Jetta 2017 wolfsburg (same as Golf mk5?) adaption of gas pedal possibilities?
TBxPsi
Canada
C?ID=397313
This is my first post, I bought a HEX-V2 just the other day. The auto scan I'm posting only has comfort signal changed to 4 from 3. I also want to add that even though I have had this car for 3 yearsish, I'm completely new to the VW/Audi world. I used to have a Mustang, tuned that, but like I said I'm a noob with this Euro stuff. It took me like 30 min to figure out if I have a MK5,6 or 7 car, and I still don't really know, do I have a facelift?. Just to give a basis of my terminology and understanding of this realm of vehicles. A bit of a background however, I am a Heavy Duty Parts Technician, so I do have a very good understanding of vehicles, and vehicle systems.
So I have a 2017 Jetta wolfsburg 1.4t with iptronic AUTO 6 speed and I was wanting to change the gas pedal from adaptive to direct throttle. It seems(after talking to a fantastic redditor) that my MK6 jetta MAY specc'd with MK5 computers. He suggested this after seeing the part numbers of the modules.
THE MAIN REASON I purchased the HEX-V2 is to change the throttle from Adaptive to Direct. However after some research is seems that may not be possible. It's just that the lag sometimes gets to me, is it because of drive by wire? I also tried that hold the pedal down for 20 seconds to reset, not sure if it did anything. Kinda felt like it did, however it could be placebo.
Should I be worried about the Malfunctions, and the fact that is says a module wasn't programmed correctly at 0 KM?
Also should I be googling MK5 mods or MK6?
Now on top of everything I have put above, anyone have all the available mods via VCDS for my vehicle? Also do i google "Golf MkX", or do I google "Jetta MkX", I just dont get the terminology.
VIN: 3VWDB7AJ8HM415178   License Plate:
Mileage: 25120km-15608mi   Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 44 5F
VIN: 3VWDB7AJ8HM415178   Mileage: 25120km-15608miles
Address 01: Engine (J623-CZTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AL    HW: 04E 907 309 AP
   Component: R4 1.4l TFS   H22 3669
   Revision: X5H22---
   Coding: 011A0012232400001000
   Shop #: WSC 00066 790 00015
   ASAM Dataset: EV_ECM14TFS01104E906023AL 005004
   ROD: EV_ECM14TFS01104E906023AL.rod
   VCID: 6A8DC4232CFF1447771-803E
   CAN Converter 01:
29693 - Sensor for Ambient Air Temperature (G17)
          P0071 00 [096] - Implausible Signal
   Part No SW: 09G 927 158 BA    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3117
   Coding: 010100000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW26.rod
   VCID: 73B3D9477B35D58FC47-8026
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B400C492300FF850C02EB9221004120100010
   Shop #: WSC 00066 790 00295
   VCID: 75B7E75F75C1CBBFEA3-8020
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0440400033
   Coding: 032C0C
   VCID: 392F2B6F19D96FDFCEB-806C
   Part No SW: 1K8 907 044 CL    HW: 1K8 907 044 CL
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 005000C002
   Shop #: WSC 00066 790 00319
   VCID: 7BA3F16753659DCF9C7-802E
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [008] - Open or Short to Plus
                    Reset counter: 51
                    Mileage: 24890 km
                    Date: 2020.03.22
                    Time: 17:08:56
   Part No SW: 7E0 937 189 A    HW: 7E0 937 189
   Component: BCM PQ25 MMI3 H81 0744
   Revision: BA081001    Serial number: 91007130170042
   Coding: 7B994B9A082B0F000939268024C886C54BC6720E60A571F0B0A010032844
   Shop #: WSC 00066 000 00000
   VCID: 323D1C43C42F9C870F1-8066
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 260417 04  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  022 1467
   Serial number: 14102743170519061315
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  022 1467
   Serial number: 14202742170518203142
   Coding: 820000
   Subsystem 4 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST001NJRUS00000
   Coding: 180000
   Subsystem 5 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Serial number: 1141701553500184AD2B
   Coding: 280000
   Subsystem 6 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14102745170531054930
   Subsystem 7 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14102744170522131204
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0DW82B
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411_VW32.rod
   VCID: 6393A907CBD5450FB47-8036
   Serial number: IBH000000000007CAX5R
   Coding: 303252
   Subsystem 2 - Part No SW: -----------    HW: 480 000 605 17
   Serial number: 35700000000241E4C32E
   Subsystem 3 - Part No SW: -----------    HW: 480 000 605 17
   Serial number: 358000000009004DD32H
   Subsystem 4 - Part No SW: -----------    HW: 480 022 010 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B3229A9E3182+
   Subsystem 5 - Part No SW: -----------    HW: 480 021 304 17
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001BB24D8E654418
   Subsystem 6 - Part No SW: -----------    HW: 480 021 805 17
   Component: FrontSensor_D  000 0189
   Serial number: 3550001A524FDE4626FO
   Subsystem 7 - Part No SW: -----------    HW: 480 021 805 17
   Component: FrontSensor_P  000 0189
   Serial number: 3560001A524FDE44B5BR
   Part No SW: 5C6 920 876 C    HW: 5C6 920 876 C
   Component: KOMBI         H02 1104
   Coding: 331E000000
   VCID: 313F134FC1A9A79F76B-8064
   Part No SW: 7E0 909 901     HW: 7E0 937 189
   Component: GW-K-CAN TP20 H81 0744
   Revision: BA081001
   Coding: 102201
   VCID: 6889BE2B32732657615-803C
                    Date: 2018.12.03
                    Time: 02:24:33
   Component: IMMO          H02 1104
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 17000123242005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 305    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F2B6F15596FDFCEB-806C
   Part No SW: 5C0 035 200 B    HW: 5C0 035 200 B
   Component: MU-S-S-US     H32 0363
   Serial number: VWZAZ2T1331788
   Coding: 02630100BE00000011220001001828001F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 1471BADB5EFB72B77DD-8040
          B11CF 53 [009] - Deactivated
                    Reset counter: 184
                    Mileage: 3403 km
                    Date: 2018.03.04
                    Time: 20:42:24
                    Voltage terminal 30: 14.3 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 0 mA
                    SDARS_tuner_status_2-Reception quality: Not available
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: FF
End----(Elapsed Time: 01:29, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
iichel
Eindhoven, NB, NL
C?ID=284912
Your Jetta comes with the PQ25 platform, that it shares with a VW Polo, Beetle, Transporter T5 GP/T6. You can see it in Address 09: "Component: BCM PQ25"
In some cases, it will come on a different platform, the PQ35 platform that it shares with the Golf Mk6 etc.
That's all I can say, I'm no expert on the Mk5 Golf or throttle adaptations.
Your engine is a relatively new (2012) engine for the NAR market
1.4 TSI (EA211)
For 2012, these newly developed generation of modern petrol engines are manufactured at the Škoda Auto plant in Mladá Boleslav.
identification
EA211 engine family.
description
1.4 TFSI Green tec engine with 110 kW (140 hp). This engine achieves its maximum torque of 250 Nm at 1,500 to 3,500 rpm.
In North American market it is referred to as CZTA type engine (150 hp). In Chilean market it is referred to as CHPA type engine (140 hp) or CZDA type engine (150 hp).
New lightweight aluminum construction, an integrated (into the head) exhaust manifold, and a toothed-belt drive for its double overhead camshaft valvetrain that incorporates variable intake and exhaust timing. The only aspect to be carried over from the EA111 engine that preceded it is the 82 mm cylinder spacing. The cylinder bore was decreased by 2 mm (to 74.5mm) while the stroke was increased to 80mm, a change which helps compactness, increases torque, and is ideal for adding boost.
I'm not sure this engine has ever been in the Mk5 Golf, but I wouldn't bet on it.
This car itself is an Mk.6. "VW36", but VW used a less expensive "Polo" PQ25 BCM in many of these cars. "Parts bin cost engineering".
I would not worry too much about the fault in 01-Engine because it is "Intermittent - Not Confirmed" and the ECU has not seen fit to report it to the Gatway "01-Engine -- Status: OK 0000"
The fault in the HVAC sounds like a bad sensor or bad connection to that sensor. Unfortunately, it's likely buried and would require lots of disassembly to get to. If this was my car, I'd clear it and see how quickly (and under what circumstances) it comes back.
The "Control Module Incorrectly Coded" is flagged "Intermittent". Clear it and see if it comes back. My guess is someone was fooling with something back in December of 2018 and never cleared the fault.
"Tuner for Satellite Radio -- Deactivated" just tells you that the subscription to Sirius/XM is not active. The only way to get rid of this "fault" is to get a Sirius/XM subscription.
You can't really do much about the behavior of the gas pedal. Since the car has an automatic transmission, it's difficult to say whether any lag you are experiencing is actually in the throttle/engine or whether it's due to some behavior in the transmission. One thing that might be worth trying is to calibrate the throttle body. See this page. Please read the whole page. The actual procedure applicable to your car is the last one, "Drive-by-Wire (DBW) Engines using KWP-7000 (UDS/ODX)", and the Basic Setting in your ECU should be:
IDE00754 -- Test of throttle valve adaptation
TBxPsi
Canada
C?ID=397313
Well that's extremely helpful, really are a Benevolent Dictator. You've cleared up my worries with those codes.
That being said, with your experience, do you think that a Throttle body calibration would actually do anything?
I kinda wish I knew about this stuff before I purchased this car.. i would have gotten a different model with more possibilities.
Going forward if I have any issues trying to enable/disable something, do I just create a new thread under tweaks?
Very friendly community, nice to see.
TBxPsi
Canada
C?ID=397313
This information has helped greatly, thank you sir. @iichel
So I have to look up each individual module instead of the vehicle model?
You can check VW Jetta (16/AJ) Tweaks but if something isn't listed create a new thread under the tweaks sub-forum with a scan and someone should be able to assist.
Sorta. You can search online for Mk6 Jetta Sedan tweaks but make sure the instructions aren't for a Mk6 based JSW or GLI which used the higher-end PQ35 BCM (which supported a larger list of tweaks).
