Function not supported by gateway during autoscan
73blazer
MI, USA
C?ID=397169
Hello. And Forgive me if this is somewhere else. I did some searches and found alot of threads on this but none of them seem to have actual specific solutions just stuff like the key wasn't on or the cable wasn't hooked up right or something.
I've got an 05 Phaeton w12. I bought this vcds from Ross directly. I'm very unfamiliar with the VW way. I am very familiar with Chrysler and GM diag tools, this is my first VAG vehicle.
The whole VW module thing, seems, a bit whacky to me. But..just not used to how they organize their vehicle diagnostics...yet.
Basically, I hook up, batteries are good (I just replaced them a few days ago), 13.6v...........options test says everything good and ok, 1 vin used out of 3. I can open individual module controllers and get various group data etc. I can do all the OBII functions.
I cannot run an autoscan.
For starters, the Phaeton (3D) is not listed in the drop down of pre-defined vehicles, does that need to be there? If it's not there am I supposed to create a file for it???? If so how do I do that? Is autoscan just not possible on Phaeton? I have to do all the individual controllers? I'm pretty autoscan is possible as I've seen others posted from Phaetons and even from my very car, from 2008.
If I just hit start, it comes back fairly quickly with Function not supported by gateway.
Again, I'm very new to VAG vehicles and VCDS, so it's likely (hopeful) i'm just doing something wrong. I've read the manual it's possible I missed pertinent info, but as of now I'm not see a way through to get around my issue.
Any suggestions???? Thanks for any help! There's some threads seemingly indicating Ross would like some feedback in the form of this is what my modules my vehicle has or some kind of file they'd like to get back to help other owners of the same vehicle line. I'm happy to provide that if I can figure out how!
73blazer
MI, USA
C?ID=397169
BTW, I have a HEX V2 interface, and latest vcds software. Windows 10 x64 pro laptop if any of that is relevant.
The whole VW module thing, seems, a bit wacky to me.
blazer: Hi - I'm sure that you are not the first to have made the exquisitely profound observation above!!!;)
I'm not certain that it's at all possible to address the "wacky-ness" issue, but try this:
VCDS does indeed work on Pheatons - see HERE
Turn car ignition on - doesn't matter if engine running for auto-scan
When you connect the dongle to the car - do the LEDs illuminate on the housing?
After you have run the software, press "Options" on the screen below:
Then select the USB radio button on the screen below and select "Test"
If the port test has successfully completed, you should see a screen that's similar (it's not exactly the same on the current software) to below:
If you get this screen, press OK, then select Save on the Program Options screen.
Try the auto-scan again - the Phaeton is on the select chassis drop-down list.
Enter "Pha" into the search box next to select chassis, or scroll down the list of cars - it's called "3D-VW Phaeton (2002-2006)" - see the line starting with the words "Chassis Type" in the auto-scan in my link above
73blazer
MI, USA
C?ID=397169
Well, therein lies my problem. The Phaeton, was not in that drop down list. In fact that list was so small and I know I seen screenshots of of others where the list is much bigger.
The lights are green on the connectors, the test returns ok can ok everything ok just like your pic. Like i said I could open some controllers and read data, like trans temp etc...Just no autoscan.
I just wasn't sure if users had to somehow amend or create some config file that would populate that list with their car somehow or what.
So I reinstalled VCDS. then i had a full list and now i see the 3D Phaeton. :D I remember now my laptop locked up around the time vcds was installing the first time. I was sidetracked and looked at it the next day and forgot mabey that install got messed up. Seems, it did.
I'm not by the car but I have my laptop, Now that I have a proper install of VCDS, I'll try an autoscan later today.
What is it you guys are looking from users to give you? Some list of modules or just an auto scan file or something? You probably have all the info on1st gen Phaetons you need, but if you don't I'm happy to supply any info from my car.
Thanks for the help!
Glad you got that sorted.
An 05 Phaeton does not yet have a proper Gateway Installation List, hence "Function not supported by gateway" is normal when VCDS asks for a list of installed modules.
By all means, post a full Auto-Scan. We've had plenty of customers with Phaetons, but the more scans, the merrier.
73blazer
MI, USA
C?ID=397169
Well, I had to lite up my cigar while it ran, but auto scan now working!
Wednesday,11,March,2020,22:59:36:45260
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWAH93D458002326   License Plate:
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
          34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWAH93D458002326   Mileage: 177760km-110454miles
Address 01: Engine        Labels: 07C-906-018-BAP1.lbl
   Part No SW: 07C 906 018 AB    HW:
   Component: D1-6.0L-AT-LEV  G  ª6418
   Revision: 57ÿAT-LE    Serial number:  000-00005.09.
   Coding: 0000173
   Shop #: WSC 01065 000 00000
   VCID: 6597B7EBD97ACAEF5A3-513C
18331 - Please Check DTC Memory of ECU Number 2
            P1923 - 008 -
Address 02: Auto Trans        Labels: 3D0-927-156.lbl
   Part No: 3D0 927 156 R
   Component: AG5 01L 6.0 W12 USA 0404
   Coding: 0001102
   VCID: 372B2DA33356887F38F-5160
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 R
   Component: ESP 5.7 allrad  H33 0043
   Coding: 0008397
   Shop #: WSC 12345 000 00000
   VCID: 313F13BBDD32564F76B-51CE
   Part No SW: 3D0 909 135 R    HW: 5WK 470 26
   Component:    Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0D7238103
   Coding: 0133356
   VCID: 34311AAF222063671DD-5160
01176 - Key
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 B
   Component: Sitzmemory D1 BF    1520
   Coding: 0000003
   VCID: 353727AB295A7A6F2A3-5160
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3D0 035 008 Q
   Component:    ZAB COCKPIT      0223
   Coding: 0500325
   Shop #: WSC 23337 444 59015
   VCID: 2809FEDFEEE81787A15-5160
00856 - Radio Antenna
00385 - Positive Output Audio Channel for Speech/Telephone
00386 - Negative Output Audio Channel for Speech/Telephone
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 H
   Component: Climatronic D1      2021
   Coding: 0000002
   VCID: 2313E9F397CEF4DFF47-5160
00445 - Loss of Refrigerant
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 G
   Component: STG.Bordnetz        5001
   Coding: 0000002
   Shop #: WSC 23337 444 66590
   VCID: 2E0508C7CC0C49B76B9-5160
Address 11: Engine II        Labels: 07C-906-018-BAP2.lbl
   Revision: 64ÿAT-LE    Serial number:  000-00005.09.
   Coding: 0000173
   VCID: 6597B7EBD97ACAEF5A3-5160
19755 - Catalyst System; Bank 4
            P3299 - 001 - Efficiency Below Threshold - Intermittent
   Part No: 3D0 909 601 E
   Component: 0G Airbag 8.4E+ H10 0934
   Coding: 0012359
   VCID: 2517F7EB99FA0AEF9A3-5160
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 E
   Coding: 0000232
   VCID: 2F3B15C3CB0640BF60F-5160
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No: 3D0 920 981 P
   Component: KOMBIINSTRUMENT RB8 0517
   Coding: 0007221
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D6BF16B81F47395-5160
Address 28: HVAC, Rear        Labels: 3D0-919-158.lbl
   Part No: 3D0 919 158 F
   Component: Klima-Bedienteil D1 0117
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000001
   VCID: 6695B0E7247CC1F7539-513C
Address 34: Level Control        Labels: 3D0-907-553-V1.clb
   Part No: 3D0 907 553 B
   Component: LUFTFDR.-CDC- 3C1V0 1101
   Coding: 0017700
   Shop #: WSC 25807 444 57975
   VCID: 2615F0E7E4FC01F7939-5160
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 B
   Component: Sitzmemory D1 F     1520
   Coding: 0000004
   VCID: 2D070FCBC10A32AF523-5160
Address 37: Navigation        Labels: 3D0-919-887.lbl
   Part No: 3D0 919 887 F
   Component:    NAVIGATION       0168
   Coding: 0400000
   Shop #: WSC 23337 444 85697
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 B
   Component: Dachmodul           0605
   Coding: 0000015
   VCID: 221DECF788D4FDD7FF1-5160
00220 - Connection to Sunroof
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000001
   VCID: 678BBDE32376D8FF68F-5160
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component:    HSG              0101
   Coding: 0000040
   Shop #: WSC 23069 444 11734
   VCID: 333319B3272E645F047-4B1E
   Subsystem 1 - Part No: 3D1 959 701 F
   Component: Tuersteuergeraet FS 5616
   Subsystem 2 - Part No: 3D1 959 702 F
   Component: Tuersteuergeraet BF 5616
   Subsystem 3 - Part No: 3D0 959 703 F
   Component: Tuersteuergeraet HL 5616
   Subsystem 4 - Part No: 3D0 959 704 F
   Component: Tuersteuergeraet HR 5616
   Subsystem 5 - Part No: 3D0 909 610 G
   Component: 3P HDSG             2630
   Subsystem 6 - Part No: 7L0 907 719
   Part No: 3D0 035 466 A
   Component: 12K-AUDIOVERST      0118
   VCID: 2019E6FF86D8EFC7E95-5160
Address 65: Tire Pressure        Labels: Redir Fail!
   Part No: 3D0 907 273 G
   Component: Reifendruckueberw.  0026
   Coding: 0210330
   VCID: 2A0D04D7F0E42597B71-5160
Address 66: Seat, Rear        Labels: None
   Part No: 3D0 959 860 C
   Component: Sitzmemory D1 H     1724
   Coding: 0000001
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
   Part No: 3D1 955 119 A
   Component: Front Wiper         2005
   VCID: 270BFDE3E3F618FFA8F-5160
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 C
   Component: Batteriemanagement  2700
00086 - Parallel Battery Connection Relay (J581)
Address 75: Telematics        Labels: 3D0-035-617.lbl
   Part No SW: 3D0 035 617 A    HW: 3D0 035 617 A
   Component: Telematik NAR1      0106
   Coding: 0061860
   Shop #: WSC 23337 444 00989
   VCID: 1E65D807BCACD937DB9-5160
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 C
   Component: 03 Einparkhilfe     0807
Address 77: Telephone        Labels: None
   Part No: 3D0 035 729
   Component: Telefon             0118
   VCID: 619FA3FBCD52A6CFA6B-5160
End----(Elapsed Time: 08:09, VBatt start/end: 13.4V/13.7V. VIgn 0.0V)------
Not surprising on that car. All module access is via K-line, where it takes an absolute minimum of about 2-1/2 seconds to establish a connection with a module and then the communications happen at a blazing 10.4 kbps (and in some cases, even more slowly than that).
Possible modules in a Phaeton:
01,02,03,05,06,07,08,09,11,13,15,16,17,18,19,23,27,28,29,2E,34,36,37,38,39,46,47,55,56,57,65,66,68,69,71,75,76,77
Modules present in yours:
01,02,03,05,06,07,08,09,11,15,16,17,19,28,29,34,36,37,38,39,46,47,65,66,68,71,75,76,77
If you use the second list to make a custom Auto-Scan entry, future scans will run somewhat faster since VCDS won't bother trying to access the nine modules that could be in your car but aren't.
