200331 DS317.0
;VCID: 40D8BAC11A0523CB132-8014
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
IDE04733-Road sign detection fusion mode,Road sign fusion ,1
IDE07358-Distance to calibration field,1500 mm,2
IDE09375-IDE05717-Axle offset-Front axle transverse position,2.20001 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,1.60001 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,809 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,809.25 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,858.75 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,859 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2405 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,642 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,2107 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2405 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-642 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,2107 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2405 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,642 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,1593 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2405 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-642 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,1593 mm,24
IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
IDE10872-Warning intensity: lane depart. warning,Selection via menu ,1
IDE10873-BAP personalization,activated ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.234 ∞,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,-0.136 ∞,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.004 ∞,8
IDE10924-MAS10678-Initial calibration: result-Camera height,2004 mm,8
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
ENG120319-Mask_error_reactions_for_development,not activated ,1
ENG107577-Masked_fault_classes-,255 ,4
ENG130777-standstill_mode,not activated ,1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1 ,5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20 ,5
ENG130779-Xcp_interface,not activated ,1
Elapsed Time: 00:07
### Adaptation ACC:
;SW:2Q0-907-572-R HW:2Q0-907-572-B --- Auto Dist. Reg
;Component:ACCCONTIMQB H03 0372, Coding:30015F4B44EF8448949C814D20308500000000000000000004
;EV_ACCMRRCONTIVW376,003016,EV_ACCMRRCONTIVW376_003_VW27.rod
;Friday,03,April,2020,21:46:29:28172
;VCID: 43D2B5CD0B1338D30E0-8016
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01949-Distance basic setting option,On ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,On ,1
IDE09564-Distance change via speed adjustment,On ,1
IDE09565-Prioritized target object display,OFF ,1
IDE10280-Constant delay after transfer request,No ,1
IDE13334-Reduced radar performance,38 ,1
MAS19336-Active participant function activated,Deactivated ,1
Elapsed Time: 00:05
;SW:3Q0-035-846-B HW:3Q0-035-846-B --- Information Electr.
;Component:MU-S-N-ER H42 0475, Coding:084500013C00000051110001000808001F060BD401200500C7
;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW37.rod
;Sunday,05,April,2020,18:17:01:28172
;VCID: 3038EA01AAA5B34BE32-8064
IDE00346-Summertime-automatic,Europe ,1
IDE00758-Base volume of telephone,50 %,1
IDE00759-Base volume of speech output,50 %,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00769-Number 1 for Info call,5E 07 A1 80 00 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 07 A1 80 00 98 37 87 24 F3 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE00845-Wheel circ.,0 mm,2
IDE02121-CD eject button,Enabled ,1
IDE02330-Number 2 for Info call,5E 08 91 94 81 20 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 06 91 94 81 60 11 21 31 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
IDE02502-Confirmation of installation change,FF 98 ,2
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE05111-Fee-based traffic information (TMC),3 ,2
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE11122-Country identification: country of sale HMI,DE ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,21
IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57,not activated ,192
IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus,Comfort data bus ,192
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C,not activated ,192
IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus,Comfort data bus ,192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,Comfort data bus ,192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,activated ,192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,Comfort data bus ,192
IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65,not activated ,192
IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus,Comfort data bus ,192
IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64,not activated ,192
IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus,Comfort data bus ,192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,Comfort data bus ,192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,Comfort data bus ,192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,Comfort data bus ,192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
MAS03782-WLAN,On ,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus extended ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,gear_selection ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,not activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,not activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE ,40
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF ,30
ENG109862-ENG249824-Vehicle_configuration-AliBox,OFF ,30
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF ,30
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF ,30
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked ,30
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
ENG109862-ENG263540-Vehicle_configuration-correction_e_mileage,0 ,30
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP ,30
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF ,30
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
ENG109862-ENG261211-Vehicle_configuration-internet_over_WLAN_default_setting,OFF ,30
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present ,30
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present ,30
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,On ,30
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF ,30
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not activated ,30
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not activated ,30
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present ,30
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 ,30
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked ,30
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF ,30
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,OFF ,30
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
Elapsed Time: 00:33
