Hi all, totally new here.
Got my T6 California just 2 month ago, bought a HEX-V2 to do some changes like auto-lock and CH/LH on fogs.
My question concerns the auxillary heater.
I upgraded it to a parking heater using a plug and play solution. (https://www.cum-cartec-shop.de/VW-T6-Zuheizer-zur-Standheizung-Plug-Play.html)
(It's a sort of Can-gateway)
Everything works fine, exept
1: The (fresh) air blower starts already 3 minutes after the heater starts
2: The main problem: it starts with the Climatronic on Auto, 22deg, and blower on max., draining the battery.
I read in a German forum that in some cars the Climatronic starts on the last used settings. Is this somehow posibble in VCDS?
I would be nice if the blower starts at a certain water temperature, but that not the most important
Thanks!
Jaap
Autoscan is added
Thanks!
Jaap
Autoscan is added
Thursday,19,March,2020,19:30:35:04391
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ7HZJH0XXXXX License Plate:
Mileage: 24900km-15472mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 14 15 17 18 19 25 3C 55 5F 61 69 0B
VIN: WV2ZZZ7HZJH0XXXXX Mileage: 24900km-15472miles
Address 01: Engine (2D2D2-CXEB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 LB HW: 04L 907 445 A
Component: R4 2.0l BTD H03 6177
Revision: 23101001
Coding: 0019401C435401080000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_ECM20BTD03004L906056LB 004008
ROD: EV_ECM20BTD03004L906056KT.rod
VCID: 78A9EEA1025259B7F15-802C
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 63157000001821
Coding: 617E4098656B848086790278A68721D278F500
VCID: 3FDB45BD67FCAE8FF0F-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 10111713470690
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F8B920766787BB9-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 R HW: 7E0 907 040 R
Component: ClimatronicT5 H04 0613
Revision: 00001K04
Coding: 0000018123
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 323D1C89A4AE73E70F1-8066
Slave 1:
Subsystem 1 - Part No SW: 7E0 907 049 A HW: 7E0 907 049 A
Component: Heckbedienung H04 0044
Serial number: PAG00227101700010113
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 317170381
Coding: B8A839B84B61341293284F406D8B8BDCC094738960CD79703304003F0860
Shop #: WSC 02739 534 196175
VCID: 2B0301ED8304222F4C7-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 251017 04 47 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 7E0 959 801 N HW: 7E0 959 801 N Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0653
Serial number: KU0KU008111773121316
Coding: 0400A1
Subsystem 3 - Part No SW: 7E0 959 802 R HW: 7E0 959 802 R Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 005 0653
Serial number: KU0KU001111773051090
Coding: 1400A1
Subsystem 4 - Part No: 7E1 951 172
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29170002189300077437
Coding: B4FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231729905015
Coding: 31800C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BFD385612808FF36B-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Serial number: 1411170440AAE5
Coding: 00004800FE0779
Shop #: WSC 01383 790 50316
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 3635209948C66FC7239-8062
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 16101700550001
Coding: 000180
Shop #: WSC 02759 790 00000
VCID: 270BFDDD9FEC064FA8F-8072
Part No SW: 7E0 959 655 H HW: 7E0 959 655 H
Component: VW10Airbag01R H08 0018
Revision: -------- Serial number: 003V40041527
Coding: 000000000000000000000000000000003152
Shop #: WSC 02734 790 50316
VCID: 3B2331AD73E4B2AFDC7-806E
Serial number: 3495ZRB400I5BMP6P9BF
Serial number: 3505ZRB400I5BMP699P5
Part No SW: 7E0 920 880 S HW: 7E0 920 880 S
Component: KOMBI H04 1109
Coding: 140F010300
VCID: 3A2D34A97CDE8BA7C71-806E
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 A HW: 7E0 963 273 A
Component: STH-T5GP2 003 0009
Coding: 4101
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B0301ED8384222F4C7-807E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 04220F
VCID: 6889BEE15272C937615-803C
Component: IMMO H04 1109
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC4E94CFEFB27771-803E
Part No SW: 7E0 907 566 C HW: 4H0 907 566 F
Component: SWA Master H08 0030
Serial number: 0459912795
Coding: 030321
ROD: EV_LaneChangAssis_VN75.rod
VCID: 30391681AAA241F7795-8064
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 7E0 907 568 C HW: 4H0 907 568 F
Component: SWA Slave H08 0030
Serial number: 0457529406
Coding: 030321
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Coding: 0FC2020001000000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0468
Serial number: VWZAZ2T5464584
Coding: 06570001FF00000011111101008808031F0100D4002001004F
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 2517F7D5E560145F9A3-8070
Subsystem 1 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 530B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Serial number: 758857000017103102F2
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000459581863
Coding: 410D000103000000
VCID: 323D1C89A42E73E70F1-8066
Address 0B: Sec. Air Heating Labels: None
Part No: 7E0 819 006 M
Component: J604 Standheizung 0401
Revision: L100400A Serial number: 00000000000000
VCID: 313F1385AD3848FF76B-513C
End----------(Elapsed Time: 02:21, VBatt start/end: 12.2V/12.1V)-----------
