Hi,
I fitted towbar 5G9 803 881 F and other parts. Installation checked.
Does anyone know why led for release hitch doesn't work? Wrong coding? In VCDS no errors.
On the photos I showed what I mean.
Below photos and autoscan.
BR
Pumpkin
BR
Pumpkin
Tuesday,24,March,2020,18:55:56:00732
VCDS Version: 19.6.2.2 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZAUZJP509107 License Plate: WR7738W
Mileage: 31273km-19432mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 36 39 3C 42 44
4B 52 5F 69 6C A5 D6 D7
VIN: WVWZZZAUZJP509107 Mileage: 31273km-19432miles
Address 01: Engine (J623-DGCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EM HW: 04L 907 309 R
Component: R4 2.0l TDI H24 4027
Revision: B5H24---
Coding: 01250032037605083000
Shop #: WSC 45711 002 104857
ASAM Dataset: EV_ECM20TDI01104L906026EM 004003
ROD: EV_ECM20TDI01104L906026LP.rod
VCID: F9BA68F278DB0E8762-80AC
Part No SW: 0GC 300 011 N HW: 0GC 927 711 G
Component: GSG DQ381 H06 0708
Revision: 00H06V07
ROD: EV_TCMDQ381061_VW37.rod
VCID: AD128CA2FC136227BE-80F8
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 61657000000956
Coding: 43FA62A1342009754778070040CA29C2462C90E2E002947D38625078E289430000010312121212B435351919323200
VCID: F7BE6ECA4ECF18F714-80A2
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0443027861
Coding: 032C0C
VCID: BC34B1E63769FBAF39-80E8
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0202010420211001100500000010102A
Shop #: WSC 00028 028 00068
VCID: ED924CA23C93A227FE-80B8
Air quality sensor:
Part No SW: 5Q0 937 086 BL HW: 5Q0 937 086 BG
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 8658080617008P
Shop #: WSC 00028 028 00202
ROD: EV_BCMBOSCH_018.rod
VCID: 8542140204237A6716-80D0
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170512 043 0551
Serial number: 170530053838
Component: RLHS 042 0105
Serial number: S3Y17M06D13H11M03S00
Coding: 00A8DD
Serial number: 000000000ZY171383C1F
Serial number: 00000000000069795533
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417616344
Coding: 0271167A51
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: D0ECF5568BE16FCFF5-8084
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 331D67E995FFCF28949C810580400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: BE30BBEE2175E9BF17-80EA
Part No SW: 5Q0 959 655 BH HW: 5Q0 959 655 BH
Component: AirbagVW21 005 0336
Serial number: 003VVR31DP9E
Coding: 98CCC000000000005C0000CF000800000065
Shop #: WSC 00028 028 00060
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 875E1E0A3E2F687764-80D2
Subsystem 1 - Part No SW: ----------- HW: 480 001 106 17
Serial number: 357000000004E665F42S
Subsystem 2 - Part No SW: ----------- HW: 480 001 006 17
Serial number: 3580000000017B7D452N
Subsystem 3 - Part No SW: ----------- HW: 480 401 306 17
Serial number: 3510001BD260B432223Q
Subsystem 4 - Part No SW: ----------- HW: 480 401 306 17
Serial number: 3520001C72522C16262R
Subsystem 5 - Part No SW: ----------- HW: 480 401 206 17
Serial number: 3550001B1260B43331FV
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170609300212
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 844409060F19436F01-80D0
Part No SW: 5G1 920 751 C HW: 5G1 920 751 C
Component: KOMBI 302 0310
Coding: 07A4201B6F8C000801882B0B5401000000000000
VCID: A81C7DB6D3F1470F4D-80FC
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 03061710520866
Coding: 0B0100345F086800DB00225A1E0F00010001070000000000000000000000
Shop #: WSC 64239 001 1048576
ROD: EV_GatewNF.rod
VCID: B3269ADA1A3734D7E8-80E6
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 46170001521250107233
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 5716414104
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 HW: 5Q0 907 155
Component: U13DCAC H25 0790
Serial number: 0003589
Serial number: HA1-00028.04.17
Coding: 0001
VCID: CAD8E73E6DBD551FBB-809E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
VCID: C7DEDE0A7EAFA877A4-8092
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000154921010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: B42499C61F3933EFF1-80E0
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H05 0022
Serial number: Y0006QE522662
Coding: 001000020000050081C280808080000000008181000000F400
Shop #: WSC 01730 666 28888
ASAM Dataset: EV_SeatMemorDriveSide 002021
VCID: BA38B7FE3D5DC59F2B-80EE
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0403694986
Coding: 02032103
ROD: EV_HREntryHella_VW37.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0403543451
Coding: 020321
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000260307237
Coding: 003B1220DE00020000001000
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000005904935
Coding: 110000
Component: EPS_MQB_ZFLS 129 1072
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
VCID: C5C2D40244A3BA6756-8090
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 29051710521833
Coding: 000000050100195200100F40020000000000000000000000000000000000
VCID: F2A85FDE25AD7DDF23-80A6
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000262773063
Coding: 003B1020DE00020000801000
VCID: C6C0D30E79A5B17F5F-8092
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000005991910
Coding: 090000
Part No SW: 3Q0 035 824 C HW: 3Q0 035 824 C
Component: MU-S--ER H41 0449
Serial number: VWZAZ2T1402668
Coding: 02731200FF0000005111000100080A001F0508C40120050003
ROD: EV_MUStd4CTSAT_VW37.rod
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJT1640281
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0509730500
Coding: 0100000202000000
Shop #: WSC 40431 004 104857
VCID: C2C8CF1E558D8D5F73-8096
Component: RVC Compact H12 0231
Coding: 01840201A3002017000040
VCID: B93AA8F2385BCE8722-80EC
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 100
Mileage: 31273 km
Date: 2020.03.24
Time: 18:43:49
passive
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 07081712P22956
Coding: 000307020000040100262054C156890090000E200020
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 02:04, VBatt start/end: 12.4V/12.4V)-----------
