Hi,
I'm looking to buy the HEX-V2 for my 2017 NAR VW Jetta SEL (MK 6 Face Lift)
But before purchasing is there any way of getting sample screenshots of how many bits are actually labeled in the long coding helper along with which adaptation channels I can modify? The reason I ask is because I have had a bad experience in the past with another device so wanted to be sure that I can actually use the cable and not have a bunch of unlabeled bits where I can't modify anything with confidence
Also, could someone guide me if the following is actually possible:
I have to often go through a security checkpoint and the DRLs on the 2017 Jetta are causing problems for me since Im required to turn them off but I can't turn them off through MFD like the GLI owners since my BCM is PQ25
I read that I can bend the TFL pin and/or use VCDS to turn off DRL but I like the DRL and it's safety features so I was wondering if it's possible to only have them off when the light switch is in 0
Thank you very much!
Kind Regards,
gokarty
Kind Regards,
gokarty
