12715520 - No retrofit/stock car - but code doesn't get cleared
   #21
Did you disconnect battery and run a jumper to do capacitor discharge & for 5 minutes and then remove jumper and reconnect battery and restart the cars systems like a computer being rebooted?
Is VCDS setup in configuration screen please show me yours?
   #22
Dana
Western PA, USA
Dana, no changes were made prior, do you think a dealership can decode what's going on? The car gives the error a high priority but the dashboard has no lights and all KESSY functions are working normally
Also, would you by chance have the adaptations map for all the modules from your other 2017 NAR Jetta SEL scan? Maybe then I could compare each adaptation just to be very very sure
The dealer may be able to determine the cause however they may not be very enthusiastic about doing so without any functional problems. Jack's battery Jesus suggestion is worth a shot but don't do that if time is limited. You may need to re-calibrate the steering angle sensor to resolve new (battery related) fault codes.
I do not have maps from that car but you may find some in our forum. I did find this (DRL winking and dimming discussion) when searching for your BCM part number though:
https://forums.ross-tech.com/showthread.php?8859-2017-Jetta-SE-TSI-DRL-wink
If you cannot locate a complete map set from a similar vehicle it might not hurt to post a wanted thread here: https://forums.ross-tech.com/forumdisplay.php?45-Reference-Scans-and-Maps-of-Non-Broken-Cars
   #23
gokarty
C?ID=401142
Okay, I'll try the battery disconnect when I get the time thanks!
   #24
gokarty
C?ID=401142
Hi Jack, I'll do the battery disconnect asap
Also, what setup screen are you talking about? Your image doesn't load for some reason
Thanks!
   #26
gokarty
C?ID=401142
DV52
C?ID=194404
gokarty: hmm....... you may be misunderstanding what "Priority 4" means. DTC s have 6 x Priority levels: Priority 1 is the highest - Priority 6 is the lowest. So, viewed from the opposite end - your DTC is two-up from trivial (no offense intended)!;)
   #28
I need to be connected to the car via the cable right to get this information? Because currently I'm not connected right now and the shop name is blank and all other numbers (WSC/VZ/Equipment) are all zero
That means your tester is not setup properly yet because you didn't RTFB.
I believe the USB is all that will need to be hooked up to the computer to configure VCDS but it would be best to have plugged into battery voltage on DLC port.
   #29
No, you do not need to be connected to your car or even your cable.
Shop Name: Put any name you like, such as "gokarty". This is never sent to the car.
WSC, put your ZIP code (provided it's less than 65535)
VZ/Importer, put: 444 (correct for all US dealers)
Equipment Number, put: the last five digits of your H11-nnnnnn serial number.
Since there are modules that block any of the defaults in VCDS, the idea here is to get some semblance of randomness that VW can't block.
Then click [Save] and exit VCDS. Re-start VCDS and make sure your inputs are on the above screen.
My personal opinion is that this won't help with your Kessy fault, but hey, it doesn't cost much to try.
In fact, I'm not sure this is a good idea at all, because if you then re-code your Kessy module with the same value that's already in there, the new WSC and Equipment number will be stored in there and your dealer (and VW) will be able to tell someone has been playing with this module.
That means your tester is not setup properly yet because you didn't RTFB..
Depends what a person is doing, Jack. On a brand-new car, if one wishes to be stealthy and not leave tracks, it's actually better not to mess with those values unless it's absolutely necessary.
Well being stealthy implies hiding. :D
Me personally I think fair is fair, if you are in there, you should be with full disclosure, especially if you expect a warranty if messing with stuff.
Why should the dealer or OEM be on hook for your tinkering?
The whole purpose of login of tester credentials was to track repairs/changes between franchises or IRF & to give insight who did what to help with diagnosis testing too.
Hiding tampering of any kind or to deceive or shift a cost responsibility to me seems unfair.
Unlike a factory tester, VCDS permits the WSC to be altered anyway, so the OP could always change the WSC back.
   #32
gokarty
C?ID=401142
Don, the Ross Tech manual mentions that a Priority 4 code affects "drivability" and action must be taken. So the DTC is something that I would prefer to get sorted out.
When I said "high" priority I didn't mean that it's something drastic but more relative
   #33
gokarty
C?ID=401142
This is what the manual/book says:
Note: If you are an individual user or independent mechanic, just leave the WorkShop Code set to "00000". This allows VCDS to operate in �stealth� mode, keeping whatever WSC that was already in the controller. If you are using VCDS at a Dealership, enter your Dealer's Workshop Code. The Work Shop Code is not easily changed once set on this screen. Contact us for advice if you need to do so.
Some control modules do not allow themselves to be Coded with the default 00000 WSC in place. VCDS should prompt you with a message to input non-zero values in such cases. You should NOT make such changes in the Options screen itself.
Also, I am trying to patiently learn. Thanks for your understanding.
   #34
An original factory tester from day one if reading the RTFB & if it was not configured; stated that a tester would not permit coding or a login and or adaption procedure.
   #35
That's correct.
And VAG-COM / VCDS has defaulted to "stealth mode" since day one. :D
"Stealth Mode" is where it tries to put back whatever WSC, Importer, and Equipment Number that was already in the module. This works most of the time, but not always.
My point was that an un-configured factory tester cripples functions and is only for "looking" & not "telling", further being less perfect or inferior than VCDS!
   #37
gokarty
C?ID=401142
Since it's the weekend, I'll give the battery disconnect a shot. In older cars it was just plug the battery in, get a radio code to reset the radio.
Is it the same in these newer Jettas? Or would I need to take it to the dealership/shop for getting all systems back to normal?
Dana, when you mention recalibrate steering sensor, is that something that can be done via VCDS?
   #38
You should not need a radio code. That stuff is smart enough to know it's in the car it belongs to.
gokarty
C?ID=401142
Just did the battery reset. Have multiple warning lights on dash. What do I do now?
Auto Scan below:
Saturday,04,April,2020,22:26:26:39190
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
VIN: 3VWL17AJ2HM299863   License Plate: BATT_RESET
Mileage: 61140km-37990mi   Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 02 03 04 05 08 09 13 15 17 19 25 2B 3C 44 5F 61 75
VIN: 3VWL17AJ2HM299863   Mileage: 61140km-37990miles
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BE    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 4889
   Revision: --H13---
   Coding: 001A0092244400175000
   Shop #: WSC 00066 790 00015
   ASAM Dataset: EV_ECM18TFS02006K906071BE 001009
   ROD: EV_ECM18TFS02006K906071BE.rod
   VCID: 6FBBD54837149D13BA8-803B
17178 - Implausible Data Received from ESP Control Module
          U0416 00 [039] - -
                    Mileage: 61143 km
                    Date: 2020.04.04
                    Time: 00:03:01
                    Engine speed: 1491.25 /min
                    Normed load value: 5.9 %
                    Coolant temperature: 77 ∞C
                    Intake air temperature: 64 ∞C
                    Voltage terminal 30: 12.050 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Readiness: 1010 1101
   Part No SW: 09G 927 158 BC    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3114
   ROD: EV_TCMAQ250031_002_VW26.rod
   VCID: 75B7E7205548A7C3704-8021
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B400C492B0003851302EA921C004100F0F01A
   Shop #: WSC 00066 790 00295
   VCID: 75B7E72055C8A7C3704-8021
                    Reset counter: 221
                    Mileage: 61143 km
                    Date: 2020.04.04
                    Time: 00:03:00
                    Count: 16386
                    Count: 12
                    Count: 29184
                    Count: 297
                    Count: 43520
                    Count: 254
                    Count: 10496
                    Reset counter: 221
                    Mileage: 61143 km
                    Date: 2020.04.04
                    Time: 00:03:10
                    Count: 2
                    Count: 12
                    Count: 29184
                    Count: 16390
                    Count: 48896
                    Count: 254
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0418626241
   Coding: 032C0C
   Shop #: WSC 12345 123 61029
   VCID: 392F2B1039D003A354C-806D
12715520 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 221
                    Mileage: 61142 km
                    Date: 2020.04.04
                    Time: 21:30:29
   Part No SW: 1K8 907 044 CL    HW: 1K8 907 044 CL
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 0050019002
   VCID: 7BA3F118736CF1B3060-802F
   Part No SW: 7E0 937 190 B    HW: 7E0 937 190
   Component: BCM PQ25 Max3 H81 0744
   Revision: B8081001    Serial number: 88003324160043
   Coding: 7B994B9A08AB0B000939268024C886C54BC6720E60A571F0B0A050032844
   VCID: 2B030158C30CA133D60-807F
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 051016 04  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 DF    HW: 6R0 959 801 DF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  022 1467
   Serial number: 14102743161111040253
   Coding: 820000
   Subsystem 3 - Part No SW: 6R0 959 802 DJ    HW: 6R0 959 802 DJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  022 1467
   Serial number: 14102742161107144632
   Coding: 820000
   Subsystem 4 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST00183XGP00000
   Coding: 180000
   Subsystem 5 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B
   Serial number: 2771623205202400AF1B
   Coding: 2C0000
   Subsystem 6 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14102745161111130501
   Subsystem 7 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14202744161107074551
01800 - Light Switch (E1)
                    Reset counter: 5
                    Mileage: 61142 km
                    Date: 2020.04.04
                    Time: 21:38:46
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 24111604380638
   Coding: 01005002FE0779
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: 3635202C08CEECDBB9E-8063
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 221
                    Mileage: 61143 km
                    Date: 2020.04.04
                    Time: 00:03:01
                    Control Module temperature: 44 ∞C
                    Voltage terminal 15: 11.8 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s≤
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 221
                    Mileage: 61143 km
                    Date: 2020.04.04
                    Time: 00:03:01
                    Voltage terminal 15: 12.0 V
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 221
                    Mileage: 61143 km
                    Date: 2020.04.04
                    Time: 00:03:01
                    Voltage terminal 15: 11.9 V
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM09RC9D
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 6393A978EBDC29732E0-8037
   Serial number: IBH0000000000063C6NA
   Coding: 303146
   Subsystem 2 - Part No SW: -----------    HW: 480 002 510 16
   Serial number: 3570000000075D84DE1.
   Subsystem 3 - Part No SW: -----------    HW: 480 002 510 16
   Serial number: 3580000000094784DE1X
   Subsystem 4 - Part No SW: -----------    HW: 480 020 810 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001B72303C93847-
   Subsystem 5 - Part No SW: -----------    HW: 480 020 810 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001B72303C93883.
   Subsystem 6 - Part No SW: -----------    HW: 480 022 710 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001C1223536345FW
   Subsystem 7 - Part No SW: -----------    HW: 480 022 710 16
   Component: FrontSensor_P  000 0189
   Serial number: 35600019D22AFFC6626R
   Part No SW: 5C6 920 976 D    HW: 5C6 920 976 D
   Component: KOMBI         H02 1104
   Coding: 221A010000
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 333319381BBCF9F39E0-8067
   Part No SW: 7E0 909 901     HW: 7E0 937 190
   Component: GW-K-CAN TP20 H81 0744
   Revision: B8081001
   Coding: 102203
   VCID: 6889BE54127A4A2BFB2-803D
   Component: IMMO          H02 1104
   Coding: 000007
   Shop #: WSC 00066 790 00318
   VCID: 6A8DC45C0CF6783BED6-803F
   Revision: 00000000    Serial number: 16000164262007
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW31.rod
   VCID: 313F1330E1A0CBE3ECC-8065
   Serial number: 0419928869
   Coding: 01011101
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C21320436E2368B4FA-8069
   Component: HRE_Slave  H12 0071
   Serial number: 0417102021
   Coding: 010111
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F2B10355003A354C-806D
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 8.7 V
                        PD
                    Temperature: 37.0∞C
                    Count: 2
                    Steering Angle: 0.00∞
                    Count: 1
                        SteerAng n.Init
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H31 0359
   Serial number: VWZAZ2S0626354
   Coding: 02630102BE00000051220001001808009F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2411EA64AE526E4B17A-8071
   Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
   Part No SW: 7E0 907 534     HW: 7E0 937 190
   Component: Batt.regelung H81 0744
   Coding: 01240859
   Shop #: WSC 45359 001 1048576
                    Date: 2020.04.04
                    Time: 00:00:00
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0160
   Serial number: 000003554140557
   Coding: 02630102C24232107F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 1471BAA47EF21ECBE7A-8041
End----------(Elapsed Time: 01:43, VBatt start/end: 13.7V/13.8V)-----------
   #40
gokarty
C?ID=401142
SOLVED! and possible bug in VCDS?
Uwe, Jack, Dana, Don thank you very much for all your help. Honestly, I do not know if "battery Jesus" did the trick but heres what I did to solve it:
1) Battery Disconnected for 10 min
2) Battery Reconnected
3) Drove 10 miles on highway, all dash warning lights turned off automatically
4) Got back from road, connected VCDS, kessy fault still present and would not clear
5) Noticed possible bug: In central Electric, when I used VCDS to implement Dana's factory coding, the long coding had the bit "Auto Unlock" and "Auto Lock" set to 0. So following Dana's suggestion, I set both to 1. But! Channel 3 and Channel 4 in adaptations for central electric, still had the value 0 ! Both those channel control the Auto lock and unlock, they should have matched the long coding! (Right?)
6) So, I set the Channel 3 and Channel 4 values accordingly to match the long coding
7) Did another battery disconnect
8) Drove again on highway until dash warnings went away
9) Came back and and VCDS clears the KESSY DTC
[Note: I am using the latest VCDS version]
Auto-Scan below:
Saturday,04,April,2020,23:53:03:39190
VIN: 3VWL17AJ2HM299863   License Plate: REFRENCE_SCAN
Mileage: 61170km-38009mi   Repair Order:
VIN: 3VWL17AJ2HM299863   Mileage: 61170km-38009miles
   Revision: --H13---
Readiness: 1110 1101
   Revision: 00H46001
   Coding: 032C0C
   Revision: 00001K05
   Coding: 0050019002
   Coding: 0228DD
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 2C0000
   Coding: 303146
   Coding: 221A010000
   Revision: B8081001
   Coding: 102203
   Coding: 000007
   Coding: 01011101
   Coding: 010111
   Revision: 00H22000
   Coding: 01240859
End----------(Elapsed Time: 01:39, VBatt start/end: 13.9V/13.9V)-----------
