2009 GOLF TDi DSG DQ200 GEARBOX HELP !
TD&MCK Car Sales
C?ID=160148
2009 mk6 golf 1.6tdi dsg with gearbox issue, we have had a new mechatronics fitted and the original tcm software cloned onto it but still got same fault !
car doesn't know which gear to select, bangs between gears, sometimes when you put into drive the car stalls, slows down whilst driving as if you were pressing brakes until it changes gear and then goes again ? possible adaptations ? tried the basic settings a few times and it drives ok for about a mile then starts playing up again.
had new clutches last year (apparently according to customer ?)
any help appreciated ? possible coding issue ??
Sunday,22,March,2020,11:43:45:17628
VCDS Version: 19.6.2.2 (x64)
VIN: WVWZZZ1KZAW215483   License Plate: GOLF TDI DSG 59
Mileage: 183020km-113723mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAW215483   Mileage: 183020km-113723miles
   Part No SW: 03L 997 558 A    HW: 03L 906 023 A
   Component: R4 1.6l TDI   H23 9980
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00254014032500080000
   ASAM Dataset: EV_ECM16TDI02103L997558A 003002
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 3B7F76B5B2217C97B0-806E
   Part No SW: 0AM 300 053 J    HW: 0AM 927 769 D
   Component: GSG DSG AG7     451 3012
   Revision: 00045014    Serial number: CU501905295635
   Coding: 0000024
   Shop #: WSC 06402 785 00200
   VCID: 336F5E955271B4D768-8066
006011 - Clutch 1
               P177B - 003 - Tolerance Limit Reached
                    Fault Status: 01100011
                    Reset counter: 10
                    Mileage: 183024 km
                    Date: 2014.08.13
                    Time: 11:33:30
005925 - Comparison of Transmission Output Speeds 1 + 2
               P1725 - 001 - Implausible Signal - Intermittent
                    Fault Status: 00100001
                    Reset counter: 10
                    Mileage: 183025 km
                    Date: 2014.08.13
                    Time: 11:34:36
006012 - Clutch 2
               P177C - 003 - Tolerance Limit Reached
                    Reset counter: 10
                    Mileage: 183026 km
                    Date: 2014.08.13
                    Time: 11:37:51
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 133B200D092300FFC80F04EC901C0080310000
   VCID: 7AF1B3B1F59B859FEB-802E
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6DDB88EDBCD522277E-8038
   Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
   Component: BCM PQ35  B   103 0573
   Revision: 00103 AF
   Coding: 48180A3A9025F1C044000080340000E443510088536D8160648000200000
   VCID: 2D5B48ED7455E2273E-8078
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 20100  21  0512
   Coding: 009795
   Component: RLS 101109 05  54  0402
   Coding: 0330AD
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA0FDK.
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   Serial number: 3572MSME3F19554AZZZ2
   Serial number: 3582MSME2617664CZZZ
   Serial number: 3512QSME28544216ZZZN
   Serial number: 3522QSME06423D65ZZZV
9440017 - Driver's side; side-airbag igniter
          B100B 11 [136] - Short to Ground
                    Fault Frequency: 14
                    Mileage: 182998 km
                    Date: 2020.03.19
                    Time: 01:52:04
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001034
   VCID: 0201CB515D4BCD5FB3-8056
   Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
   Component: KOMBI         H04 0308
   Coding: 470B00
   VCID: 387569B98317578F5D-806C
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0231
   Revision:   H16       Serial number: 4320K09B110809
   Coding: ED807F06000212000003
   VCID: 69D3FCFD403D3E0712-803C
   Component: IMMO          H04 0308
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD183F18D3B351F1B-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667656908
   VCID: 2649B7C151A3D17FFF-8072
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2114
   Coding: 0000692
   VCID: 3163549DA86D86C71A-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Component: Tuer-SG         009 2140
   Coding: 0000692
   VCID: 346D5D89577FB3EF71-8060
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2I7194866
   Coding: 0100040004
   VCID: 65CBF0CD6C251A6736-8030
                    Reset counter: 241
                    Mileage: 183018 km
                    Date: 2014.08.11
                    Time: 13:02:27
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 356B608D5C05AAE746-8060
End-------------------------(Elapsed Time: 02:18)--------------------------
Any chance those clutches were Chinese Replacement Auto Parts?
The faults seem to point directly at the clutches...
NostraJackAss
Dud you know that mechanical components can not be circumvented by a controller being replaced or failure to set new adaption limits when tolerance have been altered from or too baseline?
OP are you aware that firmware levels appear way behind for the ECU & TCU at 9980/3012?
Sure makes you wonder if any of this is under warranty extension or for useful life & even in the Queens Country for Her Royal subjects being violated?
Danners74
C?ID=273244
Clutches sound as though they were not shimmed properly. Run the latest software as there have been issue with this and a full adaption drive...…. Also pattern parts as UWE said as there have been an updated clutch pack kit in the last few months. Improves shift quality but as I said only as good as the software and the installer if you knows what youre doing. Also has the needle roller been replaced in the crankshaft?
Mandatory whenever gearbox is removed and reinstalled.
regards Danners74
Golftwincharged
Guyana
C?ID=320847
Looks pretty much like the clutch unit maybe the adjusters are worn, but i would recommend to recheck your software version, what flash file are you using? use MVB 041 to view flash file, and why is your coding 0000024???? on the 0AM is usually 20, instead of 24?
also did the dual mass flywheel was changed on this car?? looks like the input speed sensor G182 does not equal the engine speed when in comparison, the control unit need this signal to control the clutches and to calculate slip, the TCU is good?
