VW TRANSPORTER 2008 T5 2.5TDI NO POWER AND VIBRATIONS UNDER LOAD.
Gapel3
Australia
C?ID=313356
Hi guys.
could any one help?
cheers
Tuesday,24,March,2020,12:42:47:39620
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: WV1ZZZ7HZ8H047706   License Plate: CS76AQ
Mileage: 284600km-176842mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H047706   Mileage: 284600km-176842miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 DQ    HW: 070 906 016 DQ
   Component: R5 2,5L EDC G000SG  1583
   Revision: --H05---    Serial number: VWZ7Z0G5746272
   Coding: 0051172
   Shop #: WSC 02736 790 00000
   VCID: E288F0DD3CD5F55F53-513C
               P0299 - 000 - Control Range Not Reached - Intermittent
                    Mileage: 284301 km
                    RPM: 2016 /min
                    Speed: 44.0 km/h
                    Load: 100.0 %
                    Voltage: 13.83 V
                    Bin. Bits: 00101100
                    Absolute Pres.: 2315.4 mbar
                    Absolute Pres.: 1723.8 mbar
Readiness: 0 1 0 0 0
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
   Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
   Component: ESP MK25E1          0104
   Revision: 00H31001
   Coding: 0001634
   VCID: C4C4164586019B6F41-5118
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 R
   Component: CLIMA/AC            0202
   VCID: B4244685D6A12BEFF1-5118
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 AD
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000101
   VCID: F4A4868596216BEF31-5118
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
   Part No: 1C0 909 605 F
   Component: 0T AIRBAG VW61 0R   0004
   Coding: 12372
   Shop #: WSC 02736
   VCID: A71EA1C94777507744-5118
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 851 R
   Coding: 00722
   Shop #: WSC 00001
   VCID: BA3868BDA4C5DD9F2B-5118
   WV1ZZZ7HZ8H047706     VWZ7Z0G5746272
            30-00 - Open or Short to Plus
   Part No: 6N0 909 901
   Coding: 00022
   Shop #: WSC 02736
   VCID: F0AC8A95B23957CFD5-5118
Address 22: AWD        Labels: 7H0-907-554.clb
   Part No: 7H0 907 554 F
   Component: HALDEX 4Motion      2110
   Coding: 0000002
   VCID: B3264599D3AF2CD7E8-5118
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C11 Komfortgerát     0004
   Coding: 00031
   Shop #: WSC 02736
   VCID: B228409D7CB525DFE3-4B00
Address 76: Park Assist        Labels: 7H0-919-283.lbl
   Part No: 7H0 919 283
   Component: Parkingsyst. T5 T5N 401
   Coding: 00137
   Shop #: WSC 02736
   VCID: EFAE89E9AF074837CC-513C
01545 - Sensor for Parking Aid; Rear Left (G203)
            37-00 - Faulty
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
            37-00 - Faulty
End----------(Elapsed Time: 05:54, VBatt start/end: 14.0V/14.0V)-----------
HMC
C?ID=28246
Hi Gapel3,
What have you done to check for boost pressure leaks?
Regards HMC
Gapel3
Australia
C?ID=313356
One injector is new,had to change it.I checked exhaust dpf,boost sensor ,new n75 new differencial pressure sensor....turbo is boosting but seems to be to late and too long getting over boost on graf but no faults just one which i posted it.
check for boost leak no leak.
Uwe what to look for in group 11?
Gapel3
Australia
C?ID=313356
chanell 011 ENGINE 798/min boost pressure(specified)1009.8mbar boost pressure (actual) 1020 mbar charge pressure control duty cycle 75.4%
Gapel3
Australia
C?ID=313356
WHAT AM I LOOKING FOR ...DIFFERENCE BETWEEN SPEC AND ACTUAL
Yes, how actual behaves in relation to spec.
Gapel3
Australia
C?ID=313356
got log but not sure how to transfer ower here....on test drive asking for more boost as creates...other hand it good ...low rpm its feels like turbo kick in to late around 1800-2100rpm. i know u send me how to post logs here but seems to be to complicated
Those logs are just text files. Right-click on one of them, Open with Notepad, then copy the contents in-line here, same as the Auto-Scan in your first post.
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, when I look at the Freeze Frame, it does not indicate any boost pressure. Are all relevant vacuum hoses attached? The turbocharger is a VTG charger, it needs negative pressure to build up the boost pressure. You also wrote that you replaced the boost pressure control valve. Have you accidentally swapped the hoses?
Gapel3
Australia
C?ID=313356
Friday,27,March,2020,15:26:00:39620-VCID:E288F0DD3CD5F55F51-513C,VCDS Version: Release 19.6.2 (x64),Data version: 20190930 DS308.0
070 906 016 DQ,,R5 2.5L EDC G000SG  1583,
,Group A:,'011,,,,Group B:, Not Running,,,,Group C:, Not Running
,,Engine Speed,Boost Pressure,Boost Pressure,Charge Pressure,,,,,,,,,,
,TIME,(G28),(specified),(actual),Control Duty Cycle,TIME,,,,,TIME,,,,
Marker,STAMP, /min, mbar, mbar, %,STAMP,,,,,STAMP,,,,
,0.01,798,1009.8,1081.2,75.4,,,,,,,,,,
,0.27,798,1009.8,1081.2,75.4,,,,,,,,,,
,0.53,798,1009.8,1081.2,75.4,,,,,,,,,,
,0.80,798,1009.8,1081.2,75.4,,,,,,,,,,
,1.06,798,1009.8,1081.2,75.4,,,,,,,,,,
,1.32,798,1009.8,1081.2,75.4,,,,,,,,,,
,1.59,798,1009.8,1081.2,75.4,,,,,,,,,,
,1.86,798,1009.8,1081.2,75.4,,,,,,,,,,
,2.12,798,1009.8,1081.2,75.4,,,,,,,,,,
,2.39,798,1009.8,1081.2,75.4,,,,,,,,,,
,2.66,798,1009.8,1081.2,75.4,,,,,,,,,,
,2.92,798,1009.8,1081.2,75.4,,,,,,,,,,
,3.19,798,1009.8,1081.2,75.4,,,,,,,,,,
,3.45,798,1009.8,1081.2,75.4,,,,,,,,,,
,3.71,798,1009.8,1081.2,75.4,,,,,,,,,,
,3.99,798,1009.8,1081.2,75.4,,,,,,,,,,
,4.26,798,1009.8,1081.2,75.4,,,,,,,,,,
,4.52,798,1009.8,1081.2,75.4,,,,,,,,,,
,4.79,798,1009.8,1081.2,75.4,,,,,,,,,,
,5.05,798,1009.8,1081.2,75.4,,,,,,,,,,
,5.32,798,1009.8,1081.2,75.4,,,,,,,,,,
,5.58,882,1295.4,1081.2,75.4,,,,,,,,,,
,5.85,1470,1417.8,1091.4,73.4,,,,,,,,,,
,6.11,2058,1693.2,1142.4,63.9,,,,,,,,,,
,6.38,2709,2131.8,1315.8,19.7,,,,,,,,,,
,6.64,2898,1132.2,1550.4,19.7,,,,,,,,,,
,6.91,2898,1132.2,1234.2,47.3,,,,,,,,,,
,7.18,2898,1132.2,1132.2,49.7,,,,,,,,,,
,7.44,2898,1142.4,1132.2,52.1,,,,,,,,,,
,7.71,2898,1152.6,1142.4,53.7,,,,,,,,,,
,7.97,2898,1142.4,1162.8,50.5,,,,,,,,,,
,8.23,2898,1142.4,1162.8,50.5,,,,,,,,,,
,8.50,2898,1132.2,1173.0,47.7,,,,,,,,,,
,8.77,2898,1132.2,1173.0,48.5,,,,,,,,,,
,9.03,2898,1142.4,1173.0,48.1,,,,,,,,,,
,9.30,2898,1132.2,1173.0,46.2,,,,,,,,,,
,9.56,2898,1142.4,1173.0,48.5,,,,,,,,,,
,9.83,2898,1132.2,1173.0,45.8,,,,,,,,,,
,10.09,2898,1152.6,1173.0,49.7,,,,,,,,,,
,10.36,2898,1132.2,1173.0,48.5,,,,,,,,,,
,10.62,2898,1142.4,1173.0,48.1,,,,,,,,,,
,10.89,2898,1152.6,1162.8,50.9,,,,,,,,,,
,11.15,2877,1142.4,1173.0,49.3,,,,,,,,,,
,11.42,2898,1122.0,1162.8,46.6,,,,,,,,,,
,11.68,2898,1132.2,1162.8,46.6,,,,,,,,,,
,11.95,2898,1132.2,1162.8,46.9,,,,,,,,,,
,12.21,2667,1081.2,1162.8,36.7,,,,,,,,,,
,12.48,2226,1071.0,1162.8,38.7,,,,,,,,,,
,12.74,1806,1050.6,1122.0,46.6,,,,,,,,,,
,13.01,1470,1030.2,1091.4,59.6,,,,,,,,,,
,13.28,1134,1020.0,1091.4,73.8,,,,,,,,,,
,13.55,819,1009.8,1081.2,75.4,,,,,,,,,,
,13.80,798,1009.8,1071.0,75.4,,,,,,,,,,
,14.07,798,1009.8,1060.8,75.4,,,,,,,,,,
,14.33,798,1009.8,1050.6,75.4,,,,,,,,,,
,14.61,798,1009.8,1050.6,75.4,,,,,,,,,,
,14.95,798,1009.8,1040.4,75.4,,,,,,,,,,
,15.21,798,1009.8,1040.4,75.4,,,,,,,,,,
,15.47,798,1009.8,1040.4,75.4,,,,,,,,,,
,15.74,798,1009.8,1040.4,75.4,,,,,,,,,,
,16.01,798,1009.8,1040.4,75.4,,,,,,,,,,
,16.27,798,1009.8,1030.2,75.4,,,,,,,,,,
,16.54,798,1009.8,1030.2,75.4,,,,,,,,,,
,16.80,798,1009.8,1030.2,75.4,,,,,,,,,,
,17.06,798,1009.8,1030.2,75.4,,,,,,,,,,
,17.33,798,1009.8,1030.2,75.4,,,,,,,,,,
,17.59,777,1009.8,1030.2,75.4,,,,,,,,,,
,17.86,798,1193.4,1030.2,75.4,,,,,,,,,,
,18.13,1218,1642.2,1030.2,75.4,,,,,,,,,,
,18.39,1785,2223.6,1050.6,69.4,,,,,,,,,,
,18.66,2331,2376.6,1142.4,60.4,,,,,,,,,,
,18.92,2856,1356.6,1407.6,36.7,,,,,,,,,,
,19.19,2898,1122.0,1417.8,32.7,,,,,,,,,,
,19.45,2898,1122.0,1193.4,47.7,,,,,,,,,,
,19.72,2898,1132.2,1132.2,50.1,,,,,,,,,,
,19.98,2898,1142.4,1132.2,51.7,,,,,,,,,,
,20.25,2898,1132.2,1142.4,48.1,,,,,,,,,,
,20.51,2898,1142.4,1152.6,48.9,,,,,,,,,,
,20.78,2898,1132.2,1162.8,50.1,,,,,,,,,,
,21.04,2898,1132.2,1162.8,48.9,,,,,,,,,,
,21.31,2898,1132.2,1162.8,49.3,,,,,,,,,,
,21.57,2898,1142.4,1162.8,48.9,,,,,,,,,,
,21.84,2898,1122.0,1162.8,46.9,,,,,,,,,,
,22.10,2898,1152.6,1162.8,49.3,,,,,,,,,,
,22.37,2898,1132.2,1162.8,47.7,,,,,,,,,,
,22.64,2772,1091.4,1162.8,40.6,,,,,,,,,,
,22.90,2310,1071.0,1152.6,38.3,,,,,,,,,,
,23.16,1911,1050.6,1132.2,44.2,,,,,,,,,,
,23.43,1533,1040.4,1101.6,54.8,,,,,,,,,,
,23.70,1197,1020.0,1091.4,72.6,,,,,,,,,,
,23.96,882,1009.8,1081.2,75.4,,,,,,,,,,
,24.22,819,1009.8,1071.0,75.4,,,,,,,,,,
,24.49,798,1009.8,1060.8,75.4,,,,,,,,,,
,24.75,798,1009.8,1050.6,75.4,,,,,,,,,,
,25.02,798,1009.8,1050.6,75.4,,,,,,,,,,
,25.29,798,1009.8,1040.4,75.4,,,,,,,,,,
,25.55,798,1009.8,1040.4,75.4,,,,,,,,,,
,25.82,798,1009.8,1040.4,75.4,,,,,,,,,,
,26.08,798,1009.8,1040.4,75.4,,,,,,,,,,
,26.35,798,1009.8,1040.4,75.4,,,,,,,,,,
,26.61,798,1009.8,1040.4,75.4,,,,,,,,,,
,26.88,945,1305.6,1030.2,75.4,,,,,,,,,,
,27.14,1470,2070.6,1030.2,73.8,,,,,,,,,,
,27.41,2016,2305.2,1081.2,65.5,,,,,,,,,,
,27.67,2562,2407.2,1234.2,55.6,,,,,,,,,,
,27.94,2898,1132.2,1540.2,17.0,,,,,,,,,,
,28.20,2898,1132.2,1305.6,42.6,,,,,,,,,,
,28.47,2898,1132.2,1152.6,50.5,,,,,,,,,,
,28.73,2898,1132.2,1132.2,50.5,,,,,,,,,,
,29.00,2898,1132.2,1142.4,50.9,,,,,,,,,,
,29.26,2898,1122.0,1152.6,48.5,,,,,,,,,,
,29.53,2898,1152.6,1152.6,51.3,,,,,,,,,,
,29.80,2898,1132.2,1162.8,48.9,,,,,,,,,,
,30.06,2898,1132.2,1162.8,49.3,,,,,,,,,,
,30.32,2898,1132.2,1162.8,48.5,,,,,,,,,,
,30.59,2877,1142.4,1162.8,50.1,,,,,,,,,,
,30.86,2898,1142.4,1162.8,49.3,,,,,,,,,,
,31.12,2688,1081.2,1162.8,35.9,,,,,,,,,,
,31.39,2226,1071.0,1162.8,38.7,,,,,,,,,,
,31.65,1848,1050.6,1132.2,45.4,,,,,,,,,,
,31.92,1491,1030.2,1091.4,58.4,,,,,,,,,,
,32.18,1155,1020.0,1091.4,73.8,,,,,,,,,,
,32.45,840,1009.8,1081.2,75.4,,,,,,,,,,
,32.71,798,1009.8,1071.0,75.4,,,,,,,,,,
,32.98,798,1009.8,1060.8,75.4,,,,,,,,,,
,33.24,798,1009.8,1050.6,75.4,,,,,,,,,,
,33.51,798,1009.8,1050.6,75.4,,,,,,,,,,
,33.77,798,1009.8,1040.4,75.4,,,,,,,,,,
,34.04,798,1009.8,1040.4,75.4,,,,,,,,,,
,38.31,798,1009.8,1030.2,75.4,,,,,,,,,,
,38.56,798,1009.8,1030.2,75.4,,,,,,,,,,
,38.83,798,1009.8,1030.2,75.4,,,,,,,,,,
,39.09,798,1009.8,1030.2,75.4,,,,,,,,,,
,39.36,798,1009.8,1030.2,75.4,,,,,,,,,,
,39.62,798,1009.8,1030.2,75.4,,,,,,,,,,
,39.89,798,1009.8,1030.2,75.4,,,,,,,,,,
,40.16,798,1009.8,1030.2,75.4,,,,,,,,,,
,40.42,798,1009.8,1030.2,75.4,,,,,,,,,,
,40.69,798,1009.8,1030.2,75.4,,,,,,,,,,
,40.96,798,1009.8,1030.2,75.4,,,,,,,,,,
,41.22,798,1009.8,1030.2,75.4,,,,,,,,,,
,41.79,798,1009.8,1030.2,75.4,,,,,,,,,,
,42.06,798,1009.8,1030.2,75.4,,,,,,,,,,
,42.32,798,1009.8,1030.2,75.4,,,,,,,,,,
,42.59,798,1009.8,1030.2,75.4,,,,,,,,,,
,42.85,798,1009.8,1030.2,75.4,,,,,,,,,,
,43.12,798,1009.8,1030.2,75.4,,,,,,,,,,
,43.39,798,1009.8,1030.2,75.4,,,,,,,,,,
,43.65,798,1009.8,1030.2,75.4,,,,,,,,,,
,43.91,798,1009.8,1030.2,75.4,,,,,,,,,,
,44.18,798,1009.8,1030.2,75.4,,,,,,,,,,
,44.45,798,1009.8,1030.2,75.4,,,,,,,,,,
,44.72,798,1009.8,1030.2,75.4,,,,,,,,,,
,44.98,798,1009.8,1030.2,75.4,,,,,,,,,,
,45.24,798,1009.8,1030.2,75.4,,,,,,,,,,
,45.51,798,1009.8,1030.2,75.4,,,,,,,,,,
,45.77,798,1009.8,1030.2,75.4,,,,,,,,,,
,46.04,798,1009.8,1030.2,75.4,,,,,,,,,,
,46.30,798,1009.8,1030.2,75.4,,,,,,,,,,
,46.57,798,1009.8,1030.2,75.4,,,,,,,,,,
,46.83,798,1009.8,1030.2,75.4,,,,,,,,,,
,47.10,798,1009.8,1030.2,75.4,,,,,,,,,,
,47.36,798,1009.8,1030.2,75.4,,,,,,,,,,
,47.63,798,1009.8,1030.2,75.4,,,,,,,,,,
,47.89,798,1009.8,1030.2,75.4,,,,,,,,,,
,48.16,798,1009.8,1030.2,75.4,,,,,,,,,,
,48.42,798,1009.8,1030.2,75.4,,,,,,,,,,
,48.69,798,1009.8,1030.2,75.4,,,,,,,,,,
,48.95,798,1009.8,1030.2,75.4,,,,,,,,,,
,49.22,798,1009.8,1030.2,75.4,,,,,,,,,,
,49.48,798,1009.8,1030.2,75.4,,,,,,,,,,
,49.75,798,1009.8,1030.2,75.4,,,,,,,,,,
,50.01,798,1009.8,1030.2,75.4,,,,,,,,,,
,50.28,798,1009.8,1030.2,75.4,,,,,,,,,,
,50.54,798,1009.8,1030.2,75.4,,,,,,,,,,
,50.81,798,1009.8,1030.2,75.4,,,,,,,,,,
,51.07,798,1009.8,1030.2,75.4,,,,,,,,,,
,51.34,798,1009.8,1030.2,75.4,,,,,,,,,,
,51.60,798,1009.8,1030.2,75.4,,,,,,,,,,
,51.87,798,1009.8,1030.2,75.4,,,,,,,,,,
,52.13,798,1009.8,1030.2,75.4,,,,,,,,,,
,52.40,798,1009.8,1030.2,75.4,,,,,,,,,,
,52.67,798,1009.8,1030.2,75.4,,,,,,,,,,
,52.93,798,1009.8,1030.2,75.4,,,,,,,,,,
,53.19,798,1009.8,1030.2,75.4,,,,,,,,,,
,53.46,798,1009.8,1030.2,75.4,,,,,,,,,,
,53.72,798,1009.8,1030.2,75.4,,,,,,,,,,
,53.99,798,1009.8,1030.2,75.4,,,,,,,,,,
,54.25,798,1009.8,1030.2,75.4,,,,,,,,,,
,54.52,798,1009.8,1030.2,75.4,,,,,,,,,,
,54.79,798,1009.8,1030.2,75.4,,,,,,,,,,
,55.05,798,1009.8,1030.2,75.4,,,,,,,,,,
,55.32,798,1009.8,1030.2,75.4,,,,,,,,,,
,55.58,798,1009.8,1030.2,75.4,,,,,,,,,,
,55.85,798,1009.8,1030.2,75.4,,,,,,,,,,
,56.11,798,1009.8,1030.2,75.4,,,,,,,,,,
,56.38,798,1009.8,1030.2,75.4,,,,,,,,,,
,56.64,798,1009.8,1030.2,75.4,,,,,,,,,,
,56.91,798,1009.8,1030.2,75.4,,,,,,,,,,
,57.18,798,1009.8,1030.2,75.4,,,,,,,,,,
,57.44,798,1009.8,1030.2,75.4,,,,,,,,,,
,57.70,798,1009.8,1030.2,75.4,,,,,,,,,,
,57.97,798,1009.8,1030.2,75.4,,,,,,,,,,
,58.23,798,1009.8,1030.2,75.4,,,,,,,,,,
,58.50,798,1009.8,1030.2,75.4,,,,,,,,,,
,58.77,798,1009.8,1030.2,75.4,,,,,,,,,,
,59.03,798,1009.8,1030.2,75.4,,,,,,,,,,
,59.30,798,1009.8,1030.2,75.4,,,,,,,,,,
,59.56,798,1009.8,1030.2,75.4,,,,,,,,,,
,59.82,798,1009.8,1030.2,75.4,,,,,,,,,,
,60.09,798,1009.8,1030.2,75.4,,,,,,,,,,
,60.36,798,1009.8,1030.2,75.4,,,,,,,,,,
,60.62,798,1009.8,1030.2,75.4,,,,,,,,,,
,60.89,798,1009.8,1030.2,75.4,,,,,,,,,,
,61.15,798,1009.8,1030.2,75.4,,,,,,,,,,
,61.42,798,1009.8,1030.2,75.4,,,,,,,,,,
,61.68,798,1009.8,1030.2,75.4,,,,,,,,,,
,61.95,798,1009.8,1030.2,75.4,,,,,,,,,,
,62.21,798,1009.8,1030.2,75.4,,,,,,,,,,
,62.48,798,1009.8,1030.2,75.4,,,,,,,,,,
Was the above data collected under load, or was it done in neutral, without any real load on the engine?
Gapel3
Australia
C?ID=313356
Gapel3
Australia
C?ID=313356
what u mean accidentally?i had this issue before cos of this so didnt make difference...all hose attached no boost leak confirm
Gapel3
Australia
C?ID=313356
was stationary no while driving
ai_Ingo
C?ID=56975
I meant that it can happen quickly that you make a mistake when connecting the hoses. I probably hadn't read correctly and overlooked the fact that your problem existed before you replaced the valve, please excuse me.
ai_Ingo
C?ID=56975
I would maybe first look with a vacuum pump and an external hose to see if the vacuum holds on to the turbocharger and whether the linkage moves slightly to the stop. If so, please drive with the external hose and the vacuum pump. If the boost pressure then rises and the power is there, then you at least know that the turbocharger is mechanically correct and all charge air pipes and hoses do not lose pressure.
NostraJackAss
At idle you should be able to manipulate the WG arm with a mighty vac and see the deviation and then have a second tech under load actuate and again the log should show in VCDS.
This looks to be a weak air motor or sticky WG VNT not a boost leak.
I would watch the VNT air motor for full range and possible lubricate and clean, they often rust or carbon up.
If so it can be removed from air motor in or out of vehicle and exercised with a fine lubricant then cleaned and a basic setting made of jam nut performed as per the RTFB.
Additionally if a shaft is sheared on turbo charger it could be doing this too in a log or as described symptom!
To verify the turbo shaft turbines, the exhaust will need to be removed and the inlet boot to verify the the shaft is with integrity.
If lubricating exhaust manifold and turbo components, make sure they are clean and dry so no fires can be had during burn off!
