Hi,
just hoping someone could shed some light on a ABS problem I am having with my wifes car.
A little history first
It had an ABS fault so I plugged in and vagcom could not communicate with module, I read a little and found it was most likely the ABS module gone bad. So I looked online and sent it to cheap ABS, I got it back plugged in and the ABS fault had gone (brake error warning light) and vagcom could communicate and told me of a few codes, scan below:
Saturday,31,January,2015,15:34:28:34201
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Mileage: Repair Order: rene dub
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Control Module Part Number: 3B0 614 111
Component and/or Version: ABS/ASR 5.3 FRONT D00
Software Coding: 00021
Work Shop Code: WSC 05314
VCID: 53AF696EA170D1B9829-508E
30-00 - Open or Short to Plus
18258 - Powertrain Data Bus
P1850 - 35-00 - Missing Message from ECU
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
I replaced the RHS ABS sensor, as I thought it was a simple sensor failure and logged in to watch the wheel speeds on all corners and confirmed no speed pick up on that wheel. cleared the codes, re scanned and it was the same as before. All the wiring looks good as do the connections.
A little more online searching led me to the coding of the ABS module which may be wrong. sure enough, the coding is 00021 which is for a 1.8t with 5 speed auto with canbus, this car is a 2.8 with a 5 speed without canbus (I think).
so I tried to change the coding, but the ross tech wiki says it cannot change the coding although I did try.
would this cause the fault or am I missing something else. The other 2 faults support that the ecm is looking for coms on the canbus but as its not present it cant communicate. Any ideas?
thanks.
thanks.
