Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 15 16 17 19 23 29 2B 39 42 44 4B 51 52 5F
8C BD C0 C5 C6 D6 D7
VIN: WVWPR7AU4JWxxxxxx Mileage: 57218km-35553miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
Address 01: Engine (J623-EAZA) Labels:. 0EA-907-309-V1.clb
Part No SW: 0EA 906 016 F HW: 0EA 907 309 A
Component: E-Vehicle H24 4238
Revision: WMH24---
Coding: 000D0016002400007000
Shop #: WSC 58974 002 1048576
ASAM Dataset: EV_VCU00XXX0110EA906016F 004005
ROD: EV_VCU00XXX0110EA906016F_004.rod
VCID: B22844CCE52F8FDFE1-80E6
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 DB HW: 5Q0 614 517 AH
Component: ESC H62 0856
Revision: 00000000 Serial number: 63467000000602
Coding: 01FA40A12C20217485780209A1C32980023484A14085943222815058C24203
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
VCID: F4A482D45FBBC1EF33-80A0
8400 - Databus
[FCAN: AB_Gurt_FA signal is invalid]
16401 - Tire Pressure Warning
C102D 00 [108] - -
Mileage: 56656 km
Date: 2020.01.27
Time: 18:02:12
32832 - Switch for Electric Parking Brake
C100C 07 [032] - Mechanical Failure
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0464849300
Coding: 032C0C
VCID: BC346AF4376B49AF3B-80E8
Part No SW: 5GE 907 044 AN HW: 5GE 907 044 AN
Component: Climatronic H04 1702
Revision: 00001K01
Coding: 0002220020011001040500020010102B
VCID: 885CC6243333D50F6F-80DC
Air quality sensor:
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001736300091
ROD: EV_BCMBOSCH_018.rod
VCID: 8640C81C3927C37F1D-80D2
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 171202 043 0551
Serial number: 171207165651
Component: RLHS 047 0105
Serial number: TAY18M01D04H17M05S41
Coding: 00A8DD
Part No SW: 5QA 919 294 D HW: 5QA 919 294
Component: PDC 8 KanalH07 0452
Serial number: 000308418618001
Coding: 2471151011
ASAM Dataset: EV_EPHVA18AU3700000 009036
VCID: CDD237309CD1F0279C-8098
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR09NB5K
Coding: 8CCCFC00002000005000001AC20800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: C7DE05187EAD1A77A6-8092
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000008FTIE1
Coding: 303139
Subsystem 2 - Part No SW: ----------- HW: 480 002 912 17
Serial number: 35700000000785F45A2S
Subsystem 3 - Part No SW: ----------- HW: 480 003 012 17
Serial number: 358000000008339C1A2L
Subsystem 4 - Part No SW: ----------- HW: 480 402 112 17
Serial number: 3510001A3284E2D643D6
Subsystem 5 - Part No SW: ----------- HW: 480 402 112 17
Serial number: 35200019B284E2D297CI
Subsystem 6 - Part No SW: ----------- HW: 480 402 112 17
Serial number: 3550001B7284E2D6D45H
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 112 17
Component: FrontSensor_P 000 6149
Serial number: 3560001A5284E2D44599
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 18121708490805
Coding: 0410
VCID: 875EC5183E2DDA7766-80D2
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 5GE 920 755 C HW: 5GE 920 755 C
Component: KOMBI 302 0310
Coding: 0BB4281A2B808809020869001701002080000000
VCID: C0CC1E045B832D4F67-8094
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Fault Frequency: 8
Reset counter: 45
Mileage: 52352 km
Date: 2019.11.29
Time: 05:19:08
Part No SW: 3Q0 907 530 M HW: 3Q0 907 530 D
Component: GW MQB EV 618 6322
Serial number: 04121710520008
Coding: 0201001704F81000FB001202081D00000001070100070000000300000000
ROD: EV_GatewNF.rod
VCID: B93A73E038597C8720-80EC
Subsystem 1 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 29170002323050027421
Coding: 30FFFF
Subsystem 2 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 8316825904
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 G HW: 5QE 909 059 B
Component: EBKV H14 0211
Serial number: 085460010800
Coding: 06720100321A02030002000500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: D2E8244C85EFAFDFC1-8086
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 D HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0155
Serial number: 05802861291117230659
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
0033 - Supply voltage
[Supply voltage - lower limit exceeded]
Reset counter: 45
Mileage: 52055 km
Date: 2019.11.25
Time: 20:01:59
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000374146004
Coding: 7900000000000000
ROD: EV_ELVMarquMQB.rod
VCID: B42442D41F3B81EFF3-80E0
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Reset counter: 33
Mileage: 56140 km
Date: 2020.01.22
Time: 05:27:07
Component: TSG FS 020 0041
Serial number: 081217EL809865
Coding: 003E13208000040000000000
VCID: C3C611084A9536577A-8096
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000018166814
Coding: 111000
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1081
Coding: C1020000
ROD: EV_SteerAssisMQB_015.rod
VCID: F3A681C85AB5C6D72A-80A6
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 16121710800967
Coding: 000000050100054A00310F01040000000000000000000000000000000000
VCID: F2A884CC25AFCFDF21-80A6
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5QE 907 080 K HW: 5QE 907 080 K
Component: LE Gen 3.3H16 2052
Revision: 00H16000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM10030115QE907080K 001008
ROD: EV_DMCM10030115QE907080K.rod
VCID: CED0303C91D7CB3FE5-809A
Component: TSG BFS 020 0041
Serial number: 021217EL124173
VCID: C2C8140C558F3F5F71-8096
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000018301231
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 047 B HW: 5NA 035 047
Component: MU-H-NS-US H54 1126
Serial number: A852L0HB001386
Coding: 02738002FF00000051220001001828009F0105D401200505DE
Subsystem 1 - Part No SW: 5G6 919 606 B HW: 5G6 919 606 B
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT3415247
Subsystem 2 - Part No SW: V03 959 803 SR HW: -----------
Component: NAR 2017/2018 --- 0060
Compact Disc Database:
Component: Gracenote2 --- 3011
B11CF 53 [009] - Deactivated
Reset counter: 236
Mileage: 29723 km
Date: 2019.02.08
Time: 08:47:33
Voltage terminal 30: 12.9 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5GE 915 225 A HW: 5GE 915 225 A
Component: K8C 005 0350
Serial number: 28111707010261
ASAM Dataset: EV_BECM08820215GE915225A 001003
ROD: EV_BECM08820215GE915225A.rod
VCID: BA386CEC3D5F779F29-80EE
Battery Junction Box:
Subsystem 1 - Part No SW: 5GE 915 316 A HW: 5GE 915 316 A
Component: A2 HVSMBJBECU 011 0300
Serial number: 00000016111705010316
Cell module: control module 1:
Subsystem 2 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J991Battmod1 H08 0322
Serial number: 17A23Y18AH0803226928
Cell module: control module 2:
Subsystem 3 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J992Battmod2 H08 0322
Serial number: 17A24Y18AH0803227123
Cell module: control module 3:
Subsystem 4 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J993Battmod3 H08 0322
Serial number: 17A25Y18AH0803226177
Cell module: control module 4:
Subsystem 5 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J994Battmod4 H08 0322
Serial number: 17A26Y18AH0803227442
Cell module: control module 5:
Subsystem 6 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J995Battmod5 H08 0322
Serial number: 17A23Y18AH0803226938
Cell module: control module 6:
Subsystem 7 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J996Battmod6 H08 0322
Serial number: 17A13Y18AH0803226396
Cell module: control module 7:
Subsystem 8 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J997Battmod7 H08 0322
Serial number: 17A26Y18AH0803226876
Cell module: control module 8:
Subsystem 9 - Part No SW: 5QE 915 599 AH HW: 5QE 915 599 AH
Component: J998Battmod8 H08 0322
Serial number: 17A24Y18AH0803225031
Address BD: Hi Volt. Batt. Charg. (J966) Labels:| 5QE-915-022.clb
Part No SW: 5QE 915 022 AP HW: 12E 915 022 H
Component: LMSG H20 1096
Serial number: 01148074750089
Coding: 4A4914040400
ASAM Dataset: EV_HVChargManagVWMQB 003004
ROD: EV_HVChargManagVWMQB.rod
VCID: 8F6EED38565D8237AE-80DA
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 M HW: 5QE 035 335 B
Component: E_SOUND_SG H10 0223
Serial number: EN174802580000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 007015
ROD: EV_ENoiseS1NNVW3707_007.rod
VCID: CBD6392862C5FE1782-809E
Address C5: Therm. mgt. (J1024) Labels:* None
Part No SW: 5GE 907 458 C HW: 5GE 907 458
Component: TME-Min H06 0203
Serial number: 0058569
Coding: 02
ASAM Dataset: EV_ThermContrVISAU49X 001021
ROD: EV_ThermContrVISAU49X_VW37.rod
VCID: C5C20F1044A1086754-8090
Subsystem 1 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G395 pT-Sens1 H11 0010
Subsystem 2 - Part No SW: 12E 963 231 G HW: 12E 963 231 G
Component: J848 HV-PTC H09 0208
Serial number: LR173483003810000146
Air Conditioning Compressor Sub:
Subsystem 3 - Part No SW: 5QE 816 803 A HW: 5QE 816 803 A
Component: J842 eKK H03 0009
Geber für Kältemitteldruck/Kältemitteltemperatur 2:
Subsystem 4 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G826 pT-Sens2 H11 0010
Geber für Kältemitteldruck/Kältemitteltemperatur 3:
Subsystem 5 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G827 pT-Sens3 H11 0010
Geber für Kältemitteldruck/Kältemitteltemperatur 4:
Subsystem 6 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G828 pT-Sens4 H11 0010
Geber für Kältemitteldruck/Kältemitteltemperatur 5:
Subsystem 7 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G829 pT-Sens5 H11 0010
Refrigerant Expansion Valve 1:
Subsystem 8 - Part No SW: 4M0 816 682 D HW: 4M0 816 682 D
Component: N636 EV1_KaMi H12 0102
Serial number: 00000000000120273211
Refrigerant Expansion Valve 2:
Subsystem 9 - Part No SW: 4M0 816 682 D HW: 4M0 816 682 D
Component: N637 EV2_KaMi H12 0102
Serial number: 00000000000120273575
Refrigerant Expansion Valve 3:
Subsystem 10 - Part No SW: 4M0 816 682 D HW: 4M0 816 682 D
Component: N638 EV3_KaMi H12 0102
Serial number: 00000000000120273383
Refrigerant Shut Off Valve 1:
Subsystem 11 - Part No SW: 4M0 816 703 B HW: 4M0 816 703 B
Component: V424 AV1_KaMi H12 0102
Serial number: 00000000000140272877
Refrigerant Shut Off Valve 4:
Subsystem 12 - Part No SW: 4M0 816 703 B HW: 4M0 816 703 B
Component: N642 AV4_KaMi H12 0102
Serial number: 00000000000140273153
Refrigerant Shut Off Valve 5:
Subsystem 13 - Part No SW: 4M0 816 703 B HW: 4M0 816 703 B
Component: N643 AV5_KaMi H12 0102
Serial number: 00000000000140268331
37024 - A/C Compressor
U103B 00 [032] - No Communication
37096 - Automatic addressing Sub Bus 1
B1484 21 [032] - Signal Amplitude Too Low
37126 - Automatic addressing Sub Bus 2
B1485 21 [032] - Signal Amplitude Too Low
Address C6: Batt. Chrg. (J1050) Labels: 5QE-915-681.clb
Part No SW: 5QE 915 681 B HW: 5QE 915 681 B
Component: OBC Delta-ES H59 1560
ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
ROD: EV_OBCTwoPhaseDT2VW3707.rod
14746197 - Battery Charger; Charging Module 2
P31EA 00 [008] - Faulty
[AC_current_sensor_R2_PA_RAT]
Mileage: 51098 km
Date: 2019.11.13
Time: 08:23:55
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 02:03, VBatt start/end: 13.2V/13.2V)-----------
