2013 Golf VI GTI OEM LED with rear foglight
cochino2000
C?ID=182041
Hello
I have a 2013 Golf VI GTI with DRL, OEM Halogen headlights and OEM taillights. I also have the (front fog and rear fog) OEM switch installed.
I will install the OEM LED Taillights with rear fog light.
Now I need some help with the coding and wiring.
I did the retrofit with the DIY from the VWVortex on my 2012 Golf R
http://forums.vwvortex.com/showthread.php?5552288-Notes-on-LED-Tail-Rear-Fog-Install
Is the coding and wiring the same like with a Golf VI R?
Can someone confirm if this will work for the Golf VI GTI or if I am wrong?
Any help would be appreciated.
Cheers
Torsten
Auto scan :
Saturday,29,March,2014,14:26:11:00778
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWFV7AJ9DW121883   License Plate: DETLEF GTI 2
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AS    HW: 1K0 907 115 AA
   Revision: AAH18---    Serial number:
   Coding: 0403010A1C070160
   VCID: 77FD319A06CE4EA6AAD-8022
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3513
   Revision: 05651213    Serial number: 00001212041632
   VCID: 275D21DA96EE1E26FAD-8072
   Revision: 00H31001
   Coding: 114B600C492400FB881306EC921C0041B70800
   VCID: 7DF123B2E4F264F6F01-8028
Address 08: Auto HVAC (J301)       Labels: 7N0-907-426.clb
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010002002
   ROD: EV_ACManueBHBVW36X_SE36.rod
   VCID: 7BF52DAAF2E66AC6CE5-802E
   Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
   Component: BCM PQ35  M   111 0709
   Revision: AC111709
   Coding: 6F180A1A90272A04008800C17000054448010386534D8D60648020200040
   VCID: 41899F42D88AC016D49-8014
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 12121  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R0147L2
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C77EEB6B768ADFE87F-8069
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00004VYU00
   Serial number: 3572MSME61725375ZZZT
   Serial number: 3582MSME0A0E5475ZZZ$
   Serial number: 3512QSME5A4A2308ZZZX
   Serial number: 3522QSME480B2167ZZZV
   Serial number: 35527SME13096B2EZZZM
   Crash sensor for front airbag; passenger side:
   Serial number: 35627SME5F2B6B2EZZZ0
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90422LLD000ZM
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 76E33C9EC9C437AEB1B-8023
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0101244
   Coding: 830000
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Component: KOMBI         H05 0705
   Coding: 270F01
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 377DF19A8E4E8EA66AD-8062
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 131212F2000900
   Coding: 350000
   VCID: 74E70696D7B825BE8FF-8021
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RLWLF07
   Coding: 0000002
   VCID: FEF3A4BEA9F4FFEE69B-80AB
   Component: IMMO          H05 0705
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADB98EE0D7C634EA53-80BF
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7663972789
   Coding: 010100
   VCID: 2A5BD8EE45FC234EE53-807F
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: 3169CF82A82A5096249-8064
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: 377DF19A464E8EA66AD-8062
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001076
   VCID: 326BC08EAD2C6B8E5D3-8067
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H04 0008
   Revision: -----08S    Serial number: VWZ4Z7M1141172
   Coding: 01000400040005
   VCID: 64C776D66758B53E1FF-8031
                    Reset counter: 15
                    Mileage: 5573 km
                    Date: 2013.14.28
                    Time: 14:23:07
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663989358
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A7BE8AEBD5C93CE953-806F
United States
Hello Torsten,
With the exception of nicer seats and AWD with a manual transmission... the US market Golf R is a Mk6 Golf so the DIY you linked pretty much applies. RoW Golf R models actually come with Golf R tail lights :confused: unlike the poor guys over here that have to retrofit R lights.
After you install the headlight switch (and any necessary wires to/from the BCM) and install the tails with the BCM side wire swap Hex 04 should work in Byte 18 with the rear fog lamp. If you encounter any difficulty post another scan with the lights installed and coded.
Regards,
cochino2000
C?ID=182041
Hello Torsten,
Regards,
Hello Dana
Thank you for your quick answer. I will install the LED Tails tomorrow on the GTI.
I will let you know if it worked.
Regards
Torsten
cochino2000
C?ID=182041
Her my feedback..
So I installed the tail lights with the BCM side wire and swapped HEX 04/BITE 18 today.Everything is working fine. The Rear fog light is working, also the front fog lights.
The only problem that I have now is that the DRL's in the headlights are not working anymore. There are not even displayed in the cluster anymore.
Do you have any Idea how I can solve the problem, and can run the DRL's with the rear fog lights together?
Regards
Torsten
Friday,04,April,2014,10:18:56:00778
VIN: WVWFV7AJ9DW121883   License Plate: GTI VI 2013
Readiness: 1110 0101
   Revision: 00H31001
   Revision: 00001018
   Coding: 0010002002
   Revision: AC111709
   Coding: 009795
   Coding: 00004737
   Coding: 189A140000
   Coding: 830000
   Coding: 270F01
   Coding: 350000
   Coding: 0000002
   Coding: 010100
   Coding: 0001076
   Revision: 00H22000
   Coding: 0001076
                    Reset counter: 28
                    Mileage: 5833 km
                    Date: 2014.14.02
                    Time: 00:09:05
   ROD: EV_UHVNA.rod
United States
   Revision: AC111709
Hi Torsten. Sorry I missed that. The Long Coding is exactly the same in both scans. Are you sure you posted the newest scan (after modifications) from Friday, April 4th? Since Hex 04 didn't work you might want to try Hex 22 but I would like to see if the latest scan has any DRL functionality faults first.
-Dana
cochino2000
C?ID=182041
-Dana
Hello Dana
that's the latest scan from today.
Thursday,01,May,2014,20:23:54:00778
VIN: WVWFV7AJ9DW121883   License Plate: GTI VI DETLEF
   Revision: 00H31001
   Revision: 00001018
   Coding: 0010002002
   Revision: AC111709
   Coding: 6F180A1A90252A04008800C17000054448010486534D8D60648020200040
   Coding: 009795
   Coding: 00004737
   Coding: 189A140000
   Coding: 830000
   Coding: 270F01
   Coding: 350000
   Coding: 0000002
   Coding: 010100
   Coding: 0001076
   Revision: 00H22000
   Coding: 0001076
                    Reset counter: 29
                    Mileage: 5836 km
                    Date: 2014.14.02
                    Time: 01:02:03
   ROD: EV_UHVNA.rod
Tanks for helping
Regards
Torsten
United States
Revision: AC111709
Revision: AC111709
Ok, Byte 5 (Locking Confirmation via Horn active) is tweaked but I don't' think that would cause issues. So.. I do not see anything alarming but I'm not sure if the DRL issue is directly related to Byte 18.
What happens if you enable 'Daytime Running Light (DRL) Adaptation active (MFA+)' in Byte 15? Please see if that enables a tick box on the MFA, and if it does, see if ticking it on/off either enables DRLs or creates fault code to confirm that Byte 18 may require some fine tuning.
-Dana
