ABS CODING LOST, ANYONE HELP PLEASE (MK60EC1)
Shuhel
Birmingham, UK
C?ID=368132
Tuesday,17,March,2020,21:34:54:58999
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1KZBW306741   License Plate:
Mileage: 101430km-63025mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZBW306741   Mileage: 101430km-63025miles
   Part No SW: 03L 906 018 AT    HW: 03L 907 309 R
   Component: R4 2.0l TDI   H23 9977
   Revision: 42H23---    Serial number: 00000000000000
   Coding: 001D0012042500080000
   Shop #: WSC 00110 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018AT 003012
   ROD: EV_ECM20TDI01103L906018_003_VW36.rod
   VCID: 7CA1F56B7665009795D-8028
5286 - Throttle Position Sensor (G69)
          P0121 00 [237] - Implausible Signal
                    Mileage: 101261 km
                    Date: 2020.03.16
                    Time: 05:58:22
                    Engine speed: 568.50 /min
                    Coolant temperature: 63 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 13.300 V
                    Air mass: actual value (mg/stroke): 473.5 mg/stroke
                    Throttle valve adapter: specified value: 0.00 %
                    Throttle valve adapter: actual value: 6.93 %
                    Throttle valve adapter: offset closed: -9.44 %
                    Throttle valve adapter: status-Bits 0-7: 0
                    Throttle valve adapter: status-Bits 0-7: 8
                    Throttle valve adapter: status-Bits 0-7: 55
                    Throttle valve adapter: uncond voltage actual value: 1099.6 mV
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 054 J    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2602
   Revision: 05351113    Serial number: 00001104050603
   VCID: 1D67D8EF81BFA99FC23-8048
   Revision: 00H31001
   VCID: 76B5E74348C95AC7E39-8022
                    Reset counter: 151
                    Date: 2014.08.06
                    Time: 23:37:57
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 43008
                    Fault Status: 01100101
                    Reset counter: 151
                    Mileage: 101171 km
                    Date: 2014.08.06
                    Time: 23:37:57
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 279
                    Count: 43008
                    Reset counter: 151
                    Mileage: 101171 km
                    Date: 2014.08.06
                    Time: 23:37:57
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 295
                    Count: 43008
                    Reset counter: 151
                    Mileage: 101171 km
                    Date: 2014.08.06
                    Time: 23:37:57
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 270
                    Count: 43008
   Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3C21356B36E5C097D5D-8068
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AE
   Coding: 48180A3A8825F1C040080080340000E443510088536D8160648000200040
   VCID: 2F3B1227F7132B0F60F-807A
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 30031  26  0512
   Coding: 009795
   Component: RLS 090411 05  54  0403
   Coding: 0330AD
                    Reset counter: 153
                    Mileage: 101171 km
                    Date: 2014.08.06
                    Time: 23:38:04
                    Voltage: 12.35 V
                        Term 50 Off
                    Reset counter: 151
                    Mileage: 101171 km
                    Date: 2014.08.06
                    Time: 23:42:13
                    Voltage: 14.15 V
                        Term 50 Off
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 22
                    Reset counter: 153
                    Mileage: 101171 km
                    Date: 2014.08.06
                    Time: 23:42:13
                    Voltage: 14.15 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12501108800790
   Coding: 108101
   VCID: 3829297B025DECB7315-806C
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA3RU91
   Coding: 00003948
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 313F145FE1A73DFF76B-8064
   Serial number: 3572MSME4E08065EZZZ1
   Serial number: 3582MSME386E635DZZZ9
   Serial number: 3512QSME423F092DZZZ$
   Serial number: 3522QSME4C570A3DZZZ3
   Revision: --------    Serial number:  90440KD8000ZY
   Coding: 1882140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B5E74348495AC7E39-8022
   Serial number: 40000000000000316335
   Coding: E20000
448019 - Multi-Function Switches in Steering Wheel; Left
          B114B 96 [008] - Component internal failure
                    Reset counter: 191
                    Mileage: 101171 km
                    Date: 2020.03.15
                    Time: 23:38:17
   Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
   Coding: 470B00
   VCID: 2D07082FFD9F591F523-8078
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 140411F2000089
   Coding: 350003
   VCID: 3039115BEA2D34F7795-8064
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC3330CF18E27771-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669766642
   VCID: 2809F93BD2FD7C37A15-807C
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2120
   Coding: 0000692
   VCID: 313F145FED273DFF76B-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 34311D4B123508D71DD-8060
                    Fault Status: 11100101
                    Mileage: 101171 km
                    Date: 2014.08.06
                    Time: 23:38:29
                    Battery Volts: 12.1 V
                        DD
                    Temperature: 12.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0000948
   VCID: 33331E57173B0FEF047-8066
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  041 0166
   Revision: 00000001    Serial number: VWZ1Z3L0742023
   Coding: 0100040004
   VCID: 2615F703D8E96A47939-8072
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 3537204F194F11DF2A3-8060
   Coding: 0000144
   VCID: 3635274304491AC7239-8062
   Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669717369
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 2411ED0BAE5598578DD-8070
End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.3V)-----------
Jef
HQ
VCDS automatically saves Auto-Scans. If an Auto-Scan was performed prior to the soft coding being lost, you can retrieve that information. Details here.
Shuhel
Birmingham, UK
C?ID=368132
hello jef, this vehicle was not scanned before,
I believe the factory condition 03-ABS coding of WVWZZZ1KZBW306741 was:
163B400D09220000681202E8901A0082310000
Vehicle Identification No.WVWZZZ1KZBW306741
ModelGolf 2,0 GOLF
Date of production19.04.2011
Model year2011
Sales type5K1373
Engine CodeCFFB
Transmission CodeMSV
Axle drive6A
EquipmentFW
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HAVehicle class differentiation -1K0/5K0-
tail pipe0P1Rear side exhaust tailpipe
Hill start assistUG1Hill start assist
Emission standard7MGEmission standard EU5
Trailer hitch1D0Without trailer hitch
airbag4UPAirbag for driver and front passenger with knee airbag and front passenger airbag deactivation
Aktivkohlebehälter / Ottopartikelfilter1E0Without activated carbon canister
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XGExterior mirrors with memory feature, power-adjustable/heated
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8CComfort equipment
Brake type in rear1KDDisc brakes in rear
batteriesJ0NBattery 330 A (61 Ah)
Brake type, front1ZEDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0NComponent parts set, complying with vehicle type for Great Britain, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
Operating voltage9Z0Operating voltage 12 V
Brake pad wear indicator9U1Brake pad wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
Chrome packageQJ1Chrome package
General operating permit, alterationsC36Operating permit, alteration
Roof insert/convertible top3FAWithout roof insert (standard roof)
Suspension system in rear1JARear shock absorption, basic version 1
Suspension system in frontG07Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G5Filler neck module 1 without insert
Installation differentiation for components0ESInstallation differentiation for transmission DQ250 -- vehicle components --
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Inserts5MBDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X2Park distance control in front and rear
Electric interface for external useUF6Electric interface for external use (MEDIA-IN jack)
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL1Extended pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K3Separate daytime running light with automatic headlight control and Coming Home feature
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YCWeight range 3 installation control only, no requirement forecast
Weight category front axleL14Suspension range 14 installation control only, no requirement forecast
Base engineTL44-cylinder diesel engine 2.0 l unit 03L.L
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U1Folding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG1A6-speed automatic transmission
handle for hand brake lever6PCHand brake lever handle in leather
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating and air-conditioning systemKH6Air conditioning system with electronic control
Headlamps8BKTwin headlamps for driving on the left, with integrated high beam
Customized installationFC0Without customized installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5BInstrument cluster, mph speedometer -Great Britain-
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8GHatchback
Refrigerator1W2Glove compartment cooling system
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Rear head restraints3T2Three rear head restraints
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel tank treatment2LDFuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems0F5Fuel system for diesel engine
Body measures5C0Without special body measures
Radiator grille6KCRadiator grille
License plate lightingKL0Standard license plate lighting
Rear license plate carrier6P1Rear license plate carrier (ECE)
Front license plate carrier6W1Front license plate carrier (large)
Paint preservative/transit coating5K7Transport protection film (minimum protection) with additional transport protection measures
Paint coatingFB0standard paint coating
Steering system arrangementL0RRight-hand drive
Reading lamp8S4Two reading lights in front, two in rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Air duct, front areaVK1Air duct, type 1
Light control systems8G0Without Light Assist
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels2PPLeather-wrapped multi-function steering wheel
Speaker installation8RM8 speakers (passive)
Headlight range control8Q1Headlight range control
Center armrest6E3Center armrest in front
Marten repellerUM0Without marten repeller
Multi-function display/trip computer9Q5Multi-function display with control
Engine cooling8Z5not hot country
Engine specificationsD914-cyl. turbo diesel engine 2.0 l/103 kW (4V) TDI common rail; Base engine: TG3/ TJ3/TU3/TU4/TL4/TP4/TM3/TW3/TR4/TS1/TN5
Left vanity mirror4SDVanity mirror, left, illuminated
Right vanity mirror4TDVanity mirror, right, illuminated
Navigation device7Q0without navigation system
rear fog lamp8TDRear fog light for driving on the left
Front fog lamp/additional headlamp8WAWithout fog lights
Upgrading measuresGP1Vehicles with special upgrade measures
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCB9Alloy wheels 6.5J x 16
Radios8AIRadio "RCD510 MP3"
Smoker's/non-smoker's package9JBSmoker's package, ashtrays in front and rear
Tire pressure monitoring system7K0Without tyre pressure monitor
tireHH7Tires 205/55 R16 91V
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G6Space-saving spare wheel
Restraint systems, front3QT3-point seat belts in front, with pretensioner and height adjustment
PJ8"Pescara" - 4 alloy wheels 6.5J x 16
PLA"Lights & Vision" Pack
PU2Multi-function leather steering wheel
RHZRadio CD "510" con lector de MP3, 4x20 W, 8 altavoces, con pantalla táctil
W4BPower windows front and rear
WD5Anti-theft alarm system including single door opening
WDAPark distance control
WX5Match Country: GB
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Tail lamp assemblies8SARear combination lamp, standard design
Locking mechanism for boot lid/cover rear4E0Tailgate/trunk lid unlocking from outside
Front seat, left3TFComfort seat in front, left
Front seat, right3SFComfort seat, front right
Nameplate for sales nameQD1Nameplate for sales name
Seat belt check9P3Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
Center rear seat belts3C73-point seat belt for center rear seat
seat coversN3BSeat trim covers in fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Safety head restraint system3K0w/o safety head restraint system
Side lights7R3Side turn signals (white)
Start-stop system/regenerative braking7L3Without start-stop system without regenerative braking
Horns8Y1Two-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
power outlet7B212 volt socket in luggage compartment
Bumper2JBStandard bumpers
Rear stabilizer bar0BDRear stabilizer bar
Front stabilizer bar0ADFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Special approval measures3M0Without special measures
Nameplate set1DGNameplate set "TDI"
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5 Hz
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A24 doors
TV reception/digital radio receptionQV3digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification label for EC for M1 passenger vehicles
Delivery equipment2A0Without delivery equipment
First aid kit / warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Telephone / telematics9ZBMobile phone interface High
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E6Electric auxiliary air heater
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W0without washer water level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TAwithout floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
