P0301
eman
Chicago, USA
C?ID=181824
000769 - Cylinder 1 P0301 - 000 - Misfire Detected
eman
Chicago, USA
C?ID=181824
I have a VW Jetta Wagon 2.0T FSI and I am having a cylinder 1 misfire.
eman
Chicago, USA
C?ID=181824
Here is my engine fault code:
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AF HW: 1K0 907 115 AD
Component: 2.0l R4/4V TFSI 0010
Revision: E3H12--- Serial number: VWX7Z0H82460LT
Coding: 0403010818070160
Shop #: WSC 00066 000 00000
VCID: 6A8ECB7AE074EB4793D-803E
000769 - Cylinder 1
Mileage: 120453 km
Time: 09:07:14
RPM: 2985 /min
Load: 16.5 %
Speed: 26.0 km/h
Temperature: 93.0°C
Temperature: 29.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
Readiness: 0110 1101
eman
Chicago, USA
C?ID=181824
The car misfires when idle and when I'm driving it the misfire goes away!
eman
Chicago, USA
C?ID=181824
I have check the spark plugs and the coils!
eman
Chicago, USA
C?ID=181824
The cables look ok! Seem to have a vacuum leak so changing the Engine Crankcase Vent Valve but I still think something is wrong! Is it my fuel injector or do I have a bent valve. I check the compression on all cylinders and got 90 PSI on 2, 3, and 4 but 1 only had 60 PSI. I need to know if I should take out the head and check the injector and walnut blast the valves?
eman
Chicago, USA
C?ID=181824
There is no coolant in my oil so I don't have a cracked head!
eman
Chicago, USA
C?ID=181824
The car starts to vibrate after sitting there idle then I get the code P0301. It misfires and I can clear the code and the car is fine again!
eman
Chicago, USA
C?ID=181824
Checked my FUEL RAIL and the pressure increased after and I turned the car off! I can't get this figured out. What is wrong with this car!?
Hi and welcome.
Is this your first time on a forum? Normally, one would put all the above information into just one post rather than ten different ones where you're replying to yourself. ;)
Fuel pressure rising after the engine has been shut down is normal. It's due to the fuel in the rail no longer moving and warming up from the residual heat of the engine.
The first thing I would do with a single cylinder misfire is to swap the plug and coil from that cylinder to a different one. If the problem moves with them, then you know it's either that plug of that coil. If it doesn't, then it's something else. Next I would try swapping the injector for that cylinder with a different one.
eman
Chicago, USA
C?ID=181824
I have switched the coils! The problem stays with cylinder one! I have not swapped the injector. It is a very long process taking everything out for this test. I need to make sure before I move the injector. Thank you so much for your response!
eman
Chicago, USA
C?ID=181824
Do you know how to test the injectors with VCDS!?
A scan tool cannot "test injectors" beyond perhaps actuating them momentarily, but you already know they would pass such a test because the engine smooths out when you drive the car.
eman
Chicago, USA
C?ID=181824
Just got my new vent valve. I put it in and now it seems the vacuum leak is in another location. This adds to the misfire! The oil cap and dip stick have vacuum. I need to fix this before I move to the injectors!
Gone But Not Forgotten
Did you install the N80 vent valve in proper direction and check intake for leaks directly?
Did you know that before doing any swapping of anything, a compression check should be done to determine if the cylinder is in proper order mechanically?
If it is not with maximum specified numbers & observed via RTFB maybe look at carbon build up on intake valves and inspect intake gasket real good before doing an injector swap, because did you know a compression check can be done with intake off during inspection?
