Retrofitting 12-button MK6 steering wheel in place of 8-button MK5 steering wheel
NitrousOxide
Jamaica
C?ID=269481
I just swapped a 12-button MK6 Golf steering wheel in place of my 8-button MK5 Golf steering wheel. The swap went well, and all 12 buttons work. My issue is that the horn button does not work. I had swapped over the steering wheel control module from the stock ***AQ model to the ***CD model as it supports lin 1.3 and 2.0. I also replaced my old revision-C clock-spring with a new one as I wanted to ensure I had no wiring issues due to a previous airbag related fault in my old steering wheel (which appears to have now gone). I didn't make any coding changes to the new steering wheel control module, as I noticed a new fault in some modules about not being able to see the steering angle sensor (although the steering assistance "feels" fine). I had disconnected the main battery during the swap since I was replacing the driver's airbag.
Here is the AUTOSCAN after the swap with the new steering wheel and second-hand control module with airbag (however horn does not work).
Friday,27,March,2020,15:22:39:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078   License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: WVWZZZ1KZ8W111078   Mileage: 191360km-118905miles
04-Steering Angle -- Status: Cannot be reached 1100
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070160
   Shop #: WSC 66565 257 00032
   VCID: 354FD8585CDD5EE746-8060
Readiness: 0110 0001
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 05108020    Serial number: 00001009061622
   Shop #: WSC 04940 001 00001
   VCID: 1C192DFCDF37EFAF59-8048
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor
                    Fault Frequency: 255
                    Mileage: 191365 km
                    Date: 2014.08.18
                    Time: 00:07:27
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900D7A8-8026
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000014002
   Shop #: WSC 12345 123 61029
   VCID: 0021798C9B9F2B4FA5-8054
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus
                    Reset counter: 81
                    Mileage: 191365 km
                    Date: 2020.03.27
                    Time: 00:07:28
   Revision: 00H54000    Serial number: 01000007456322
   Coding: F78F8B270004800047140A001400008000191C075C00010D000000000000
   Shop #: WSC 12345 111 45725
   VCID: 71C72C48683532C75A-8024
   Component: Wischer 300807 021  0501
   Coding: 00039861
   Shop #: WSC 12345
   Component: RLS     130907 046  0204
   Coding: 00208933
   Shop #: WSC 12345
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86A78E-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
00589 - Airbag Igniter 1; Passenger Side (N131)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001632
   VCID: 76CD1F54015B15FF8F-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H06 0010
   Coding: 00000131
   Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
   Component: KOMBI         H04 0617
   Coding: 170C01
   VCID: 3851D16C83CFA38F5D-806C
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 030312F2002329
   Coding: 350001
   VCID: 3A55CB64B5C3B19FAB-806E
                    Reset counter: 81
                    Mileage: 191365 km
                    Date: 2014.08.18
                    Time: 00:07:38
   Component: IMMO          H04 0617
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AF53B248DE3C11F1B-803E
   Component: Tuer-SG         006 120B
   Coding: 0000560
   VCID: 3851D16C4BCFA38F5D-806C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 207    3305
   Revision: 00H22000
   Shop #: WSC 00028 028 00001
   VCID: 3753D25046D1ACF754-8062
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 191365 km
                    Date: 2014.08.18
                    Time: 00:07:38
                    Battery Volts: 13.6 V
                        DU
                    Temperature: 40.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Coding: 98900A085103007F42000F0FF0CA5A0610BC40
   VCID: 032B768042893057B8-8056
                    Reset counter: 81
                    Mileage: 191365 km
                    Date: 2014.08.18
                    Time: 00:07:39
   Coding: 0000564
   VCID: 3957D46870C5BA87A2-806C
   Part No: 1T0 907 357
   Coding: 0000003
   Shop #: WSC 00000 785 00200
   VCID: 74C9255C172707EFB1-8020
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3180243
   Coding: 00000401000005
   VCID: 63EB560062C99057D8-8036
                    Reset counter: 81
                    Mileage: 191365 km
                    Date: 2014.08.18
                    Time: 00:07:42
02633 - Antenna for Satellite Tuner
                    Reset counter: 81
                    Mileage: 191365 km
                    Date: 2014.08.18
                    Time: 00:07:42
                    Reset counter: 81
                    Mileage: 191365 km
                    Date: 2014.08.18
                    Time: 00:07:42
                    Reset counter: 81
                    Mileage: 191365 km
                    Date: 2014.08.18
                    Time: 00:10:51
End-------------------------(Elapsed Time: 01:24)--------------------------
Here is the AUTOSCAN prior to the swap with the horn working on my 8-button steering wheel, but original clock-spring and steering wheel control module
Friday,07,February,2020,06:36:12:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ8W111078   Mileage: 190190km-118178miles
77-Telephone -- Status: Sporadic communication error 1000
   VCID: 354FD8585CDD5EE744-8060
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:14
                    RPM: 823 /min
                    Load: 28.2 %
                    Temperature: 89.0°C
                    Temperature: 57.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.589 V
Readiness: 0110 0101
   VCID: 1C192DFCDF37EFAF5B-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900D7AA-8026
7 Faults Found:
   Revision: 00001004
   Coding: 0000014002
   VCID: 0021798C9B9F2B4FA7-8054
                    Reset counter: 243
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:07
   Coding: F78F8B270004800047140A001400008000197E075C00010C000000000000
   VCID: 71C72C48683532C758-8024
   Coding: 00039861
   Shop #: WSC 12345
   Coding: 00208933
   Shop #: WSC 12345
01502 - Bulb for Rear Fog; Left (L46)
                    Fault Status: 01101100
                    Reset counter: 243
                    Mileage: 190182 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.20 V
   Coding: 0013121
   VCID: 3D5FC07864ED86A78C-8068
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012122
   VCID: 01277C8858952247A8-8054
   Coding: 170C01
   VCID: 3851D16C83CFA38F5F-806C
   Coding: 350001
   VCID: 3A55CB64B5C3B19FA9-806E
                    Reset counter: 27
                    Mileage: 190187 km
                    Date: 2020.02.07
                    Time: 04:50:41
   VCID: 6AF53B248DE3C11F19-803E
   Coding: 0000564
   Shop #: WSC 11111 111 45799
   VCID: 3851D16C4BCFA38F5F-806C
00109 - Left Mirror Turn Signal Lamp (L131)
   Revision: 00H22000
   VCID: 3753D25046D1ACF756-8062
                    Fault Status: 11100101
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:19
                        DU
                    Temperature: 44.0°C
                    Count: 3
                    Count: 1
                        SteerAng n.Init
   Coding: 98900A085103007F42040F0FF00A5A0690BC00
   VCID: 032B768042893057BA-8056
                    Reset counter: 242
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:19
   Coding: 0000564
   VCID: 3957D46870C5BA87A0-806C
   Coding: 0000003
   VCID: 74C9255C172707EFB3-8020
   Coding: 01000401000005
   VCID: 63EB560062C99057DA-8036
                    Reset counter: 242
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:21
                    Reset counter: 242
                    Mileage: 190182 km
                    Date: 2020.02.07
                    Time: 04:28:21
                    Reset counter: 242
                    Mileage: 190185 km
                    Date: 2020.02.07
                    Time: 04:45:08
Address 77: Telephone
End-------------------------(Elapsed Time: 01:29)--------------------------
Can someone please suggest suitable coding for me, as I forgot to look at the configuration from my previous steering wheel configuration information before I pulled the module from the vehicle.
golfi_vend
Tartu, Estonia
C?ID=195131
Your old module had G85 sensor built in. Your current CD doesn't.
Luckily You have a gen3 zf steering rack with built in sensor. Check the adaptions there and turn on steering rack internal sensor.
NitrousOxide
Jamaica
C?ID=269481
Thanks, I'll try it when next I get to the car.
Do you have any suggestions on my non functioning horn?
golfi_vend
Tartu, Estonia
C?ID=195131
Is wiring correct?
You may wanna look at Measuring Values in Module 16 if SWCM sees signal from MFSW-module. And then MVB in 09 module if they are transmitted from SWCM(16) module.
NitrousOxide
Jamaica
C?ID=269481
Thanks Golf_vendi, I forgot o mention that my horn actually started working perfectly without me having to do anything else. All 12 buttons on my steering wheel also work perfectly as well.
dieseltje
The Netherlands
C?ID=148044
You should swap slib ring to newer type
To 1K0959653C
Edit
This evening new try with slib ring extention C
Again same problem.
We took the slib ring from a 2008 golf5
Old slib ring was exact the same part number
dieseltje
The Netherlands
C?ID=148044
Conclusion
We used the wrong steering electronics.
With also extention CD. This has to be the version with extention CH. That one does support G85 sensor.
NitrousOxide
Jamaica
C?ID=269481
I'm happy to hear that you've found the root cause for your issues.
Were you able to source and fit a suitable replacement as yet?
dieseltje
The Netherlands
C?ID=148044
Two days later we changed the module. All is now working as should be. We only had one other obstackle. The Cruiseconrol wasn't funcitoning anymore.
After some searching it was clear that the stalk wasn't defect, but wiring has changed.
We changed wiring to new version and also that obstackle was behind us. Now happy mate with his Golf5 GTI
