Audi a4 b7 wastegate help
audi4ever
Hi everyone I bought a project b7 2.0t with a broken timing belt, everything went well.now as I was inspecting the turbo before I install it . I applied pressure to the wastegate and the wastegate slowly creeps back.is it suppose to? Or is it suppose to hold? I used a hand held vacuum pump .I also made sure connections were tight . Ty so much and have a great day😊😊
Moving to General VW/Audi Repair.
United States
The wastegate should have held the pressure in my opinion because the system dumps/vents that pressure back off via N75.
HMC
C?ID=28246
Hi audi4ever,
Are you sure your vacuum pump is ok and holding vacuum?
Regards HMC
audi4ever
When I plug my vacuum with my finger it holds well,but also know, it's not vacuum I'm using it's pressure,anything I could do to test the pressure side of my vacuum?
HMC
C?ID=28246
You could connect it to a low pressure gauge and see what happens.
Regards HMC
audi4ever
Hi I used the same vacuum pump on my sons wastegate , his A5 , cuz he was doing a service on it and I just happen to be there .his wastegate did hold, unlike the one in my B7 2.0 T.so is my diaphram torn you think? I apply pressure to it, then it slowly retracts.
