Audi A7 2012 Media player 1 0E cannot be reached.
Dp41n8w
Finland
C?ID=372411
Hi. I took from A7 autoscan and there is a lot of faults. Cars owner just bought that car and almost all the faults was about 5000-6000km back. Maybe there was bad battery or some repairs, dont know. But then there is fault media player 1 cannot be reached. I checked all fuses, both sides of dash panel and back of the car was also some fuses, fuses was good. I didnt have WD but i didnt saw any blowen fuses. Radio works fine, the MMI screen sometimes shuts down when you have driven about hour or more, but there is the screen cable repared a long way back. Must repair again or change the wires. But Media player 1.. Evrything works fine, all features can be done what is in MMI. Can someone point me to right direction?
Here is first autoscan.
Friday,20,March,2020,20:18:40:19148
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
Workshop Code: 358 14250 022663
VIN: WAUZZZ4G5CN047070   License Plate: 409-GBS
Mileage: 166957km-103742mi   Repair Order: AUDIA7
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 20 28 30 36 3B 3C 42 44
          46 52 53 55 5F 62 6C 6D 72 8F 90
VIN: WAUZZZ4G5CN047070   Mileage: 166957km-103742miles
0E-Media Player 1 -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 G    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0003
   Revision: 53H37---
   Coding: 1A034012042401020800
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311G 001003
   ROD: EV_ECM30TDI0114G0907311G.rod
   VCID: 270BFB8BBF69B8FFA8F-8072
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G2 927 155 E    HW: 0AW 927 156 K
   Component: 0AW 30TDI RdW H04 0003
   Revision: --H04---    Serial number: 0000000458
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: 2F3B13AB9799E0BF60F-807A
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 07A18703E085E1C0DB00
   Shop #: WSC 00864 461 104432
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 34311CC77EBFC3671DD-8060
0674 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_LH_EPS_02_Timeout]
                    Reset counter: 120
                    Mileage: 166509 km
                    Date: 2020.03.07
                    Time: 21:19:26
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: D3
                    Uz: B4
0469 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ComScl_PDU_LH_EPS_03_Timeout]
                    Reset counter: 120
                    Mileage: 166509 km
                    Date: 2020.03.07
                    Time: 21:19:26
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: D4
                    Uz: B4
0601 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Dst_EpsCommError]
                    Reset counter: 120
                    Mileage: 166457 km
                    Date: 2020.03.06
                    Time: 17:02:33
                    VzRef: 0A
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 0D
                    Uz: B5
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0330
   Coding: 01AA3000000000000000
   VCID: 76B5E6CF28C39177E39-8022
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000154769008
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 250
                    Mileage: 161934 km
                    Date: 2019.11.06
                    Time: 15:49:34
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 4G0 820 043 C    HW: 4G0 820 043 C
   Component: KLIMA 4 ZONEN H11 0054
   Serial number: 16031000030050
   Coding: 3603007888
   Shop #: WSC 06745 128 28888
   ASAM Dataset: EV_AirCondiComfoUDS 002027
   VCID: 1F1BE36BE739703FD0F-804A
7 Faults Found:
0182 - Temperature Sensor for Left Footwell Vent
          B1083 15 [009] - Open or Short to Plus
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
                    Voltage terminal 30: 11.35 V
                    Outside air temperature: 11.5 °C
                    Vehicle speed: 0.00 km/h
0194 - Position Sensor in Left Center Vent
          B10E1 15 [008] - Open or Short to Plus
                    Reset counter: 121
                    Mileage: 166568 km
                    Date: 2020.03.09
                    Time: 21:20:31
                    Voltage terminal 30: 11.97 V
                    Terminal 15 status: Terminal 15 on
                    Supply voltage for external components: 5.02 V
0196 - Position Sensor in Right Center Vent
          B10E2 15 [008] - Open or Short to Plus
                    Reset counter: 121
                    Mileage: 166568 km
                    Date: 2020.03.09
                    Time: 21:20:31
0275 - Development code 1
          B2F01 00 [008] - -
          [PTC–Zusatzheizung dauerhaft leistungsreduziert Entwicklungscode 2]
                    Reset counter: 103
                    Mileage: 165208 km
                    Date: 2020.02.18
                    Time: 01:59:06
                    Voltage terminal 30: 13.44 V
                    Outside air temperature: 5.5 °C
                    Energy management heat output control status: Stage 2
                    Electric auxiliary air heater: stage: 1
0317 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Klima hinten: kein Signal / Kommunikation]
                    Fault Frequency: 178
                    Reset counter: 129
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
                    Engine speed: 0 /min
0384 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
                    Reset counter: 103
                    Mileage: 165206 km
                    Date: 2020.02.18
                    Time: 01:55:58
                    Voltage terminal 30: 11.78 V
                    Engine speed: 914 /min
0518 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Sensor für Luftfeuchte aussen: unplausibles Signal]
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
                    Voltage terminal 30: 11.34 V
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001250060
   Coding: 0907201009749FE01181008300001800CF9CC7082E080301000108546F01
   Shop #: WSC 06443 128 28888
   VCID: 6FBBD3AB5799A0BF20F-803A
   Subsystem 1 - Part No SW: 4G8 955 119 D    HW: 4G8 955 119   Labels: 1KX-955-119.CLB
   Component: WWS57X 090715  H32 0051
   Serial number: 90B01114100208103030
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11609095
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 09 08 2011  00000384
   Subsystem 4 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H01 0001
   Serial number: 00000000001006243169
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H01 0001
   Serial number: 00000000001005283398
   Subsystem 6 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H02 0002
   Serial number: EE288EB5000000000001
00379 - Terminal 58s
                    Fault Status: 00101100
                    Reset counter: 121
                    Mileage: 166568 km
                    Date: 2020.03.09
                    Time: 21:20:00
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:00
03608 - Humidity Sensor in Fresh Air Intake Duct
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:00
                    Fault Status: 01100101
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:00
                    Reset counter: 120
                    Mileage: 166509 km
                    Date: 2020.03.07
                    Time: 21:19:00
03816 - Left Low Beam Headlamp: Electrical Current Coding Implausible
                    Fault Frequency: 27
                    Reset counter: 129
                    Mileage: 162228 km
                    Date: 2019.11.25
                    Time: 11:19:00
Address 0E: Media Player 1
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H06 0030
   Revision: 11001001    Serial number: --------------
   Coding: 300303
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 372B2BCB6FC9287F38F-8062
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG003WGDG
   Coding: 30314530323130303133554A305234473853
   Shop #: WSC 02391 785 00200
   VCID: 363526CF68C3D177239-8062
   Serial number: 3575HRB40650NI36D9MC
   Serial number: 3585HRB405P0P13E71C1
   Serial number: 3515JRB405L0M98E514Z
   Serial number: 3525JRB405D0M98EFH3A
   Serial number: 3554VRB40550M8GE4PEV
   Serial number: 3564VRB40550M8GE7P9U
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20111114000677
   Coding: 000034
   Shop #: WSC 66666 000 00000
   VCID: 303910D78A27FF47795-8064
   Subsystem 1 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
                    Fault Frequency: 21
                    Reset counter: 125
                    Mileage: 162137 km
                    Date: 2019.11.20
                    Time: 17:08:39
   Part No SW: 4G8 920 930 G    HW: 4G8 920 930 G
   Component: TDieRdw   Nv  H30 0307
   Revision: 10003051    Serial number: 658120210593643
   Coding: 03A601020B0300080D0100
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 313F15D381ADF64F76B-8064
16776978 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [LH_EPS_01 keine Kommunikation]
                    Reset counter: 120
                    Mileage: 166509 km
                    Date: 2020.03.07
                    Time: 21:19:26
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000004173
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 303910D78AA7FF47795-8064
   Voltage stabilizer:
   Subsystem 1 - Part No SW: 8K0 959 663     HW: 8K0 959 663
   Serial number: 11220001085021200181
5088 - Rear A/C control module
          U1072 00 [008] - No communication
                    Fault Frequency: 52
                    Reset counter: 129
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
                    Voltage terminal 30: 11.4 V
                    Voltage terminal 15: 11.4 V
                    Control Module temperature: 19 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4906 - Power Steering Control Module
          U101D 00 [008] - No Communication
                    Reset counter: 120
                    Mileage: 166509 km
                    Date: 2020.03.07
                    Time: 21:19:26
                    Voltage terminal 30: 14.0 V
                    Voltage terminal 15: 13.9 V
                    Control Module temperature: 22 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5081 - Front Right belt tensioner control module
          U107D 00 [009] - No communication
          [Steuergerät für RGS Rechts Keine Kommunikation]
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6656 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
6232 - Media player in position 1
          U105E 00 [009] - No Communication
          [Mediaplayer Position 1 Keine Kommunikation]
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:28
                    Voltage terminal 30: 11.5 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 Y132
   Revision: AA001002
   Coding: 04018E64747464545425363E00
   VCID: 33331FDB7B31C45F047-8066
   Part No SW: 4G0 919 158     HW: 4G0 919 158
   Component: KLIMA FOND    H06 0054
   Serial number: 10120900031864
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002010
   VCID: 6C81C4A7660F5BA705D-8038
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 112
                    Mileage: 165850 km
                    Date: 2020.02.28
                    Time: 23:40:11
                    Outside air temperature: -6.0 °C
                    Left rear vent temperature: 32.4 °C
0080 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz Kein Signal/keine Kommunikation]
                    Reset counter: 112
                    Mileage: 165850 km
                    Date: 2020.02.28
                    Time: 23:41:07
                    Voltage terminal 30: 14.04 V
                    Engine speed: 1340 /min
                    Vehicle speed: 44.00 km/h
0105 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
                    Reset counter: 121
                    Mileage: 156911 km
                    Date: 2019.06.18
                    Time: 18:53:48
                    Voltage terminal 30: 13.89 V
                    Outside air temperature: 21.5 °C
                    Engine speed: 1596 /min
0106 - Combination / Chassis CAN Bus (SAE Bus D)
          U0055 00 [008] - Malfunction
                    Reset counter: 119
                    Mileage: 165248 km
                    Date: 2020.02.18
                    Time: 11:09:38
                    Voltage terminal 30: 13.73 V
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000018023
   Coding: 01010101000000000001000203
   VCID: 6491AC878E5F13E74DD-8030
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000004742330
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77ABEBCB2FC9E87FF8F-8022
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:30
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200G79V0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6B83C7BB63015C9F0C7-803E
   Part No SW: 4G0 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH02 0010
   Revision: 00H02000    Serial number: 6PZ 010 287-02
   Coding: 0000103
   Shop #: WSC 02729 823 28888
   VCID: 6C81C4A76A8F5BA705D-8038
   Subsystem 1 - Part No: 4G0 907 568
   Component: J770  SWA Slave H01 0010
   Subsystem 2 - Serial number: 6PZ 010 287-22
   Subsystem 3 - Serial number: 5F27.11.0900H010003C720870ÿ
   Subsystem 4 - Serial number: 720870ÿ
02856 - Sensing Area for Control Module 2 Blocked
                    Reset counter: 118
                    Mileage: 166260 km
                    Date: 2020.03.03
                    Time: 21:21:00
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
                    Fault Status: 00101010
                    Fault Frequency: 14
                    Reset counter: 120
                    Mileage: 162227 km
                    Date: 2019.11.22
                    Time: 12:44:18
   Part No SW: 4G8 959 793 B    HW: 4G8 959 793
   Component: TSG FA        H04 0210
   Coding: 011C5F625000628002080002
   VCID: 3FDB43EB4779103FF0F-806A
                    Fault Status: 01101100
                    Fault Frequency: 82
                    Reset counter: 59
                    Mileage: 161939 km
                    Date: 2019.11.10
                    Time: 16:50:58
   Part No SW: 4G0 909 144 G    HW: 4G0 909 144 G
   Component: RCEPS         H33 0005
   Revision: 00001000    Serial number: 0014067153
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 005004
   ROD: EV_RCEPS_005.rod
   VCID: 2D0709A39D9592AF523-8078
3158336 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Ausfall der FlexRay-PDU "PDU_HCA_01" des BVS-Steuergeräts]
                    Reset counter: 91
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
                    Write only channel
   Revision: 00002001    Serial number: 0156487604
   Coding: 0139062220B9B40003220A04000100000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 2 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H08 0027
   Serial number: WA090917000000012227
00230 - Transmission Park Selector Switch (F305)
                    Fault Frequency: 12
                    Reset counter: 103
                    Mileage: 162043 km
                    Date: 2019.11.13
                    Time: 12:18:57
   Part No SW: 4G8 959 792 B    HW: 4G8 959 792
   Component: TSG BF        H04 0210
   VCID: 3E253EEF40731937FB9-806A
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000128145
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D02BFAC7B8597B71-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 111215-0001-031
   Coding: 112296101000A300
   Shop #: WSC 66666 123 12345
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C0104A7A68F9BA745D-8078
   Part No SW: 4G0 035 192 B    HW: 4G0 035 192
   Component: RMC Nav Plus  H41 0530
   Coding: 0100040001415FCF422B060301010000000000
   VCID: 211FE593D1CD46CFE6B-8074
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H41 0084
   Serial number: 9464AE0A0002723
   Subsystem 3 - Part No SW: 4G1 919 612 K    HW: 4G1 919 612 A
   Component: E380 BDT C7  H07 0120
   Serial number: 90349JB300023
7 Faults Found:
                    Reset counter: 91
                    Mileage: 166901 km
                    Date: 2020.03.20
                    Time: 15:37:09
                    Voltage: 12.30 V
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:33
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000001 00010000
03787 - Rotation Mechanism for Display Module Front
                    Fault Status: 00100011
                    Fault Frequency: 32
                    Reset counter: 129
                    Mileage: 166509 km
                    Date: 2020.03.07
                    Time: 21:59:45
                    Voltage: 12.00 V
03788 - Rotation Mechanism for Display Module Front; Play Protection Activated
                    Reset counter: 129
                    Mileage: 166509 km
                    Date: 2020.03.07
                    Time: 22:04:10
                    Voltage: 13.90 V
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 129
                    Mileage: 166568 km
                    Date: 2020.03.09
                    Time: 20:25:03
02071 - Local Databus
                    Fault Frequency: 78
                    Reset counter: 131
                    Mileage: 166923 km
                    Date: 2020.03.20
                    Time: 18:41:20
                    Bin. Bits:       01
                    Fault Status: 00101011
                    Fault Frequency: 26
                    Reset counter: 129
                    Mileage: 166568 km
                    Date: 2020.03.09
                    Time: 21:33:49
                    Voltage: 11.60 V
   Part No SW: 4G8 959 795 B    HW: 4G8 959 795
   Component: TSG HL        H02 0210
   Coding: 01081D624000628002080002
   VCID: 41DF4513318D66CF86B-8014
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H03---    Serial number: 525PA8-J01D0BE
   Coding: 1020013
   Shop #: WSC 06745 128 46587
   VCID: 2517F183C9E5AAEF9A3-8070
   Part No SW: 4G8 959 107     HW: 4G8 959 107
   Component: HDSG-Modul    H12 0032
   Revision: 09145329    Serial number: 333900029
   Coding: 0A2305C000
   Shop #: WSC 00070 000 00000
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 72BDDADF442B8D57CF1-8026
   Component: TSG HR        H02 0210
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
12583695 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:27:29
12589824 - Data Set Implausible
          B2012 00 [009] - -
          [Implausible Datase]
                    Reset counter: 249
                    Mileage: 161929 km
                    Date: 2019.11.05
                    Time: 12:33:05
Address 90: Pretens. Frt Right
End----------(Elapsed Time: 02:11, VBatt start/end: 14.1V/14.0V)-----------
And then I erased fault and readed again
Friday,20,March,2020,20:24:44:19148
Mileage: 166957km-103742mi   Repair Order: AUDIA71
28-HVAC, Rear -- Status: Malfunction 0110
   Revision: 53H37---
   Coding: 3603007888
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:55
                    Outside air temperature: -0.5 °C
          U1111 00 [009] - -
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:55
                    Engine speed: 749 /min
          U1113 00 [009] - -
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:56
                    Voltage terminal 30: 14.00 V
                    Engine speed: 750 /min
   Coding: 0045F7
   Coding: 02562B
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:00
            014 - Defective
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:00
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:00
   Coding: 300303
   Coding: 000034
   Coding: 00CD077D00
   Voltage stabilizer:
          U1072 00 [009] - No communication
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:21:02
                    Voltage terminal 15: 14.0 V
                    Control Module temperature: 28 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:21:02
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Revision: AA001002
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:53
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:54
   Coding: 0000103
          U1111 00 [009] - -
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:55
                    Write only channel
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:53
                    Voltage: 13.80 V
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:57
   Coding: 1020013
   Coding: 0A2305C000
   ROD: EV_RGS_L.rod
          U1111 00 [009] - -
                    Reset counter: 91
                    Mileage: 166957 km
                    Date: 2020.03.20
                    Time: 20:19:55
End----------(Elapsed Time: 02:11, VBatt start/end: 14.0V/14.0V)-----------
I think there is maybe bigger problem cause rear AC screen dont work and there is few CM that also cannot be reached and there is still electrical faults in system. Have to get WD then it will be easier to check
But thanks!
On an only somewhat similar car (a 2012 A6), Media Player 1 is:
Address 0E: Media Player 1 (R41)       Labels: None
   Part No SW: 8X0 035 110 B    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0480
   Revision: 00000007
I suspect that's the CD changer in the glovebox. Does this car have one of those? Does it work?
golfi_vend
Tartu, Estonia
C?ID=195131
This car is a mess.
I might be able to check VIN if this car has a dvd changer, but right now it's missing communication. It either doesn't have it or has MOST- loop installed.
Also Battery module cannot be reached. Same goes for Pretensioner Front Right. Left one seems to be replaced, but not coded/svm correctly?
Dp41n8w
Finland
C?ID=372411
@golfi_vend And I need dealer To code pret. Front right? If it is swm coding?
Dp41n8w
Finland
C?ID=372411
@Uwe I can check if it work later today. Thanks!
Dp41n8w
Finland
C?ID=372411
Cd changer In glove box works.
United States
Hmm, the PR code is 7A7 without CD changer and PL24 shows it isn't installed (not black and bold). Temp photo link here:
https://media.trillian.im/media/?m=...ZhszOHramsEd7JuCwecahBcHaWrSnvwJHauo/kQxwAg==
If the VIN is WAUZZZ4G5CN047070 then I suspect it was a retrofit. Either way, I'd pull it to see what the part number is.
Edit, in regards to the Address 90: Pretens. Frt Right; Yes, when you get that online it will need dealer SVM config.
United States
PR-Code list for WAUZZZ4G5CN047070
If the OP doesn't want this VIN specific info posted online we can delete this post but it should be helpful IMO.
[TABLE="class: vinInfoTable"]
[TR]
[TH]Vehicle Identification No.[/TH]
[TD="colspan: 2"]WAUZZZ4G5CN047070[/TD]
[/TR]
[TR]
[TH]Model[/TH]
[TD="colspan: 2"]Audi A7 Sportback
TDI 3.0
A7   [/TD]
[/TR]
[TR]
[TH]Date of production[/TH]
[TD="colspan: 2"]26.09.2011[/TD]
[/TR]
[TR]
[TH]Model year[/TH]
[TD="colspan: 2"]2012[/TD]
[/TR]
[TR]
[TH]Sales type[/TH]
[TD="colspan: 2"]4GA0NH[/TD]
[/TR]
[TR]
[TH]Engine Code[/TH]
[TD="colspan: 2"]CLAB[/TD]
[/TR]
[TR]
[TH]Transmission Code[/TH]
[TD="colspan: 2"]NKP[/TD]
[/TR]
[TR]
[TH]Axle drive[/TH]
[TD="colspan: 2"]SA[/TD]
[/TR]
[TR]
[TH]Equipment[/TH]
[TD="colspan: 2"]QE[/TD]
[/TR]
[TR]
[TH]Roof color[/TH]
[TD="colspan: 2"]A2[/TD]
[/TR]
[TR]
[TH]Carpet color code[/TH]
[TD="colspan: 2"][/TD]
[/TR]
[TR]
[TH]Exterior color / Paint Code[/TH]
[TD="colspan: 2"]A2 / Y9B[/TD]
[/TR]
[TR]
[TH]Seat combination no.[/TH]
[/TR]
[TR]
[TH]Number of Z-Orders[/TH]
[/TR]
[/TABLE]
[TR]
[TH]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PD[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH]Vehicle class differentiation
powertrains/platform parts[/TH]
[TD="class: prCode"]7JV[/TD]
[TD]Vehicle class differentiation -4G0/4G8-[/TD]
[/TR]
[TR]
[TH]Tailpipes[/TH]
[TD="class: prCode"]0P0[/TD]
[TD]Rear exhaust tailpipe (standard)[/TD]
[/TR]
[TR]
[TH]Emission standard[/TH]
[TD="class: prCode"]7MG[/TD]
[TD]Emission standard EU5[/TD]
[/TR]
[TR]
[TH]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]Without trailer hitch[/TD]
[/TR]
[TR]
[TH]airbag[/TH]
[TD="class: prCode"]4UF[/TD]
[TD]Airbag for driver and front passenger
with front passenger airbag
deactivation[/TD]
[/TR]
[TR]
[TH]Activated carbon canister/gasoline
particulate filter[/TH]
[TD="class: prCode"]1E0[/TD]
[TD]Without activated carbon canister[/TD]
[/TR]
[TR]
[TH]Label for central electric system[/TH]
[TD="class: prCode"]0W2[/TD]
[TD]Label for central electric system
English-speaking countries[/TD]
[/TR]
[TR]
[TH]Storage compartment package[/TH]
[TD="class: prCode"]QE0[/TD]
[TD]Without storage compartment package/box[/TD]
[/TR]
[TR]
[TH]Exterior mirror adjustment[/TH]
[TD="class: prCode"]6XG[/TD]
[TD]Exterior mirrors with memory feature,
power-adjustable/heated[/TD]
[/TR]
[TR]
[TH]Follow-on warranty[/TH]
[TD="class: prCode"]EA0[/TD]
[TD]Without subsequent warranty[/TD]
[/TR]
[TR]
[TH]Left exterior mirror[/TH]
[TD="class: prCode"]5SJ[/TD]
[TD]Left exterior mirror, convex[/TD]
[/TR]
[TR]
[TH]Right exterior mirror[/TH]
[TD="class: prCode"]6TS[/TD]
[TD]Right exterior mirror, aspherical,
large viewing field[/TD]
[/TR]
[TR]
[TH]Alternative drive system[/TH]
[TD="class: prCode"]0K0[/TD]
[TD]Without alternative drive system[/TD]
[/TR]
[TR]
[TH]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH]Multimedia/video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WC[/TD]
[TD]Without "Multimedia" in vehicle[/TD]
[/TR]
[TR]
[TH]Equipment lines[/TH]
[TD="class: prCode"]A8S[/TD]
[TD]Standard equipment[/TD]
[/TR]
[TR]
[TH]Rear brakes[/TH]
[TD="class: prCode"]1KW[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH]batteries[/TH]
[TD="class: prCode"]J0B[/TD]
[TD]Battery 520 A (92 Ah)[/TD]
[/TR]
[TR]
[TH]Front brakes[/TH]
[TD="class: prCode"]1LA[/TD]
[TD]Disc brakes in front[/TD]
[/TR]
[TR]
[TH]Components with special surface[/TH]
[TD="class: prCode"]6FA[/TD]
[TD]Components without special surface
appearance[/TD]
[/TR]
[TR]
[TH]Handset (telephone)[/TH]
[TD="class: prCode"]QF0[/TD]
[TD]Without receiver (car phone)[/TD]
[/TR]
[TR]
[TH]Battery/alternator capacities[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH]Component sets for country-specific
prescriptive standards[/TH]
[TD="class: prCode"]B0N[/TD]
[TD]Component parts set, complying with
vehicle type for Great Britain, various
parts[/TD]
[/TR]
[TR]
[TH]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH]Brake systems[/TH]
[TD="class: prCode"]1AS[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH]Front passenger seat control[/TH]
[TD="class: prCode"]4V0[/TD]
[TD]Without front passenger seat control[/TD]
[/TR]
[TR]
[TH]Owner's manuals[/TH]
[TD="class: prCode"]0VF[/TD]
[TD]Information kit in English[/TD]
[/TR]
[TR]
[TH]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH]CD changer/CD player[/TH]
[TD="class: prCode"]7A7[/TD]
[TD]without CD changer[/TD]
[/TR]
[TR]
[TH]General operating license additions[/TH]
[TD="class: prCode"]C05[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH]CO2 variant[/TH]
[TD="class: prCode"]0C0[/TD]
[TD]Standard[/TD]
[/TR]
[TR]
[TH]Cd-enhancing underbody panel[/TH]
[TD="class: prCode"]2D0[/TD]
[TD]Without cd enhancing underbody panel[/TD]
[/TR]
[TR]
[TH]Shock absorption/suspension system[/TH]
[TD="class: prCode"]1BE[/TD]
[TD]Sports suspension/shock absorption[/TD]
[/TR]
[TR]
[TH]Roof rails/roof rack[/TH]
[TD="class: prCode"]3S0[/TD]
[TD]Without roof rails/roof load rack[/TD]
[/TR]
[TR]
[TH]2-DIN/dual-view display[/TH]
[TD="class: prCode"]2T5[/TD]
[TD]Without dual-view display[/TD]
[/TR]
[TR]
[TH]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FA[/TD]
[TD]Without roof insert (standard roof)[/TD]
[/TR]
[TR]
[TH]Decorative films/emblems[/TH]
[TD="class: prCode"]6F1[/TD]
[TD]Emblems[/TD]
[/TR]
[TR]
[TH]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH]Eco feature for driver profile and
driving mode selection[/TH]
[TD="class: prCode"]EF1[/TD]
[TD]ECO function[/TD]
[/TR]
[TR]
[TH]Theft protection system[/TH]
[TD="class: prCode"]7AL[/TD]
[TD]Anti-theft alarm system, interior
monitoring, backup horn and towing
protection[/TD]
[/TR]
[TR]
[TH]Inserts[/TH]
[TD="class: prCode"]5TG[/TD]
[TD]Decorative inserts, brushed, matte
aluminum[/TD]
[/TR]
[TR]
[TH]Scuff plates[/TH]
[TD="class: prCode"]7M8[/TD]
[TD]Scuff plates in door apertures[/TD]
[/TR]
[TR]
[TH]Input medium for multimedia[/TH]
[TD="class: prCode"]UJ0[/TD]
[TD]Input medium for multimedia[/TD]
[/TR]
[TR]
[TH]Park distance control[/TH]
[TD="class: prCode"]7X2[/TD]
[TD]Park distance control in front and rear[/TD]
[/TR]
[TR]
[TH]Extended safety system[/TH]
[TD="class: prCode"]7W0[/TD]
[TD]Without extended safety system[/TD]
[/TR]
[TR]
[TH]Electric interface for external use[/TH]
[TD="class: prCode"]UF7[/TD]
[TD]Electric interface for external use[/TD]
[/TR]
[TR]
[TH]Power-operated door (power latching)[/TH]
[TD="class: prCode"]GZ0[/TD]
[TD]Manually operated doors[/TD]
[/TR]
[TR]
[TH]Differentiation for manufacturing
process[/TH]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[TH]Color of dashboard/door trim panel and
side trim panel[/TH]
[TD="class: prCode"]6RB[/TD]
[TD]Dashboard and door trim panel
two-piece, single-color, multi-colored[/TD]
[/TR]
[TR]
[TH]Headlight activation[/TH]
[TD="class: prCode"]8K4[/TD]
[TD]Separate daytime running light
-- NAR --[/TD]
[/TR]
[TR]
[TH]Fresh air intake for vehicle interior
(with particle filter)[/TH]
[TD="class: prCode"]2V5[/TD]
[TD]Fresh air intake system with combination
filter[/TD]
[/TR]
[TR]
[TH]Parking brake[/TH]
[TD="class: prCode"]UH2[/TD]
[TD]Parking brake[/TD]
[/TR]
[TR]
[TH]Vehicle tracking system[/TH]
[TD="class: prCode"]7G9[/TD]
[TD]Interface for locating assistant[/TD]
[/TR]
[TR]
[TH]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH]Night vision[/TH]
[TD="class: prCode"]9R0[/TD]
[TD]without night-vision system[/TD]
[/TR]
[TR]
[TH]Alternators[/TH]
[TD="class: prCode"]9G3[/TD]
[TD]Alternator 120-180 A[/TD]
[/TR]
[TR]
[TH]Transmission types/gear shift mechanisms[/TH]
[TD="class: prCode"]0G7[/TD]
[TD]tiptronic[/TD]
[/TR]
[TR]
[TH]Weight category for rear axle[/TH]
[TD="class: prCode"]0YJ[/TD]
[TD]Weight range 9
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH]Noise cancellation[/TH]
[TD="class: prCode"]EP0[/TD]
[TD]No noise cancellation[/TD]
[/TR]
[TR]
[TH]Weight category for front axle[/TH]
[TD="class: prCode"]0JH[/TD]
[TD]Weight category front axle
weight range 8[/TD]
[/TR]
[TR]
[TH]Base engine[/TH]
[TD="class: prCode"]TF1[/TD]
[TD]6-cylinder diesel engine 3.0 l
unit 059.H[/TD]
[/TR]
[TR]
[TH]Tie down straps/net/pocket[/TH]
[TD="class: prCode"]6M0[/TD]
[TD]Without tie down straps/net/pocket[/TD]
[/TR]
[TR]
[TH]cruise control system[/TH]
[TD="class: prCode"]8T1[/TD]
[TD]Cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH]Transmission specification[/TH]
[TD="class: prCode"]G0Z[/TD]
[TD]Variable gearing ratio[/TD]
[/TR]
[TR]
[TH]rear axle differential[/TH]
[TD="class: prCode"]GH0[/TD]
[TD]Without rear axle differential[/TD]
[/TR]
[TR]
[TH]Rear trim panel[/TH]
[TD="class: prCode"]6V1[/TD]
[TD]Rear trim panel (ECE)[/TD]
[/TR]
[TR]
[TH]Manufacturer[/TH]
[TD="class: prCode"]A51[/TD]
[TD]Audi AG[/TD]
[/TR]
[TR]
[TH]Rear spoiler[/TH]
[TD="class: prCode"]5J2[/TD]
[TD]Rear spoiler (type 2)[/TD]
[/TR]
[TR]
[TH]Molded headliner[/TH]
[TD="class: prCode"]6NQ[/TD]
[TD]Standard molded headliner[/TD]
[/TR]
[TR]
[TH]Rear seats[/TH]
[TD="class: prCode"]3NJ[/TD]
[TD]Rear bench seat, not split, split backrest, folding[/TD]
[/TR]
[TR]
[TH]Heating system/air conditioning system[/TH]
[TD="class: prCode"]9AK[/TD]
[TD]Climatronic with impact pressure
control, CFC-free[/TD]
[/TR]
[TR]
[TH]Main headlamps[/TH]
[TD="class: prCode"]8BP[/TD]
[TD]Bi-functional headlamp with gas
discharge lamp[/TD]
[/TR]
[TR]
[TH]Head-up display[/TH]
[TD="class: prCode"]KS0[/TD]
[TD]Without head-up display[/TD]
[/TR]
[TR]
[TH]Customized installation[/TH]
[TD="class: prCode"]FC1[/TD]
[TD]Customized installation[/TD]
[/TR]
[TR]
[TH]Dashboard inserts[/TH]
[TD="class: prCode"]U1B[/TD]
[TD]Instrument cluster with mph
speedometer, clock, tachometer and trip
odometer[/TD]
[/TR]
[TR]
[TH]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L6[/TD]
[TD]Breakaway interior rearview mirror,
auto-dimming[/TD]
[/TR]
[TR]
[TH]Body forms[/TH]
[TD="class: prCode"]K8R[/TD]
[TD]Sportsback[/TD]
[/TR]
[TR]
[TH]Camera/distance sensor[/TH]
[TD="class: prCode"]QK0[/TD]
[TD]Without camera without distance sensor
(driver assistance system)[/TD]
[/TR]
[TR]
[TH]Luggage compartment floor covering[/TH]
[TD="class: prCode"]6SS[/TD]
[TD]Luggage compartment floor covering[/TD]
[/TR]
[TR]
[TH]Fuel tank volume[/TH]
[TD="class: prCode"]0M0[/TD]
[TD]Fuel tank[/TD]
[/TR]
[TR]
[TH]Climate zones[/TH]
[TD="class: prCode"]0Y1[/TD]
[TD]Standard climatic zones[/TD]
[/TR]
[TR]
[TH]Compass/road sign display[/TH]
[TD="class: prCode"]QR8[/TD]
[TD]without road sign recognition[/TD]
[/TR]
[TR]
[TH]Seat ventilation/massage seat[/TH]
[TD="class: prCode"]4D0[/TD]
[TD]Without seat ventilation/massage seat[/TD]
[/TR]
[TR]
[TH]Fuel filling volume[/TH]
[TD="class: prCode"]1Z5[/TD]
[TD]Increase in initial standard fuel
filling[/TD]
[/TR]
[TR]
[TH]Fuel quality[/TH]
[TD="class: prCode"]0U2[/TD]
[TD]Fuel quality < 50 ppm[/TD]
[/TR]
[TR]
[TH]Fuel systems[/TH]
[TD="class: prCode"]0F3[/TD]
[TD]Fuel system for diesel engine[/TD]
[/TR]
[TR]
[TH]Body measures[/TH]
[TD="class: prCode"]5C0[/TD]
[TD]Without special body measures[/TD]
[/TR]
[TR]
[TH]Child seat anchors in front[/TH]
[TD="class: prCode"]3G1[/TD]
[TD]Child seat anchors, front left (ISOFIX)[/TD]
[/TR]
[TR]
[TH]Camera systems/surround sensors[/TH]
[TD="class: prCode"]KA0[/TD]
[TD]without camera systems/environment sensors[/TD]
[/TR]
[TR]
[TH]License plate carrier in front[/TH]
[TD="class: prCode"]6W6[/TD]
[TD]License plate carrier in front[/TD]
[/TR]
[TR]
[TH]Paint preservation/transport protection[/TH]
[TD="class: prCode"]5K5[/TD]
[TD]Transport protection film with
additional transport protection measures[/TD]
[/TR]
[TR]
[TH]Luggage/load compartment floor in rear[/TH]
[TD="class: prCode"]3GA[/TD]
[TD]Without luggage compartment floor[/TD]
[/TR]
[TR]
[TH]Lighting package (lighting)[/TH]
[TD="class: prCode"]QQ1[/TD]
[TD]With additional lights (interior
lighting)[/TD]
[/TR]
[TR]
[TH]Steering system setup[/TH]
[TD="class: prCode"]L0R[/TD]
[TD]Right-hand drive[/TD]
[/TR]
[TR]
[TH]Steering system[/TH]
[TD="class: prCode"]QZ7[/TD]
[TD]Power steering[/TD]
[/TR]
[TR]
[TH]Lumbar support in backrests[/TH]
[TD="class: prCode"]7P1[/TD]
[TD]Power-adjustable lumbar support in front
seats[/TD]
[/TR]
[TR]
[TH]steering wheels[/TH]
[TD="class: prCode"]1XX[/TD]
[TD]Leather-wrapped multi-function sports
steering wheel with tiptronic[/TD]
[/TR]
[TR]
[TH]Driving on the left/right side[/TH]
[TD="class: prCode"]AV0[/TD]
[TD]Driving on the left[/TD]
[/TR]
[TR]
[TH]Loudspeaker installation[/TH]
[TD="class: prCode"]9VD[/TD]
[TD]active loudspeakers[/TD]
[/TR]
[TR]
[TH]Steering column systems[/TH]
[TD="class: prCode"]2C5[/TD]
[TD]Axial and vertical adjustable steering
column[/TD]
[/TR]
[TR]
[TH]Leather parts[/TH]
[TD="class: prCode"]7HA[/TD]
[TD]Without leather trim[/TD]
[/TR]
[TR]
[TH]Headlight range control[/TH]
[TD="class: prCode"]8Q3[/TD]
[TD]Dynamic headlight range control
(self-adjusting while driving)[/TD]
[/TR]
[TR]
[TH]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH]Variants[/TH]
[TD="class: prCode"]FM0[/TD]
[TD]Basic equipment variant[/TD]
[/TR]
[TR]
[TH]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q8[/TD]
[TD]Multi-function display/trip computer[/TD]
[/TR]
[TR]
[TH]Center console[/TH]
[TD="class: prCode"]3D1[/TD]
[TD]Center console[/TD]
[/TR]
[TR]
[TH]Engine cooling[/TH]
[TD="class: prCode"]8Z5[/TD]
[TD]not hot country[/TD]
[/TR]
[TR]
[TH]Engine specification[/TH]
[TD="class: prCode"]D1Q[/TD]
[TD]6-cyl. turbo dies. eng. 3.0 l/150 kW
(24V), base engine is T41/TF1/TH1[/TD]
[/TR]
[TR]
[TH]Navigation system[/TH]
[TD="class: prCode"]7T2[/TD]
[TD]Navigation system (LOW)[/TD]
[/TR]
[TR]
[TH]Platform group class[/TH]
[TD="class: prCode"]7PB[/TD]
[TD]Platform group class 2[/TD]
[/TR]
[TR]
[TH]Audi Sport/ Quattro GmbH[/TH]
[TD="class: prCode"]FQ1[/TD]
[TD]Wheels of Audi Sport/ Quattro GmbH[/TD]
[/TR]
[TR]
[TH]Quality class[/TH]
[TD="class: prCode"]AQ0[/TD]
[TD]Standard-production quality[/TD]
[/TR]
[TR]
[TH]Wheels[/TH]
[TD="class: prCode"]CE5[/TD]
[TD]Alloy wheels 9J x 20[/TD]
[/TR]
[TR]
[TH]Radios[/TH]
[TD="class: prCode"]8DP[/TD]
[TD]Radio "LOW II"[/TD]
[/TR]
[TR]
[TH]Smoker's/non-smoker's version[/TH]
[TD="class: prCode"]9JA[/TD]
[TD]Non smoker version[/TD]
[/TR]
[TR]
[TH]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K6[/TD]
[TD]Tire pressure monitoring system[/TD]
[/TR]
[TR]
[TH]tire[/TH]
[TD="class: prCode"]HL9[/TD]
[TD]Tires 265/35 R20 99Y XL[/TD]
[/TR]
[TR]
[TH]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G5[/TD]
[TD]Space-saving spare wheel, same size
(same rolling circumference) as original
equipment tires[/TD]
[/TR]
[TR]
[TH]Type of tire[/TH]
[TD="class: prCode"]VG6[/TD]
[TD]Type of tire: design 2[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PQ6[/TD]
[TD]Audi exclusive cast aluminium alloy
wheels, 5 segment-spoke design, size 9J
x 20, with 265/35 R 20 tyres[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PQD[/TD]
[TD]PACK_SPORT_DESIGN[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]WQR[/TD]
[TD][/TD]
[/TR]
[TR]
[TH]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH]Gearshift knob/gearshift handle[/TH]
[TD="class: prCode"]7F9[/TD]
[TD]Gearshift knob/handle in plastic/leather[/TD]
[/TR]
[TR]
[TH]Self pick-up/special control[/TH]
[TD="class: prCode"]A00[/TD]
[TD]No self-collection[/TD]
[/TR]
[TR]
[TH]Special labels[/TH]
[TD="class: prCode"]2KR[/TD]
[TD]Labels in English and German[/TD]
[/TR]
[TR]
[TH]Tail lamp assemblies[/TH]
[TD="class: prCode"]8SK[/TD]
[TD]Taillight assemblies with diodes (LED)[/TD]
[/TR]
[TR]
[TH]Closing/opening mechanism
tailgate/trunk lid/rear gate[/TH]
[TD="class: prCode"]4E7[/TD]
[TD]Tailgate/trunk lid power closing[/TD]
[/TR]
[TR]
[TH]Bumper systems[/TH]
[TD="class: prCode"]2K7[/TD]
[TD]bumper reinforced[/TD]
[/TR]
[TR]
[TH]Seat belt reminder[/TH]
[TD="class: prCode"]9P3[/TD]
[TD]Seat belt reminder, electric contact in
buckle[/TD]
[/TR]
[TR]
[TH]seat covers[/TH]
[TD="class: prCode"]N1V[/TD]
[TD]Seat trim covers in leather[/TD]
[/TR]
[TR]
[TH]Seat adjustment[/TH]
[TD="class: prCode"]3L4[/TD]
[TD]Power seats in front, driver seat with
memory feature[/TD]
[/TR]
[TR]
[TH]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH]Safety certificates[/TH]
[TD="class: prCode"]0LL[/TD]
[TD]With special labels
safety certificates for England[/TD]
[/TR]
[TR]
[TH]Start-stop system/regenerative braking[/TH]
[TD="class: prCode"]7L8[/TD]
[TD]Start-stop system with regenerative
braking[/TD]
[/TR]
[TR]
[TH]Lane change system/lane keeping system[/TH]
[TD="class: prCode"]7Y0[/TD]
[TD]no lane change assistant[/TD]
[/TR]
[TR]
[TH]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH]Sun blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH]Control of production/pre-production[/TH]
[TD="class: prCode"]FA0[/TD]
[TD]Control of series production[/TD]
[/TR]
[TR]
[TH]Headlamp washer system[/TH]
[TD="class: prCode"]8X1[/TD]
[TD]Headlamp washer system[/TD]
[/TR]
[TR]
[TH]Intermittent windshield wiper control/
light/rain sensor[/TH]
[TD="class: prCode"]8N6[/TD]
[TD]Windshield wiper intermittent control
with light/rain sensor[/TD]
[/TR]
[TR]
[TH]Special approval measures[/TH]
[TD="class: prCode"]3M3[/TD]
[TD]Passenger car design[/TD]
[/TR]
[TR]
[TH]Nameplate set[/TH]
[TD="class: prCode"]0NB[/TD]
[TD]Nameplate set in basic style[/TD]
[/TR]
[TR]
[TH]Thermal insulation insert
(beverage holder)[/TH]
[TD="class: prCode"]KT0[/TD]
[TD]Without thermal insulation insert (cup
holder)[/TD]
[/TR]
[TR]
[TH]Door and tailgate/trunk lid locking
mechanism[/TH]
[TD="class: prCode"]4K4[/TD]
[TD]Central locking w/ radio remote control[/TD]
[/TR]
[TR]
[TH]Type-approval testing countries/
countries with specific requirements[/TH]
[TD="class: prCode"]B09[/TD]
[TD]Type approval country GB/Northern
Ireland[/TD]
[/TR]
[TR]
[TH]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D7[/TD]
[TD]Carrier frequency 868 MHz
without panic button[/TD]
[/TR]
[TR]
[TH]Transport protection[/TH]
[TD="class: prCode"]NT1[/TD]
[TD]Transit coating (type 2)[/TD]
[/TR]
[TR]
[TH]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QV3[/TD]
[TD]digital radio reception[/TD]
[/TR]
[TR]
[TH]Installation parts for engines
(engine mount system)[/TH]
[TD="class: prCode"]1VH[/TD]
[TD]Installation parts for six-cylinder
engine[/TD]
[/TR]
[TR]
[TH]Front-end underbody cladding[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH]Identification labels[/TH]
[TD="class: prCode"]1EX[/TD]
[TD]Special identification label for EC
for M1 passenger vehicles[/TD]
[/TR]
[TR]
[TH]Type signs[/TH]
[TD="class: prCode"]2Z1[/TD]
[TD]Type sign at rear
and "Quattro" nameplates respectively[/TD]
[/TR]
[TR]
[TH]First aid kit/warning triangle[/TH]
[TD="class: prCode"]1T2[/TD]
[TD]warning triangle[/TD]
[/TR]
[TR]
[TH]Front seats[/TH]
[TD="class: prCode"]Q1D[/TD]
[TD]Sports front seats[/TD]
[/TR]
[TR]
[TH]Telephone/telematics[/TH]
[TD="class: prCode"]9ZF[/TD]
[TD]preperation for mobile phone with hands free teleph.[/TD]
[/TR]
[TR]
[TH]Maintenance contract[/TH]
[TD="class: prCode"]EW0[/TD]
[TD]Without maintenance contract[/TD]
[/TR]
[TR]
[TH]Thermal energy storage system/auxiliary
heater[/TH]
[TD="class: prCode"]7E6[/TD]
[TD]Electric auxiliary air heater[/TD]
[/TR]
[TR]
[TH]Windshield[/TH]
[TD="class: prCode"]4GQ[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH]Central display and control unit[/TH]
[TD="class: prCode"]QW1[/TD]
[TD]Central control unit in front[/TD]
[/TR]
[TR]
[TH]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH]Decorative trims[/TH]
[TD="class: prCode"]4ZB[/TD]
[TD]Bright decorative trims[/TD]
[/TR]
[TR]
[TH]Additional body protective covers, side[/TH]
[TD="class: prCode"]6EA[/TD]
[TD]Without additional side body covers
(stone guard)[/TD]
[/TR]
[TR]
[TH]Additional child seat anchorage[/TH]
[TD="class: prCode"]3B4[/TD]
[TD]Child seat anchors for
child seat system ISOFIX[/TD]
[/TR]
[TR]
[TH]Ignition locking system/electronic
steering column lock[/TH]
[TD="class: prCode"]0RC[/TD]
[TD]Starter switch locking system[/TD]
[/TR]
[TR]
[TH]Auxiliary heater[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
