01044 - Control Module Incorrectly Coded 000 - - 2004 vw beetle cab MK60
DAP
C?ID=342053
This is my first post need help to code the abs module. Here is scan the abs module is the original I was told they sent it out for repair but the repair shop nothing was wrong. During my troubleshooting found a bent pin on the abs connector corrected it and here I am now thanks in advance.
Wednesday,11,March,2020,14:40:24:09909
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: 3VWCD31Y34M321134   License Plate:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCD31Y34M321134   Mileage: 101520km-63081miles
Address 01: Engine        Labels: 06A-906-032-AWV.lbl
   Part No: 06A 906 032 PS
   Component: 1.8l 5VT NBC AG6G   5107
   Coding: 00004
   Shop #: WSC 00066
   VCID: FEB0817AF8D140BF57-513C
   3VWCD31Y34M321134     VWZ5Z0C8092283
Readiness: 0110 1101
   Part No: 09G 927 750 P
   Component: AQ 250 6F           0387
   Coding: 0000008
   VCID: BE30417AE85180BF17-513C
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0018945
   Shop #: WSC 00001 785 00200
   VCID: B228654A2C0954DFE3-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AF
   Component: 05 AIRBAG VW71      0509
   Coding: 0012341
   Shop #: WSC 00066 000 00000
   VCID: FBB6886EBBC3559770-513C
   Subsystem 1 - Part No: 1C0 959 339
   Component: BF-Gewichtsens. 004 0004
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 951 N
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11234
   Shop #: WSC 26097
   VCID: AC147B325E2D022FA9-4B1E
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 00066
   VCID: F0ACAF42B28526CFD5-4B00
Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
   Part No: 1Y0 959 255
   Component:  VSG  NBC       ü
   VCID: FDB28676A5D75BA74E-513C
   Part No: 1C0 959 799 G
   Component: 6J Komfortgerát HLO 0004
   Coding: 00256
   Shop #: WSC 00066
   VCID: BB36486EAB43959730-4B00
   Subsystem 1 - Part No: 1Y1959801
   Component: 6J Tõrsteuer.FS KLO 0005
   Subsystem 2 - Part No: 1Y1959802A
   Component: Tõrsteuer.BF KLO 0005
   Subsystem 3 - Part No: 1Y0959811
   Component: 6J Tõrsteuer.HL KLO 0001
   Subsystem 4 - Part No: 1Y0959812
   Component: 6J Tõrsteuer.HR KLO 0001
            52-10 - Supply Voltage Too High - Intermittent
            62-00 - No or Incorrect Adjustment
End----------(Elapsed Time: 04:00, VBatt start/end: 14.1V/14.1V)-----------
DAP
C?ID=342053
did you get yours to work
MartinsX
Riga, Latvia
C?ID=268515
Check pins 38 and 14 very carefully. Are they ok at module side? Are corresponding contacts ok at connector side and are they connected together electrically at connector side? Or 38 is connected to 12, maybe?
DAP
C?ID=342053
I used a digital camera and verified all pins and the conector are in good shape Previously I found a pin bent and was getting left wheel speed sensor circuit problem once i corrected it the code whent away so now i have the module code issue.
MartinsX
Riga, Latvia
C?ID=268515
Ok, now take a DVOM, switch it to continuity test mode and check continuity between pins 38-14 and 38-12 (connector side)
DAP
C?ID=342053
all continuity checks good no codes except for code issue. I even checked wheel speed sensors using VCDS all check good.
United States
In reply to your PM, I suspect someone installed the incorrect ASR (non ESP) module. This is a temp screen shot of PL24 by VIN:
https://media.trillian.im/media/?m=...tB3hE9YOJ3Ez3Ft1aPUjqW0yAS4eMvol5ocxeHe9PKg==
If we were to look at scan data from a 1C0 907 379 M unit it would look like:
> Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
> Part No: 1C0 907 379 M
> Component: ESP FRONT MK60 0102
> Coding: 0019970
It also showed a slip ring for vehicles with ESP, brake pressure sensor and ESP dashboard switch so I'm reasonably confident it wasn't incorrect in regards to the ABS module type but do confirm the switch in the car has ESP printed on it.
DAP
C?ID=342053
Thanks I belive you are right the vehicle has the ESP button supposedly the unit in the vehicle was the origianal . I will try to get another module and see if I can get it working when it is time to code it could you send me the code based on the infomation on my scan and vin please let me know thakns for your help.
United States
Thanks for confirming the ESP button is present.
I'm reasonably confident that 0019970 will be the correct coding (that example scan was from a NAR 1Y chassis 1.8T NBC) but feel free to post the Auto-Scan with the new module installed if you have any coding issues.
