Audi C7 A6 DRL White to Orange conversion on full LED headlights.
nthusiastt
C?ID=397880
Hey guys,
I posted about this a while back and couldn't find any info on it. I have the full LED headlights. The DRL is a solid white line. The indicator is a solid orange line.
I spent about 3 hours with my Ross-Tech going through but I couldn't figure out where to code it in so I then pulled the headlight plug and ran a voltimeter to the pins
Purple/Green - Constant 9v always
Black/Blue - 10v when hazard indicator is on.
Solid Purple - 10v when hazard indicator is on.
blue/white - 7v when headlight switch is turned to running.
blue/red - 10v when headlight switch is turned to running.
My thinking was the LED strips have two sections so I spliced and tied the wires to be reversed:
Blue/Black -> Blue/White
Purple -> Blue Red
Blue/White -> Blue Black
Blue/Red -> Purple
When reversed the white LED strip lights up when hazards are on, however when the running lights are turned on (The dimmed setting by headlight switch), it only lights up half the orange strip. I thought for a while that there must be another circuit I'm missing so I went back to my voltimeter and retested everything. Then I realized, that the white bulbs are dimmable and are simply dimmed when there's a lower voltage. The orange bulbs do not dimm so on lower voltage only half the strip lights up.
I soldered the wires back to their original position and heat shrink wrapped them so I could do more research on the best method here. Maybe someone with more VCDS experience than me can assist. Open to any suggestions.
Please refrain from posting your opinion about whether you think this is cool or not. I've also confirmed it is legal in my state to run a solid orange indicator up front.
hmm..... certainly an innovative approach to solving your problem (based predominantly on the fundamental assumption that the turn-signal LED fittings are EXACTLY the same as the DRL LED fittings - except for colour!!!)
Perhaps it might help if you posted-up a current UNEDITED auto-scan so forum folk can see how the car is equipped - it's always a good starting point for discussion!!
nthusiastt
C?ID=397880
Here ya go
Friday,13,March,2020,16:34:30:42847
VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
VIN: WAUHMAFC3EN122101   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
          52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 AC
VIN: WAUHMAFC3EN122101   Mileage: 61495km-38211miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 N    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0013
   Revision: 58H14---
   Coding: 0A2A4012056601050000
   Shop #: WSC 63778 002 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401N 002013
   ROD: EV_ECM30TDI0114G0907401N_002.rod
   VCID: 2E05082BD09D30876B9-807A
   Part No SW: 4G0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H16 1008
   Revision: --H16---
   VCID: 3C21326316E1D217D5D-8068
   Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
   Component: ESP PREMIUM   H09 0450
   Coding: 27A79701E4E5E9804B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3B23317F13EFD52FDC7-806E
0478 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [SCL_Gateway_05_BCM1_01_alt]
                    Reset counter: 81
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: FD
                    Uz: 7F
   Part No SW: 4H0 907 064 ER    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0521
   Coding: 0DA82046000000000000
   VCID: 7DA7FF674DFB1B1FA23-8028
   Serial number: 0214000023613014
00956 - Key 2
                    Reset counter: 79
                    Mileage: 59444 km
                    Date: 2020.02.03
                    Time: 08:04:24
   Part No SW: 4G0 820 043 AN    HW: 4G0 820 043 AN
   Component: KLIMA 4 ZONEN H14 0093
   Serial number: 05021400041733
   Coding: 368120BA4D
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6B83C13F230F85AF0C7-803E
0386 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
                    Reset counter: 75
                    Mileage: 61071 km
                    Date: 2020.02.28
                    Time: 15:43:14
                    Voltage terminal 30: 11.30 V
                    Outside air temperature: 11.5 °C
                    Energy management deactivation stage: 1
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001697224
   Coding: 8907A091073C9FE281800084A0003800CF9CD208A60802258001085C7B00
   VCID: 6FBBD52F1797798F20F-803A
   Component: WWS57X 140201  H37 0080
   Serial number:         140204201113
   Coding: 0045F7
   Serial number: 22234636
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 31 01 2014  00000765
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RA4WJ03
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0090184005
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000003021400010485
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000005021400010491
   Coding: 110000
   Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA107528000006088584
   Coding: 020300
   Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 58388F07000000000001
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 81
                    Mileage: 61361 km
                    Date: 2020.03.09
                    Time: 16:06:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 81
                    Mileage: 61361 km
                    Date: 2020.03.09
                    Time: 16:06:00
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61031404900509
   Coding: A8EB06
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD35701236F7F36B-8024
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7E01010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2809FE33F2796EB7A15-807C
10240 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_BLR_BLK8_31]
                    Reset counter: 82
                    Mileage: 61401 km
                    Date: 2020.03.09
                    Time: 19:34:09
                    Control Module temperature: 12 °C
                    Voltage terminal 15: 14.290 V
                    Velocity_vehicle_reference: 28.19 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.10 m/s²
16640 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VMON_VZ_LOW1]
                    Reset counter: 81
                    Mileage: 61361 km
                    Date: 2020.03.09
                    Time: 17:34:06
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 9.212 V
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8003VW48
   Coding: 303234373131303030324A55304C34473053
   VCID: 3333195F3BBF1D6F047-8066
   Serial number: 6940000Y14000124AW0L
   Serial number: 3575HRB405L2ATKI9PDG
   Serial number: 3585HRB40572ANV45HKW
   Serial number: 3515JRB400E50REKKQ8.
   Serial number: 3525JRB400G50S02FGM8
   Serial number: 3554VRB401E50SAMO98$
   Serial number: 3564VRB400A50TIMMGKI
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372NB5000GW
   Coding: 0004DC
   VCID: 38292E732259FE37315-806C
   Subsystem 1 - Part No SW: 4G0 951 528 F    HW: 4G0 951 528 F
   Component: E221 - MFL  H09 0010
   Serial number: 16 10 2013  B1250065
   Part No SW: 4G8 920 984 A    HW: 4G8 920 984 A
   Component: TDieUsaAccNv  H58 0621
   Revision: 29460235    Serial number: 658120214596006
   Coding: 0BCF0A040F51D705020000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 34311A433EB11A571DD-8060
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001268944
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BDDC5B04255467CF1-8026
   Serial number: 8076742403
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 1310080000000000049F
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 81
                    Mileage: 61359 km
                    Date: 2020.03.08
                    Time: 22:00:45
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 13 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 14
                    Reset counter: 81
                    Mileage: 61071 km
                    Date: 2020.02.28
                    Time: 15:43:13
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 11.2 V
                    Control Module temperature: 22 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
   Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
   Component: KLIMA FOND    H08 0093
   Serial number: 06021400042063
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 3A2D347B1CD5EC27C71-806E
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 79
                    Mileage: 61235 km
                    Date: 2020.03.07
                    Time: 14:56:17
                    Outside air temperature: 7.0 °C
                    Left rear vent temperature: 21.3 °C
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Revision: AA000000    Serial number: 00000089777525
   Coding: C0581B008F006001000001010101102030303232203232
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA82069GE6
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635204B28CD0847239-8062
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0060
   Revision: 00H03000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 30391653C6292677795-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H03 0060
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F14.02.1400H03000AMS14119ÿ
   Subsystem 4 - Serial number: S14119ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F17005E00628002000013
   VCID: 45D7578765AB93DFBA3-8010
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0002274758
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1C5BC4A514670F1-8066
   Revision: 00002001    Serial number: 0327071888
   Coding: 0106063A00FA408580A0088402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000205085
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO27056464
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00005883221
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93165332
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 41
                    Mileage: 60888 km
                    Date: 2020.02.25
                    Time: 19:56:31
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 41
                    Mileage: 60888 km
                    Date: 2020.02.26
                    Time: 06:35:55
   Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
   Component: BO G3 C7      H09 0160
   Revision: 11000000    Serial number: 0019033
   VCID: 2517F70785EB73DF9A3-8070
   Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
   Component: BO C7 SLAVE  H51 0100
   Serial number: 01412130026332
   Component: TSG BF        H03 0507
   Coding: 011F17005E00628002000002
   VCID: 46D5508B58AD98C7B39-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000000959061
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070F27DD9B4B9F523-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140207-0002-129
   Coding: 1221A6601002A500
   ROD: EV_HeadlRegulBasic.rod
392711 - Positioning Motor for Headlight Range Left
          C1085 11 [008] - Short to Ground
                    Reset counter: 72
                    Mileage: 61071 km
                    Date: 2020.02.28
                    Time: 15:53:58
   Revision: AB001007    Serial number: 156B%0E7966262
   Coding: 020007010000000001
   VCID: 2411EA038ED18AD78DD-8070
   Part No SW: 4G0 035 746 F    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 0757
   Revision: --------    Serial number: 194BX0E7601904
   Coding: 050200000003E9EF7D12CB1E00000003100001000000000000
   VCID: 2A0D043BECF55CA7B71-807E
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD003RCXH
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NBD00092
   Component: CD-Database  5571
02067 - Optical Databus; Unpermitted Wake-Up Request
                    Reset counter: 81
                    Mileage: 61359 km
                    Date: 2020.03.08
                    Time: 21:10:01
                    Voltage: 11.90 V
   Component: TSG HL        H03 0507
   Coding: 010F17004000628002000002
   VCID: 49CF5BB749B377BF5EB-801C
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0133842
   Coding: 0200000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007_AU57.rod
   VCID: 2C010223E681429745D-8078
9617697 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Functional limitation by undervoltage]
                    Mileage: 61361 km
                    Date: 2020.03.09
                    Time: 17:59:09
                    Voltage terminal 30: 8.3 V
                    Terminal 15 status: Terminal 15 on
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F00BF86D78C7939-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7E01010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000121102147
   Coding: 04C198180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F1357C1A32F7F76B-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 133330161
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B03013FE38F45AF4C7-807E
End----(Elapsed Time: 02:57, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
nthusiastt
C?ID=397880
Thoughts? :)
^^^hmm........ nothing obvious to me - perhaps someone else here has insights?
I've had a read of the SSP for the A6 here and it mentions on page 46 that the DRL and turn-signal LED strips share the same power supply module (A32 is the Left-side "Module 2" for parking/DRL and turn signal)
The SSP also confirms that the headlight assemblies on the car are controlled by the BCM via separate wiring for the various lamps - which is not incompatible with your objective (I'm guessing of course). At least these 2 x lighting functions don't appear to be enabled via a CAN message. However, it's not clear whether the design of the orange LEDs permit dimming (i.e. whereas the DRLs permit variable states of illumination via Pulse Width Modulation, turn-signals have a binary ON/OFF state as factory designed). If dimming is not permitted, it might be necessary to disable this function - I'm not sure how, or even if it's possible.
Perhaps reference to the WD will shed further light (pun intended) on the potential success of your venture? The WD should identify which BCM pins are dedicated to each of the DRL and Turn-signal functions - it may be as simple as swapping these wires (or not).
Now that we know that the BCM is the lighting controller, the other option that might be worth pursuing is investigation of the adaptation channels in the hex09 module. Perhaps make an admap- maybe?
nthusiastt
C?ID=397880
Jesus, you're a beast!
I'll take a stab at it tomorrow.
nthusiastt
C?ID=397880
Jesus was a beast. Dude was money ;)
Mk2VRT
C?ID=371814
I looking for the same answer..
Someone did this before ?
Orange DRL on a 2016 RS6 with full led matrix headlights.
Witch vcds i cant find anything..
JDrew
46143, USA
C?ID=441034
Anyone figure this out yet? 2017 S7 wanting to do the same.
