2015 Skoda Octavia 1.4 TGI CNG 110PS CPWA
maros4341
Slovakia
C?ID=8477
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 2B 42 44 52 55 5F
VIN: TMBAM7NE4F0040869   Mileage: 196636km-122183miles
Address 01: Engine (J623-CPWA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 N    HW: 04E 907 309 E
   Component: 1.4l TSI CNG  H12 7572
   Revision: WIH12---
   Coding: 01190072232401081000
   Shop #: WSC 73430 031 00121
   ASAM Dataset: EV_ECM14CSI01104E906016N 001006
   ROD: EV_ECM14CSI_VW37.rod
   VCID: 2D06FE797D9D00EF51F-8078
   CAN Converter 01:
7 Faults Found:
15361 - Oxygen (Lambda) Sensor Signal B1 S2
          P2271 00 [096] - too Rich
                    Mileage: 195851 km
                    Date: 2019.07.08
                    Time: 09:37:28
                    Engine speed: 1971.50 /min
                    Normed load value: 8.2 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 63 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 14.630 V
                    Unlearning counter according OBD: 10
                    Oxygen sensor 2 bank 1 internal resistance limit value: 130320 Ohm
                    Mass flow through throttle valve: 13.7 kg/h
10204 - Misfire detected during Nat.Gas Operation
          P3361 00 [104] - -
                    Fault Frequency: 8
                    Mileage: 196394 km
                    Date: 2019.07.14
                    Time: 06:45:42
                    Engine speed: 1373.50 /min
                    Normed load value: 55.7 %
                    Coolant temperature: 54 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 12.863 V
                    Mass flow through throttle valve: 44.3 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
10195 - Cylinder 1 Misfire detected during Nat.Gas Operation
          P3362 00 [104] - -
                    Mileage: 196394 km
                    Date: 2019.07.14
                    Time: 06:46:41
                    Engine speed: 2080.00 /min
                    Normed load value: 65.5 %
                    Vehicle speed: 17 km/h
                    Voltage terminal 30: 12.627 V
                    Mass flow through throttle valve: 117.8 kg/h
10199 - Cylinder 3 Misfire detected during Nat.Gas Operation
          P3364 00 [104] - -
                    Fault Frequency: 8
                    Mileage: 196394 km
                    Date: 2019.07.14
                    Time: 06:46:41
10201 - Cylinder 4 Misfire detected during Nat.Gas Operation
          P3365 00 [104] - -
                    Mileage: 196413 km
                    Date: 2019.07.14
                    Time: 20:03:19
10197 - Cylinder 2 Misfire detected during Nat.Gas Operation
          P3363 00 [104] - -
                    Fault Frequency: 8
                    Mileage: 196394 km
                    Date: 2019.07.14
                    Time: 06:46:41
4116 - Oxygen (Lambda) Sensor B1 S1
          P2196 00 [237] - Signal too High (Rich)
                    Mileage: 196148 km
                    Date: 2019.07.11
                    Time: 22:08:13
                    Engine speed: 1918.50 /min
                    Normed load value: 16.5 %
                    Vehicle speed: 57 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 13.994 V
                    Oxygen sensor 1 bank 1 fast offset adaptation counter: 12
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 61754000000244
   Coding: 1A076A912424116C007F060641CC295856248800608294F000230070C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44D0BBDDCE17E1A7AE1-8010
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 105
                    Mileage: 151708 km
                    Date: 2016.10.31
                    Time: 00:19:15
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Fault Frequency: 205
                    Reset counter: 50
                    Mileage: 154010 km
                    Date: 2017.02.04
                    Time: 21:09:23
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 48
                    Mileage: 195051 km
                    Date: 2019.06.22
                    Time: 20:38:30
   Revision: 00021000    Serial number: 0338552084
   Coding: 030C0C
   Shop #: WSC 73430 790 00121
   VCID: 3A2CC525BCD3A757C4D-806E
   Part No SW: 5E0 907 044 N    HW: 5E0 907 044 N
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 01010004000100011005000100101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 3038E70D6AAF6D077A9-8064
   Air quality sensor:
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [008] - Open or Short to Plus
                    Reset counter: 38
                    Mileage: 196267 km
                    Date: 2019.07.13
                    Time: 09:02:54
                    Voltage terminal 30: 13.9 V
                    Outside air temperature: 19.5 °C
                    Interior temperature: 27.6 °C
                    Right temperature flap: actual value: 53
                    Right temperature flap: actual value: 12.0 %
                    Right temperature flap: specified value: 53
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011417400836
   Coding: 0C010B66424722FB07A04082B11C07080800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 005877CD9A8F3D87CA9-8054
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140623  041 0570
   Serial number:         140625101810
   Coding: 065DDD
   Component: RLHS  037 0059
   Serial number: S4Y14M07D03H00M43S54
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY140974T23
   Serial number: 00000000000030072804
5898 - Bulb for Rear Left Side Turn Signal
          B12D0 15 [008] - Open or Short to Plus
                    Reset counter: 39
                    Mileage: 196377 km
                    Date: 2019.07.13
                    Time: 19:29:12
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331417805554
   Coding: 0031051041
   Shop #: WSC 73430 790 00063
   VCID: 3D26CE39ADFD906FE1F-8068
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PC2N9HY
   Coding: 98CCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5AF431E771427FB33-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 506 14
   Serial number: 3576U000000E282CFF0X
   Subsystem 2 - Part No SW: -----------    HW: 454 001 506 14
   Serial number: 3586U0000003D62CFF0W
   Subsystem 3 - Part No SW: -----------    HW: 454 802 506 14
   Serial number: 3516RC774F3030000007
   Subsystem 4 - Part No SW: -----------    HW: 454 802 506 14
   Serial number: 3526RE39DEF03000000S
   Subsystem 5 - Part No SW: -----------    HW: 454 801 905 14
   Serial number: 3556V61459F030000007
   Part No SW: 5Q0 953 507 EE    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 29061404401688
   Coding: 1400
   VCID: 7DA60E39ED7D506FA1F-8028
   Part No SW: 5E0 920 752     HW: 5E0 920 752
   Component: KOMBI         304 4280
   Coding: 07A401102980000801086A001000000000000000
   VCID: 639258416BD9869FB7B-8036
13639427 - Databus
          [Steuergerät für Motor: bitte Fehlerspeicher auslesen]
                    Reset counter: 48
                    Mileage: 196315 km
                    Date: 2019.07.13
                    Time: 12:47:47
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002195691
   Coding: 030100042F085700EF00024A080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42DCBDC5D403EF979CD-8016
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Serial number: 000000000A0072180614
   Serial number: 2347573603
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 02018F6B74745D545420363E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B02F06143890EDF4FB-807E
   Revision: 00000000    Serial number: 14000155014002
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3430EB1D9EB751271E1-8060
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000108803497
   Coding: 00150020D000040000001100
   Serial number: 00000000000003021067
   Coding: 010200
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 0102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DEB2C9D105F48F857-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000108960853
   VCID: 43D2B8C1CB19E69F97B-8016
   Serial number: 00000000000003077930
   Coding: 190200
   Coding: 03DA02003F000000
   VCID: 40D8B7CDDA0FFD878A9-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 864 A    HW: 5E0 035 864 A
   Component: MU-S-N-ER     041 0435
   Serial number: S3F02906140753
   Coding: 03730101FF00000011110001000800002F0000840100010046
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 25160659256D38AF99F-8070
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: SKZ8Z9PT3002UF
   Subsystem 2 - Part No SW: 5E0 051 236 E    HW: -----------
   Component:  ECE 2014/15  --- 0040
Emulino
Slovakia
C?ID=103006
Hi, did you find solution for misfire cylinders during natural gas operation? I have the same intermittent fault on Octavia 1,4 CNG. During petrol operation everything works fine. Regards,
Trowbridge, UK
Ahoj, podarilo sa ti vyriesit vypadok zapalovania na octavii CNG pocas chodu na plyn? Mne vypadavaju vsetky valce, system prepne na benzin a auto ide bez problemov. Hlava je po GO. Vdaka
The language of this forum is English, please post only in English :thumbs:
