Disable Polo 6C Headlight Washers (non xenon)
rsmagee
C?ID=229750
Does anyone know how to do this? I cant find any options under adaptation (all in German).
I dont have xenon headlights, they came with the winter pack. I want to disable them as they use an offensive amount of water.
Using VCDS 15.1 and a micro can cable.
I really doubt anyone knows how to do this off the top of their heads and the only reasonable way for anyone to even begin to research whether it's there's a feasible tweak would be to see exactly what stuff is installed in your car and how it's configured. I.e. it might help if you would post an Auto-Scan ;)
rsmagee
C?ID=229750
Haha, ok sorry should have thought about that a little harder. It seems most mk7 Golf tweaks work with the new Polo. Here is my autoscan
Friday,30,January,2015,10:16:41:43478
VCDS Version: 15.1.0.0 (x64)
Data version: 20150118
VIN: WVWZZZ6RZFY174818   License Plate: PJ64 OFM
Mileage: 4908km-3049mi   Repair Order:
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY174818   Mileage: 4908km-3049miles
Address 01: Engine (J623-CZEA)       Labels: None
   Part No HW: 04E 907 309 AB
   Component: 1.4l R4 TSI   H21 8140
   Revision: R6H21---
   Coding: 01190012232419080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TFS01104E906027AT 001007
   ROD: EV_ECM14TFS01104E906027AT.rod
   VCID: 558F725034A88091FC-8000
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08506430140915
   Coding: 23DD48858B2A33C4091C106A0059C412D1CC9008000ACB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
   VCID: 334BECC89A9CBEA132-8066
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0105
   Serial number:  1409091B-0150
   Coding: 200000001000000000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26_SE25.rod
   VCID: 1D1F2A700C1818D1F4-8048
   Part No SW: 6C0 937 089 A    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0047
   Serial number: 009458010741
   Coding: 0300085042130A7B0B244080B12F078800005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_BCMA0_VW26.rod
   VCID: 2E7DFDBC71BE93495D-807B
   Slave 2:
   Subsystem 1 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A
   Component: RLS  037 0059
   Serial number: S3Y14M09D23H20M17S27
   Coding: 0038DD
   Subsystem 2 - Part No SW: 6R0 959 802 CE    HW: 6R0 959 801 CB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8620
   Serial number: KU0KU018091442613321
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 801 CB    HW: 6R0 959 802 CE
   Component: J387__TSG_BT  003 8620
   Serial number: KU0KU023091442662656
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY142112H81
   Serial number: 00000000000060080591
138240 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 106
                    Mileage: 4260 km
                    Date: 2015.01.16
                    Time: 17:49:41
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag010 001 0330
   Revision: --------    Serial number: 003LM005LF34
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X_SK26.rod
   VCID: 3147E6C060808CB140-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 820 409 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C71628C10B22F
   Subsystem 2 - Part No SW: -----------    HW: 410 820 409 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00C515C41D0625I
   Subsystem 3 - Part No SW: -----------    HW: 442 150 410 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00C31751144A06.
   Subsystem 4 - Part No SW: -----------    HW: 442 150 410 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C71751143A462
   Part No SW: 6C0 920 940 A    HW: 6C0 920 940 A
   Component: KOMBI         211 0290
   Coding: 27AD01002180260001082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW26.rod
   VCID: 2265198C35662729C9-8077
16777024 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 65
                    Mileage: 2700 km
                    Date: 2014.12.22
                    Time: 13:44:02
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0047
   Revision: --------    Serial number: 009458010741
   Coding: 030100046F0A560071000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 65EF429064C810116C-8030
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C
   Component: E221__MFL-DC1  H03 0102
   Serial number: 27140001500340034325
   Coding: 30FFFF
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 51276013572821879090
Address 44: Steering Assist (J792)       Labels: Redir Fail!
   Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3211
   Serial number: CEA20854
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_VW26.rod
   Part No SW: 3Q0 035 820     HW: 3Q0 035 820
   Component: MU-S-D-ER     H11 0133
   Serial number: VWZAZ2P4602013
   Coding: 02620000BE00000011111201000808001F0100C60120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 66ED459C99CE1B0965-8033
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H41 1015
   Serial number: VWZ8Z9PH0013Z5
          B201A 00 [009] -  -
                    Reset counter: 67
                    Mileage: 2700 km
                    Date: 2014.12.22
                    Time: 13:43:57
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
                    Fault Frequency: 11
                    Reset counter: 160
                    Mileage: 4175 km
                    Date: 2015.01.15
                    Time: 16:31:38
End-------------------------(Elapsed Time: 01:57)--------------------------
rsmagee
C?ID=229750
Ok, I managed to do this using the guide for a Golf MK 7
1. Go to [09] Central Electronics
2. STG access permissions -> Function 16
3. Enter access code 31347
4. Go to adaptation channels (Function 10)
5. Select channel 3 - Select (3)-Windshield wiper-SRA Waschzeit,2300 ms
6. Adjust value to 0
Excellent, thanks! We don't get Polos at all here in NAR, and haven't seen a whole lot of data from the 6C yet.
PS: Please register your system with us by filling out this form so we can make you a Verified User.
rsmagee
C?ID=229750
Well if there is anything I can do to add more support I would love to help. Lots of stuff that the golf ml7 has in adaptation is missing for the Polo and it would be great to have it. I think it would be cross compatible as long coding from the mk7 seems to work and the security codes are the same.
Will register when I get home :)
rsmagee: I concur with the man from RT. - your car is A very rare beast indeed (even down here in the very, very Deep South where the new Polo is actually sold). Any chance of sharing a few adpmaps with the rest of us who have an interest?
rsmagee
C?ID=229750
Ok doing it now. Cent elect is massive. Doing pre label files with measuring blocks and adaptations. How do I upload them?
See below
Also registered with that form Uwe
NEtech
Denmark
C?ID=56995
It is only adaptation file.
Make a reply and insert your copied adpmap file text in place of ..XYZ..:
[code]
..XYZ..
[/code]
rsmagee
C?ID=229750
Ok, big post coming...
ABS Breaks
;SW:6C0-907-379-G   HW:6R0-907-379-BA ---  ABS Brakes
;Component:ESP9.0i       H03 0003, Coding:23DD48858B2A33C4091C106A0059C412D1CC9008000ACB098F00
;EV_Brake1ESP90iBOSCHPQ26,100018,EV_Brake1ESP90iBOSCHPQ26_SE26.rod
;Sunday,01,February,2015,11:45:53:43478
;VCDS Version: Beta 15.1.0 (x64)  Data version: 20150118
;VCID: 334BECC89A9CBEA132-8066
ABS in lower speed range,activated
(1)-Activating and deactivating all development messages-VW Botschaften,not activated
(2)-Activating and deactivating all development messages-BOSCH Botschaften,not activated
(3)-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 1,not activated
(4)-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 2,not activated
(5)-Activating and deactivating all development messages-Dynamische Entwicklungsbotschaft 3,not activated
Anti-slip regulation (ASR),activated
Brake disk drying,Medium
Electronic Differential Lock,activated
Electronic Stability Program,activated
Engine drag torque control,activated
Expanded electronic differential lock,Strong
Hill-start assistant,normal
Hill-start assistant; increase threshold,Three Percent
Hydraulic brake assistant,normal
Overboost in brake system,120BAR
Rear axle hard braking,activated
Roller test bench mode,activated
Roller test bench mode; functional,not activated
Straight ahead brake stabilization,activated
Tire pressure monitoring display,2
Tire pressure monitoring display; tire selection,1
XCP calibration protocol,not activated
Developer_Function_120,No Warning/Errro(Default)
Developer_Function_121,not activated
Tyre_pressure_control_monitoring_datalogging,0
Auto HVAC
;SW:6C0-820-045-A   HW:6C0-820-045-A ---  Auto HVAC
;Component:AC Manuell    H02 0105, Coding:200000001000000000
;EV_ACManueKMMValeoPQ26,002001,EV_ACManueKMMValeoPQ26_SE25.rod
;Sunday,01,February,2015,11:37:23:43478
;VCID: 1D1F2A700C1818D1F4-8048
Analysis 6,not activated
Analysis 7,00 00
Deactivate production mode,0
Deactivation of start-stop function,not active
Duration of compressor run in,60 s
Interior target temperature for production routines,22
Production mode,Deactivating
Recirculation air for production routines,No effect
Runtime for compressor run-in basic setting,120 s
Speed switch-off threshold for compressor run-in (engine speed),1500 /min
(1)-dimming_characteristic_curve_function_illumination_general-X1,0
(2)-dimming_characteristic_curve_function_illumination_general-Y1,30 %
(3)-dimming_characteristic_curve_function_illumination_general-X2,10
(4)-dimming_characteristic_curve_function_illumination_general-Y2,30 %
(5)-dimming_characteristic_curve_function_illumination_general-X3,50
(6)-dimming_characteristic_curve_function_illumination_general-Y3,30 %
(7)-dimming_characteristic_curve_function_illumination_general-X4,100
(8)-dimming_characteristic_curve_function_illumination_general-Y4,30 %
(9)-dimming_characteristic_curve_function_illumination_general-X5,220
(10)-dimming_characteristic_curve_function_illumination_general-Y5,100 %
(11)-dimming_characteristic_curve_function_illumination_general-X6,253
(12)-dimming_characteristic_curve_function_illumination_general-Y6,100 %
(1)-dimming_characteristic_curve_search_illumination-X1,0
(2)-dimming_characteristic_curve_search_illumination-Y1,0 %
(3)-dimming_characteristic_curve_search_illumination-X2,6
(4)-dimming_characteristic_curve_search_illumination-Y2,6 %
(5)-dimming_characteristic_curve_search_illumination-X3,40
(6)-dimming_characteristic_curve_search_illumination-Y3,40 %
(7)-dimming_characteristic_curve_search_illumination-X4,60
(8)-dimming_characteristic_curve_search_illumination-Y4,60 %
(9)-dimming_characteristic_curve_search_illumination-X5,80
(10)-dimming_characteristic_curve_search_illumination-Y5,80 %
(11)-dimming_characteristic_curve_search_illumination-X6,100
(12)-dimming_characteristic_curve_search_illumination-Y6,100 %
Cent Elec
;SW:6C0-937-089-A   HW:6C0-937-089 ---  Cent. Elect.
;Component:BCM PQ26 Hi4R H06 0047, Coding:0300085042130A7B0B244080B12F078800005B0257010000000000000000
;EV_BCMA0,004003,EV_BCMA0_VW26.rod
;Sunday,01,February,2015,10:31:13:43478
;VCID: 2E7DFDBC71BE93495D-807B
(1)-A/C heater function via remote control-valid_remote_starts,0
(2)-A/C heater function via remote control-Remote_Start_Duration,0 min
(1)-Access control-Funk bei Klemme 15 ein,not active
(2)-Access control-Notschließfunktion,active
(3)-Access control-automatisches Verriegeln bei Geschwindigkeit,not active
(4)-Access control-automatisches Entriegeln,not active
(5)-Access control-ZV Tuerentriegelung,Einzeltuerentriegelung
(6)-Access control-CAN Wecken bei Softtouchbetaetigung,not active
(7)-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
(8)-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
(9)-Access control-Valet Parking,not active
(10)-Access control-Direkter Auswurf des Heckdeckels,active
(11)-Access control-ZV entriegelt auch Heckdeckel,active
(12)-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
(13)-Access control-Autolock Autounlock wirkt auf Heck,active
(14)-Access control-ZV Heck nur direkt auswerfen,not active
(15)-Access control-Manuelle ZV Variantenprogrammierung,not active
(16)-Access control-ZV-Entriegelung nach Seitencrash,not active
(17)-Access control-Menuesteuerung Tuerentriegelung,active
(18)-Access control-Menuesteuerung ZV Autolock-Unlock,not active
(19)-Access control-Autounlock NAR,not active
(20)-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
(21)-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
(1)-Access control 2-Komfortbedienung global,active
(2)-Access control 2-Comfort opening,active
(3)-Access control 2-Comfort closing,active
(4)-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
(5)-Access control 2-Funk Komfort schliessen,active
(6)-Access control 2-Funk Komfort oeffnen,active
(7)-Access control 2-Schliesszylinder Komfort oeffnen,active
(8)-Access control 2-Schliesszylinder Komfort schliessen,active
(9)-Access control 2-SAD Richtung Komfortoeffnen,Open
(10)-Access control 2-SAD Komfort schliessen,not active
(11)-Access control 2-SAD Komfort oeffnen,not active
(12)-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
(13)-Access control 2-Freigabenachlauf FH bei Tueroeffnen,active
(14)-Access control 2-Regenschließen,not active
(15)-Access control 2-Regenschliessen_art,once
(16)-Access control 2-Kessy Komfort oeffnen,No
(17)-Access control 2-Kessy Komfort schliessen,No
(18)-Access control 2-Funk Spiegelanklappen,not active
(19)-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
(20)-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active
(21)-Access control 2-Menuesteuerung Komfortbedienung einstellbar,not active
(22)-Access control 2-Menuesteuerung Regenschliessen,not active
(23)-Access control 2-SAD PreCrash Konturschliessen,active
(24)-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
(25)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
(26)-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
(27)-Access control 2-Profilfunktion für Anklappung der Außenspiegel,active
(28)-Access control 2-Spiegelanklappung geschwindigkeitsabhängig,not active
(1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
(2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active
(3)-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal
(4)-Acknowledgement signals-Optical feedback during locking,Decelerate
(5)-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active
(6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
(7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active
(8)-Acknowledgement signals-Akustische Rueckmeldung global,not active
(9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active
(10)-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl,not active
(11)-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl,not active
Activating and deactivating all development messages,not active
(1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %
(2)-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %
(3)-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %
(4)-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
(5)-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
(6)-Ambient lighting-Innenlichtinszenierung,not enabled
(7)-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled
(1)-Anti-theft device-Alarmsignal,frequency modulated
(2)-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
(3)-Anti-theft device-DWA Alarmverzoegerung,immidiat_driver_door_contact_thatcham
(4)-Anti-theft device-DWA Camper Modus,not active
(5)-Anti-theft device-Sirenen Alarmzahl,10 Alarme
(6)-Anti-theft device-Akustischer Alarm Signalhorn,not active
(1)-Assistance light functions-Notbremsanzeige NBA,active
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
(3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
(4)-Assistance light functions-Fernlichtassistent Reset,active
(5)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
(6)-Assistance light functions-Assistenzfahrlicht bei Regen,not active
(7)-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein Hinweis
(8)-Assistance light functions-AFL Zeitverzoegerung,0 ms
(9)-Assistance light functions-Lichtsensorempfindlichkeit,normal
(1)-Auxiliary functions-Signalhorn ohne KL15,not active
(2)-Auxiliary functions-Klemmenfehler auf CAN ausgeben,not active
Characteristics in production mode,0 ms
(1)-Comfort illumination-Coming Home Verbaustatus,manual
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
(3)-Comfort illumination-Menueeinstellung Cominghome,10 s
(4)-Comfort illumination-Coming Home Leuchten,Low beam
(5)-Comfort illumination-Coming-home Einschaltereignis,Driver door
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,72.0
(7)-Comfort illumination-Leaving-Home Verbausstatus,Enabled
(8)-Comfort illumination-lho_aktiviert,active
(9)-Comfort illumination-lho_zeit,10 s
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung,0
Component protection showroom mode,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(1)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_0,not active
(2)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_1,not active
(3)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_2,not active
(4)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_3,not active
(5)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_4,not active
(6)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_5,not active
(7)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_6,not active
(8)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_7,not active
(9)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_8,not active
(10)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_9,not active
(11)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_10,not active
(12)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_11,not active
(13)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_12,not active
(14)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_13,not active
(15)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_14,not active
(16)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_15,not active
(17)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_16,not active
(18)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_17,not active
(19)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_18,not active
(20)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_19,not active
(21)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_20,not active
(22)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_21,not active
(23)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_22,not active
(24)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_23,not active
(25)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_24,not active
(26)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_25,not active
(27)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_26,not active
(28)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_27,not active
(29)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_28,not active
(30)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_29,not active
(31)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_30,not active
(32)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_31,not active
(33)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_32,not active
(34)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_33,not active
(35)-Configuration of light collective diagnostic line 1; instance 1-Leuchte_34,not active
(36)-Configuration of light collective diagnostic line 1; instance 1-Wiederstand,150_Ohm
(37)-Configuration of light collective diagnostic line 1; instance 1-DTCDFCC,36
(38)-Configuration of light collective diagnostic line 1; instance 1-Defektbit,Licht_vorne_01 Byte 5
(1)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_0,not active
(2)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_1,not active
(3)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_2,not active
(4)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_3,not active
(5)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_4,not active
(6)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_5,not active
(7)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_6,not active
(8)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_7,not active
(9)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_8,not active
(10)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_9,not active
(11)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_10,not active
(12)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_11,not active
(13)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_12,not active
(14)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_13,not active
(15)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_14,not active
(16)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_15,not active
(17)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_16,not active
(18)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_17,not active
(19)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_18,not active
(20)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_19,not active
(21)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_20,not active
(22)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_21,not activ;SW:6C0-937-089-A   HW:6C0-937-089 ---  Cent. Elect.
;Sunday,01,February,2015,10:33:05:43478
(22)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_21,not active
(23)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_22,not active
(24)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_23,not active
(25)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_24,not active
(26)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_25,not active
(27)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_26,not active
(28)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_27,not active
(29)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_28,not active
(30)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_29,not active
(31)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_30,not active
(32)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_31,not active
(33)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_32,not active
(34)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_33,not active
(35)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_34,not active
(36)-Configuration of light collective diagnostic line 2; instance 1-Wiederstand,150_Ohm
(37)-Configuration of light collective diagnostic line 2; instance 1-DTCDFCC,40
(38)-Configuration of light collective diagnostic line 2; instance 1-Defektbit,Licht_vorne_01 Byte 5
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
(8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
(3)-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active
(4)-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
(5)-Driving light and parking light-beidseitiges_dauerparklicht,active
(6)-Driving light and parking light-max_scheinwerfer_2limitieren,not active
(7)-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
(8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
(9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
(10)-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
(11)-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
(12)-Driving light and parking light-Allwetterlicht Einschaltgrenze,350.0 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350.0 km/h
(14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,255 km/h
DWA Interior monitoring,100 %
DWA Vehicle inclination sensor,60 %
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
(3)-Dyn. turn signal modes-ZV_Blinken_zu,not active
(4)-Dyn. turn signal modes-ZV_Blinken_auf,not active
(5)-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
(8)-Dyn. turn signal modes-Taxi alarm flashing,not active
(9)-Dyn. turn signal modes-Panic flashing,not active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
(13)-Dyn. turn signal modes-Richtungs_blinken_links,not active
(14)-Dyn. turn signal modes-ABBA_Blinken,not active
(15)-Dyn. turn signal modes-Crash flashing,not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
(1)-Energy management-Adapting for energy management,Energy management not active
(2)-Energy management-Prädiktives Energiemanagement,not active
(1)-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,not active
(2)-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
(3)-Interior lighting-KL30G ohne PWM,not active
(4)-Interior lighting-KL58 Einschalten mit Rampe,not active
(5)-Interior lighting-KL58 Verriegelungsausschalten,not active
(6)-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
(7)-Interior lighting-Suchbeleuchtung Festwert,100 %
(1)-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs,Time
(2)-Leaving concept-Bedingungen zur Standlichtbegrenzung,not active
(3)-Leaving concept-Bedingungen zur Parklichtbegrenzung,not active
(4)-Leaving concept-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x1 Stunden
(5)-Leaving concept-Standlicht-Nachlaufzeit,30 min
(6)-Leaving concept-Standlicht-Verfuegbarkeit,0 s
(7)-Leaving concept-ZV verriegeln bei Klemme 15 Ein,not active
(1)-Light configuration-Type_Of_Load_0,Blinkleuchten
(2)-Light configuration-BAP_Bitposition_0,34
(3)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0,14
(4)-Light configuration-Light_Function_A_0,2
(5)-Light configuration-Light_Function_B_0,0
(6)-Light configuration-Dimming_AB_0,100
(7)-Light configuration-Light_Control_HD_AB_0,Always
(8)-Light configuration-Light_Function_C_0,0
(9)-Light configuration-Light_Function_D_0,0
(10)-Light configuration-Dimming_CD_0,0
(11)-Light configuration-Dimming_Direction_CD_0,maximize
(12)-Light configuration-Light_Function_E_0,0
(13)-Light configuration-Light_Function_F_0,0
(14)-Light configuration-Dimming_EF_0,0
(15)-Light configuration-Dimming_Direction_EF_0,maximize
(16)-Light configuration-Light_Function_G_0,0
(17)-Light configuration-Light_Function_H_0,0
(18)-Light configuration-Dimming_GH_0,0
(19)-Light configuration-Dimming_Direction_GH_0,maximize
(20)-Light configuration-Type_Of_Load_1,Blinkleuchten
(21)-Light configuration-BAP_Bitposition_1,3E
(22)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1,15
(23)-Light configuration-Light_Function_A_1,4
(24)-Light configuration-Light_Function_B_1,0
(25)-Light configuration-Dimming_AB_1,100
(26)-Light configuration-Light_Control_HD_AB_1,Always
(27)-Light configuration-Light_Function_C_1,0
(28)-Light configuration-Light_Function_D_1,0
(29)-Light configuration-Dimming_CD_1,0
(30)-Light configuration-Dimming_Direction_CD_1,maximize
(31)-Light configuration-Light_Function_E_1,0
(32)-Light configuration-Light_Function_F_1,0
(33)-Light configuration-Dimming_EF_1,0
(34)-Light configuration-Dimming_Direction_EF_1,maximize
(35)-Light configuration-Light_Function_G_1,0
(36)-Light configuration-Light_Function_H_1,0
(37)-Light configuration-Dimming_GH_1,0
(38)-Light configuration-Dimming_Direction_GH_1,maximize
(39)-Light configuration-Type_Of_Load_2,allgemeineGluehlampe6W;auchH6W
(40)-Light configuration-BAP_Bitposition_2,35
(41)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2,26
(42)-Light configuration-Light_Function_A_2,8
(43)-Light configuration-Light_Function_B_2,9
(44)-Light configuration-Dimming_AB_2,100
(45)-Light configuration-Light_Control_HD_AB_2,Always
(46)-Light configuration-Light_Function_C_2,0
(47)-Light configuration-Light_Function_D_2,0
(48)-Light configuration-Dimming_CD_2,0
(49)-Light configuration-Dimming_Direction_CD_2,maximize
(50)-Light configuration-Light_Function_E_2,0
(51)-Light configuration-Light_Function_F_2,0
(52)-Light configuration-Dimming_EF_2,0
(53)-Light configuration-Dimming_Direction_EF_2,maximize
(54)-Light configuration-Light_Function_G_2,0
(55)-Light configuration-Light_Function_H_2,0
(56)-Light configuration-Dimming_GH_2,0
(57)-Light configuration-Dimming_Direction_GH_2,maximize
(58)-Light configuration-Type_Of_Load_3,allgemeineGluehlampe6W;auchH6W
(59)-Light configuration-BAP_Bitposition_3,3F
(60)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3,27
(61)-Light configuration-Light_Function_A_3,8
(62)-Light configuration-Light_Function_B_3,10
(63)-Light configuration-Dimming_AB_3,100
(64)-Light configuration-Light_Control_HD_AB_3,Always
(65)-Light configuration-Light_Function_C_3,0
(66)-Light configuration-Light_Function_D_3,0
(67)-Light configuration-Dimming_CD_3,0
(68)-Light configuration-Dimming_Direction_CD_3,maximize
(69)-Light configuration-Light_Function_E_3,0
(70)-Light configuration-Light_Function_F_3,0
(71)-Light configuration-Dimming_EF_3,0
(72)-Light configuration-Dimming_Direction_EF_3,maximize
(73)-Light configuration-Light_Function_G_3,0
(74)-Light configuration-Light_Function_H_3,0
(75)-Light configuration-Dimming_GH_3,0
(76)-Light configuration-Dimming_Direction_GH_3,maximize
(77)-Light configuration-Type_Of_Load_4,allgemeineGluehlampe27W;auchH15-TFL
(78)-Light configuration-BAP_Bitposition_4,3A
(79)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4,20
(80)-Light configuration-Light_Function_A_4,20
(81)-Light configuration-Light_Function_B_4,0
(82)-Light configuration-Dimming_AB_4,100
(83)-Light configuration-Light_Control_HD_AB_4,Always
(84)-Light configuration-Light_Function_C_4,0
(85)-Light configuration-Light_Function_D_4,0
(86)-Light configuration-Dimming_CD_4,0
(87)-Light configuration-Dimming_Direction_CD_4,maximize
(88)-Light configuration-Light_Function_E_4,0
(89)-Light configuration-Light_Function_F_4,0
(90)-Light configuration-Dimming_EF_4,0
(91)-Light configuration-Dimming_Direction_EF_4,maximize
(92)-Light configuration-Light_Function_G_4,0
(93)-Light configuration-Light_Function_H_4,0
(94)-Light configuration-Dimming_GH_4,0
(95)-Light configuration-Dimming_Direction_GH_4,maximize
(96)-Light configuration-Type_Of_Load_5,allgemeineGluehlampe27W;auchH15-TFL
(97)-Light configuration-BAP_Bitposition_5,44
(98)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5,21
(99)-Light configuration-Light_Function_A_5,20
(100)-Light configuration-Light_Function_B_5,0
(101)-Light configuration-Dimming_AB_5,100
(102)-Light configuration-Light_Control_HD_AB_5,Always
(103)-Light configuration-Light_Function_C_5,0
(104)-Light configuration-Light_Function_D_5,0
(105)-Light configuration-Dimming_CD_5,0
(106)-Light configuration-Dimming_Direction_CD_5,maximize
(107)-Light configuration-Light_Function_E_5,0
(108)-Light configuration-Light_Function_F_5,0
(109)-Light configuration-Dimming_EF_5,0
(110)-Light configuration-Dimming_Direction_EF_5,maximize
(111)-Light configuration-Light_Function_G_5,0
(112)-Light configuration-Light_Function_H_5,0
(113)-Light configuration-Dimming_GH_5,0
(114)-Light configuration-Dimming_Direction_GH_5,maximize
(115)-Light configuration-Type_Of_Load_6,Low beam
(116)-Light configuration-BAP_Bitposition_6,36
(117)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6,1A
(118)-Light configuration-Light_Function_A_6,11
(119)-Light configuration-Light_Function_B_6,30
(120)-Light configuration-Dimming_AB_6,100
(121)-Light configuration-Light_Control_HD_AB_6,Always
(122)-Light configuration-Light_Function_C_6,0
(123)-Light configuration-Light_Function_D_6,0
(124)-Light configuration-Dimming_CD_6,0
(125)-Light configuration-Dimming_Direction_CD_6,maximize
(126)-Light configuration-Light_Function_E_6,0
(127)-Light configuration-Light_Function_F_6,0
(128)-Light configuration-Dimming_EF_6,0
(129)-Light configuration-Dimming_Direction_EF_6,maximize
(130)-Light configuration-Light_Function_G_6,0
(131)-Light configuration-Light_Function_H_6,0
(132)-Light configuration-Dimming_GH_6,0
(133)-Light configuration-Dimming_Direction_GH_6,maximize
(134)-Light configuration-Type_Of_Load_7,Low beam
(135)-Light configuration-BAP_Bitposition_7,40
(136)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7,1B
(137)-Light configuration-Light_Function_A_7,12
(138)-Light configuration-Light_Function_B_7,30
(139)-Light configuration-Dimming_AB_7,100
(140)-Light configuration-Light_Control_HD_AB_7,Always
(141)-Light configuration-Light_Function_C_7,0
(142)-Light configuration-Light_Function_D_7,0
(143)-Light configuration-Dimming_CD_7,0
(144)-Light configuration-Dimming_Direction_CD_7,maximize
(145)-Light configuration-Light_Function_E_7,0
(146)-Light configuration-Light_Function_F_7,0
(147)-Light configuration-Dimming_EF_7,0
(148)-Light configuration-Dimming_Direction_EF_7,maximize
(149)-Light configuration-Light_Function_G_7,0
(150)-Light configuration-Light_Function_H_7,0
(151)-Light configuration-Dimming_GH_7,1
(152)-Light configuration-Dimming_Direction_GH_7,maximize
(153)-Light configuration-Type_Of_Load_8,LED Tagfahrlichtmodul Versorgung
(154)-Light configuration-BAP_Bitposition_8,00
(155)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8,01
(156)-Light configuration-Light_Function_A_8,16
(157)-Light configuration-Light_Function_B_8,0
(158)-Light configuration-Dimming_AB_8,0
(159)-Light configuration-Light_Control_HD_AB_8,Always
(160)-Light configuration-Light_Function_C_8,0
(161)-Light configuration-Light_Function_D_8,77
(162)-Light configuration-Dimming_CD_8,0
(163)-Light configuration-Dimming_Direction_CD_8,maximize
(164)-Light configuration-Light_Function_E_8,173
(165)-Light configuration-Light_Function_F_8,1
(166)-Light configuration-Dimming_EF_8,28
(167)-Light configuration-Dimming_Direction_EF_8,minimize
(168)-Light configuration-Light_Function_G_8,0
(169)-Light configuration-Light_Function_H_8,0
(170)-Light configuration-Dimming_GH_8,1
(171)-Light configuration-Dimming_Direction_GH_8,maximize
(172)-Light configuration-Type_Of_Load_9,LED Kleinleistung ohne Open Load Diagnose
(173)-Light configuration-BAP_Bitposition_9,39
(174)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9,00
(175)-Light configuration-Light_Function_A_9,176
(176)-Light configuration-Light_Function_B_9,0
(177)-Light configuration-Dimming_AB_9,73
(178)-Light configuration-Light_Control_HD_AB_9,only_if_closed
(179)-Light configuration-Light_Function_C_9,1
(180)-Light configuration-Light_Function_D_9,3
(181)-Light configuration-Dimming_CD_9,0
(182)-Light configuration-Dimming_Direction_CD_9,maximize
(183)-Light configuration-Light_Function_E_9,0
(184)-Light configuration-Light_Function_F_9,42
(185)-Light configuration-Dimming_EF_9,101
(186)-Light configuration-Dimming_Direction_EF_9,maximize
(187)-Light configuration-Light_Function_G_9,42
(188)-Light configuration-Light_Function_H_9,54
(189)-Light configuration-Dimming_GH_9,1
(190)-Light configuration-Dimming_Direction_GH_9,maximize
(192)-Light configuration-BAP_Bitposition_10,00
(193)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10,00
(194)-Light configuration-Light_Function_A_10,208
(195)-Light configuration-Light_Function_B_10,1
(196)-Light configuration-Dimming_AB_10,52
(197)-Light configuration-Light_Control_HD_AB_10,only_if_closed
(198)-Light configuration-Light_Function_C_10,0
(199)-Light configuration-Light_Function_D_10,0
(200)-Light configuration-Dimming_CD_10,0
(201)-Light configuration-Dimming_Direction_CD_10,maximize
(202)-Light configuration-Light_Function_E_10,0
(203)-Light configuration-Light_Function_F_10,0
(204)-Light configuration-Dimming_EF_10,0
(205)-Light configuration-Dimming_Direction_EF_10,maximize
(206)-Light configuration-Light_Function_G_10,0
(207)-Light configuration-Light_Function_H_10,1
(208)-Light configuration-Dimming_GH_10,0
(209)-Light configuration-Dimming_Direction_GH_10,maximize
(210)-Light configuration-Type_Of_Load_11,not active
(211)-Light configuration-BAP_Bitposition_11,00
(212)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11,01
(213)-Light configuration-Light_Function_A_11,0
(214)-Light configuration-Light_Function_B_11,0
(215)-Light configuration-Dimming_AB_11,80
(216)-Light configuration-Light_Control_HD_AB_11,Always
(217)-Light configuration-Light_Function_C_11,0
(218)-Light configuration-Light_Function_D_11,16
(219)-Light configuration-Dimming_CD_11,42
(220)-Light configuration-Dimming_Direction_CD_11,maximize
(221)-Light configuration-Light_Function_E_11,147
(222)-Light configuration-Light_Function_F_11,113
(223)-Light configuration-Dimming_EF_11,80
(224)-Light configuration-Dimming_Direction_EF_11,minimize
(225)-Light configuration-Light_Function_G_11,1
(226)-Light configuration-Light_Function_H_11,0
(227)-Light configuration-Dimming_GH_11,0
(228)-Light configuration-Dimming_Direction_GH_11,maximize
(229)-Light configuration-Type_Of_Load_12,LED Tagfahrlichtmodul Versorgung
(230)-Light configuration-BAP_Bitposition_12,00
(231)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12,36
(232)-Light configuration-Light_Function_A_12,0
(233)-Light configuration-Light_Function_B_12,0
(234)-Light configuration-Dimming_AB_12,35
(235)-Light configuration-Light_Control_HD_AB_12,only_if_closed
(236)-Light configuration-Light_Function_C_12,113
(237)-Light configuration-Light_Function_D_12,208
(238)-Light configuration-Dimming_CD_12,1
(239)-Light configuration-Dimming_Direction_CD_12,maximize
(240)-Light configuration-Light_Function_E_12,0
(241)-Light configuration-Light_Function_F_12,0
(242)-Light configuration-Dimming_EF_12,1
(243)-Light configuration-Dimming_Direction_EF_12,maximize
(244)-Light configuration-Light_Function_G_12,0
(245)-Light configuration-Light_Function_H_12,0
(246)-Light configuration-Dimming_GH_12,0
(247)-Light configuration-Dimming_Direction_GH_12,maximize
(248)-Light configuration-Type_Of_Load_13,LED Tagfahrlichtmodul Versorgung
(249)-Light configuration-BAP_Bitposition_13,00
(250)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13,01
(251)-Light configuration-Light_Function_A_13,1
(252)-Light configuration-Light_Function_B_13,0
(253)-Light configuration-Dimming_AB_13,26
(254)-Light configuration-Light_Control_HD_AB_13,Always
(255)-Light configuration-Light_Function_C_13,1
(256)-Light configuration-Light_Function_D_13,87
(257)-Light configuration-Dimming_CD_13,1
(258)-Light configuration-Dimming_Direction_CD_13,maximize
(259)-Light configuration-Light_Function_E_13,247
(260)-Light configuration-Light_Function_F_13,0
(261)-Light configuration-Dimming_EF_13,80
(262)-Light configuration-Dimming_Direction_EF_13,minimize
(263)-Light configuration-Light_Function_G_13,1
(264)-Light configuration-Light_Function_H_13,0
(265)-Light configuration-Dimming_GH_13,0
(266)-Light configuration-Dimming_Direction_GH_13,maximize
(267)-Light configuration-Type_Of_Load_14,LED Tagfahrlichtmodul Versorgung
(268)-Light configuration-BAP_Bitposition_14,00
(269)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14,00
(270)-Light configuration-Light_Function_A_14,0
(271)-Light configuration-Light_Function_B_14,0
(272)-Light configuration-Dimming_AB_14,7
(273)-Light configuration-Light_Control_HD_AB_14,only_if_closed
(274)-Light configuration-Light_Function_C_14,1
(275)-Light configuration-Light_Function_D_14,1
(276)-Light configuration-Dimming_CD_14,0
(277)-Light configuration-Dimming_Direction_CD_14,maximize
(278)-Light configuration-Light_Function_E_14,1
(279)-Light configuration-Light_Function_F_14,0
(280)-Light configuration-Dimming_EF_14,0
(281)-Light configuration-Dimming_Direction_EF_14,maximize
(282)-Light configuration-Light_Function_G_14,0
(283)-Light configuration-Light_Function_H_14,255
(284)-Light configuration-Dimming_GH_14,52
(285)-Light configuration-Dimming_Direction_GH_14,maximize
(286)-Light configuration-Type_Of_Load_15,not active
(287)-Light configuration-BAP_Bitposition_15,00
(288)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15,01
(289)-Light configuration-Light_Function_A_15,2
(290)-Light configuration-Light_Function_B_15,0
(291)-Light configuration-Dimming_AB_15,104
(292)-Light configuration-Light_Control_HD_AB_15,only_if_closed
(293)-Light configuration-Light_Function_C_15,1
(294)-Light configuration-Light_Function_D_15,1
(295)-Light configuration-Dimming_CD_15,0
(296)-Light configuration-Dimming_Direction_CD_15,maximize
(297)-Light configuration-Light_Function_E_15,9
(298)-Light configuration-Light_Function_F_15,54
(299)-Light configuration-Dimming_EF_15,15
(300)-Light configuration-Dimming_Direction_EF_15,maximize
(301)-Light configuration-Light_Function_G_15,0
(302)-Light configuration-Light_Function_H_15,0
(303)-Light configuration-Dimming_GH_15,0
(304)-Light configuration-Dimming_Direction_GH_15,maximize
(305)-Light configuration-Type_Of_Load_16,not active
(306)-Light configuration-BAP_Bitposition_16,00
(307)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16,00
(308)-Light configuration-Light_Function_A_16,254
(309)-Light configuration-Light_Function_B_16,0
(310)-Light configuration-Dimming_AB_16,96
(311)-Light configuration-Light_Control_HD_AB_16,Always
(312)-Light configuration-Light_Function_C_16,0
(313)-Light configuration-Light_Function_D_16,16
(314)-Light configuration-Dimming_CD_16,0
(315)-Light configuration-Dimming_Direction_CD_16,maximize
(316)-Light configuration-Light_Function_E_16,56
(317)-Light configuration-Light_Function_F_16,0
(318)-Light configuration-Dimming_EF_16,16
(319)-Light configuration-Dimming_Direction_EF_16,maximize
(320)-Light configuration-Light_Function_G_16,0
(321)-Light configuration-Light_Function_H_16,246
(322)-Light configuration-Dimming_GH_16,0
(323)-Light configuration-Dimming_Direction_GH_16,maximize
(324)-Light configuration-Type_Of_Load_17,not active
(325)-Light configuration-BAP_Bitposition_17,00
(326)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17,01
(327)-Light configuration-Light_Function_A_17,0
(328)-Light configuration-Light_Function_B_17,0
(329)-Light configuration-Dimming_AB_17,126
(330)-Light configuration-Light_Control_HD_AB_17,only_if_closed
(331)-Light configuration-Light_Function_C_17,255
(332)-Light configuration-Light_Function_D_17,1
(333)-Light configuration-Dimming_CD_17,0
(334)-Light configuration-Dimming_Direction_CD_17,maximize
(335)-Light configuration-Light_Function_E_17,176
(336)-Light configuration-Light_Function_F_17,1
(337)-Light configuration-Dimming_EF_17,48
(338)-Light configuration-Dimming_Direction_EF_17,minimize
(339)-Light configuration-Light_Function_G_17,1
(340)-Light configuration-Light_Function_H_17,82
(341)-Light configuration-Dimming_GH_17,1
(342)-Light configuration-Dimming_Direction_GH_17,maximize
(344)-Light configuration-BAP_Bitposition_18,2A
(345)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18,01
(346)-Light configuration-Light_Function_A_18,168
(347)-Light configuration-Light_Function_B_18,1
(348)-Light configuration-Dimming_AB_18,7
(349)-Light configuration-Light_Control_HD_AB_18,Always
(350)-Light configuration-Light_Function_C_18,0
(351)-Light configuration-Light_Function_D_18,14
(352)-Light configuration-Dimming_CD_18,0
(353)-Light configuration-Dimming_Direction_CD_18,maximize
(354)-Light configuration-Light_Function_E_18,13
(355)-Light configuration-Light_Function_F_18,85
(356)-Light configuration-Dimming_EF_18,0
(357)-Light configuration-Dimming_Direction_EF_18,maximize
(358)-Light configuration-Light_Function_G_18,0
(359)-Light configuration-Light_Function_H_18,0
(360)-Light configuration-Dimming_GH_18,0
(361)-Light configuration-Dimming_Direction_GH_18,maximize
(363)-Light configuration-BAP_Bitposition_19,01
(364)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19,01
(365)-Light configuration-Light_Function_A_19,0
(366)-Light configuration-Light_Function_B_19,0
(367)-Light configuration-Dimming_AB_19,0
(368)-Light configuration-Light_Control_HD_AB_19,Always
(369)-Light configuration-Light_Function_C_19,0
(370)-Light configuration-Light_Function_D_19,0
(371)-Light configuration-Dimming_CD_19,0
(372)-Light configuration-Dimming_Direction_CD_19,maximize
(373)-Light configuration-Light_Function_E_19,0
(374)-Light configuration-Light_Function_F_19,0
(375)-Light configuration-Dimming_EF_19,0
(376)-Light configuration-Dimming_Direction_EF_19,maximize
(377)-Light configuration-Light_Function_G_19,0
(378)-Light configuration-Light_Function_H_19,99
(379)-Light configuration-Dimming_GH_19,1
(380)-Light configuration-Dimming_Direction_GH_19,maximize
(381)-Light configuration-Type_Of_Load_20,not active
(382)-Light configuration-BAP_Bitposition_20,00
(383)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20,00
(384)-Light configuration-Light_Function_A_20,0
(385)-Light configuration-Light_Function_B_20,0
(386)-Light configuration-Dimming_AB_20,0
(387)-Light configuration-Light_Control_HD_AB_20,Always
(388)-Light configuration-Light_Function_C_20,0
(389)-Light configuration-Light_Function_D_20,62
(390)-Light configuration-Dimming_CD_20,0
(391)-Light configuration-Dimming_Direction_CD_20,maximize
(392)-Light configuration-Light_Function_E_20,146
(393)-Light configuration-Light_Function_F_20,1
(394)-Light configuration-Dimming_EF_20,0
(395)-Light configuration-Dimming_Direction_EF_20,maximize
(396)-Light configuration-Light_Function_G_20,0
(397)-Light configuration-Light_Function_H_20,0
(398)-Light configuration-Dimming_GH_20,0
(399)-Light configuration-Dimming_Direction_GH_20,maximize
(400)-Light configuration-Type_Of_Load_21,not active
(401)-Light configuration-BAP_Bitposition_21,00
(402)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21,00
(403)-Light configuration-Light_Function_A_21,0
(404)-Light configuration-Light_Function_B_21,0
(405)-Light configuration-Dimming_AB_21,0
(406)-Light configuration-Light_Control_HD_AB_21,Always
(407)-Light configuration-Light_Function_C_21,0
(408)-Light configuration-Light_Function_D_21,0
(409)-Light configuration-Dimming_CD_21,0
(410)-Light configuration-Dimming_Direction_CD_21,maximize
(411)-Light configuration-Light_Function_E_21,0
(412)-Light configuration-Light_Function_F_21,0
(413)-Light configuration-Dimming_EF_21,0
(414)-Light configuration-Dimming_Direction_EF_21,maximize
(415)-Light configuration-Light_Function_G_21,0
(416)-Light configuration-Light_Function_H_21,0
(417)-Light configuration-Dimming_GH_21,0
(418)-Light configuration-Dimming_Direction_GH_21,maximize
(419)-Light configuration-Type_Of_Load_22,not active
(420)-Light configuration-BAP_Bitposition_22,00
(421)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22,00
(422)-Light configuration-Light_Function_A_22,0
(423)-Light configuration-Light_Function_B_22,0
(424)-Light configuration-Dimming_AB_22,0
(425)-Light configuration-Light_Control_HD_AB_22,Always
(426)-Light configuration-Light_Function_C_22,0
(427)-Light configuration-Light_Function_D_22,0
(428)-Light configuration-Dimming_CD_22,0
(429)-Light configuration-Dimming_Direction_CD_22,maximize
(430)-Light configuration-Light_Function_E_22,0
(431)-Light configuration-Light_Function_F_22,0
(432)-Light configuration-Dimming_EF_22,99
(433)-Light configuration-Dimming_Direction_EF_22,minimize
(434)-Light configuration-Light_Function_G_22,113
(435)-Light configuration-Light_Function_H_22,1
(436)-Light configuration-Dimming_GH_22,0
(437)-Light configuration-Dimming_Direction_GH_22,maximize
(438)-Light configuration-Type_Of_Load_23,allgemeine LED mit Open Load Diagnose
(439)-Light configuration-BAP_Bitposition_23,00
(440)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23,01
(441)-Light configuration-Light_Function_A_23,246
(442)-Light configuration-Light_Function_B_23,0
(443)-Light configuration-Dimming_AB_23,16
(444)-Light configuration-Light_Control_HD_AB_23,only_if_closed
(445)-Light configuration-Light_Function_C_23,0
(446)-Light configuration-Light_Function_D_23,144
(447)-Light configuration-Dimming_CD_23,0
(448)-Light configuration-Dimming_Direction_CD_23,maximize
(449)-Light configuration-Light_Function_E_23,1
(450)-Light configuration-Light_Function_F_23,0
(451)-Light configuration-Dimming_EF_23,96
(452)-Light configuration-Dimming_Direction_EF_23,maximize
(453)-Light configuration-Light_Function_G_23,0
(454)-Light configuration-Light_Function_H_23,82
(455)-Light configuration-Dimming_GH_23,1
(456)-Light configuration-Dimming_Direction_GH_23,maximize
(457)-Light configuration-Type_Of_Load_24,not active
(458)-Light configuration-BAP_Bitposition_24,00
(459)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24,00
(460)-Light configuration-Light_Function_A_24,0
(461)-Light configuration-Light_Function_B_24,0
(462)-Light configuration-Dimming_AB_24,1
(463)-Light configuration-Light_Control_HD_AB_24,Always
(464)-Light configuration-Light_Function_C_24,0
(465)-Light configuration-Light_Function_D_24,16
(466)-Light configuration-Dimming_CD_24,0
(467)-Light configuration-Dimming_Direction_CD_24,maximize
(468)-Light configuration-Light_Function_E_24,145
(469)-Light configuration-Light_Function_F_24,0
(470)-Light configuration-Dimming_EF_24,64
(471)-Light configuration-Dimming_Direction_EF_24,minimize
(472)-Light configuration-Light_Function_G_24,1
(473)-Light configuration-Light_Function_H_24,96
(474)-Light configuration-Dimming_GH_24,0
(475)-Light configuration-Dimming_Direction_GH_24,maximize
(477)-Light configuration-BAP_Bitposition_25,00
(478)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25,00
(479)-Light configuration-Light_Function_A_25,203
(480)-Light configuration-Light_Function_B_25,0
(481)-Light configuration-Dimming_AB_25,50
(482)-Light configuration-Light_Control_HD_AB_25,Always
(483)-Light configuration-Light_Function_C_25,1
(484)-Light configuration-Light_Function_D_25,192
(485)-Light configuration-Dimming_CD_25,1
(486)-Light configuration-Dimming_Direction_CD_25,maximize
(487)-Light configuration-Light_Function_E_25,144
(488)-Light configuration-Light_Function_F_25,0
(489)-Light configuration-Dimming_EF_25,1
(490)-Light configuration-Dimming_Direction_EF_25,maximize
(491)-Light configuration-Light_Function_G_25,0
(492)-Light configuration-Light_Function_H_25,0
(493)-Light configuration-Dimming_GH_25,0
(494)-Light configuration-Dimming_Direction_GH_25,maximize
(496)-Light configuration-BAP_Bitposition_26,00
(497)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26,00
(498)-Light configuration-Light_Function_A_26,222
(499)-Light configuration-Light_Function_B_26,0
(500)-Light configuration-Dimming_AB_26,0
(501)-Light configuration-Light_Control_HD_AB_26,Always
(502)-Light configuration-Light_Function_C_26,0
(503)-Light configuration-Light_Function_D_26,0
(504)-Light configuration-Dimming_CD_26,0
(505)-Light configuration-Dimming_Direction_CD_26,maximize
(506)-Light configuration-Light_Function_E_26,1
(507)-Light configuration-Light_Function_F_26,0
(508)-Light configuration-Dimming_EF_26,31
(509)-Light configuration-Dimming_Direction_EF_26,maximize
(510)-Light configuration-Light_Function_G_26,0
(511)-Light configuration-Light_Function_H_26,136
(512)-Light configuration-Dimming_GH_26,1
(513)-Light configuration-Dimming_Direction_GH_26,maximize
(514)-Light configuration-Type_Of_Load_27,not active
(515)-Light configuration-BAP_Bitposition_27,00
(516)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27,01
(517)-Light configuration-Light_Function_A_27,254
(518)-Light configuration-Light_Function_B_27,255
(519)-Light configuration-Dimming_AB_27,20
(520)-Light configuration-Light_Control_HD_AB_27,only_if_closed
(521)-Light configuration-Light_Function_C_27,1
(522)-Light configuration-Light_Function_D_27,0
(523)-Light configuration-Dimming_CD_27,0
(524)-Light configuration-Dimming_Direction_CD_27,maximize
(525)-Light configuration-Light_Function_E_27,80
(526)-Light configuration-Light_Function_F_27,0
(527)-Light configuration-Dimming_EF_27,0
(528)-Light configuration-Dimming_Direction_EF_27,maximize
(529)-Light configuration-Light_Function_G_27,0
(530)-Light configuration-Light_Function_H_27,240
(531)-Light configuration-Dimming_GH_27,1
(532)-Light configuration-Dimming_Direction_GH_27,maximize
(534)-Light configuration-BAP_Bitposition_28,00
(535)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28,FA
(536)-Light configuration-Light_Function_A_28,4
(537)-Light configuration-Light_Function_B_28,0
(538)-Light configuration-Dimming_AB_28,0
(539)-Light configuration-Light_Control_HD_AB_28,Always
(540)-Light configuration-Light_Function_C_28,0
(541)-Light configuration-Light_Function_D_28,160
(542)-Light configuration-Dimming_CD_28,0
(543)-Light configuration-Dimming_Direction_CD_28,maximize
(544)-Light configuration-Light_Function_E_28,0
(545)-Light configuration-Light_Function_F_28,250
(546)-Light configuration-Dimming_EF_28,0
(547)-Light configuration-Dimming_Direction_EF_28,maximize
(548)-Light configuration-Light_Function_G_28,0
(549)-Light configuration-Light_Function_H_28,178
(550)-Light configuration-Dimming_GH_28,1
(551)-Light configuration-Dimming_Direction_GH_28,maximize
(552)-Light configuration-Type_Of_Load_29,not active
(553)-Light configuration-BAP_Bitposition_29,00
(554)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29,00
(555)-Light configuration-Light_Function_A_29,23
(556)-Light configuration-Light_Function_B_29,0
(557)-Light configuration-Dimming_AB_29,0
(558)-Light configuration-Light_Control_HD_AB_29,Always
(559)-Light configuration-Light_Function_C_29,0
(560)-Light configuration-Light_Function_D_29,0
(561)-Light configuration-Dimming_CD_29,127
(562)-Light configuration-Dimming_Direction_CD_29,minimize
(563)-Light configuration-Light_Function_E_29,0
(564)-Light configuration-Light_Function_F_29,0
(565)-Light configuration-Dimming_EF_29,126
(566)-Light configuration-Dimming_Direction_EF_29,minimize
(567)-Light configuration-Light_Function_G_29,255
(568)-Light configuration-Light_Function_H_29,196
(569)-Light configuration-Dimming_GH_29,1
(570)-Light configuration-Dimming_Direction_GH_29,maximize
(572)-Light configuration-BAP_Bitposition_30,00
(573)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30,FA
(574)-Light configuration-Light_Function_A_30,130
(575)-Light configuration-Light_Function_B_30,0
(576)-Light configuration-Dimming_AB_30,19
(577)-Light configuration-Light_Control_HD_AB_30,Always
(578)-Light configuration-Light_Function_C_30,0
(579)-Light configuration-Light_Function_D_30,5
(580)-Light configuration-Dimming_CD_30,0
(581)-Light configuration-Dimming_Direction_CD_30,maximize
(582)-Light configuration-Light_Function_E_30,0
(583)-Light configuration-Light_Function_F_30,0
(584)-Light configuration-Dimming_EF_30,0
(585)-Light configuration-Dimming_Direction_EF_30,maximize
(586)-Light configuration-Light_Function_G_30,0
(587)-Light configuration-Light_Function_H_30,0
(588)-Light configuration-Dimming_GH_30,0
(589)-Light configuration-Dimming_Direction_GH_30,maximize
(591)-Light configuration-BAP_Bitposition_31,01
(592)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31,00
(593)-Light configuration-Light_Function_A_31,0
(594)-Light configuration-Light_Function_B_31,0
(595)-Light configuration-Dimming_AB_31,49
(596)-Light configuration-Light_Control_HD_AB_31,Always
(597)-Light configuration-Light_Function_C_31,1
(598)-Light configuration-Light_Function_D_31,178
(599)-Light configuration-Dimming_CD_31,4
(600)-Light configuration-Dimming_Direction_CD_31,minimize
(601)-Light configuration-Light_Function_E_31,0
(602)-Light configuration-Light_Function_F_31,0
(603)-Light configuration-Dimming_EF_31,88
(604)-Light configuration-Dimming_Direction_EF_31,minimize
(605)-Light configuration-Light_Function_G_31,1
(606)-Light configuration-Light_Function_H_31,0
(607)-Light configuration-Dimming_GH_31,0
(608)-Light configuration-Dimming_Direction_GH_31,maximize
(609)-Light configuration-Type_Of_Load_32,not active
(610)-Light configuration-BAP_Bitposition_32,00
(611)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32,00
(612)-Light configuration-Light_Function_A_32,240
(613)-Light configuration-Light_Function_B_32,0
(614)-Light configuration-Dimming_AB_32,50
(615)-Light configuration-Light_Control_HD_AB_32,Always
(616)-Light configuration-Light_Function_C_32,250
(617)-Light configuration-Light_Function_D_32,1
(618)-Light configuration-Dimming_CD_32,0
(619)-Light configuration-Dimming_Direction_CD_32,maximize
(620)-Light configuration-Light_Function_E_32,1
(621)-Light configuration-Light_Function_F_32,0
(622)-Light configuration-Dimming_EF_32,78
(623)-Light configuration-Dimming_Direction_EF_32,maximize
(624)-Light configuration-Light_Function_G_32,0
(625)-Light configuration-Light_Function_H_32,84
(626)-Light configuration-Dimming_GH_32,0
(627)-Light configuration-Dimming_Direction_GH_32,maximize
(628)-Light configuration-Type_Of_Load_33,not active
(629)-Light configuration-BAP_Bitposition_33,00
(630)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33,FF
(631)-Light configuration-Light_Function_A_33,99
(632)-Light configuration-Light_Function_B_33,0
(633)-Light configuration-Dimming_AB_33,0
(634)-Light configuration-Light_Control_HD_AB_33,Always
(635)-Light configuration-Light_Function_C_33,45
(636)-Light configuration-Light_Function_D_33,42
(637)-Light configuration-Dimming_CD_33,0
(638)-Light configuration-Dimming_Direction_CD_33,maximize
(639)-Light configuration-Light_Function_E_33,0
(640)-Light configuration-Light_Function_F_33,250
(641)-Light configuration-Dimming_EF_33,72
(642)-Light configuration-Dimming_Direction_EF_33,maximize
(643)-Light configuration-Light_Function_G_33,0
(644)-Light configuration-Light_Function_H_33,1
(645)-Light configuration-Dimming_GH_33,122
(646)-Light configuration-Dimming_Direction_GH_33,maximize
(647)-Light configuration-Type_Of_Load_34,not active
(648)-Light configuration-BAP_Bitposition_34,00
(649)-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34,00
(650)-Light configuration-Light_Function_A_34,112
(651)-Light configuration-Light_Function_B_34,0
(652)-Light configuration-Dimming_AB_34,127
(653)-Light configuration-Light_Control_HD_AB_34,only_if_closed
(654)-Light configuration-Light_Function_C_34,255
(655)-Light configuration-Light_Function_D_34,255
(656)-Light configuration-Dimming_CD_34,127
(657)-Light configuration-Dimming_Direction_CD_34,minimize
(658)-Light configuration-Light_Function_E_34,115
(659)-Light configuration-Light_Function_F_34,250
(660)-Light configuration-Dimming_EF_34,50
(661)-Light configuration-Dimming_Direction_EF_34,maximize
(662)-Light configuration-Light_Function_G_34,250
(663)-Light configuration-Light_Function_H_34,0
(664)-Light configuration-Dimming_GH_34,117
(665)-Light configuration-Dimming_Direction_GH_34,minimize
(1)-other-pa_Funktion_2aus3,not installed
(2)-other-auspraegung_Bremsfluessigkeitsschalter,closed
(3)-other-mute_mode_aktiv,not active
(1)-Production mode-Window_regulator_nr_1,not active
(2)-Production mode-Window_reversing_threshold,not active
(3)-Production mode-Aussenbeleuchtung,not active
(4)-Production mode-Entry_control,not active
(5)-Production mode-Scheinwerferreinigung,not active
(6)-Production mode-Heckwischer,not active
(7)-Production mode-Interior lighting,not active
(1)-Rear Window Wiper-Komfortwischen Heck,active
(2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
(3)-Rear Window Wiper-Automatisches Heckwischen,not active
(4)-Rear Window Wiper-Traenenwischen Heck,not active
(5)-Rear Window Wiper-Heckwischer Weiterlauf,not active
(6)-Rear Window Wiper-no_automativ_parking_after_kl15_on,not active
(7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
(8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
(9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
(10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
Roller test bench mode; functional,not active
(1)-static AFS light-bei Rueckwaertsfahrt,OFF
(2)-static AFS light-Vorschrift,ECE R119
(3)-static AFS light-Lower speed threshold,0.0 km/h
(4)-static AFS light-Upper speed threshold,40.0 km/h
(5)-static AFS light-Steering wheel angle; offset,-63.50 °
(6)-static AFS light-Unterer Lenkradwinkel,120 °
(7)-static AFS light-Oberer Lenkradwinkel,180 °
(8)-static AFS light-Abdimmgeschwindigkeit,50.0 %/s
(9)-static AFS light-Maximaltemperatur,100.0 °C
(10)-static AFS light-obere Grenztemperatur,95.0 °C
(11)-static AFS light-untere Grenztemperatur,80.0 °C
Transport mode,active
(1)-Turn signal control-Warnblinken_bei_Verdeckentriegelung,not active
(2)-Turn signal control-Komfortblinken_Blinkzyklen,5
(3)-Turn signal control-Sonderfunktionen_2,not enabled
(4)-Turn signal control-Signalprioritaet_fuer_Blinker,SMLS
(5)-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger,combined
(6)-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung,Always active
(7)-Turn signal control-Komfortblinken,active
(8)-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert,3.0 %
(9)-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor,0.100 %
(10)-Turn signal control-Freilaufendes_Warnblinken,not active
(11)-Turn signal control-Abbruch Komfortblinken,not active
(1)-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
(2)-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value
(3)-Window heater-Heckscheibenheizung Zeitwert,600 s
(4)-Window heater-Running time of heated front window,240 s
(5)-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C
(6)-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C
(7)-Window heater-Aussenspiegelheizung,0.0 s
(1)-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0
(2)-Windshield wiper-SRA Verzoegerungszeit,0 ms
(4)-Windshield wiper-SRA Einweichpausenzeit,0 ms
(5)-Windshield wiper-SRA Nachwaschzeit,0 ms
(6)-Windshield wiper-SRA Pausenzeit,0 ms
(7)-Windshield wiper-SRA bei Waschwassermangel,not active
(8)-Windshield wiper-Frontwischer Referenzlauf,active
(9)-Windshield wiper-Wischer stop bei KL15 aus,not active
(10)-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
(11)-Windshield wiper-Regensensor aktivieren,activated
(12)-Windshield wiper-Menuesteuerung Frontwischer,not active
(13)-Windshield wiper-Frontwischer Notlaufprogramm,active
(14)-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,not active
(15)-Windshield wiper-Traenenwischen Front Status,not active
(16)-Windshield wiper-Adaptives Nachwischen bei SRA,active
(17)-Windshield wiper-Frontwischer_Serviceposition,active
(18)-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active
(19)-Windshield wiper-Wischer stop bei Motorstart,kein Wischerstopp
(20)-Windshield wiper-Frontwischer Abtauposition,keine Abtaupostition
Adaptation_theft_protection_2,not active
(1)-Innenbeleuchtung Abdimmen-x0,0 ms
(2)-Innenbeleuchtung Abdimmen-X1,200 ms
(3)-Innenbeleuchtung Abdimmen-X2,400 ms
(4)-Innenbeleuchtung Abdimmen-X3,600 ms
(5)-Innenbeleuchtung Abdimmen-X4,800 ms
(6)-Innenbeleuchtung Abdimmen-X5,1000 ms
(7)-Innenbeleuchtung Abdimmen-X6,1200 ms
(8)-Innenbeleuchtung Abdimmen-x7,1400 ms
(9)-Innenbeleuchtung Abdimmen-x8,1600 ms
(10)-Innenbeleuchtung Abdimmen-x9,1800 ms
(11)-Innenbeleuchtung Abdimmen-x10,2000 ms
(12)-Innenbeleuchtung Abdimmen-y0,100.0 %
(13)-Innenbeleuchtung Abdimmen-Y1,72.0 %
(14)-Innenbeleuchtung Abdimmen-Y2,48.0 %
(15)-Innenbeleuchtung Abdimmen-Y3,33.0 %
(16)-Innenbeleuchtung Abdimmen-Y4,18.0 %
(17)-Innenbeleuchtung Abdimmen-Y5,12.0 %
(18)-Innenbeleuchtung Abdimmen-Y6,8.0 %
(19)-Innenbeleuchtung Abdimmen-y7,6.0 %
(20)-Innenbeleuchtung Abdimmen-y8,4.0 %
(21)-Innenbeleuchtung Abdimmen-y9,2.0 %
(22)-Innenbeleuchtung Abdimmen-y10,0.0 %
(1)-Innenbeleuchtung Fotosensor-x0,0
(2)-Innenbeleuchtung Fotosensor-X1,50
(3)-Innenbeleuchtung Fotosensor-X2,100
(4)-Innenbeleuchtung Fotosensor-X3,200
(5)-Innenbeleuchtung Fotosensor-X4,253
(6)-Innenbeleuchtung Fotosensor-y0,0 lx
(7)-Innenbeleuchtung Fotosensor-Y1,50 lx
(8)-Innenbeleuchtung Fotosensor-Y2,100 lx
(9)-Innenbeleuchtung Fotosensor-Y3,200 lx
(10)-Innenbeleuchtung Fotosensor-Y4,500 lx
(1)-Innenbeleuchtung Hochdimmen-x0,0 ms
(2)-Innenbeleuchtung Hochdimmen-X1,200 ms
(3)-Innenbeleuchtung Hochdimmen-X2,400 ms
(4)-Innenbeleuchtung Hochdimmen-X3,600 ms
(5)-Innenbeleuchtung Hochdimmen-X4,800 ms
(6)-Innenbeleuchtung Hochdimmen-X5,1000 ms
(7)-Innenbeleuchtung Hochdimmen-X6,1200 ms
(8)-Innenbeleuchtung Hochdimmen-x7,1400 ms
(9)-Innenbeleuchtung Hochdimmen-x8,1600 ms
(10)-Innenbeleuchtung Hochdimmen-x9,1800 ms
(11)-Innenbeleuchtung Hochdimmen-x10,2000 ms
(12)-Innenbeleuchtung Hochdimmen-y0,0.0 %
(13)-Innenbeleuchtung Hochdimmen-Y1,1.0 %
(14)-Innenbeleuchtung Hochdimmen-Y2,3.0 %
(15)-Innenbeleuchtung Hochdimmen-Y3,5.0 %
(16)-Innenbeleuchtung Hochdimmen-Y4,11.0 %
(17)-Innenbeleuchtung Hochdimmen-Y5,22.0 %
(18)-Innenbeleuchtung Hochdimmen-Y6,40.0 %
(19)-Innenbeleuchtung Hochdimmen-y7,80.0 %
(20)-Innenbeleuchtung Hochdimmen-y8,95.0 %
(21)-Innenbeleuchtung Hochdimmen-y9,100.0 %
(22)-Innenbeleuchtung Hochdimmen-y10,100.0 %
(1)-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %
(2)-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %
(3)-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %
(4)-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %
(5)-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %
(6)-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %
(7)-Innenbeleuchtung KL 58xd log Bus-y0,10
(8)-Innenbeleuchtung KL 58xd log Bus-Y1,10
(9)-Innenbeleuchtung KL 58xd log Bus-Y2,100
(10)-Innenbeleuchtung KL 58xd log Bus-Y3,150
(11)-Innenbeleuchtung KL 58xd log Bus-Y4,220
(12)-Innenbeleuchtung KL 58xd log Bus-Y5,253
(1)-Innenbeleuchtung KL 58xd max-x0,0 lx
(2)-Innenbeleuchtung KL 58xd max-X1,8 lx
(3)-Innenbeleuchtung KL 58xd max-X2,200 lx
(4)-Innenbeleuchtung KL 58xd max-X3,300 lx
(5)-Innenbeleuchtung KL 58xd max-X4,500 lx
(6)-Innenbeleuchtung KL 58xd max-y0,16.0
(7)-Innenbeleuchtung KL 58xd max-Y1,16.0
(8)-Innenbeleuchtung KL 58xd max-Y2,100.0
(9)-Innenbeleuchtung KL 58xd max-Y3,100.0
(10)-Innenbeleuchtung KL 58xd max-Y4,100.0
(1)-Innenbeleuchtung KL 58xd min-x0,0 lx
(2)-Innenbeleuchtung KL 58xd min-X1,8 lx
(3)-Innenbeleuchtung KL 58xd min-X2,220 lx
(4)-Innenbeleuchtung KL 58xd min-X3,300 lx
(5)-Innenbeleuchtung KL 58xd min-X4,500 lx
(6)-Innenbeleuchtung KL 58xd min-y0,6.0
(7)-Innenbeleuchtung KL 58xd min-Y1,6.0
(8)-Innenbeleuchtung KL 58xd min-Y2,100.0
(9)-Innenbeleuchtung KL 58xd min-Y3,100.0
(10)-Innenbeleuchtung KL 58xd min-Y4,100.0
(1)-Innenbeleuchtung KL 58xd PWM-x0,0
(2)-Innenbeleuchtung KL 58xd PWM-X1,10
(3)-Innenbeleuchtung KL 58xd PWM-X2,50
(4)-Innenbeleuchtung KL 58xd PWM-X3,100
(5)-Innenbeleuchtung KL 58xd PWM-X4,220
(6)-Innenbeleuchtung KL 58xd PWM-X5,253
(7)-Innenbeleuchtung KL 58xd PWM-y0,100.0 %
(8)-Innenbeleuchtung KL 58xd PWM-Y1,100.0 %
(9)-Innenbeleuchtung KL 58xd PWM-Y2,100.0 %
(10)-Innenbeleuchtung KL 58xd PWM-Y3,100.0 %
(11)-Innenbeleuchtung KL 58xd PWM-Y4,100.0 %
(12)-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %
(1)-Innenbeleuchtung KL 58xs max-x0,0 lx
(2)-Innenbeleuchtung KL 58xs max-X1,8 lx
(3)-Innenbeleuchtung KL 58xs max-X2,50 lx
(4)-Innenbeleuchtung KL 58xs max-X3,500 lx
(5)-Innenbeleuchtung KL 58xs max-y0,100.0
(6)-Innenbeleuchtung KL 58xs max-Y1,100.0
(7)-Innenbeleuchtung KL 58xs max-Y2,100.0
(8)-Innenbeleuchtung KL 58xs max-Y3,100.0
(1)-Innenbeleuchtung KL 58xs min-x0,0 lx
(2)-Innenbeleuchtung KL 58xs min-X1,8 lx
(3)-Innenbeleuchtung KL 58xs min-X2,50 lx
(4)-Innenbeleuchtung KL 58xs min-X3,500 lx
(5)-Innenbeleuchtung KL 58xs min-y0,6.0
(6)-Innenbeleuchtung KL 58xs min-Y1,6.0
(7)-Innenbeleuchtung KL 58xs min-Y2,100.0
(8)-Innenbeleuchtung KL 58xs min-Y3,100.0
(1)-Innenbeleuchtung KL 58xs PWM-x0,0.0 %
(2)-Innenbeleuchtung KL 58xs PWM-X1,50.0 %
(3)-Innenbeleuchtung KL 58xs PWM-X2,100.0 %
(4)-Innenbeleuchtung KL 58xs PWM-y0,0.0 %
(5)-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %
(6)-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %
(1)-Innenbeleuchtung KL 58xt max-x0,0 lx
(2)-Innenbeleuchtung KL 58xt max-X1,8 lx
(3)-Innenbeleuchtung KL 58xt max-X2,50 lx
(4)-Innenbeleuchtung KL 58xt max-X3,500 lx
(5)-Innenbeleuchtung KL 58xt max-y0,100.0
(6)-Innenbeleuchtung KL 58xt max-Y1,100.0
(7)-Innenbeleuchtung KL 58xt max-Y2,100.0
(8)-Innenbeleuchtung KL 58xt max-Y3,100.0
(1)-Innenbeleuchtung KL 58xt min-x0,0 lx
(2)-Innenbeleuchtung KL 58xt min-X1,8 lx
(3)-Innenbeleuchtung KL 58xt min-X2,50 lx
(4)-Innenbeleuchtung KL 58xt min-X3,500 lx
(5)-Innenbeleuchtung KL 58xt min-y0,6.0
(6)-Innenbeleuchtung KL 58xt min-Y1,6.0
(7)-Innenbeleuchtung KL 58xt min-Y2,100.0
(8)-Innenbeleuchtung KL 58xt min-Y3,100.0
(1)-Innenbeleuchtung KL 58xt PWM-x0,0.0 %
(2)-Innenbeleuchtung KL 58xt PWM-X1,50.0 %
(3)-Innenbeleuchtung KL 58xt PWM-X2,100.0 %
(4)-Innenbeleuchtung KL 58xt PWM-y0,0.0 %
(5)-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %
(6)-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %
(1)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
(2)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,0 ms
(3)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,0 ms
(4)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,0 ms
(5)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,0 ms
(6)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,0.0 %
(7)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,0.0
(8)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,0.0
(9)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,0.0
(10)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,0.0
(1)-Leuchte 0 BLK VL B35-Type_Of_Load_0,Blinkleuchten
(2)-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0,34
(3)-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0,14
(4)-Leuchte 0 BLK VL B35-Light_Function_A_0,Blinken links Hellphase
(5)-Leuchte 0 BLK VL B35-Light_Function_B_0,not active
(6)-Leuchte 0 BLK VL B35-Dimming_AB_0,100
(7)-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0,Always
(8)-Leuchte 0 BLK VL B35-Light_Function_C_0,not active
(9)-Leuchte 0 BLK VL B35-Light_Function_D_0,not active
(10)-Leuchte 0 BLK VL B35-Dimming_CD_0,0
(11)-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0,maximize
(12)-Leuchte 0 BLK VL B35-Light_Function_E_0,not active
(13)-Leuchte 0 BLK VL B35-Light_Function_F_0,not active
(14)-Leuchte 0 BLK VL B35-Dimming_EF_0,0
(15)-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0,maximize
(16)-Leuchte 0 BLK VL B35-Light_Function_G_0,not active
(17)-Leuchte 0 BLK VL B35-Light_Function_H_0,not active
(18)-Leuchte 0 BLK VL B35-Dimming_GH_0,0
(19)-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0,maximize
(1)-Leuchte10SHUTTER LRB45-Type_Of_Load_10,not active
(2)-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10,00
(3)-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10,00
(4)-Leuchte10SHUTTER LRB45-Light_Function_A_10,not active
(5)-Leuchte10SHUTTER LRB45-Light_Function_B_10,not active
(6)-Leuchte10SHUTTER LRB45-Dimming_AB_10,0
(7)-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10,Always
(8)-Leuchte10SHUTTER LRB45-Light_Function_C_10,not active
(9)-Leuchte10SHUTTER LRB45-Light_Function_D_10,not active
(10)-Leuchte10SHUTTER LRB45-Dimming_CD_10,0
(11)-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10,maximize
(12)-Leuchte10SHUTTER LRB45-Light_Function_E_10,not active
(13)-Leuchte10SHUTTER LRB45-Light_Function_F_10,not active
(14)-Leuchte10SHUTTER LRB45-Dimming_EF_10,0
(15)-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10,maximize
(16)-Leuchte10SHUTTER LRB45-Light_Function_G_10,not active
(17)-Leuchte10SHUTTER LRB45-Light_Function_H_10,not active
(18)-Leuchte10SHUTTER LRB45-Dimming_GH_10,0
(19)-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10,maximize
(1)-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11,LED Kleinleistung ohne Open Load Diagnose
(2)-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11,00
(3)-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11,00
(4)-Leuchte11WARNBLK TASTERC54-Light_Function_A_11,Warnblinktaster
(5)-Leuchte11WARNBLK TASTERC54-Light_Function_B_11,not active
(6)-Leuchte11WARNBLK TASTERC54-Dimming_AB_11,100
(7)-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11,Always
(8)-Leuchte11WARNBLK TASTERC54-Light_Function_C_11,not active
(9)-Leuchte11WARNBLK TASTERC54-Light_Function_D_11,not active
(10)-Leuchte11WARNBLK TASTERC54-Dimming_CD_11,0
(11)-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11,maximize
(12)-Leuchte11WARNBLK TASTERC54-Light_Function_E_11,not active
(13)-Leuchte11WARNBLK TASTERC54-Light_Function_F_11,not active
(14)-Leuchte11WARNBLK TASTERC54-Dimming_EF_11,0
(15)-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11,maximize
(16)-Leuchte11WARNBLK TASTERC54-Light_Function_G_11,not active
(17)-Leuchte11WARNBLK TASTERC54-Light_Function_H_11,not active
(18)-Leuchte11WARNBLK TASTERC54-Dimming_GH_11,0
(19)-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11,maximize
(1)-Leuchte12NL LB40-Type_Of_Load_12,allgemeine Scheinwerfer
(2)-Leuchte12NL LB40-Lampendefektbit_Position_12,38
(3)-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12,22
(4)-Leuchte12NL LB40-Light_Function_A_12,Nebellicht links
(5)-Leuchte12NL LB40-Light_Function_B_12,Abbiegelicht links
(6)-Leuchte12NL LB40-Dimming_AB_12,100
(7)-Leuchte12NL LB40-Light_Control_HD_AB_12,Always
(8)-Leuchte12NL LB40-Light_Function_C_12,not active
(9)-Leuchte12NL LB40-Light_Function_D_12,not active
(10)-Leuchte12NL LB40-Dimming_CD_12,0
(11)-Leuchte12NL LB40-Dimming_Direction_CD_12,maximize
(12)-Leuchte12NL LB40-Light_Function_E_12,not active
(13)-Leuchte12NL LB40-Light_Function_F_12,not active
(14)-Leuchte12NL LB40-Dimming_EF_12,0
(15)-Leuchte12NL LB40-Dimming_Direction_EF_12,maximize
(16)-Leuchte12NL LB40-Light_Function_G_12,not active
(17)-Leuchte12NL LB40-Light_Function_H_12,not active
(18)-Leuchte12NL LB40-Dimming_GH_12,0
(19)-Leuchte12NL LB40-Dimming_Direction_GH_12,maximize
(1)-Leuchte13NL RB3-Type_Of_Load_13,allgemeine Scheinwerfer
(2)-Leuchte13NL RB3-Lampendefektbit_Position_13,42
(3)-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13,23
(4)-Leuchte13NL RB3-Light_Function_A_13,Nebellicht rechts
(5)-Leuchte13NL RB3-Light_Function_B_13,Abbiegelicht rechts
(6)-Leuchte13NL RB3-Dimming_AB_13,100
(7)-Leuchte13NL RB3-Light_Control_HD_AB_13,Always
(8)-Leuchte13NL RB3-Light_Function_C_13,not active
(9)-Leuchte13NL RB3-Light_Function_D_13,not active
(10)-Leuchte13NL RB3-Dimming_CD_13,0
(11)-Leuchte13NL RB3-Dimming_Direction_CD_13,maximize
(12)-Leuchte13NL RB3-Light_Function_E_13,not active
(13)-Leuchte13NL RB3-Light_Function_F_13,not active
(14)-Leuchte13NL RB3-Dimming_EF_13,0
(15)-Leuchte13NL RB3-Dimming_Direction_EF_13,maximize
(16)-Leuchte13NL RB3-Light_Function_G_13,not active
(17)-Leuchte13NL RB3-Light_Function_H_13,not active
(18)-Leuchte13NL RB3-Dimming_GH_13,0
(19)-Leuchte13NL RB3-Dimming_Direction_GH_13,maximize
(1)-Leuchte15 SAFE LED C55-Type_Of_Load_15,allgemeineLEDmitOpenLoadDiagnose
(2)-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15,00
(3)-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15,00
(4)-Leuchte15 SAFE LED C55-Light_Function_A_15,SafeLED
(5)-Leuchte15 SAFE LED C55-Light_Function_B_15,not active
(6)-Leuchte15 SAFE LED C55-Dimming_AB_15,100
(7)-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15,Always
(8)-Leuchte15 SAFE LED C55-Light_Function_C_15,not active
(9)-Leuchte15 SAFE LED C55-Light_Function_D_15,not active
(10)-Leuchte15 SAFE LED C55-Dimming_CD_15,0
(11)-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15,maximize
(12)-Leuchte15 SAFE LED C55-Light_Function_E_15,not active
(13)-Leuchte15 SAFE LED C55-Light_Function_F_15,not active
(14)-Leuchte15 SAFE LED C55-Dimming_EF_15,0
(15)-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15,maximize
(16)-Leuchte15 SAFE LED C55-Light_Function_G_15,not active
(17)-Leuchte15 SAFE LED C55-Light_Function_H_15,not active
(18)-Leuchte15 SAFE LED C55-Dimming_GH_15,0
(19)-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15,maximize
(1)-Leuchte16BLK SLC11-Type_Of_Load_16,LED Blinkleuchten
(2)-Leuchte16BLK SLC11-Lampendefektbit_Position_16,00
(3)-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16,00
(4)-Leuchte16BLK SLC11-Light_Function_A_16,Blinken links Hellphase
(5)-Leuchte16BLK SLC11-Light_Function_B_16,not active
(6)-Leuchte16BLK SLC11-Dimming_AB_16,100
(7)-Leuchte16BLK SLC11-Light_Control_HD_AB_16,Always
(8)-Leuchte16BLK SLC11-Light_Function_C_16,not active
(9)-Leuchte16BLK SLC11-Light_Function_D_16,not active
(10)-Leuchte16BLK SLC11-Dimming_CD_16,0
(11)-Leuchte16BLK SLC11-Dimming_Direction_CD_16,maximize
(12)-Leuchte16BLK SLC11-Light_Function_E_16,not active
(13)-Leuchte16BLK SLC11-Light_Function_F_16,not active
(14)-Leuchte16BLK SLC11-Dimming_EF_16,0
(15)-Leuchte16BLK SLC11-Dimming_Direction_EF_16,maximize
(16)-Leuchte16BLK SLC11-Light_Function_G_16,not active
(17)-Leuchte16BLK SLC11-Light_Function_H_16,not active
(18)-Leuchte16BLK SLC11-Dimming_GH_16,0
(19)-Leuchte16BLK SLC11-Dimming_Direction_GH_16,maximize
(1)-Leuchte17 BLK SR A72-Type_Of_Load_17,LED Blinkleuchten
(2)-Leuchte17 BLK SR A72-Lampendefektbit_Position_17,00
(3)-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17,00
(4)-Leuchte17 BLK SR A72-Light_Function_A_17,Blinken rechts Hellphase
(5)-Leuchte17 BLK SR A72-Light_Function_B_17,not active
(6)-Leuchte17 BLK SR A72-Dimming_AB_17,100
(7)-Leuchte17 BLK SR A72-Light_Control_HD_AB_17,Always
(8)-Leuchte17 BLK SR A72-Light_Function_C_17,not active
(9)-Leuchte17 BLK SR A72-Light_Function_D_17,not active
(10)-Leuchte17 BLK SR A72-Dimming_CD_17,0
(11)-Leuchte17 BLK SR A72-Dimming_Direction_CD_17,maximize
(12)-Leuchte17 BLK SR A72-Light_Function_E_17,not active
(13)-Leuchte17 BLK SR A72-Light_Function_F_17,not active
(14)-Leuchte17 BLK SR A72-Dimming_EF_17,0
(15)-Leuchte17 BLK SR A72-Dimming_Direction_EF_17,maximize
(16)-Leuchte17 BLK SR A72-Light_Function_G_17,not active
(17)-Leuchte17 BLK SR A72-Light_Function_H_17,not active
(18)-Leuchte17 BLK SR A72-Dimming_GH_17,0
(19)-Leuchte17 BLK SR A72-Dimming_Direction_GH_17,maximize
(1)-Leuchte18BLK HLA71-Type_Of_Load_18,Blinkleuchten
(2)-Leuchte18BLK HLA71-Lampendefektbit_Position_18,08
(3)-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18,16
(4)-Leuchte18BLK HLA71-Light_Function_A_18,Blinken links Hellphase
(5)-Leuchte18BLK HLA71-Light_Function_B_18,not active
(6)-Leuchte18BLK HLA71-Dimming_AB_18,100
(7)-Leuchte18BLK HLA71-Light_Control_HD_AB_18,Always
(8)-Leuchte18BLK HLA71-Light_Function_C_18,not active
(9)-Leuchte18BLK HLA71-Light_Function_D_18,not active
(10)-Leuchte18BLK HLA71-Dimming_CD_18,0
(11)-Leuchte18BLK HLA71-Dimming_Direction_CD_18,maximize
(12)-Leuchte18BLK HLA71-Light_Function_E_18,not active
(13)-Leuchte18BLK HLA71-Light_Function_F_18,not active
(14)-Leuchte18BLK HLA71-Dimming_EF_18,0
(15)-Leuchte18BLK HLA71-Dimming_Direction_EF_18,maximize
(16)-Leuchte18BLK HLA71-Light_Function_G_18,not active
(17)-Leuchte18BLK HLA71-Light_Function_H_18,not active
(18)-Leuchte18BLK HLA71-Dimming_GH_18,0
(19)-Leuchte18BLK HLA71-Dimming_Direction_GH_18,maximize
(1)-Leuchte19BLK HRC10-Type_Of_Load_19,Blinkleuchten
(2)-Leuchte19BLK HRC10-Lampendefektbit_Position_19,18
(3)-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19,18
(4)-Leuchte19BLK HRC10-Light_Function_A_19,Blinken rechts Hellphase
(5)-Leuchte19BLK HRC10-Light_Function_B_19,not active
(6)-Leuchte19BLK HRC10-Dimming_AB_19,100
(7)-Leuchte19BLK HRC10-Light_Control_HD_AB_19,Always
(8)-Leuchte19BLK HRC10-Light_Function_C_19,not active
(9)-Leuchte19BLK HRC10-Light_Function_D_19,not active
(10)-Leuchte19BLK HRC10-Dimming_CD_19,0
(11)-Leuchte19BLK HRC10-Dimming_Direction_CD_19,maximize
(12)-Leuchte19BLK HRC10-Light_Function_E_19,not active
(13)-Leuchte19BLK HRC10-Light_Function_F_19,not active
(14)-Leuchte19BLK HRC10-Dimming_EF_19,0
(15)-Leuchte19BLK HRC10-Dimming_Direction_EF_19,maximize
(16)-Leuchte19BLK HRC10-Light_Function_G_19,not active
(17)-Leuchte19BLK HRC10-Light_Function_H_19,not active
(18)-Leuchte19BLK HRC10-Dimming_GH_19,0
(19)-Leuchte19BLK HRC10-Dimming_Direction_GH_19,maximize
(1)-Leuchte1BLK VRB23-Type_Of_Load_1,Blinkleuchten
(2)-Leuchte1BLK VRB23-Lampendefektbit_Position_1,3E
(3)-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1,15
(4)-Leuchte1BLK VRB23-Light_Function_A_1,Blinken rechts Hellphase
(5)-Leuchte1BLK VRB23-Light_Function_B_1,not active
(6)-Leuchte1BLK VRB23-Dimming_AB_1,100
(7)-Leuchte1BLK VRB23-Light_Control_HD_AB_1,Always
(8)-Leuchte1BLK VRB23-Light_Function_C_1,not active
(9)-Leuchte1BLK VRB23-Light_Function_D_1,not active
(10)-Leuchte1BLK VRB23-Dimming_CD_1,0
(11)-Leuchte1BLK VRB23-Dimming_Direction_CD_1,maximize
(12)-Leuchte1BLK VRB23-Light_Function_E_1,not active
(13)-Leuchte1BLK VRB23-Light_Function_F_1,not active
(14)-Leuchte1BLK VRB23-Dimming_EF_1,0
(15)-Leuchte1BLK VRB23-Dimming_Direction_EF_1,maximize
(16)-Leuchte1BLK VRB23-Light_Function_G_1,not active
(17)-Leuchte1BLK VRB23-Light_Function_H_1,not active
(18)-Leuchte1BLK VRB23-Dimming_GH_1,0
(19)-Leuchte1BLK VRB23-Dimming_Direction_GH_1,maximize
(1)-Leuchte20BR LA70-Type_Of_Load_20,Bremsleuchten
(2)-Leuchte20BR LA70-Lampendefektbit_Position_20,09
(3)-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20,2B
(4)-Leuchte20BR LA70-Light_Function_A_20,Brake light
(5)-Leuchte20BR LA70-Light_Function_B_20,not active
(6)-Leuchte20BR LA70-Dimming_AB_20,100
(7)-Leuchte20BR LA70-Light_Control_HD_AB_20,Always
(8)-Leuchte20BR LA70-Light_Function_C_20,not active
(9)-Leuchte20BR LA70-Light_Function_D_20,not active
(10)-Leuchte20BR LA70-Dimming_CD_20,0
(11)-Leuchte20BR LA70-Dimming_Direction_CD_20,maximize
(12)-Leuchte20BR LA70-Light_Function_E_20,not active
(13)-Leuchte20BR LA70-Light_Function_F_20,not active
(14)-Leuchte20BR LA70-Dimming_EF_20,0
(15)-Leuchte20BR LA70-Dimming_Direction_EF_20,maximize
(16)-Leuchte20BR LA70-Light_Function_G_20,not active
(17)-Leuchte20BR LA70-Light_Function_H_20,not active
(18)-Leuchte20BR LA70-Dimming_GH_20,0
(19)-Leuchte20BR LA70-Dimming_Direction_GH_20,maximize
(1)-Leuchte21BR RC8-Type_Of_Load_21,Bremsleuchten
(2)-Leuchte21BR RC8-Lampendefektbit_Position_21,19
(3)-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21,2D
(4)-Leuchte21BR RC8-Light_Function_A_21,Brake light
(5)-Leuchte21BR RC8-Light_Function_B_21,not active
(6)-Leuchte21BR RC8-Dimming_AB_21,100
(7)-Leuchte21BR RC8-Light_Control_HD_AB_21,Always
(8)-Leuchte21BR RC8-Light_Function_C_21,not active
(9)-Leuchte21BR RC8-Light_Function_D_21,not active
(10)-Leuchte21BR RC8-Dimming_CD_21,0
(11)-Leuchte21BR RC8-Dimming_Direction_CD_21,maximize
(12)-Leuchte21BR RC8-Light_Function_E_21,not active
(13)-Leuchte21BR RC8-Light_Function_F_21,not active
(14)-Leuchte21BR RC8-Dimming_EF_21,0
(15)-Leuchte21BR RC8-Dimming_Direction_EF_21,maximize
(16)-Leuchte21BR RC8-Light_Function_G_21,not active
(17)-Leuchte21BR RC8-Light_Function_H_21,not active
(18)-Leuchte21BR RC8-Dimming_GH_21,0
(19)-Leuchte21BR RC8-Dimming_Direction_GH_21,maximize
(1)-Leuchte22BR MC9-Type_Of_Load_22,LEDdritteBremsleuchte
(2)-Leuchte22BR MC9-Lampendefektbit_Position_22,29
(3)-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22,2C
(4)-Leuchte22BR MC9-Light_Function_A_22,Brake light
(5)-Leuchte22BR MC9-Light_Function_B_22,not active
(6)-Leuchte22BR MC9-Dimming_AB_22,100
(7)-Leuchte22BR MC9-Light_Control_HD_AB_22,Always
(8)-Leuchte22BR MC9-Light_Function_C_22,not active
(9)-Leuchte22BR MC9-Light_Function_D_22,not active
(10)-Leuchte22BR MC9-Dimming_CD_22,0
(11)-Leuchte22BR MC9-Dimming_Direction_CD_22,maximize
(12)-Leuchte22BR MC9-Light_Function_E_22,not active
(13)-Leuchte22BR MC9-Light_Function_F_22,not active
(14)-Leuchte22BR MC9-Dimming_EF_22,0
(15)-Leuchte22BR MC9-Dimming_Direction_EF_22,maximize
(16)-Leuchte22BR MC9-Light_Function_G_22,not active
(17)-Leuchte22BR MC9-Light_Function_H_22,not active
(18)-Leuchte22BR MC9-Dimming_GH_22,0
(19)-Leuchte22BR MC9-Dimming_Direction_GH_22,maximize
(1)-Leuchte23SL HLC7-Type_Of_Load_23,allgemeineGluehlampe6W;auchH6W
(2)-Leuchte23SL HLC7-Lampendefektbit_Position_23,0A
(3)-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23,29
(4)-Leuchte23SL HLC7-Light_Function_A_23,Parking light
(5)-Leuchte23SL HLC7-Light_Function_B_23,Parking light left
(6)-Leuchte23SL HLC7-Dimming_AB_23,60
(7)-Leuchte23SL HLC7-Light_Control_HD_AB_23,Always
(8)-Leuchte23SL HLC7-Light_Function_C_23,not active
(9)-Leuchte23SL HLC7-Light_Function_D_23,not active
(10)-Leuchte23SL HLC7-Dimming_CD_23,0
(11)-Leuchte23SL HLC7-Dimming_Direction_CD_23,maximize
(12)-Leuchte23SL HLC7-Light_Function_E_23,not active
(13)-Leuchte23SL HLC7-Light_Function_F_23,not active
(14)-Leuchte23SL HLC7-Dimming_EF_23,0
(15)-Leuchte23SL HLC7-Dimming_Direction_EF_23,maximize
(16)-Leuchte23SL HLC7-Light_Function_G_23,not active
(17)-Leuchte23SL HLC7-Light_Function_H_23,not active
(18)-Leuchte23SL HLC7-Dimming_GH_23,0
(19)-Leuchte23SL HLC7-Dimming_Direction_GH_23,maximize
(1)-Leuchte24SL HRA69-Type_Of_Load_24,allgemeineGluehlampe6W;auchH6W
(2)-Leuchte24SL HRA69-Lampendefektbit_Position_24,1A
(3)-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24,2A
(4)-Leuchte24SL HRA69-Light_Function_A_24,Parking light
(5)-Leuchte24SL HRA69-Light_Function_B_24,Parking light right
(6)-Leuchte24SL HRA69-Dimming_AB_24,60
(7)-Leuchte24SL HRA69-Light_Control_HD_AB_24,Always
(8)-Leuchte24SL HRA69-Light_Function_C_24,not active
(9)-Leuchte24SL HRA69-Light_Function_D_24,not active
(10)-Leuchte24SL HRA69-Dimming_CD_24,0
(11)-Leuchte24SL HRA69-Dimming_Direction_CD_24,maximize
(12)-Leuchte24SL HRA69-Light_Function_E_24,not active
(13)-Leuchte24SL HRA69-Light_Function_F_24,not active
(14)-Leuchte24SL HRA69-Dimming_EF_24,0
(15)-Leuchte24SL HRA69-Dimming_Direction_EF_24,maximize
(16)-Leuchte24SL HRA69-Light_Function_G_24,not active
(17)-Leuchte24SL HRA69-Light_Function_H_24,not active
(18)-Leuchte24SL HRA69-Dimming_GH_24,0
(19)-Leuchte24SL HRA69-Dimming_Direction_GH_24,maximize
(1)-Leuchte25KZL HA60-Type_Of_Load_25,2* 5W
(2)-Leuchte25KZL HA60-Lampendefektbit_Position_25,00
(3)-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25,00
(4)-Leuchte25KZL HA60-Light_Function_A_25,Parking light
(5)-Leuchte25KZL HA60-Light_Function_B_25,not active
(6)-Leuchte25KZL HA60-Dimming_AB_25,100
(7)-Leuchte25KZL HA60-Light_Control_HD_AB_25,Always
(8)-Leuchte25KZL HA60-Light_Function_C_25,not active
(9)-Leuchte25KZL HA60-Light_Function_D_25,not active
(10)-Leuchte25KZL HA60-Dimming_CD_25,0
(11)-Leuchte25KZL HA60-Dimming_Direction_CD_25,maximize
(12)-Leuchte25KZL HA60-Light_Function_E_25,not active
(13)-Leuchte25KZL HA60-Light_Function_F_25,not active
(14)-Leuchte25KZL HA60-Dimming_EF_25,0
(15)-Leuchte25KZL HA60-Dimming_Direction_EF_25,maximize
(16)-Leuchte25KZL HA60-Light_Function_G_25,not active
(17)-Leuchte25KZL HA60-Light_Function_H_25,not active
(18)-Leuchte25KZL HA60-Dimming_GH_25,0
(19)-Leuchte25KZL HA60-Dimming_Direction_GH_25,maximize
(1)-Leuchte26NSL A65-Type_Of_Load_26,allgemeineGluehlampe27W;auchH15-TFL
(2)-Leuchte26NSL A65-Lampendefektbit_Position_26,0C
(3)-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26,2E
(4)-Leuchte26NSL A65-Light_Function_A_26,NebelschlusslichtwennkeinAnhaengergestecktundLinksverkehr
(5)-Leuchte26NSL A65-Light_Function_B_26,not active
(6)-Leuchte26NSL A65-Dimming_AB_26,100
(7)-Leuchte26NSL A65-Light_Control_HD_AB_26,Always
(8)-Leuchte26NSL A65-Light_Function_C_26,not active
(9)-Leuchte26NSL A65-Light_Function_D_26,not active
(10)-Leuchte26NSL A65-Dimming_CD_26,0
(11)-Leuchte26NSL A65-Dimming_Direction_CD_26,maximize
(12)-Leuchte26NSL A65-Light_Function_E_26,not active
(13)-Leuchte26NSL A65-Light_Function_F_26,not active
(14)-Leuchte26NSL A65-Dimming_EF_26,0
(15)-Leuchte26NSL A65-Dimming_Direction_EF_26,maximize
(16)-Leuchte26NSL A65-Light_Function_G_26,not active
(17)-Leuchte26NSL A65-Light_Function_H_26,not active
(18)-Leuchte26NSL A65-Dimming_GH_26,0
(19)-Leuchte26NSL A65-Dimming_Direction_GH_26,maximize
(1)-Leuchte27 KL58XS C67-Type_Of_Load_27,LED Kleinleistung ohne Open Load Diagnose
(2)-Leuchte27 KL58XS C67-Lampendefektbit_Position_27,00
(3)-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27,08
(4)-Leuchte27 KL58XS C67-Light_Function_A_27,Terminal 58xs dimmer
(5)-Leuchte27 KL58XS C67-Light_Function_B_27,not active
(6)-Leuchte27 KL58XS C67-Dimming_AB_27,100
(7)-Leuchte27 KL58XS C67-Light_Control_HD_AB_27,Always
(8)-Leuchte27 KL58XS C67-Light_Function_C_27,not active
(9)-Leuchte27 KL58XS C67-Light_Function_D_27,not active
(10)-Leuchte27 KL58XS C67-Dimming_CD_27,0
(11)-Leuchte27 KL58XS C67-Dimming_Direction_CD_27,maximize
(12)-Leuchte27 KL58XS C67-Light_Function_E_27,not active
(13)-Leuchte27 KL58XS C67-Light_Function_F_27,not active
(14)-Leuchte27 KL58XS C67-Dimming_EF_27,0
(15)-Leuchte27 KL58XS C67-Dimming_Direction_EF_27,maximize
(16)-Leuchte27 KL58XS C67-Light_Function_G_27,not active
(17)-Leuchte27 KL58XS C67-Light_Function_H_27,not active
(18)-Leuchte27 KL58XS C67-Dimming_GH_27,0
(19)-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
(1)-Leuchte28RFL C3-Type_Of_Load_28,allgemeineGluehlampe27W;auchH15-TFL
(2)-Leuchte28RFL C3-Lampendefektbit_Position_28,1B
(3)-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,32
(4)-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
(5)-Leuchte28RFL C3-Light_Function_B_28,not active
(6)-Leuchte28RFL C3-Dimming_AB_28,100
(7)-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
(8)-Leuchte28RFL C3-Light_Function_C_28,not active
(9)-Leuchte28RFL C3-Light_Function_D_28,not active
(10)-Leuchte28RFL C3-Dimming_CD_28,0
(11)-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
(12)-Leuchte28RFL C3-Light_Function_E_28,not active
(13)-Leuchte28RFL C3-Light_Function_F_28,not active
(14)-Leuchte28RFL C3-Dimming_EF_28,0
(15)-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
(16)-Leuchte28RFL C3-Light_Function_G_28,not active
(17)-Leuchte28RFL C3-Light_Function_H_28,not active
(18)-Leuchte28RFL C3-Dimming_GH_28,0
(19)-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
(1)-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W
(2)-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
(3)-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
(4)-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
(5)-Leuchte29 KL30G A69-Light_Function_B_29,not active
(6)-Leuchte29 KL30G A69-Dimming_AB_29,100
(7)-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
(8)-Leuchte29 KL30G A69-Light_Function_C_29,not active
(9)-Leuchte29 KL30G A69-Light_Function_D_29,not active
(10)-Leuchte29 KL30G A69-Dimming_CD_29,0
(11)-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
(12)-Leuchte29 KL30G A69-Light_Function_E_29,not active
(13)-Leuchte29 KL30G A69-Light_Function_F_29,not active
(14)-Leuchte29 KL30G A69-Dimming_EF_29,0
(15)-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
(16)-Leuchte29 KL30G A69-Light_Function_G_29,not active
(17)-Leuchte29 KL30G A69-Light_Function_H_29,not active
(18)-Leuchte29 KL30G A69-Dimming_GH_29,0
(19)-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
(1)-Leuchte2SL VLB22-Type_Of_Load_2,allgemeineGluehlampe6W;auchH6W
(2)-Leuchte2SL VLB22-Lampendefektbit_Position_2,35
(3)-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2,26
(4)-Leuchte2SL VLB22-Light_Function_A_2,Parking light
(5)-Leuchte2SL VLB22-Light_Function_B_2,Parking light left
(6)-Leuchte2SL VLB22-Dimming_AB_2,100
(7)-Leuchte2SL VLB22-Light_Control_HD_AB_2,Always
(8)-Leuchte2SL VLB22-Light_Function_C_2,not active
(9)-Leuchte2SL VLB22-Light_Function_D_2,not active
(10)-Leuchte2SL VLB22-Dimming_CD_2,0
(11)-Leuchte2SL VLB22-Dimming_Direction_CD_2,maximize
(12)-Leuchte2SL VLB22-Light_Function_E_2,not active
(13)-Leuchte2SL VLB22-Light_Function_F_2,not active
(14)-Leuchte2SL VLB22-Dimming_EF_2,0
(15)-Leuchte2SL VLB22-Dimming_Direction_EF_2,maximize
(16)-Leuchte2SL VLB22-Light_Function_G_2,not active
(17)-Leuchte2SL VLB22-Light_Function_H_2,not active
(18)-Leuchte2SL VLB22-Dimming_GH_2,0
(19)-Leuchte2SL VLB22-Dimming_Direction_GH_2,maximize
(1)-Leuchte30 INNENLICHT A68-Type_Of_Load_30,allgemeineGluehlampe12W
(2)-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30,00
(3)-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30,07
(4)-Leuchte30 INNENLICHT A68-Light_Function_A_30,Interior light
(5)-Leuchte30 INNENLICHT A68-Light_Function_B_30,not active
(6)-Leuchte30 INNENLICHT A68-Dimming_AB_30,100
(7)-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30,Always
(8)-Leuchte30 INNENLICHT A68-Light_Function_C_30,not active
(9)-Leuchte30 INNENLICHT A68-Light_Function_D_30,not active
(10)-Leuchte30 INNENLICHT A68-Dimming_CD_30,0
(11)-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30,maximize
(12)-Leuchte30 INNENLICHT A68-Light_Function_E_30,not active
(13)-Leuchte30 INNENLICHT A68-Light_Function_F_30,not active
(14)-Leuchte30 INNENLICHT A68-Dimming_EF_30,0
(15)-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30,maximize
(16)-Leuchte30 INNENLICHT A68-Light_Function_G_30,not active
(17)-Leuchte30 INNENLICHT A68-Light_Function_H_30,not active
(18)-Leuchte30 INNENLICHT A68-Dimming_GH_30,0
(19)-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30,maximize
(1)-Leuchte31AMBL 1C65-Type_Of_Load_31,not active
(2)-Leuchte31AMBL 1C65-Lampendefektbit_Position_31,00
(3)-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31,00
(4)-Leuchte31AMBL 1C65-Light_Function_A_31,not active
(5)-Leuchte31AMBL 1C65-Light_Function_B_31,not active
(6)-Leuchte31AMBL 1C65-Dimming_AB_31,0
(7)-Leuchte31AMBL 1C65-Light_Control_HD_AB_31,Always
(8)-Leuchte31AMBL 1C65-Light_Function_C_31,not active
(9)-Leuchte31AMBL 1C65-Light_Function_D_31,not active
(10)-Leuchte31AMBL 1C65-Dimming_CD_31,0
(11)-Leuchte31AMBL 1C65-Dimming_Direction_CD_31,maximize
(12)-Leuchte31AMBL 1C65-Light_Function_E_31,not active
(13)-Leuchte31AMBL 1C65-Light_Function_F_31,not active
(14)-Leuchte31AMBL 1C65-Dimming_EF_31,0
(15)-Leuchte31AMBL 1C65-Dimming_Direction_EF_31,maximize
(16)-Leuchte31AMBL 1C65-Light_Function_G_31,not active
(17)-Leuchte31AMBL 1C65-Light_Function_H_31,not active
(18)-Leuchte31AMBL 1C65-Dimming_GH_31,0
(19)-Leuchte31AMBL 1C65-Dimming_Direction_GH_31,maximize
(1)-Leuchte32AMBL 2C64-Type_Of_Load_32,not active
(2)-Leuchte32AMBL 2C64-Lampendefektbit_Position_32,00
(3)-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32,00
(4)-Leuchte32AMBL 2C64-Light_Function_A_32,not active
(5)-Leuchte32AMBL 2C64-Light_Function_B_32,not active
(6)-Leuchte32AMBL 2C64-Dimming_AB_32,0
(7)-Leuchte32AMBL 2C64-Light_Control_HD_AB_32,Always
(8)-Leuchte32AMBL 2C64-Light_Function_C_32,not active
(9)-Leuchte32AMBL 2C64-Light_Function_D_32,not active
(10)-Leuchte32AMBL 2C64-Dimming_CD_32,0
(11)-Leuchte32AMBL 2C64-Dimming_Direction_CD_32,maximize
(12)-Leuchte32AMBL 2C64-Light_Function_E_32,not active
(13)-Leuchte32AMBL 2C64-Light_Function_F_32,not active
(14)-Leuchte32AMBL 2C64-Dimming_EF_32,0
(15)-Leuchte32AMBL 2C64-Dimming_Direction_EF_32,maximize
(16)-Leuchte32AMBL 2C64-Light_Function_G_32,not active
(17)-Leuchte32AMBL 2C64-Light_Function_H_32,not active
(18)-Leuchte32AMBL 2C64-Dimming_GH_32,0
(19)-Leuchte32AMBL 2C64-Dimming_Direction_GH_32,maximize
(1)-Leuchte33AMBL 3C72-Type_Of_Load_33,not active
(2)-Leuchte33AMBL 3C72-Lampendefektbit_Position_33,00
(3)-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33,00
(4)-Leuchte33AMBL 3C72-Light_Function_A_33,not active
(5)-Leuchte33AMBL 3C72-Light_Function_B_33,not active
(6)-Leuchte33AMBL 3C72-Dimming_AB_33,0
(7)-Leuchte33AMBL 3C72-Light_Control_HD_AB_33,Always
(8)-Leuchte33AMBL 3C72-Light_Function_C_33,not active
(9)-Leuchte33AMBL 3C72-Light_Function_D_33,not active
(10)-Leuchte33AMBL 3C72-Dimming_CD_33,0
(11)-Leuchte33AMBL 3C72-Dimming_Direction_CD_33,maximize
(12)-Leuchte33AMBL 3C72-Light_Function_E_33,not active
(13)-Leuchte33AMBL 3C72-Light_Function_F_33,not active
(14)-Leuchte33AMBL 3C72-Dimming_EF_33,0
(15)-Leuchte33AMBL 3C72-Dimming_Direction_EF_33,maximize
(16)-Leuchte33AMBL 3C72-Light_Function_G_33,not active
(17)-Leuchte33AMBL 3C72-Light_Function_H_33,not active
(18)-Leuchte33AMBL 3C72-Dimming_GH_33,0
(19)-Leuchte33AMBL 3C72-Dimming_Direction_GH_33,maximize
(1)-Leuchte34AMBL 4C71-Type_Of_Load_34,not active
(2)-Leuchte34AMBL 4C71-Lampendefektbit_Position_34,00
(3)-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34,00
(4)-Leuchte34AMBL 4C71-Light_Function_A_34,not active
(5)-Leuchte34AMBL 4C71-Light_Function_B_34,not active
(6)-Leuchte34AMBL 4C71-Dimming_AB_34,0
(7)-Leuchte34AMBL 4C71-Light_Control_HD_AB_34,Always
(8)-Leuchte34AMBL 4C71-Light_Function_C_34,not active
(9)-Leuchte34AMBL 4C71-Light_Function_D_34,not active
(10)-Leuchte34AMBL 4C71-Dimming_CD_34,0
(11)-Leuchte34AMBL 4C71-Dimming_Direction_CD_34,maximize
(12)-Leuchte34AMBL 4C71-Light_Function_E_34,not active
(13)-Leuchte34AMBL 4C71-Light_Function_F_34,not active
(14)-Leuchte34AMBL 4C71-Dimming_EF_34,0
(15)-Leuchte34AMBL 4C71-Dimming_Direction_EF_34,maximize
(16)-Leuchte34AMBL 4C71-Light_Function_G_34,not active
(17)-Leuchte34AMBL 4C71-Light_Function_H_34,not active
(18)-Leuchte34AMBL 4C71-Dimming_GH_34,0
(19)-Leuchte34AMBL 4C71-Dimming_Direction_GH_34,maximize
(1)-Leuchte3SL VRB36-Type_Of_Load_3,allgemeineGluehlampe6W;auchH6W
(2)-Leuchte3SL VRB36-Lampendefektbit_Position_3,3F
(3)-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3,27
(4)-Leuchte3SL VRB36-Light_Function_A_3,Parking light
(5)-Leuchte3SL VRB36-Light_Function_B_3,Parking light right
(6)-Leuchte3SL VRB36-Dimming_AB_3,100
(7)-Leuchte3SL VRB36-Light_Control_HD_AB_3,Always
(8)-Leuchte3SL VRB36-Light_Function_C_3,not active
(9)-Leuchte3SL VRB36-Light_Function_D_3,not active
(10)-Leuchte3SL VRB36-Dimming_CD_3,0
(11)-Leuchte3SL VRB36-Dimming_Direction_CD_3,maximize
(12)-Leuchte3SL VRB36-Light_Function_E_3,not active
(13)-Leuchte3SL VRB36-Light_Function_F_3,not active
(14)-Leuchte3SL VRB36-Dimming_EF_3,0
(15)-Leuchte3SL VRB36-Dimming_Direction_EF_3,maximize
(16)-Leuchte3SL VRB36-Light_Function_G_3,not active
(17)-Leuchte3SL VRB36-Light_Function_H_3,not active
(18)-Leuchte3SL VRB36-Dimming_GH_3,0
(19)-Leuchte3SL VRB36-Dimming_Direction_GH_3,maximize
(1)-Leuchte4TFL LB43-Type_Of_Load_4,allgemeineGluehlampe27W;auchH15-TFL
(2)-Leuchte4TFL LB43-Lampendefektbit_Position_4,3A
(3)-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4,20
(4)-Leuchte4TFL LB43-Light_Function_A_4,Daytime running lights
(5)-Leuchte4TFL LB43-Light_Function_B_4,not active
(6)-Leuchte4TFL LB43-Dimming_AB_4,100
(7)-Leuchte4TFL LB43-Light_Control_HD_AB_4,Always
(8)-Leuchte4TFL LB43-Light_Function_C_4,not active
(9)-Leuchte4TFL LB43-Light_Function_D_4,not active
(10)-Leuchte4TFL LB43-Dimming_CD_4,0
(11)-Leuchte4TFL LB43-Dimming_Direction_CD_4,maximize
(12)-Leuchte4TFL LB43-Light_Function_E_4,not active
(13)-Leuchte4TFL LB43-Light_Function_F_4,not active
(14)-Leuchte4TFL LB43-Dimming_EF_4,0
(15)-Leuchte4TFL LB43-Dimming_Direction_EF_4,maximize
(16)-Leuchte4TFL LB43-Light_Function_G_4,not active
(17)-Leuchte4TFL LB43-Light_Function_H_4,not active
(18)-Leuchte4TFL LB43-Dimming_GH_4,0
(19)-Leuchte4TFL LB43-Dimming_Direction_GH_4,maximize
(1)-Leuchte5 TFL RB6-Type_Of_Load_5,allgemeineGluehlampe27W;auchH15-TFL
(2)-Leuchte5 TFL RB6-Lampendefektbit_Position_5,44
(3)-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5,21
(4)-Leuchte5 TFL RB6-Light_Function_A_5,Daytime running lights
(5)-Leuchte5 TFL RB6-Light_Function_B_5,not active
(6)-Leuchte5 TFL RB6-Dimming_AB_5,100
(7)-Leuchte5 TFL RB6-Light_Control_HD_AB_5,Always
(8)-Leuchte5 TFL RB6-Light_Function_C_5,not active
(9)-Leuchte5 TFL RB6-Light_Function_D_5,not active
(10)-Leuchte5 TFL RB6-Dimming_CD_5,0
(11)-Leuchte5 TFL RB6-Dimming_Direction_CD_5,maximize
(12)-Leuchte5 TFL RB6-Light_Function_E_5,not active
(13)-Leuchte5 TFL RB6-Light_Function_F_5,not active
(14)-Leuchte5 TFL RB6-Dimming_EF_5,0
(15)-Leuchte5 TFL RB6-Dimming_Direction_EF_5,maximize
(16)-Leuchte5 TFL RB6-Light_Function_G_5,not active
(17)-Leuchte5 TFL RB6-Light_Function_H_5,not active
(18)-Leuchte5 TFL RB6-Dimming_GH_5,0
(19)-Leuchte5 TFL RB6-Dimming_Direction_GH_5,maximize
(1)-Leuchte6ABL LB44-Type_Of_Load_6,Low beam
(2)-Leuchte6ABL LB44-Lampendefektbit_Position_6,36
(3)-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6,1A
(4)-Leuchte6ABL LB44-Light_Function_A_6,Abblendlicht links
(5)-Leuchte6ABL LB44-Light_Function_B_6,ComingHome LeavingHome
(6)-Leuchte6ABL LB44-Dimming_AB_6,100
(7)-Leuchte6ABL LB44-Light_Control_HD_AB_6,Always
(8)-Leuchte6ABL LB44-Light_Function_C_6,not active
(9)-Leuchte6ABL LB44-Light_Function_D_6,not active
(10)-Leuchte6ABL LB44-Dimming_CD_6,0
(11)-Leuchte6ABL LB44-Dimming_Direction_CD_6,maximize
(12)-Leuchte6ABL LB44-Light_Function_E_6,not active
(13)-Leuchte6ABL LB44-Light_Function_F_6,not active
(14)-Leuchte6ABL LB44-Dimming_EF_6,0
(15)-Leuchte6ABL LB44-Dimming_Direction_EF_6,maximize
(16)-Leuchte6ABL LB44-Light_Function_G_6,not active
(17)-Leuchte6ABL LB44-Light_Function_H_6,not active
(18)-Leuchte6ABL LB44-Dimming_GH_6,0
(19)-Leuchte6ABL LB44-Dimming_Direction_GH_6,maximize
(1)-Leuchte7ABL RB5-Type_Of_Load_7,Low beam
(2)-Leuchte7ABL RB5-Lampendefektbit_Position_7,40
(3)-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7,1B
(4)-Leuchte7ABL RB5-Light_Function_A_7,Abblendlicht rechts
(5)-Leuchte7ABL RB5-Light_Function_B_7,ComingHome LeavingHome
(6)-Leuchte7ABL RB5-Dimming_AB_7,100
(7)-Leuchte7ABL RB5-Light_Control_HD_AB_7,Always
(8)-Leuchte7ABL RB5-Light_Function_C_7,not active
(9)-Leuchte7ABL RB5-Light_Function_D_7,not active
(10)-Leuchte7ABL RB5-Dimming_CD_7,0
(11)-Leuchte7ABL RB5-Dimming_Direction_CD_7,maximize
(12)-Leuchte7ABL RB5-Light_Function_E_7,not active
(13)-Leuchte7ABL RB5-Light_Function_F_7,not active
(14)-Leuchte7ABL RB5-Dimming_EF_7,0
(15)-Leuchte7ABL RB5-Dimming_Direction_EF_7,maximize
(16)-Leuchte7ABL RB5-Light_Function_G_7,not active
(17)-Leuchte7ABL RB5-Light_Function_H_7,not active
(18)-Leuchte7ABL RB5-Dimming_GH_7,0
(19)-Leuchte7ABL RB5-Dimming_Direction_GH_7,maximize
(1)-Leuchte8FL LB42-Type_Of_Load_8,allgemeineScheinwerferohneAbschaltung
(2)-Leuchte8FL LB42-Lampendefektbit_Position_8,37
(3)-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8,1C
(4)-Leuchte8FL LB42-Light_Function_A_8,Left high beam
(5)-Leuchte8FL LB42-Light_Function_B_8,Headlamp flasher
(6)-Leuchte8FL LB42-Dimming_AB_8,100
(7)-Leuchte8FL LB42-Light_Control_HD_AB_8,Always
(8)-Leuchte8FL LB42-Light_Function_C_8,not active
(9)-Leuchte8FL LB42-Light_Function_D_8,not active
(10)-Leuchte8FL LB42-Dimming_CD_8,0
(11)-Leuchte8FL LB42-Dimming_Direction_CD_8,maximize
(12)-Leuchte8FL LB42-Light_Function_E_8,not active
(13)-Leuchte8FL LB42-Light_Function_F_8,not active
(14)-Leuchte8FL LB42-Dimming_EF_8,0
(15)-Leuchte8FL LB42-Dimming_Direction_EF_8,maximize
(16)-Leuchte8FL LB42-Light_Function_G_8,not active
(17)-Leuchte8FL LB42-Light_Function_H_8,not active
(18)-Leuchte8FL LB42-Dimming_GH_8,0
(19)-Leuchte8FL LB42-Dimming_Direction_GH_7,maximize
(1)-Leuchte9FL RB7-Type_Of_Load_9,allgemeineScheinwerferohneAbschaltung
(2)-Leuchte9FL RB7-Lampendefektbit_Position_9,41
(3)-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9,1D
(4)-Leuchte9FL RB7-Light_Function_A_9,Right high beam
(5)-Leuchte9FL RB7-Light_Function_B_9,Headlamp flasher
(6)-Leuchte9FL RB7-Dimming_AB_9,100
(7)-Leuchte9FL RB7-Light_Control_HD_AB_9,Always
(8)-Leuchte9FL RB7-Light_Function_C_9,not active
(9)-Leuchte9FL RB7-Light_Function_D_9,not active
(10)-Leuchte9FL RB7-Dimming_CD_9,0
(11)-Leuchte9FL RB7-Dimming_Direction_CD_9,maximize
(12)-Leuchte9FL RB7-Light_Function_E_9,not active
(13)-Leuchte9FL RB7-Light_Function_F_9,not active
(14)-Leuchte9FL RB7-Dimming_EF_9,0
(15)-Leuchte9FL RB7-Dimming_Direction_EF_9,maximize
(16)-Leuchte9FL RB7-Light_Function_G_9,not active
(17)-Leuchte9FL RB7-Light_Function_H_9,not active
(18)-Leuchte9FL RB7-Dimming_GH_9,0
(19)-Leuchte9FL RB7-Dimming_Direction_GH_9,maximize
(1)-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14,allgemeineLEDmitOpenLoadDiagnose
(2)-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14,00
(3)-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14,00
(4)-Leuchten14LOCKUNLOCKC61-Light_Function_A_14,LockUnlockLED
(5)-Leuchten14LOCKUNLOCKC61-Light_Function_B_14,not active
(6)-Leuchten14LOCKUNLOCKC61-Dimming_AB_14,100
(7)-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14,Always
(8)-Leuchten14LOCKUNLOCKC61-Light_Function_C_14,not active
(9)-Leuchten14LOCKUNLOCKC61-Light_Function_D_14,not active
(10)-Leuchten14LOCKUNLOCKC61-Dimming_CD_14,0
(11)-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14,maximize
(12)-Leuchten14LOCKUNLOCKC61-Light_Function_E_14,not active
(13)-Leuchten14LOCKUNLOCKC61-Light_Function_F_14,not active
(14)-Leuchten14LOCKUNLOCKC61-Dimming_EF_14,0
(15)-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14,maximize
(16)-Leuchten14LOCKUNLOCKC61-Light_Function_G_14,not active
(17)-Leuchten14LOCKUNLOCKC61-Light_Function_H_14,not active
(18)-Leuchten14LOCKUNLOCKC61-Dimming_GH_14,0
(19)-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14,maximize
(1)-LIN-Mirrormode-Activation,not active
(2)-LIN-Mirrormode-Data bus LIN 3,not active
(3)-LIN-Mirrormode-Data bus LIN 4,not active
(4)-LIN-Mirrormode-Data bus LIN 5,not active
(1)-LuB Lichtrouter Kennlinie 1-x0,0
(2)-LuB Lichtrouter Kennlinie 1-X1,10
(3)-LuB Lichtrouter Kennlinie 1-X2,100
(4)-LuB Lichtrouter Kennlinie 1-X3,150
(5)-LuB Lichtrouter Kennlinie 1-X4,220
(6)-LuB Lichtrouter Kennlinie 1-X5,253
(7)-LuB Lichtrouter Kennlinie 1-y0,0.0 %
(8)-LuB Lichtrouter Kennlinie 1-Y1,6.0 %
(9)-LuB Lichtrouter Kennlinie 1-Y2,16.0 %
(10)-LuB Lichtrouter Kennlinie 1-Y3,30.0 %
(11)-LuB Lichtrouter Kennlinie 1-Y4,60.0 %
(12)-LuB Lichtrouter Kennlinie 1-Y5,100.0 %
Patch_Code; Beifahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
Patch_Code; Fahrer,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
Reversing_Threshold_Driver_Side_Rear,0 %
Reversing_Threshold_Passenger_Side_Front,0 %
RLS_Washer_Front,15 s
(1)-Vernetzungs- Diagnosefunktionen-can msg 1,00 00
(2)-Vernetzungs- Diagnosefunktionen-can msg 2,00 00
(3)-Vernetzungs- Diagnosefunktionen-can msg 3,00 00
(4)-Vernetzungs- Diagnosefunktionen-can msg 4,00 00
(5)-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00
(6)-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00
(7)-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00
(8)-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00
(9)-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00
(10)-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00
Window_Regulator_Supplier_Settings_Driver_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
Window_Regulator_Supplier_Settings_Passener_Side_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
Window_Regulator_Supplier_Settings_Passener_Side_2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
Window_Regulator_Supplier_Settings_Passener_Side_3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 400D01CC 01 110 00 00 00 4D 00 400792AD 01 FFFFFF9C 00 00 01 40000024 370039 00 00 2B9A5B0 00 4006C8C9 01 03 00 00 00 8255BC54 2A 400EFBB2 01 B7FE044D 00 00 00 403BEDD0 01 477A87D 00 00 00 00 00 700 00 01 00 700 00 40045224 01 00 00 50 37313300 8255BC87 2A EE0F1E93 3D71 403BEDD0 01 100 00 01 00 31000000 30393336 00 00 EE0F1EA3 3D71 403BEDD0 01 100 00 01 00 00 00 01 00 4004A199 01 01 00 40106C1A 01 4039D557 01 7FFFFFF7 00 403BEDD0 01 100 00 01 00 00 00 00 00 40079487 01 01 00 01 00 700 00 312F72FF 171F2F34 00 00 400784FE 01 02 00 4039E5E8 01 01 00 322F7309 7F1F3630 477A87D 00 00 00 00 00 01 00 FE 00 135B60 00 110 00 2B91038 00 134F10 00 E04F6 00 00 00 400475D3 01 134F00 00 FFFFFFFE FFFFFFFF 01 00 4039CBB0 01 4039CBB0 01 40046D52 01 8255BC65 2A 400FF8F1 01 4018B0A8 01 07 00 70E 22030800 55556816 5555 00 00 00 00 4039CBB0 01 40046970 01 00 00 00 00 00 00 00 00 00 00 40046663 01 00 00 00 00 00 00 00 00 135B3E 00 40077192 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EE0F1AE3 3D71 01 00 136428 00 400EBA8D 01 E04F6 00 135090 00 135090 00 01 00 135B60 00 400EE952 01 00 00 00 00 00 00 01 00 110 00 91 00 404B2BC0 01 135B60 00 D2 00 D3 00 74A 00 4000D332 01 404B2BC0 01 135590 00 01 00 00 00 135C50 00 14E 00 74A 00 00 00 00 00 01 7FFA 01 00 400ECA88 01 2CF000 00 40100994 01 FFFFFFFE FFFFFFFF 40100994 01 00 00 135C50 00 00 00 400ECBF0 01 135C50 00 7F89DB57 7FFA 74A 00 00 00 1351A0 00 7F89DB57 7FFA 00 00 400EFBB2 01 00 00 00 00 74A 00 2CF000 00 00 FFFFFFFF 2CF000 00 FFFFFFFE FFFFFFFF 400F5BC4 01 120254 00 120582 00 120582 00 113 00 05 00 00 00 00 00 00 00 400EFBD8 01 00 00 00 00 400EFC31 01 272477B2 AA84 00 00 400EFBD8 01 00 00 00 00 74A 00 1354F0 00 7E872532 7FFA 01 00 01 00 14E 00 120254 00 FFFFFFFF FFFFFFFF 7E8916C7 7FFA 74A 00 00 00 00 00 00 7FFA 48 00 01 7FFA 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7E872473 7FFA 7E872532 7FFA FFFFC000 7FF5 00 00 80000000 00 00 00 00 00 40000000 00 7E873B02 7FFA 00 00 00 00 120254 00 00 00 74A 00 00 00 01 00 01 00 74A 00 00 00 00 00 7E873BE5 7FFA 7F910B70 7FFA 00 00 135468 00 05 00 400EFBD8 01 7E872532 7FFA 74A 00 00 00 00 00 7E8A0A80 7FFA 00 00 7F912AB4 7FFA 00 00 00 00 70 00 FFFFFFFF FFFFFFFF 135468 00 30 02 7E87102A 7FFA 00 00 70 00 135498 00 FFFFFFFF FFFFFFFF 6960C0 00 14E 00 74A 00 00 00
Window_Regulator_VW_Settings_Passenger_Side,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Window_Regulator_VW_Settings_Passenger_Side_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 400D01CC 01 110 00 00 00 4D 00 400792AD 01 FFFFFF9C 00 00 01 40000024 370039 00 00 2B9A5B0 00 4006C8C9 01 03 00 00 00 827A0424 2A 400EFBB2 01 B7FE044D 00 00 00 403BEDD0 01 477AC55 00 00 00 00 00 700 00 01 00 700 00 40045224 01 00 00 50 35313300 827A0458 2A EE0F1E93 3D71 403BEDD0 01 100 00 01 00 31000000 30393336 00 00 EE0F1EA3 3D71 403BEDD0 01 100 00 01 00 00 00 01 00 4004A199 01 01 00 40106C1A 01 4039D557 01 7FFFFFF7 00 403BEDD0 01 100 00 01 00 00 00 00 00 40079487 01 01 00 01 00 700 00 312F72FF 6C1F3134 00 00 400784FE 01 02 00 4039E5E8 01 01 00 322F7309 7F1F3430 477AC55 00 00 00 00 00 01 00 FE 00 135B60 00 110 00 2B91038 00 134F10 00 E04F6 00 00 00 400475D3 01 134F00 00 FFFFFFFE FFFFFFFF 01 00 4039CBB0 01 4039CBB0 01 40046D52 01 827A0436 2A 400FF8F1 01 4018B0A8 01 07 00 70E 22030800 55556716 5555 00 00 00 00 4039CBB0 01 40046970 01 00 00 00 00 00 00 00 00 00 00 40046663 01 00 00 00 00 00 00 00 00 135B3E 00 40077192 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EE0F1AE3 3D71 01 00 136428 00 400EBA8D 01 E04F6 00 135090 00 135090 00 01 00 135B60 00 400EE952 01 00 00 00 00 00 00 01 00 110 00 91 00 404B2BC0 01 135B60 00 D2 00 D3 00 74C 00 4000D332 01 404B2BC0 01 135590 00 01 00 00 00 135C50 00 14E 00 74C 00 00 00 00 00 01 7FFA 2BC5290 00 400ECA88 01 2CF000 00 40100994 01 FFFFFFFE FFFFFFFF 40100994 01 00 00 135C50 00 00 00 400ECBF0 01 135C50 00 7F89DB57 7FFA 74C 00 00 00 1351A0 00 283 00 00 00 400EFBB2 01 00 00 00 00 74C 00 2CF000 00 00 FFFFFFFF 2CF000 00 FFFFFFFE FFFFFFFF 400F5BC4 01 120254 00 00 00 120582 00 113 00 05 00 00 00 00 00 00 00 400EFBD8 01 00 00 00 00 400EFC31 01 272477B2 AA84 00 00 400EFBD8 01 00 00 00 00 74C 00 1354F0 00 7E872532 7FFA 01 00 01 00 14E 00 120254 00 FFFFFFFF FFFFFFFF 7E8916C7 7FFA 74C 00 00 02 01 00 00 7FFA 48 00 01 00 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7E872473 7FFA 7E872532 7FFA FFFFC000 7FF5 00 00 80000000 00 00 00 00 00 40000000 00 7E873B02 7FFA 00 00 00 00 120254 00 EF000CE3 00 74C 00 00 00 01 00 01 00 74C 00 00 00 00 00 7E873BE5 7FFA 7F910B70 7FFA 00 00 135468 00 05 00 400EFBD8 01 7E872532 7FFA 74C 00 00 00 00 00 7E8A0A80 7FFA 00 00 7F912AB4 7FFA 00 00 00 FFFFD000 67 AA84 00 00 135468 00 30 02 7E87102A 7FFA 00 00 EF000CE3 00 135498 00 69 00 6960C0 00 14E 00 74C 00 00 00
Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 400D01CC 01 110 00 00 00 04 00 400792AD 01 FFFFFF9C 00 00 01 40000024 370039 00 00 2B9A5B0 00 4006C8C9 01 03 00 00 00 829CC6BF 2A 400EFBB2 01 B7FE044D 00 00 00 403BEDD0 01 477AFFF 00 00 00 00 00 700 00 01 00 700 00 40045224 01 00 00 50 32313300 829CC6ED 2A EE0F1E93 3D71 403BEDD0 01 100 00 01 00 31000000 30393336 00 00 EE0F1EA3 3D71 403BEDD0 01 100 00 01 00 00 00 01 00 4004A199 01 01 00 40106C1A 01 4039D557 01 7FFFFFF7 00 403BEDD0 01 100 00 01 00 00 00 00 00 40079487 01 01 00 01 00 700 00 312F72FF 171F2F34 00 00 400784FE 01 02 00 4039E5E8 01 01 00 322F7309 7F1F3130 477AFFF 00 00 00 00 00 01 00 FE 00 135B60 00 110 00 2B91038 00 134F10 00 E04F6 00 00 00 400475D3 01 134F00 00 FFFFFFFE FFFFFFFF 01 00 4039CBB0 01 4039CBB0 01 40046D52 01 829CC6CB 2A 400FF8F1 01 4018B0A8 01 07 00 70E 22030800 55556916 5555 00 00 00 00 4039CBB0 01 40046970 01 00 00 00 00 00 00 00 00 00 00 40046663 01 00 00 00 00 00 00 00 00 135B3E 00 40077192 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EE0F1AE3 3D71 01 00 136428 00 400EBA8D 01 E04F6 00 135090 00 135090 00 01 00 135B60 00 400EE952 01 00 00 00 00 00 00 01 00 110 00 91 00 404B2BC0 01 135B60 00 D2 00 D3 00 74E 00 4000D332 01 404B2BC0 01 135590 00 01 00 00 00 135C50 00 14E 00 74E 00 00 00 00 00 01 00 00 00 400ECA88 01 2CF000 00 40100994 01 FFFFFFFE FFFFFFFF 40100994 01 00 00 135C50 00 00 00 400ECBF0 01 135C50 00 7F89DB57 7FFA 74E 00 00 00 1351A0 00 288A660 00 00 00 400EFBB2 01 00 00 00 00 74E 00 2CF000 00 00 FFFFFFFF 2CF000 00 FFFFFFFE FFFFFFFF 400F5BC4 01 120254 00 00 00 120582 00 113 00 05 00 00 00 00 00 00 00 400EFBD8 01 00 00 00 00 400EFC31 01 272477B2 AA84 00 00 400EFBD8 01 00 00 00 00 74E 00 1354F0 00 7E872532 7FFA 01 00 01 00 14E 00 120254 00 00 00 00 00 74E 00 00 FFFFDC2C 0A 00 00 7FFA 48 00 01 00 00 00 00 00 70 00 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 7E872473 7FFA 7E872532 7FFA FFFFC000 7FF5 00 00 80000000 00 00 00 00 00 40000000 00 7E873B02 7FFA 00 00 00 00 120254 00 7B695EDC 7FFA 74E 00 00 00 01 00 01 00 74E 00 00 00 00 00 7E873BE5 7FFA 7F910B70 7FFA 00 00 135468 00 00 00 400EFBD8 01 135518 00 74E 00 00 00 00 00 7E8A0A80 7FFA 00 00 7F912AB4 7FFA 00 00 1B75A30 00 09 00 6CA660 00 135468 00 30 02 7E87102A 7FFA 00 7FFA 135468 00 135498 00 20100886 00 6960C0 00 14E 00 74E 00 00 00
e
(23)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_22,not active
(24)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_23,not active
(25)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_24,not active
(26)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_25,not active
(27)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_26,not active
(28)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_27,not active
(29)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_28,not active
(30)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_29,not active
(31)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_30,not active
(32)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_31,not active
(33)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_32,not active
(34)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_33,not active
(35)-Configuration of light collective diagnostic line 2; instance 1-Leuchte_34,not active
(36)-Configuration of light collective diagnostic line 2; instance 1-Wiederstand,150_Ohm
(37)-Configuration of light collective diagnostic line 2; instance 1-DTCDFCC,40
(38)-Configuration of light collective diagnostic line 2; instance 1-Defektbit,Licht_vorne_01 Byte 5
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
(8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
Deactivate production mode,0
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integrated
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
(3)-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt,active
Airbags
;SW:6C0-959-655-A   HW:6C0-959-655-A ---  Airbags
;Component:VW20Airbag010 001 0330, Coding:88C0C000000000005C000000008800000000
;EV_AirbaVW20BPAVW26X,001001,EV_AirbaVW20BPAVW26X_SK26.rod
;Sunday,01,February,2015,11:37:55:43478
;VCDS Version: Beta 15.1.0 (x64)  Data version: 20150118
;VCID: 3147E6C060808CB140-8064
(1)-Airbag adaptations-Seat occupied recognition,activated
(2)-Airbag adaptations-Igniter for battery interrupt; high voltage battery,not defined
(3)-Airbag adaptations-Igniter for battery interrupt,not defined
(4)-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized
(5)-Airbag adaptations-Front passenger side seat belt tension igniter,activated
(6)-Airbag adaptations-Driver side seat belt tension igniter,activated
(7)-Airbag adaptations-Front passenger head curtain airbag igniter,not defined
(8)-Airbag adaptations-Driver head curtain airbag igniter,not defined
(9)-Airbag adaptations-Passenger airbag igniter,activated
(10)-Airbag adaptations-Driver airbag igniter,activated
(11)-Airbag adaptations-Front passenger side airbag igniter,activated
(12)-Airbag adaptations-Driver thorax airbag igniter,activated
Instruments
;SW:6C0-920-940-A   HW:6C0-920-940-A ---  Instruments
;Component:KOMBI         211 0290, Coding:27A401002180260001083A001000000000000000
;EV_DashBoardVDDMQBAB,009040,EV_DashBoardVDDMQBAB_VW26.rod
;Sunday,01,February,2015,11:38:16:43478
;VCID: 2265198C35662729C9-8077
Activating and deactivating all development messages,not active
Cylinder shut-off,Display
Day,1 d
Day counter,99 d
Deactivate seat belt warning,Yes
Digital speedometer,Display
Display correction of consumption and operating range; gas,100 %
Display correction of consumptions and operating range,100 %
Display depiction,Not available
Distance,5009 km
Driving profile for range remaining LPG,10.0 l/100km
Driving profiled for range remaining,6.6 l/100km
Driving profiled for range remaining CNG,6.0 kg/100 km
ESI: distance driven from inspection,5001 km
ESI: maximum value km-driving distance/inspection,30000 km
ESI: maximum value of time between inspections,730 d
ESI: minimum value km-driving distance/inspection,15000 km
ESI: minimum value of time between inspections,365 d
ESI: oil quality,poor oil quality
ESI: Resetting ESI,no warning
ESI: soot entry,0 km
ESI: thermal load,6200 km
ESI: time from inspection,67 d
FIX: Distance covered since last mileage-dependent inspection,5000 km
Fix: Max. distance until next mileage-related inspection,32200 km
FIX: Maximum time until next time-dependent inspection,730 d
FIX: Reset value for next mileage-dependent inspection,32200 km
FIX: Reset value for next mileage-dependent inspections,365 d
FIX: Time since last time-dependent inspection,101 d
Hour,11 H
Ignition active message; actuator,Driver door
Language version,English
(1)-MFA3-Reset-MFI button RESET / OK,Manual reset; not possible
(2)-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
(3)-MFA3-Reset-Refuel detection gas,MFA3-Reset
(4)-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
Minute,38 min
Month,2 mon
No-voltage display,Display
(1)-Offset for tank calibration values-Offset sensor 1,-12.8 l
(2)-Offset for tank calibration values-Offset sensor 2,12.7 l
(3)-Offset for tank calibration values-Offset sensor 3,12.7 l
(4)-Offset for tank calibration values-Offset sensor 4,12.7 l
(5)-Offset for tank calibration values-Complete tank calibration,-12.8 l
Oil temperature display,On
Roller test bench mode; functional,not activated
Service notification in days,30 d
(1)-Service-key settings-p_write_delay_time,40 s
(2)-Service-key settings-p_write_delay_speed,20 km/h
(3)-Service-key settings-p_write_distance,20 km
(4)-Service-key settings-p_forcewrite_qual_time,10 s
(5)-Service-key settings-p_main_switch_keyless,On
(6)-Service-key settings-p_main_switch_Basic,On
(7)-Service-key settings-p_deactivate_SK_Function,On
SIA: maximum value of distance to service,15000 km
SIA: maximum value of time to service,365 d
Source for synchronization of time,internal clock
(1)-Speed warning-,not active
(2)-Speed warning-Unit,Miles per hour
(3)-Speed warning-Speed,0
Trip recorder,not installed
(1)-Units adjusted-Temperature,Degrees Celsius
(2)-Units adjusted-Distance,miles
(3)-Units adjusted-Speed,Miles per hour
(4)-Units adjusted-Pressure,psi
(5)-Units adjusted-Volume,Liter
(6)-Units adjusted-Time,24h
(7)-Units adjusted-Date,dd_mm_yy
(8)-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (UK)
(9)-Units adjusted-Operating range consumption; CNG (compressed natural gas),kg per 100 km
(10)-Units adjusted-Average consumption; electric drive,kWh per 100 km
Vehicle Positioning System Interface Control Module,not installed
Year,2015 yr
(1)-Total operating range gas-State,not active
(2)-Total operating range gas-selection_consumption_factor,consumption_factor_CAN
(3)-Total operating range gas-consumption_profile,consumption_profile_calculation
(4)-Total operating range gas-consumption_factor,0.000
BAP_Debug_Mode_Release,not_released
(1)-Configuration of Development CAN-Messages-Block 1,OFF
(2)-Configuration of Development CAN-Messages-Block 2,OFF
(3)-Configuration of Development CAN-Messages-Block 3,OFF
(4)-Configuration of Development CAN-Messages-Block 4,OFF
(5)-Configuration of Development CAN-Messages-Block 5,OFF
(6)-Configuration of Development CAN-Messages-Block 6,OFF
(7)-Configuration of Development CAN-Messages-Block 7,OFF
(8)-Configuration of Development CAN-Messages-Block 8,OFF
(9)-Configuration of Development CAN-Messages-Block 9,OFF
(10)-Configuration of Development CAN-Messages-Block 10,OFF
(11)-Configuration of Development CAN-Messages-Block 11,OFF
(12)-Configuration of Development CAN-Messages-Block 12,OFF
(13)-Configuration of Development CAN-Messages-Block 13,OFF
(14)-Configuration of Development CAN-Messages-Block 14,OFF
(15)-Configuration of Development CAN-Messages-Block 15,OFF
(16)-Configuration of Development CAN-Messages-Block 16,OFF
(17)-Configuration of Development CAN-Messages-Block 17,OFF
(18)-Configuration of Development CAN-Messages-Block 18,OFF
(19)-Configuration of Development CAN-Messages-Block 19,OFF
(20)-Configuration of Development CAN-Messages-Block 20,OFF
(21)-Configuration of Development CAN-Messages-Block 21,OFF
(22)-Configuration of Development CAN-Messages-Block 22,OFF
(23)-Configuration of Development CAN-Messages-Block 23,OFF
(24)-Configuration of Development CAN-Messages-Block 24,OFF
(25)-Configuration of Development CAN-Messages-Block 25,OFF
(26)-Configuration of Development CAN-Messages-Block 26,OFF
(27)-Configuration of Development CAN-Messages-Block 27,OFF
(28)-Configuration of Development CAN-Messages-Block 28,OFF
(29)-Configuration of Development CAN-Messages-Block 29,OFF
(30)-Configuration of Development CAN-Messages-Block 30,OFF
(31)-Configuration of Development CAN-Messages-Block 31,OFF
(32)-Configuration of Development CAN-Messages-Block 32,OFF
(33)-Configuration of Development CAN-Messages-Block 33,OFF
(34)-Configuration of Development CAN-Messages-Block 34,OFF
(35)-Configuration of Development CAN-Messages-Block 35,OFF
(36)-Configuration of Development CAN-Messages-Block 36,OFF
(37)-Configuration of Development CAN-Messages-Block 37,OFF
(38)-Configuration of Development CAN-Messages-Block 38,OFF
(39)-Configuration of Development CAN-Messages-Block 39,OFF
defuel_threshold,35 l
(1)-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
(2)-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
(3)-dimming_characteristic_curve_adjustment_clock_dial_day-X2,66
(4)-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
(5)-dimming_characteristic_curve_adjustment_clock_dial_day-X3,96
(6)-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,05
(7)-dimming_characteristic_curve_adjustment_clock_dial_day-X4,B4
(8)-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,0F
(9)-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
(10)-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28
(11)-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
(1)-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
(2)-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02
(3)-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
(4)-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02
(5)-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32
(6)-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0C
(7)-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64
(8)-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,19
(9)-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96
(10)-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,29
(11)-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
(1)-dimming_characteristic_curve_adjustment_gauge-X1,00
(2)-dimming_characteristic_curve_adjustment_gauge-Y1,02
(3)-dimming_characteristic_curve_adjustment_gauge-X2,0A
(4)-dimming_characteristic_curve_adjustment_gauge-Y2,02
(5)-dimming_characteristic_curve_adjustment_gauge-X3,32
(6)-dimming_characteristic_curve_adjustment_gauge-Y3,0E
(7)-dimming_characteristic_curve_adjustment_gauge-X4,64
(8)-dimming_characteristic_curve_adjustment_gauge-Y4,19
(9)-dimming_characteristic_curve_adjustment_gauge-X5,C8
(10)-dimming_characteristic_curve_adjustment_gauge-Y5,55
(11)-dimming_characteristic_curve_adjustment_gauge-X6,FD
(12)-dimming_characteristic_curve_adjustment_gauge-Y6,64
(1)-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
(2)-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05
(3)-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
(4)-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05
(5)-dimming_characteristic_curve_adjustment_indicator_lights-X3,32
(6)-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C
(7)-dimming_characteristic_curve_adjustment_indicator_lights-X4,64
(8)-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17
(9)-dimming_characteristic_curve_adjustment_indicator_lights-X5,96
(10)-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32
(11)-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
(12)-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
(1)-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
(2)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
(3)-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
(4)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E
(5)-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
(6)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41
(7)-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
(8)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
(9)-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
(10)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
(1)-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
(2)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01
(3)-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
(4)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01
(5)-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32
(6)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,08
(7)-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64
(8)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12
(9)-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96
(10)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E
(11)-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
(12)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
Gas_functionality,not active
(1)-Illumination_algorithm-Scale_switching_algorithm,parking_light
(2)-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight
init_fuel_algorithm,No
(1)-outside_temperature-p_time_constant_pt1,40 s
(2)-outside_temperature-p_time_constant_slow_damping,2.0
(3)-outside_temperature-P_speed_threshold,20 km/h
(4)-outside_temperature-p_tendency_threshold,1.0 °C
(5)-outside_temperature-p_kmt_at_delta,25 °C
(6)-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
(7)-outside_temperature-p_storage_time_engine_off,180 min
(8)-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
(9)-outside_temperature-p_ice_warning_exit_temperature,6 °C
(10)-outside_temperature-p_ice_warning_entry_temperature,4 °C
(11)-outside_temperature-p_tendency_damping,15 s
Picture_Upload_Download,not active
Service_Key_Clear_All_Counter,Yes
(1)-time_parameter_display-tDDWUP,0.0
(2)-time_parameter_display-tDD15_on,0.0
(3)-time_parameter_display-tDD15_off,0.6
(4)-time_parameter_display-hmi_t_Dreiter_ms,2.0
(5)-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
(6)-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
(7)-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
(8)-time_parameter_display-hmi_t_TWSAnz_ms,3 s
(9)-time_parameter_display-hmi_t_NextWarning_ms,6 s
(10)-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
(11)-time_parameter_display-hmi_t_P1Pause_ms,20 s
(12)-time_parameter_display-hmi_t_P2Pause_ms,900 s
(13)-time_parameter_display-hmi_t_Quit_ms,10 s
(14)-time_parameter_display-hmi_t_FondGurt,30 s
(15)-time_parameter_display-hmi_t_USZ,0.20 s
(16)-time_parameter_display-hmi_t_FTuerAUF,300 ms
(17)-time_parameter_display-rollierblockgroesse,3
CAN Gateway
;SW:6C0-909-901   HW:6C0-937-089 ---  CAN Gateway
;Component:GW MQB A0     H06 0047, Coding:030100046F0A560071000000000000010001000000000000000000000000
;EV_GatewA0Lear,001001,EV_GatewA0Lear_VW26.rod
;Sunday,01,February,2015,11:33:18:43478
;VCID: 65EF429064C810116C-8030
(1)-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active
(2)-Auxiliary heater activation restriction request-Set_point_target_time,--
(1)-Battery adaptation-Rated battery capacity,59 Ah
(2)-Battery adaptation-Battery technology,EFB
(3)-Battery adaptation-Battery manufacturer,JCB
(4)-Battery adaptation-Battery Serial Number,1111111111
Battery terminal recognition,connected
Component protection showroom mode,not active
Counter for inconsistent states,19
Deactivation of start-stop function,Mode not active
Distance left for deactivation of static current measuring mode,2
Distance left for deactivation of transport mode,50
Energy management deactivation stage,Mode not active
Energy management heat output control status,Mode not active
Generator specified voltage value variable,10.6 V
(1)-Hysteresis voltage-Voltage_lowering,12.1 V
(2)-Hysteresis voltage-Voltage_elevation,12.1 V
Increase idle speed request,Mode not active
(1)-Installation list; specified installations-Gateway,coded
(2)-Installation list; specified installations-Node_0x01,Not coded
(3)-Installation list; specified installations-Node_0x02,Not coded
(4)-Installation list; specified installations-Node_0x03,Not coded
(5)-Installation list; specified installations-Node_0x04,Not coded
(6)-Installation list; specified installations-Node_0x05,Not coded
(7)-Installation list; specified installations-Node_0x06,Not coded
(8)-Installation list; specified installations-Node_0x07,Not coded
(9)-Installation list; specified installations-Node_0x08,Not coded
(10)-Installation list; specified installations-Node_0x09,Not coded
(11)-Installation list; specified installations-Parking Assistance,Not coded
(12)-Installation list; specified installations-Tire Pressure Monitoring 1,Not coded
(13)-Installation list; specified installations-Steering Column Electronics,Not coded
(14)-Installation list; specified installations-Node_0x0D,Not coded
(15)-Installation list; specified installations-Central Electrics,coded
(16)-Installation list; specified installations-All-wheel electronics,Not coded
(17)-Installation list; specified installations-Node_0x11,Not coded
(18)-Installation list; specified installations-Steering Assistance,coded
(19)-Installation list; specified installations-Brakes 1,coded
(20)-Installation list; specified installations-Dash Board,coded
(21)-Installation list; specified installations-Airbag,coded
(22)-Installation list; specified installations-Node_0x16,Not coded
(23)-Installation list; specified installations-Node_0x17,Not coded
(24)-Installation list; specified installations-Radio,Not coded
(25)-Installation list; specified installations-Air Conditioning Compressor,Not coded
(26)-Installation list; specified installations-Node_0x1A,Not coded
(27)-Installation list; specified installations-Node_0x1B,Not coded
(28)-Installation list; specified installations-Actuator For Structure-borne Sound,Not coded
(29)-Installation list; specified installations-Node_0x1D,Not coded
(30)-Installation list; specified installations-Lock Electronics,Not coded
(31)-Installation list; specified installations-Node_0x1F,Not coded
(32)-Installation list; specified installations-Node_0x20,Not coded
(33)-Installation list; specified installations-Node_0x21,Not coded
(34)-Installation list; specified installations-Node_0x22,Not coded
(35)-Installation list; specified installations-Deck Lid Control Unit,Not coded
(36)-Installation list; specified installations-Node_0x24,Not coded
(37)-Installation list; specified installations-Node_0x25,Not coded
(38)-Installation list; specified installations-Node_0x26,Not coded
(39)-Installation list; specified installations-Node_0x27,Not coded
(40)-Installation list; specified installations-Node_0x28,Not coded
(41)-Installation list; specified installations-Node_0x29,Not coded
(42)-Installation list; specified installations-Node_0x2A,Not coded
(43)-Installation list; specified installations-Special Function 2,Not coded
(44)-Installation list; specified installations-Special Function,Not coded
(45)-Installation list; specified installations-Electronic Roof Control,Not coded
(46)-Installation list; specified installations-Node_0x2E,Not coded
(47)-Installation list; specified installations-Node_0x2F,Not coded
(48)-Installation list; specified installations-High Beam Assistance,Not coded
(49)-Installation list; specified installations-Steering Column Locking,Not coded
(50)-Installation list; specified installations-Access Startsystem Interface,Not coded
(51)-Installation list; specified installations-Sliding Door Rear Left,Not coded
(52)-Installation list; specified installations-Sliding Door Rear Right,Not coded
(53)-Installation list; specified installations-Node_0x35,Not coded
(54)-Installation list; specified installations-Node_0x36,Not coded
(55)-Installation list; specified installations-Node_0x37,Not coded
(56)-Installation list; specified installations-Node_0x38,Not coded
(57)-Installation list; specified installations-Node_0x39,Not coded
(58)-Installation list; specified installations-Node_0x3A,Not coded
(59)-Installation list; specified installations-Brake booster,Not coded
(60)-Installation list; specified installations-Node_0x3C,Not coded
(61)-Installation list; specified installations-Node_0x3D,Not coded
(62)-Installation list; specified installations-Door Electronics Rear Driver Side,Not coded
(63)-Installation list; specified installations-Door Electronics Rear Passenger Side,Not coded
(64)-Installation list; specified installations-Node_0x40,Not coded
(65)-Installation list; specified installations-Node_0x41,Not coded
(66)-Installation list; specified installations-Thermal management,Not coded
(67)-Installation list; specified installations-Node_0x43,Not coded
(68)-Installation list; specified installations-Battery Charger Control Module,Not coded
(69)-Installation list; specified installations-Node_0x45,Not coded
(70)-Installation list; specified installations-Air Conditioning,coded
(71)-Installation list; specified installations-Trailer Function,Not coded
(72)-Installation list; specified installations-Node_0x48,Not coded
(73)-Installation list; specified installations-Node_0x49,Not coded
(74)-Installation list; specified installations-Door Electronics Driver Side,Not coded
(75)-Installation list; specified installations-Door Electronics Passenger Side,Not coded
(76)-Installation list; specified installations-Seat Adjustment Driver Side,Not coded
(77)-Installation list; specified installations-Seat Adjustment Passenger Side,Not coded
(78)-Installation list; specified installations-Lane change assistance,Not coded
(79)-Installation list; specified installations-Frontsensorik für Fahrerassistenzsysteme,Not coded
(80)-Installation list; specified installations-Vehicle Position Detection,Not coded
(81)-Installation list; specified installations-Node_0x51,Not coded
(82)-Installation list; specified installations-Node_0x52,Not coded
(83)-Installation list; specified installations-Node_0x53,Not coded
(84)-Installation list; specified installations-Headlight Regulation,Not coded
(85)-Installation list; specified installations-Node_0x55,Not coded
(86)-Installation list; specified installations-Node_0x56,Not coded
(87)-Installation list; specified installations-Adaptive Cruise Control,Not coded
(88)-Installation list; specified installations-Node_0x58,Not coded
(89)-Installation list; specified installations-Node_0x59,Not coded
(90)-Installation list; specified installations-Node_0x5A,Not coded
(91)-Installation list; specified installations-Node_0x5B,Not coded
(92)-Installation list; specified installations-Node_0x5C,Not coded
(93)-Installation list; specified installations-Node_0x5D,Not coded
(94)-Installation list; specified installations-Node_0x5E,Not coded
(95)-Installation list; specified installations-Node_0x5F,Not coded
(96)-Installation list; specified installations-Node_0x60,Not coded
(97)-Installation list; specified installations-Node_0x61,Not coded
(98)-Installation list; specified installations-Node_0x62,Not coded
(99)-Installation list; specified installations-Microphone Control Unit,Not coded
(100)-Installation list; specified installations-Actuator For Exterior Noise,Not coded
(101)-Installation list; specified installations-High Voltage Battery Charge Management,Not coded
(102)-Installation list; specified installations-Node_0x66,Not coded
(103)-Installation list; specified installations-Telematics Communication Unit,Not coded
(104)-Installation list; specified installations-Node_0x68,Not coded
(105)-Installation list; specified installations-Camera System Rear View,Not coded
(106)-Installation list; specified installations-Auxiliary Parking Heater,Not coded
(107)-Installation list; specified installations-Node_0x6B,Not coded
(108)-Installation list; specified installations-Node_0x6C,Not coded
(109)-Installation list; specified installations-TV Tuner,Not coded
(110)-Installation list; specified installations-Node_0x6E,Not coded
(111)-Installation list; specified installations-Sound System,Not coded
(112)-Installation list; specified installations-Media Player Position 1,Not coded
(113)-Installation list; specified installations-Trip recorder,Not coded
(114)-Installation list; specified installations-Wheel Dampening Electronics,Not coded
(115)-Installation list; specified installations-Information Control Unit 1,coded
(116)-Installation list; specified installations-Node_0x74,Not coded
(117)-Installation list; specified installations-Node_0x75,Not coded
(118)-Installation list; specified installations-Engine Control Module 1,coded
(119)-Installation list; specified installations-Transmission Control Module,Not coded
(120)-Installation list; specified installations-Node_0x78,Not coded
(121)-Installation list; specified installations-Node_0x79,Not coded
(122)-Installation list; specified installations-Node_0x7A,Not coded
(123)-Installation list; specified installations-Battery Energy Control Module,Not coded
(124)-Installation list; specified installations-Drive Motor Control Module,Not coded
(125)-Installation list; specified installations-Node_0x7D,Not coded
(126)-Installation list; specified installations-Node_0x7E,Not coded
(127)-Installation list; specified installations-Node_0x7F,Not coded
(128)-Installation list; specified installations-Node_0x80,Not coded
(129)-Installation list; specified installations-Node_0x81,Not coded
(130)-Installation list; specified installations-Node_0x82,Not coded
(131)-Installation list; specified installations-Node_0x83,Not coded
(132)-Installation list; specified installations-Control module for sunroof,Not coded
(133)-Installation list; specified installations-Node_0x85,Not coded
(134)-Installation list; specified installations-Node_0x86,Not coded
(135)-Installation list; specified installations-Node_0x87,Not coded
(136)-Installation list; specified installations-Node_0x88,Not coded
(137)-Installation list; specified installations-Node_0x89,Not coded
(138)-Installation list; specified installations-Lane Change Assistant 2,Not coded
(139)-Installation list; specified installations-Node_0x8B,Not coded
(140)-Installation list; specified installations-Node_0x8C,Not coded
(141)-Installation list; specified installations-Node_0x8D,Not coded
(142)-Installation list; specified installations-Node_0x8E,Not coded
(143)-Installation list; specified installations-Node_0x8F,Not coded
(144)-Installation list; specified installations-Node_0x90,Not coded
(145)-Installation list; specified installations-Node_0x91,Not coded
(146)-Installation list; specified installations-Node_0x92,Not coded
(147)-Installation list; specified installations-Node_0x93,Not coded
(148)-Installation list; specified installations-Node_0x94,Not coded
(149)-Installation list; specified installations-Node_0x95,Not coded
(150)-Installation list; specified installations-Node_0x96,Not coded
(151)-Installation list; specified installations-Node_0x97,Not coded
(152)-Installation list; specified installations-Node_0x98,Not coded
(153)-Installation list; specified installations-Node_0x99,Not coded
(154)-Installation list; specified installations-Node_0x9A,Not coded
(155)-Installation list; specified installations-Node_0x9B,Not coded
(156)-Installation list; specified installations-Node_0x9C,Not coded
(157)-Installation list; specified installations-Node_0x9D,Not coded
(158)-Installation list; specified installations-Node_0x9E,Not coded
(159)-Installation list; specified installations-Node_0x9F,Not coded
(160)-Installation list; specified installations-Node_0xA0,Not coded
(161)-Installation list; specified installations-Node_0xA1,Not coded
(162)-Installation list; specified installations-Node_0xA2,Not coded
(163)-Installation list; specified installations-Node_0xA3,Not coded
(164)-Installation list; specified installations-Node_0xA4,Not coded
(165)-Installation list; specified installations-Node_0xA5,Not coded
(166)-Installation list; specified installations-Node_0xA6,Not coded
(167)-Installation list; specified installations-Node_0xA7,Not coded
(168)-Installation list; specified installations-Node_0xA8,Not coded
(169)-Installation list; specified installations-Node_0xA9,Not coded
(170)-Installation list; specified installations-Node_0xAA,Not coded
(171)-Installation list; specified installations-Node_0xAB,Not coded
(172)-Installation list; specified installations-Node_0xAC,Not coded
(173)-Installation list; specified installations-Node_0xAD,Not coded
(174)-Installation list; specified installations-Node_0xAE,Not coded
(175)-Installation list; specified installations-Node_0xAF,Not coded
(176)-Installation list; specified installations-Node_0xB0,Not coded
(177)-Installation list; specified installations-Node_0xB1,Not coded
(178)-Installation list; specified installations-Node_0xB2,Not coded
(179)-Installation list; specified installations-Node_0xB3,Not coded
(180)-Installation list; specified installations-Node_0xB4,Not coded
(181)-Installation list; specified installations-Node_0xB5,Not coded
(182)-Installation list; specified installations-Node_0xB6,Not coded
(183)-Installation list; specified installations-Node_0xB7,Not coded
(184)-Installation list; specified installations-Node_0xB8,Not coded
(185)-Installation list; specified installations-Node_0xB9,Not coded
(186)-Installation list; specified installations-Node_0xBA,Not coded
(187)-Installation list; specified installations-Node_0xBB,Not coded
(188)-Installation list; specified installations-Node_0xBC,Not coded
(189)-Installation list; specified installations-Node_0xBD,Not coded
(190)-Installation list; specified installations-Node_0xBE,Not coded
(191)-Installation list; specified installations-Node_0xBF,Not coded
(192)-Installation list; specified installations-Node_0xC0,Not coded
(193)-Installation list; specified installations-Node_0xC1,Not coded
(194)-Installation list; specified installations-Node_0xC2,Not coded
(195)-Installation list; specified installations-Node_0xC3,Not coded
(196)-Installation list; specified installations-Node_0xC4,Not coded
(197)-Installation list; specified installations-Node_0xC5,Not coded
(198)-Installation list; specified installations-Node_0xC6,Not coded
(199)-Installation list; specified installations-Node_0xC7,Not coded
(200)-Installation list; specified installations-Node_0xC8,Not coded
(201)-Installation list; specified installations-Node_0xC9,Not coded
(202)-Installation list; specified installations-Node_0xCA,Not coded
(203)-Installation list; specified installations-Node_0xCB,Not coded
(204)-Installation list; specified installations-Node_0xCC,Not coded
(205)-Installation list; specified installations-Node_0xCD,Not coded
(206)-Installation list; specified installations-Node_0xCE,Not coded
(207)-Installation list; specified installations-Node_0xCF,Not coded
(208)-Installation list; specified installations-Node_0xD0,Not coded
(209)-Installation list; specified installations-Node_0xD1,Not coded
(210)-Installation list; specified installations-Node_0xD2,Not coded
(211)-Installation list; specified installations-Node_0xD3,Not coded
(212)-Installation list; specified installations-Node_0xD4,Not coded
(213)-Installation list; specified installations-Node_0xD5,Not coded
(214)-Installation list; specified installations-Node_0xD6,Not coded
(215)-Installation list; specified installations-Node_0xD7,Not coded
(216)-Installation list; specified installations-Node_0xD8,Not coded
(217)-Installation list; specified installations-Node_0xD9,Not coded
(218)-Installation list; specified installations-Node_0xDA,Not coded
(219)-Installation list; specified installations-Node_0xDB,Not coded
(220)-Installation list; specified installations-Node_0xDC,Not coded
(221)-Installation list; specified installations-Node_0xDD,Not coded
(222)-Installation list; specified installations-Node_0xDE,Not coded
(223)-Installation list; specified installations-Node_0xDF,Not coded
(224)-Installation list; specified installations-Node_0xE0,Not coded
(225)-Installation list; specified installations-Node_0xE1,Not coded
(226)-Installation list; specified installations-Node_0xE2,Not coded
(227)-Installation list; specified installations-Node_0xE3,Not coded
(228)-Installation list; specified installations-Node_0xE4,Not coded
(229)-Installation list; specified installations-Node_0xE5,Not coded
(230)-Installation list; specified installations-Node_0xE6,Not coded
(231)-Installation list; specified installations-Node_0xE7,Not coded
(232)-Installation list; specified installations-Node_0xE8,Not coded
(233)-Installation list; specified installations-Node_0xE9,Not coded
(234)-Installation list; specified installations-Node_0xEA,Not coded
(235)-Installation list; specified installations-Node_0xEB,Not coded
(236)-Installation list; specified installations-Node_0xEC,Not coded
(237)-Installation list; specified installations-Node_0xED,Not coded
(238)-Installation list; specified installations-Node_0xEE,Not coded
(239)-Installation list; specified installations-Node_0xEF,Not coded
(240)-Installation list; specified installations-Node_0xF0,Not coded
(241)-Installation list; specified installations-Node_0xF1,Not coded
(242)-Installation list; specified installations-Node_0xF2,Not coded
(243)-Installation list; specified installations-Node_0xF3,Not coded
(244)-Installation list; specified installations-Node_0xF4,Not coded
(245)-Installation list; specified installations-Node_0xF5,Not coded
(246)-Installation list; specified installations-Node_0xF6,Not coded
(247)-Installation list; specified installations-Node_0xF7,Not coded
(248)-Installation list; specified installations-Node_0xF8,Not coded
(249)-Installation list; specified installations-Node_0xF9,Not coded
(250)-Installation list; specified installations-Node_0xFA,Not coded
(251)-Installation list; specified installations-Node_0xFB,Not coded
(252)-Installation list; specified installations-Node_0xFC,Not coded
(253)-Installation list; specified installations-Node_0xFD,Not coded
(254)-Installation list; specified installations-Node_0xFE,Not coded
(255)-Installation list; specified installations-Node_0xFF,Not coded
MKE Check box,activated
(1)-Production mode-p_mode_deactivate_mfl_keys,Deactivating
(2)-Production mode-p_mode_deactivate_recuperation,Deactivating
Production process data 1,00 00
(1)-Roller test bench mode; functional-Activation stages,not activated
(2)-Roller test bench mode; functional-Malfunction states,no error
Selection of release codes for a SWaP function,FF FF FF FF
Start/stop start voltage limit,7.6 V
Static current measuring mode,not activated
Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 400D01CC 01 110 00 00 00 4D 00 400792AD 01 FFFFFF9C 00 00 01 40000024 350032 00 00 2AF1700 00 4006C8C9 01 03 00 00 00 2A5BD8AD 2C 400EFBB2 01 B7FE044D 00 00 00 403BEDD0 01 4A43390 00 00 00 00 00 100 00 01 00 100 00 40045224 01 00 00 30 38313200 2A5BD8E3 2C 7BE7078B 3E24 403BEDD0 01 100 00 01 00 00 35393300 00 00 7BE707BB 3E24 403BEDD0 01 100 00 01 00 00 00 01 00 4004A199 01 01 00 40106C1A 01 4039D557 01 7FFFFFF7 00 403BEDD0 01 100 00 01 00 00 00 00 00 40079487 01 01 00 01 00 100 00 312F72FF 6C1F3134 00 00 400780CE 01 18B 00 40154770 01 18B 00 312F7309 7F1F3730 4A43390 00 00 00 00 00 01 00 FE 00 135B60 00 110 00 2AF27F8 00 134F10 00 26048E 00 00 00 400475D3 01 134F00 00 FFFFFFFE FFFFFFFF 01 00 4039CBB0 01 4039CBB0 01 40046D52 01 2A5BD8BF 2C 400FF8F1 01 4018B0A8 01 05 00 710 22030800 5555013C 5555 00 00 00 00 4039CBB0 01 40046970 01 00 00 00 00 00 00 00 00 00 00 40046663 01 00 00 00 00 00 00 00 00 135B3E 00 40077192 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7BE703FB 3E24 01 00 136428 00 400EBA8D 01 26048E 00 135090 00 135090 00 01 00 135B60 00 400EE952 01
Transport mode,not active
(1)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,0 ms
(2)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,0 ms
(3)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,0 ms
(4)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
(5)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms
(6)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms
(7)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms
(8)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100
(9)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms
(10)-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active
(1)-EM_energy_management_warning_displays-Generatormeldungen,Mode not active
(2)-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active
(3)-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active
(4)-EM_energy_management_warning_displays-Charge level,Mode not active
EM_nominal_voltage_limitation_low_beams,12.1 V
EM_requirement_cyclic_time_voltage_measurement,0 s
EM_requirement_reduction_air_blowers,Mode not active
(1)-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C
(2)-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C
(1)-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled
(2)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled
(3)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled
(4)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled
(5)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled
(6)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled
(7)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled
(8)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled
(9)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled
(10)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled
(11)-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled
(12)-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled
(13)-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled
(14)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled
(15)-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled
(16)-GW_Enable_CAN_Timeout_DTC-All-wheel electronics,Enabled
(17)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled
(18)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled
(19)-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled
(20)-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled
(21)-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled
(22)-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled
(23)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled
(24)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled
(25)-GW_Enable_CAN_Timeout_DTC-Radio,Enabled
(26)-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled
(27)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled
(28)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled
(29)-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
(30)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled
(31)-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled
(32)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled
(33)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled
(34)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled
(35)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled
(36)-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled
(37)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled
(38)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled
(39)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled
(40)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled
(41)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled
(42)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled
(43)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled
(44)-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled
(45)-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled
(46)-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled
(47)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled
(48)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled
(49)-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled
(50)-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled
(51)-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled
(52)-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled
(53)-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled
(54)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled
(55)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled
(56)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled
(57)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled
(58)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled
(59)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled
(60)-GW_Enable_CAN_Timeout_DTC-Brake booster,Enabled
(61)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled
(62)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled
(63)-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled
(64)-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled
(65)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled
(66)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled
(67)-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled
(68)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled
(69)-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled
(70)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled
(71)-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled
(72)-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled
(73)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled
(74)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled
(75)-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled
(76)-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled
(77)-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled
(78)-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled
(79)-GW_Enable_CAN_Timeout_DTC-Lane change assistance,Enabled
(80)-GW_Enable_CAN_Timeout_DTC-Frontsensorik für Fahrerassistenzsysteme,Enabled
(81)-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled
(82)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled
(83)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled
(84)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled
(85)-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled
(86)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled
(87)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled
(88)-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled
(89)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled
(90)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled
(91)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled
(92)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled
(93)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled
(94)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled
(95)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled
(96)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled
(97)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled
(98)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled
(99)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled
(100)-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled
(101)-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled
(102)-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled
(103)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled
(104)-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled
(105)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled
(106)-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled
(107)-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled
(108)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled
(109)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled
(110)-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled
(111)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled
(112)-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled
(113)-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled
(114)-GW_Enable_CAN_Timeout_DTC-Trip recorder,Enabled
(115)-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled
(116)-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled
(117)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled
(118)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled
(119)-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled
(120)-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled
(121)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled
(122)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled
(123)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled
(124)-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled
(125)-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled
(126)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled
(127)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled
(128)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled
(129)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled
(130)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled
(131)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled
(132)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled
(133)-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled
(134)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled
(135)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled
(136)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled
(137)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled
(138)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled
(139)-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled
(140)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled
(141)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled
(142)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled
(143)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled
(144)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled
(145)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled
(146)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled
(147)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled
(148)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled
(149)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled
(150)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled
(151)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled
(152)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled
(153)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled
(154)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled
(155)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled
(156)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled
(157)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled
(158)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled
(159)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled
(160)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled
(161)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled
(162)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled
(163)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled
(164)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled
(165)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled
(166)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled
(167)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled
(168)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled
(169)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled
(170)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled
(171)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled
(172)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled
(173)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled
(174)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled
(175)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled
(176)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled
(177)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled
(178)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled
(179)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled
(180)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled
(181)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled
(182)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled
(183)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled
(184)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled
(185)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled
(186)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled
(187)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled
(188)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled
(189)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled
(190)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled
(191)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled
(192)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled
(193)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled
(194)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled
(195)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled
(196)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled
(197)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled
(198)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled
(199)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled
(200)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled
(201)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled
(202)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled
(203)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled
(204)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled
(205)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled
(206)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled
(207)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled
(208)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled
(209)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled
(210)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled
(211)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled
(212)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled
(213)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled
(214)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled
(215)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled
(216)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled
(217)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled
(218)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled
(219)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled
(220)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled
(221)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled
(222)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled
(223)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled
(224)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled
(225)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled
(226)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled
(227)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled
(228)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled
(229)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled
(230)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled
(231)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled
(232)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled
(233)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled
(234)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled
(235)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled
(236)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled
(237)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled
(238)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled
(239)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled
(240)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled
(241)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled
(242)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled
(243)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled
(244)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled
(245)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled
(246)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled
(247)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled
(248)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled
(249)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled
(250)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled
(251)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled
(252)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled
(253)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled
(254)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled
(255)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled
(256)-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled
(1)-GW_mirror_mode-mirror_mode_typ,not active
(2)-GW_mirror_mode-mirror_mode_bus,Databus drivetrain
GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00
GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00
(1)-Multi_function_steering_wheel_control_module Coding Value-Tiptronic,not installed
(2)-Multi_function_steering_wheel_control_module Coding Value-Temp Sensor,not installed
(4)-Multi_function_steering_wheel_control_module Coding Value-development_1,active
(5)-Multi_function_steering_wheel_control_module Coding Value-development_2,not active
WakeUpMonitor_Activation,not activated
(1)-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s
(2)-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100
(3)-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s
Steering Assist
;SW:6C2-909-144-M   HW:6C2-909-144-D ---  Steering Assist
;Component:EPS_TRW_ALow  322 3211, Coding:0007
;EV_SteerAssisUDSTRW,011021,EV_SteerAssisUDSTRW_VW26.rod
;Sunday,01,February,2015,11:40:18:43478
;VCID: 334BECC89A9CBEA132-8066
Activation of pwr steering asst without engine running,not active
Download without rest bus,not active
Driving profile switchover,Incremental; controlled over time
Software end stop,active
Straight line running,active
Support power,100%
XCP calibration protocol,not active
Information Electrics
;SW:3Q0-035-820   HW:3Q0-035-820 ---  Information Electr.
;Component:MU-S-D-ER     H11 0133, Coding:02620000BE00000011111201000808001F0100C60120010000
;EV_MUStd4CTSAT,001018,EV_MUStd4CTSAT_SK35.rod
;Sunday,01,February,2015,11:40:35:43478
;VCID: 66ED459C99CE1B0965-8033
(1)-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
(2)-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
(1)-Audio Management Input Gain Generation 2-TV Tuner,-128
(2)-Audio Management Input Gain Generation 2-Radio (FM),-128
(3)-Audio Management Input Gain Generation 2-Radio (AM),-128
(4)-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
(5)-Audio Management Input Gain Generation 2-Satellite radio,-128
(6)-Audio Management Input Gain Generation 2-Tuner_TI,-128
(7)-Audio Management Input Gain Generation 2-Media_AUXIN,-128
(8)-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
(9)-Audio Management Input Gain Generation 2-Media_CDA,-128
(10)-Audio Management Input Gain Generation 2-Media_DVD,-128
(11)-Audio Management Input Gain Generation 2-Media_MFP,-128
(12)-Audio Management Input Gain Generation 2-Media_BTDevice,-128
(13)-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
(14)-Audio Management Input Gain Generation 2-Media_Bluray,-128
(15)-Audio Management Input Gain Generation 2-Media_HDMI,-128
(16)-Audio Management Input Gain Generation 2-Tuner_Online,-128
(17)-Audio Management Input Gain Generation 2-Media_Airplay,-128
(18)-Audio Management Input Gain Generation 2-Media_UPNP,-128
(19)-Audio Management Input Gain Generation 2-Media_Cloud,-128
(20)-Audio Management Input Gain Generation 2-Tuner_Personal,-128
(21)-Audio Management Input Gain Generation 2-Tone_Beep,-128
(22)-Audio Management Input Gain Generation 2-Tone_Warning,-128
(23)-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
(24)-Audio Management Input Gain Generation 2-Tone_Messaging,-128
(25)-Audio Management Input Gain Generation 2-Exbox_DMB,-128
(26)-Audio Management Input Gain Generation 2-Mirrorlink,-128
(27)-Audio Management Input Gain Generation 2-TTS_Nav,-128
(28)-Audio Management Input Gain Generation 2-TTS_SDS,-128
(29)-Audio Management Input Gain Generation 2-Phone_Voice,-128
(30)-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
(31)-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
(32)-Audio Management Input Gain Generation 2-HFP,-128
(33)-Audio Management Input Gain Generation 2-TV_AV_IN,-128
Base volume of telephone,50 %
Bluetooth,On
Bluetooth: Sniff mode,OFF
CD eject button,Enabled
(1)-Check tone frequency-High note frequency range,4000 Hz
(2)-Check tone frequency-Medium note frequency range,1000 Hz
(3)-Check tone frequency-Low note frequency range,100 Hz
Confirmation of installation change,89 A8
Country identification; country of sale HMI,GB
Deactivate production mode,0
Developer mode,not activated
(1)-Electrical test of loudspeakers-Mode,automatic
(2)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
(3)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36
(4)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
(5)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36
(6)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
(7)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36
(8)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
(9)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36
(10)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
(11)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36
(12)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
(13)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36
(14)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
(15)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36
(16)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
(17)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36
(18)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
(19)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36
(20)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
(21)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36
(22)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
(23)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36
(24)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
(25)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36
(26)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
(27)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36
(28)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
(29)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36
(30)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
(31)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36
(32)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
(33)-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36
Infotainment Recorder,activated
(1)-Interface for external media; activation-Connection 1,activated
(2)-Interface for external media; activation-Connection 2,not activated
(3)-Interface for external media; activation-Connection 3,not activated
(4)-Interface for external media; activation-Connection 4,not activated
Menu entries for mobile online services,not activated
Microphone sensitivity,0 dB
Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Production mode,00 00 00
Summertime-automatic,manual
WLAN,On
BAP_Debug_Mode_Release,not_released
Bluetooth_Phonebook_Access_Profile,PBAP
(1)-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
(2)-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
(3)-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated
(4)-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
(5)-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
(6)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
(7)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
(8)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated
(9)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
(10)-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
(11)-Car_Function_Adaptations_Gen2-menu_display_pdc,not activated
(12)-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
(13)-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated
(14)-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
(15)-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
(16)-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
(17)-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
(18)-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated
(19)-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
(20)-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
(21)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated
(22)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
(23)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated
(24)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
(25)-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
(26)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
(27)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
(28)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated
(29)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
(30)-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
(31)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
(32)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
(33)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated
(34)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
(35)-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
(36)-Car_Function_Adaptations_Gen2-menu_display_windows,activated
(37)-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
(38)-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated
(39)-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
(40)-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
(41)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated
(42)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
(43)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated
(44)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
(45)-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
(46)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
(47)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
(48)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated
(49)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
(50)-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
(51)-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
(52)-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
(53)-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated
(54)-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
(55)-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
(56)-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
(57)-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
(58)-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated
(59)-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
(60)-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
(61)-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
(62)-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
(63)-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
(64)-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
(65)-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
(66)-Car_Function_Adaptations_Gen2-menu_display_sia,activated
(67)-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
(68)-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
(69)-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
(70)-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
(71)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
(72)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
(73)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated
(74)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
(75)-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
(76)-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
(77)-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
(78)-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated
(79)-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
(80)-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
(81)-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
(82)-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
(83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated
(84)-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
(85)-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
(86)-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated
(87)-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
(88)-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated
(89)-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
(90)-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
(91)-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
(92)-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
(93)-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated
(94)-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
(95)-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
(96)-Car_Function_Adaptations_Gen2-menu_display_vin,activated
(97)-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
(98)-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
(99)-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
(100)-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
(101)-Car_Function_Adaptations_Gen2-menu_display_clock,activated
(102)-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
(103)-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
(104)-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
(105)-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
(106)-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
(107)-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
(108)-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated
(109)-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
(110)-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
(111)-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
(112)-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
(113)-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated
(114)-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
(115)-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
(116)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
(117)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
(118)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated
(119)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
(120)-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
(121)-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
(122)-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
(123)-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated
(124)-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
(125)-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
(126)-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
(127)-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
(128)-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated
(129)-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
(130)-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
(131)-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
(132)-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
(133)-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated
(134)-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
(135)-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
(136)-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
(137)-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
(138)-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated
(139)-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
(140)-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
(141)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
(142)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
(143)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated
(144)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
(145)-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
(146)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
(147)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
(148)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated
(149)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
(150)-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
(151)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
(152)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
(153)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated
(154)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
(155)-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
(156)-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
(157)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
(158)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated
(159)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
(160)-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
(161)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
(162)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
(163)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated
(164)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
(165)-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
(166)-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated
(167)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
(168)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated
(169)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
(170)-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
(171)-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
(172)-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
(173)-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated
(174)-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
(175)-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
(176)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated
(177)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
(178)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated
(179)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
(180)-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
(181)-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated
(182)-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
(183)-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated
(184)-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
(185)-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
(186)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated
(187)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
(188)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated
(189)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
(190)-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
(191)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated
(192)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
(193)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated
(194)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
(195)-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
(196)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated
(197)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
(198)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated
(199)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
(200)-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
(201)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
(202)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
(203)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated
(204)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
(205)-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
(206)-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
(207)-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
(208)-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated
(209)-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
(210)-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
(211)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
(212)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
(213)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated
(214)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
(215)-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
(216)-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
(217)-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
(218)-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated
(219)-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
(220)-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
(221)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
(222)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
(223)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated
(224)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
(225)-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
(226)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
(227)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
(228)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated
(229)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
(230)-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
(231)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
(232)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
(233)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated
(234)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
(235)-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
(236)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
(237)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
(238)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated
(239)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
(240)-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
(241)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
(242)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
(243)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated
(244)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
(245)-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
(246)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
(247)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
(248)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated
(249)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
(250)-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
(251)-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
(252)-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
(253)-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated
(254)-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
(255)-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
(256)-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
(257)-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
(258)-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated
(259)-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
(260)-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
(261)-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated
(262)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
(263)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated
(264)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
(265)-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
(266)-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
(267)-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
(268)-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
(269)-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
(270)-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
(271)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue,not activated
(272)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_clamp_15_off,not activated
(273)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_over_threshold_high,not activated
(274)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_standstill,not activated
(275)-Car_Function_Adaptations_Gen2-menu_display_ThinkBlue_after_disclaimer,not activated
(276)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
(277)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
(278)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
(279)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
(280)-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
(1)-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated
(2)-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus
(3)-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
(4)-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus
(5)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
(6)-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus
(7)-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
(8)-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus
(9)-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
(10)-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15
(11)-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
(12)-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus
(13)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
(14)-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus drivetrain
(15)-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
(16)-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus
(17)-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
(18)-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus
(19)-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated
(20)-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
(21)-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated
(22)-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment
(23)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
(24)-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus
(25)-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
(26)-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus
(27)-Car_Function_List_BAP_Gen2-mirror_0x0E,activated
(28)-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus
(29)-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
(30)-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus
(31)-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
(32)-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus
(33)-Car_Function_List_BAP_Gen2-clock_0x11,activated
(34)-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus
(35)-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
(36)-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus
(37)-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
(38)-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus
(39)-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
(40)-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15
(41)-Car_Function_List_BAP_Gen2-compass_0x15,not activated
(42)-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Comfort data bus
(43)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
(44)-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus
(45)-Car_Function_List_BAP_Gen2-charisma_0x17,not activated
(46)-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus
(47)-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
(48)-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9
(49)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated
(50)-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended
(51)-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated
(52)-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended
(53)-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
(54)-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15
(55)-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
(56)-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain
(57)-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
(58)-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9
(59)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
(60)-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain
(61)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20,not activated
(62)-Car_Function_List_BAP_Gen2-Passanger_Seat_0x20_msg_bus,Comfort data bus
(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated
(64)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended
(65)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated
(66)-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus
(67)-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated
(68)-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus
(69)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
(70)-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus
(71)-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
(72)-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain
(73)-Car_Function_List_BAP_Gen2-Brake_0x26,activated
(74)-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain
(75)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated
(76)-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus
(77)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
(78)-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus
(79)-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
(80)-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9
(81)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
(82)-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus
(83)-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
(84)-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus
(85)-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
(86)-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus
(87)-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
(88)-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus
(89)-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
(90)-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus
(91)-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
(92)-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus
(93)-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
(94)-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus
(95)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
(96)-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended
(97)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
(98)-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus
(99)-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
(100)-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus
(1)-Car_Function_List_CAN_Gen2-MFL,Available
(2)-Car_Function_List_CAN_Gen2-MFL_msg_bus,Comfort data bus
(3)-Car_Function_List_CAN_Gen2-Oil_level,Not available
(4)-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain
(5)-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available
(6)-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus
(7)-Car_Function_List_CAN_Gen2-VIN,Available
(8)-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus
(9)-Car_Function_List_CAN_Gen2-Driving_school,Not available
(10)-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus
(11)-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
(12)-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus
(1)-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
(2)-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
(3)-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50
(4)-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50
(5)-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100
(6)-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100
(1)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0
(2)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0
(3)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50
(4)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50
(5)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100
(6)-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100
(1)-Dimming_Illumination_for_Display_Unit-X1,0
(2)-Dimming_Illumination_for_Display_Unit-Y1,1 %
(3)-Dimming_Illumination_for_Display_Unit-X2,10
(4)-Dimming_Illumination_for_Display_Unit-Y2,1 %
(5)-Dimming_Illumination_for_Display_Unit-X3,100
(6)-Dimming_Illumination_for_Display_Unit-Y3,8 %
(7)-Dimming_Illumination_for_Display_Unit-X4,150
(8)-Dimming_Illumination_for_Display_Unit-Y4,20 %
(9)-Dimming_Illumination_for_Display_Unit-X5,220
(10)-Dimming_Illumination_for_Display_Unit-Y5,60 %
(11)-Dimming_Illumination_for_Display_Unit-X6,253
(12)-Dimming_Illumination_for_Display_Unit-Y6,100 %
Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 96 00 A4 01 C8 00 82 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 05
p_damping_Display,5 ms
p_HMI_Display,13 %
(1)-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
(2)-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
Startup_Screen_Sticker_HMI,00 00
(1)-Vehicle_configuration-VZAPro,OFF
(2)-Vehicle_configuration-online_POI,OFF
(3)-Vehicle_configuration-online_POI_voice,OFF
(4)-Vehicle_configuration-online_portal_browser_services,OFF
(5)-Vehicle_configuration-online_navigation,OFF
(6)-Vehicle_configuration-online_street_view,OFF
(7)-Vehicle_configuration-WIFI_Hotspot,OFF
(8)-Vehicle_configuration-my_audi,OFF
(9)-Vehicle_configuration-picture_navi,OFF
(10)-Vehicle_configuration-online_dictation,OFF
(11)-Vehicle_configuration-remote_HMI,OFF
(12)-Vehicle_configuration-advanced_range_display,OFF
(13)-Vehicle_configuration-gracenote_online_coverarts,OFF
(14)-Vehicle_configuration-gracenote_online_other,OFF
(15)-Vehicle_configuration-gracenote_local_coverarts,OFF
(16)-Vehicle_configuration-gracenote_local_other,OFF
(17)-Vehicle_configuration-UPnP,OFF
(18)-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF
(19)-Vehicle_configuration-Joker_button_1,Not Present
(20)-Vehicle_configuration-Joker_button_2,Not Present
(21)-Vehicle_configuration-LTE_modul,activated
(22)-Vehicle_configuration-Support_second_phone,OFF
(23)-Vehicle_configuration-Support_of_threeway_calling,OFF
(24)-Vehicle_configuration-Dtmf_without_active_call,On
(25)-Vehicle_configuration-Support_for_response_and_hold,OFF
(26)-Vehicle_configuration-Sim_card_mode_switch,Not Present
(27)-Vehicle_configuration-Phone_module_operation_mode,Data & language service active
(28)-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5
(29)-Vehicle_configuration-RVC_video_input,FBAS
(30)-Vehicle_configuration-Station_Logo_DB_Mode,1
(31)-Vehicle_configuration-TPEG_availability,OFF
(32)-Vehicle_configuration-VZO,OFF
(33)-Vehicle_configuration-LGI,OFF
(34)-Vehicle_configuration-ProbeCar,OFF
(35)-Vehicle_configuration-online_media,OFF
(36)-Vehicle_configuration-ProbeCar_lgi,OFF
(37)-Vehicle_configuration-NMH_stopwatch,OFF
(38)-Vehicle_configuration-Google_GAL,OFF
(39)-Vehicle_configuration-Apple_DIO,OFF
Hope this helps, took a while to gather!
OP's User status updated to Verified.
Thanks for registering, and for the data above!
Thread moved to Tweaks section.
rsmagee
C?ID=229750
No problem, hope it can unlock some cool stuff for the Polo!
I know a lot of people are trying to find is there is a way to make the heated seats remember the setting when they are switched off. It can be done in the golf.
rsmagee: Many thanks for taking the (long) time to create the data-base for your car. At a quick glance, the adaptation channels certainly do look very mk7-ish.
Apart from providing me with some fascinating reading (yes, it's a bit weird - I agree), your admaps will doubtless be a handy reference point for the virgin settings in your car should an adaptation channel tweak go "pear-shaped" some time in the future! So your efforts are beneficial on multiple levels!
As for you question about the seat heating, my understanding for the mk-7 is that remembering the seat heating setting is dependent on whether the control module has a memory function in the first-place. Alas I do not believe that it can be done with a simple coding/adaptation channel change. (i.e. you need the hardware). Down here in the balmy south, we don't have the need for seat heating (as a standard equipment). But, as a quid-pro-quo for your database efforts, I've provided a screen shot of where the equipment setting for seat heating is on a mk7. I note that RT don't have a label file for the BCM on your car yet, but when it is developed, I suspect that code setting on your car will be in the same spot (i.e. Byte 3, Bits 2-4, address hex09).
Cheers
EDIT: Update- I've subsequently found an adaptation channel in my mk7 which enables seat heating memory. The following channel is in 08- Auto HVAC control module:
Retention of driver's seat heater level- it has a default setting in my car of "not active", because I don't have seat heating, but I suspect that if activated it would retain the last heat setting!
Now, the only problem with your car is that this adaptation channel doesn't appear in your Auto HVAC admap - bummer!
rsmagee
C?ID=229750
Cheers for that Don :)
Glad to know it will be some use to people in the future!
Will take another look at the BCM and see what I can do with your info!
The files do make interesting reading dont they! The infotainment system contanins some interesting references to apple and google.
