2015 Audi Q5 TDI Quattro - weird error codes
mik15
Romania
Hi guys,
been struggling for quite some time now with my Q5 and its moody behavior in terms of error thrown. The fact is that even when the error comes up the car drives just fine, doesn't go into limp mode, the gearbox acts perfectly normal with no issues whatsoever. The error on the IC stating "Gearbox Malfunction. Please stop and put it in P" disappears within a few seconds after coming up on the IC. Sometimes the check engine comes on as well, but again it goes away after couple of cycles and no errors are stored in the ECU. The gearbox error can be deleted and until the next time it will not come up.
I am just puzzled with this error as i don't really know where to start, i initially presumed it would be the gearbox, respectively the gear lever position sensor along with the shaft 1&2 sensors, but soon i have eliminated them as being the culprit since the gearbox works perfect.
Then i went on and looked deeper into the ABS unit, but again all seems to be working just fine, all ABS sensors doing their thing well, could the ABS module be the culprit?
Below is a full scan of the car. Looking on the www for these codes couldn't really find anything, that's what seems so strange...
Friday,13,March,2020,19:20:19:59543
VCDS Version: 19.6.2.2 (x64)
VIN: WAUZZZ8R0FA009088   License Plate:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 62 72 77 AC
VIN: WAUZZZ8R0FA009088   Mileage: 98860km-61428miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JN    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 2929
   Revision: 45H25---
   Coding: 2A254012232601080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018JN 003003
   ROD: EV_ECM20TDI01103L906018JN.rod
   VCID: 7F06E1ADE615EBB7DC-802A
   Part No SW: 8R1 927 156 J    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H02 0003
   Revision: --H02---
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 438EAD5DCA7D4F57F8-8016
8100 - Vehicle Speed Sensor
          P150E 00 [096] - Implausible to ABS Control Module
                    Reset counter: 39
                    Mileage: 98824 km
                    Date: 2020.03.12
                    Time: 19:12:16
                    Engine speed: 1032 /min
                    Transmission input speed: 1032 /min
                    Transmission output speed: 493 /min
                    Engine torque: -28 Nm
                    Transmission fluid temperature: 57 °C
                    Accelerator position: 0.0 %
                    Clutch status: Kupplung 1 kann Moment übertragen
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
   Component: ESP8 quattro  H09 0020
   Coding: 211DCC01
   VCID: 0E184C69D9BFF23F27-805A
   Part No SW: 8K0 907 064 JE    HW: 8K0 907 064 JE
   Component: BCM2 2.0      H14 0650
   Coding: 01A54000000000000000
   VCID: 7CFC16A1FF03F0AFF9-8028
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0514000075798018
   Part No SW: 8K1 820 043 BB    HW: 8K1 820 043 BB
   Revision: C1000000    Serial number: 01020620140371
   Coding: 342102E000
   VCID: 69D25FF58091750712-803C
                    Reset counter: 22
                    Mileage: 87317 km
                    Date: 2019.04.25
                    Time: 10:28:56
                    Temperature: 22.0°C
                    Fault Frequency: 188
                    Reset counter: 82
                    Mileage: 87317 km
                    Date: 2019.04.25
                    Time: 10:28:59
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000826514701
   Coding: 260000108134AFC00081400300001D0D0F1C470826090201000008004401030100000024000000
   Shop #: WSC 12345 123 61029
   VCID: 78F40AB1CB3BDC8F9D-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140515  H12 0050
   Serial number: 90243014140428155235
   Coding: 01DD13
   Serial number: 22710048
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002405140045
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Reset counter: 79
                    Mileage: 98802 km
                    Date: 2020.03.12
                    Time: 18:41:21
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003JPDC0SSPO
   Coding: 30463431313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4894BA71F35B6C0F2D-801C
   Serial number: 6334MSME453B013EE
   Serial number: 6344MSME453E08109
   Serial number: 6352QSME0D3F2876V
   Serial number: 6362QSME573F4A6C/
   Serial number: 63732SME7E51257C9
   Serial number: 63832SME01522458R
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NF5000IN
   Coding: 000017
   VCID: 4894BA71FB5B6C0F2D-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 T    HW: 8R0 920 930 T
   Component: KOMBIINSTR.   H35 0564
   Revision: 00200000    Serial number: ZD431326F
   Coding: 139F220003000008010000
   Shop #: WSC 06335 123 12345
   VCID: 458AB345CC497167D6-8010
                    Reset counter: 79
                    Mileage: 98802 km
                    Date: 2020.03.12
                    Time: 18:37:27
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V145180179
   Coding: 80CF07FF00
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 5301793403
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 14147000483011200410
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000104306091
   Coding: 011D03204000440004
   VCID: 4FA6916D1E35BB376C-801A
   Part No SW: 8R0 909 144 G    HW: 8R0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0013582509
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3C7CD6A1B78330AFB9-8068
   Revision: 00002001    Serial number: 0337317970
   Coding: 0104063820B900008720053680040047
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000104194866
   VCID: 4E988C69193FB23F67-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000460063
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A70D0B9BDB70E9FAB-806E
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 N    HW: 8R1 035 186 N
   Component: Concert3      H09 0470
   Revision: 00000003    Serial number: AUZ5Z6N2047563
   Coding: 0500048204058500435B071000
   VCID: 4084A251D36B544FE5-8014
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000104605400
   Coding: 010C03204000240004
   VCID: 4688B449F14F7A7FDF-8012
Gearbox current software version: 0003. Several newer versions are available (0004, 0005, 0006).
I'm not sure whether any of them will solve this problem, but since there are no faults in the ABS itself, if it were mine, I would try to get it updated at the dealer.
mik15
Romania
i still haven't figured out a solution to this issue and given the times we're going through at the moment haven't got to the dealer for a SW update. But, here is what i have noticed...the error comes up in 95% of the time when the car is coasting and my foot is off the accelerator pedal and then as soon as the speed drops below 30kmh the error message in the cluster goes away. It doesn't matter whether the car is cold or not, and i've had like 2 days in a row with no error at all. Mechanically there is absolutely no change when the error shows up, all works just fine.
I am now starting to think that maybe the ABS module has an issue...i still can't find anyone on the internet with this error...
mik15
Romania
could someone help me out with a wiring diagram for the ABS? Since all checks out with the ABS when doing the live diagnose i can only assume there is an issue with the wiring that briefly affects the communication between the ABS and the gearbox hence the error that shows up on the gearbox but not on the ABS...
South Molton, UK
You can get all the WD for your car by logging onto the European Audi version of the erWin website - since the WD are copyright we can't post them here.
mik15
Romania
so, here is some news, did today a SW update to version 006, gearbox behavior has changed a bit, as in it no longer up shifts to 2nd gear right away after taking off, which is really good. On the error side there is also a change, as in the error still shows up when looking with the VCDS but it no longer shows up in the cluster, the usual error message "Gearbox malfunction...." doesn't show up anymore, only the MIL comes on.
So problem only partially fixed, will try next to update the ABS software.
Zality007
Nairobi, Kenya
Hello, Did you find any other solution to this? I have the exact problem as you do. A software update has not resolved the issue though. Mine also pops up when coasting. Something similar to yours is the negative Engine Torque when the error occurs. I have logged this error multiple times and it always seems to have a negative engine torque - is this a valid value? Here are my error codes:
Thursday,15,October,2020,13:30:00:00009
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ8R1AA035515   License Plate: CJ
                Address 02: Auto Trans       Labels: 0B5-927-156.clb
Control Module Part Number: 8R0 927 156 AB    HW: 0B5 927 156 E
  Component and/or Version: 0B5 20TFSIRdW H04 0011
           Software Coding: 000001
            Work Shop Code: WSC 44879 000 1048576
              ASAM Dataset: EV_TCMDL501 A02203 (AU48)
                       ROD: EV_TCMDL501.rod
                      VCID: 7BF542EBF2E56997CC-802E
          P150E 00 [175] - Implausible to ABS Control Module
                    Mileage: 91642 km
                    Date: 2020.09.14
                    Time: 10:47:52
                    Engine speed: 1426 /min
                    Transmission input speed: 1426 /min
                    Transmission output speed: 418 /min
                    Transmission fluid temperature: 62 °C
                    Clutch status: Kupplung 2 kann Moment übertragen
Mari
C?ID=150535
... post a complete and unedited autoscan if you want us to help... we need all information about the car we can get... what modules are in the car, what software version, and how are they coded? All information we can find in the autoscan!
And please update your VCDS-software to the latest version...
Zality007
Nairobi, Kenya
Unfortunately i cannot update the software at the moment. Here is a full scan of the car:
Sunday,25,October,2020,12:22:51:00009
VIN: WAUZZZ8R1AA035515   License Plate: KCJ
Mileage: 91980km-57153mi   Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 42 46 52 53 55 56 57
          5F 62 6C 6D 72
VIN: WAUZZZ8R1AA035515   Mileage: 91980km-57153miles
0E-Media Player 1 -- Status: Malfunction 0010
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8R0 907 115 R    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0002
   Revision: E1H15---
   Coding: 0121000C240F0060
   Shop #: WSC 57819 714 96552
   ASAM Dataset: EV_ECM20TFS0118R0907115R 001002
   ROD: EV_ECM20AVS.rod
   VCID: 4385FA0BCA95D157C4-8016
2937 - Please Check Fault Codes in Transmission Control Module
          U1026 00 [038] - -
                    Mileage: 91981 km
                    Date: 2020.09.24
                    Time: 12:17:13
                    Engine speed: 1069.50 /min
                    Normed load value: 6.3 %
                    Vehicle speed: 60 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 46 °C
                    Ambient air pressure: 820 mbar
                    Voltage terminal 30: 13.476 V
Readiness: 0000 0001
   Part No SW: 8R0 927 156 AB    HW: 0B5 927 156 E
   Component: 0B5 20TFSIRdW H04 0011
   Revision: --H04---    Serial number: 0000000614
   Shop #: WSC 44879 000 1048576
          P150E 00 [167] - Implausible to ABS Control Module
                    Mileage: 91981 km
                    Date: 2020.09.24
                    Time: 12:17:13
                    Engine speed: 1196 /min
                    Transmission input speed: 1196 /min
                    Transmission output speed: 426 /min
                    Engine torque: -40 Nm
                    Transmission fluid temperature: 63 °C
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 025548
   VCID: 4A9BD72FE5BF001F07-801E
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 199
                    Mileage: 91981 km
                    Date: 2020.09.24
                    Time: 12:17:12
                    Hex Value: 0x3C00
                    Hex Value: 0x4006
                    Hex Value: 0x120B
                    Hex Value: 0x23B4
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0324
   Coding: 051500
   VCID: 04073917871B166FBD-8050
   Serial number: 0209000063397008
   Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D1000000    Serial number: 01080920090581
   Coding: 64156000
   VCID: 77FD5EDBC6CD4DF7A8-8022
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000460858
   Coding: 260010800030AF010001000300001D0D0F1D470802010141000000
   Shop #: WSC 44780 000 1048576
   VCID: 3C7781F7BF6BAEAF85-8068
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 090729  H10 0041
   Serial number: 90243015090717210517
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10595082
   Coding: 024D25
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000309090608
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H49 0050
   Revision: 00000015
   VCID: 2149508338C9E347B6-8074
02261 - Data Medium
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 199
                    Mileage: 91975 km
                    Date: 2020.09.24
                    Time: 12:06:12
                    Text: 00000000
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840925905948
   Coding: 300105
   VCID: 408FF507D383CA4FD9-8014
   Part No SW: 8R0 959 655 C    HW: 8R0 959 655 C
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003FQD05BVJ.
   Coding: 30453331313030303030554A305238523053
   VCID: 4487F917CF9BD66FFD-8010
   Serial number: 6334MSME4B53564DO
   Serial number: 6344MSME4A226B4FS
   Serial number: 6352QSME243B4802B
   Serial number: 6362QSME0D3B0A0ET
   Serial number: 63732SME3E3B443CA
   Serial number: 63832SME403C1A30X
   Revision: --------    Serial number: 90304II90003M
   Coding: 000033
   VCID: 3D718CF3A471A7A7B2-8068
   Part No SW: 8R0 920 930 B    HW: 8R0 920 930 B
   Component: KOMBIINSTR.   H10 0255
   Revision: 00000000    Serial number: CJI204999
   Coding: 2F0622000200000C010000
   VCID: 3365AACB923561D754-8066
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E098268344
   Coding: 00C303
   VCID: 52ABCF4F0DEF48DF7F-8006
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140665245
   Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001001344011
   Coding: 00781B00000044440000
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009281284
   Coding: 011D12205E01440004
   VCID: 4581E413CCA1EF67EA-8010
   Revision: 00002001    Serial number: 0121462987
   Coding: 01000E22203934810530050000000000
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009289046
   VCID: 4487F917C79BD66FFD-8010
   Revision: 00000003    Serial number: 10000000316838
   VCID: 3467A9D7973B66EF4D-8060
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   VCID: 3467A9D7573B66EF4D-8060
   Part No SW: 4F0 035 083 A    HW: 4F0 035 083
   Component: Radio U JP    H45 0055
   Revision: AB001007    Serial number: 336IX097507090
   Coding: 030000020100000001
   VCID: 1E336B7F09B7DCBF8B-804A
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 8F0 919 129 E    HW: 8F0 919 129
   Component: DTV-JP        H06 0760
   Revision: R0060000    Serial number: 79300600716402
   Coding: 100300
   VCID: 326BAFCF6D2F68DF5F-8066
   Subsystem 1 - Part No SW: 4F0 919 805     HW: 4F0 919 805
   Component: R204 TVKLeser  H07 0010
   Serial number: 2172800600320403
   Part No SW: 8T2 035 678 D    HW: 8T2 035 678
   Component: H-BN-JP       H10 0272
   Revision: --------    Serial number: K5FAN1 5830043
   Coding: 01060106000581EF41080B0E00000003
   VCID: 3F8DF6FBAE7DB5B7A0-806A
   Subsystem 1 - Part No: 8R0 060 884 H
   Component: JPN_10.02.09.  P130
   Component: DU7 High  H43 0306
   Serial number: 9356IU091066505
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000540437
02168 - Left Front Microphone (R140)
                    Fault Status: 01101100
                    Reset counter: 199
                    Mileage: 91975 km
                    Date: 2020.09.24
                    Time: 12:05:26
                    Voltage: 11.50 V
02169 - Front Right Microphone (R141)
                    Reset counter: 199
                    Mileage: 91975 km
                    Date: 2020.09.24
                    Time: 12:05:26
                    Voltage: 11.50 V
02288 - Control Module for Chip Card Reader (J676)
                    Reset counter: 199
                    Mileage: 91975 km
                    Date: 2020.09.24
                    Time: 12:05:34
                    Voltage: 11.50 V
02653 - Traffic Data Antenna (R173)
                    Reset counter: 199
                    Mileage: 91975 km
                    Date: 2020.09.24
                    Time: 12:08:46
                    Voltage: 13.60 V
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101870052
   Coding: 010C12204001240004
   VCID: 428BFF0FDD8FD85FCF-8016
   Part No SW: 8R0 907 441 B    HW: 8R0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J97C05Y
   Coding: 1022010
   VCID: 356194D35C417FE77A-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B7582EBBA65A9978C-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H27 0300
   Serial number: 8R0827852B
   Revision:             Serial number: 0000101870037
End-------------------------(Elapsed Time: 03:35)--------------------------
Viking
C?ID=151455
Any particular reason why not? It's free (for genuine customers) and doesn't take long at all. :thumbs:
