T6.1 New model
vastechnics
C?ID=143747
Wednesday,01,January,2020,14:35:16:43540
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ7HZLH032678   License Plate: T6.1
Chassis Type: 7H-VN75 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 18 19 22 3C 3D 44 55 5F 65 75 D6
          D7 810B
3D-Special Function -- Status: OK 0000
810B-Aux. Air Heat. 2 -- Status: OK 0000
Address 01: Engine (J623-CXFA)       Labels: None
   Part No SW: 04L 906 056 QJ    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9696
   Revision: 23301001
   Coding: 0025401C4366050800000000000000000000000000000000
   Shop #: WSC 00012 790 00070
   ASAM Dataset: EV_ECM20TDI03004L906056QJ 004004
   ROD: EV_ECM20TDI03004L906056QF.rod
   VCID: 055667B165AB876FFA3-8050
Readiness: N/A
   Part No SW: 0BT 300 012 E    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3105
   Revision: 00H06V09
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 313EE36181A3FBCF76B-8064
   Part No SW: 7LA 614 517 A    HW: 7LA 614 517
   Component: ESC_high      H01 0700
   Serial number: 08500618191205
   Coding: 40554452C84AEE87025A22AB136E7766382723B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X.rod
   VCID: 3D26CF514DFB0FAFE23-8068
   Part No SW: 7LA 907 040 C    HW: 7LA 907 040 C
   Component: Climatronic   H01 0502
   Coding: 9030100008102100010009005040010500000000000A1501A04000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: N/A
   VCID: 3B22C14953EF019FDC7-806E
   Subsystem 1 - Part No SW: 7LA 906 453     HW: 7LA 906 453
   Component: E857  H01 0106
   Serial number: 00002281119151629102
   Subsystem 2 - Part No SW: 7LA 907 049 F    HW: 7LA 907 049 F
   Component: E857  H02 0301
   Serial number: 00002231119091437603
No ASAM data for: "EV_AirCondiBHTCT6PA" (VN75)
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01101935101582
   Shop #: WSC 00012 790 00055
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_204.rod
   VCID: 74B02A753E318EE7DDD-8020
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S2Y19M12D08H23M06S31
   Coding: 02B8DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 7L2 959 405 B    HW: 7L2 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000036915964
   Coding: 130007
   Subsystem 3 - Part No SW: 7L2 959 406 B    HW: 7L2 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000036826818
   Coding: 090007
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057319343
   Coding: 0251165851
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 55F677F1D58BF7EFCA3-8000
Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3204670301FF8748949C815580508700000000000000000004
   VCID: 43D2B9A92B1F795F947-8016
   Part No SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
   Component: VW22Airbag    013 0506
   Revision: --------
   Coding: 88CCC00000000000800000CF000C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 005876A57A89A247C95-8054
   Subsystem 1 - Part No SW: -----------    HW: 442 062 911 19
   Serial number: 3577Y51A3340E2C4227$
   Subsystem 2 - Part No SW: -----------    HW: 442 062 911 19
   Serial number: 3587Y51AF33FA1C2427I
Address 17: Instruments (J285)       Labels: None
   Part No SW: 7LA 920 751     HW: 7LA 920 751
   Component: KOMBI         305 6750
   Coding: 07A4098A2488000801882A0D1401000000200000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: N/A
   VCID: 7CA002551661C6A795D-8028
No ASAM data for: "EV_DashBoardVDDMQBAB" (VN75)
Address 18: Aux. Heat (J364)       Labels: None
   Part No SW: 5WA 963 271 A    HW: 5WA 963 271 A
   Component: STH-VW37x     006 0010
   Serial number: 000000000000947
   Coding: 7143221854121512DCE519
   ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
   ROD: N/A
   VCID: 4ACC948D0C35A817571-801E
No ASAM data for: "EV_AuxilHeateWOSVW38X" (VN75)
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 07121911601162
   Coding: 030100544F05730401100218100F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 70B826654A29B2C7395-8024
   Component: 4-00-11-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036345190749
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 7E0 915 181 L    HW: 7E0 915 181 L
   Serial number: 77197200001911250921
   Part No SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
   Component: Haldex4Motion H56 7822
   Serial number: HA1-00008.11.19
   Coding: 0001
   Shop #: WSC 00012 790 00047
   VCID: 4EC4989DF05D84370B9-801A
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0149
   Serial number: 00000533054068
   Coding: 52954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392EDB4159D3338FCEB-806C
Address 3D: Special Function (J608)       Labels:* None
   Part No SW: 2N0 907 427 P    HW: 2N0 907 427 H
   Component: KFG       H24 0306
   Serial number: GB24194842058
   Coding: 04002000000000200200000860B8135EB8000000
   ASAM Dataset: EV_SpeciFunctFlextVN54X 007029
   ROD: EV_SpeciFunctFlextVN54X.rod
   Subsystem 5 - Part No SW: 7C0 907 155     HW: 7C0 907 155
   Component: U13DCAC  H05 0870
   Serial number: A016891
   Subsystem 6 - Part No SW: 7E0 915 181 M    HW: 7E0 915 181 M
   Serial number: 7719450100191125014E
Address 44: Steering Assist (J500)       Labels:. 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0306
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: N/A
   VCID: 45D6A7B1252B476FBA3-8010
No ASAM data for: "EV_SteerAssisMNB" (VN75)
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 0C8A020009200003
   ROD: N/A
   VCID: 41DEB3A131036B4F86B-8014
No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VN75)
   Part No SW: 3G0 035 869 B    HW: 3G0 035 869 B
   Component: MU-E-D-ER     720 0740
   Serial number: 04121900020797
   Coding: 06640500FF00000041110101008000001F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 2B02F109A38F911F4C7-807E
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H05 0010
   Serial number: 40000000365324
   ROD: EV_RDKBERU30_005.rod
   VCID: 3634D07D68CDDCF7239-8062
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 2
                    Mileage: 29 km
                    Date: 2020.02.19
                    Time: 17:22:44
                    Vehicle speed: 84 km/h
                    Outside air temperature: 7.0 °C
                    Reception level antenna 1: 420 mV
                    Offset level antenna 1: 220 mV
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 2
                    Mileage: 29 km
                    Date: 2020.02.19
                    Time: 17:22:44
                    Reception level antenna 1: 440 mV
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 2
                    Mileage: 29 km
                    Date: 2020.02.19
                    Time: 17:22:44
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Reset counter: 2
                    Mileage: 29 km
                    Date: 2020.02.19
                    Time: 17:22:44
                    Reception level antenna 1: 430 mV
Address 75: Telematics (J949)       Labels: None
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000909NVCL4
   Coding: 06462000196818208005460160500607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: N/A
   VCID: 015E73A17183AB4FC6B-8054
No ASAM data for: "EV_OCUGen3Low" (VN75)
7170 - ROD - Unknown Error Code
          - 00 [008]
                    Mileage: 2226 km
                    Date: 2020.03.04
                    Time: 14:32:47
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X.rod
   VCID: 619E532191C30B4FA6B-8034
   Component: LED1R         H08 9002
Address 810B: Aux. Air Heat. 2 (J604)       Labels:* None
   Part No SW: 7C0 963 273 B    HW: 7C0 963 273 B
   Component: LSH_DIESEL    006 0026
   Coding: 3200
   ASAM Dataset: EV_LSHECCSMNB 002018
   ROD: EV_LSHECCSMNB_002.rod
   VCID: 2A0CF40DAC758817B71-807E
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0402
   Serial number: 00000000000000924743
End----------(Elapsed Time: 01:28, VBatt start/end: 12.7V/12.6V)-----------
wehnerch
C?ID=332473
Hallo
haben Sie einen vollständigen Scan des T6.1?
Ich benötige spezielle BCM (Adresse 09) Scheinwerferbereich (Adresse 55)
Das Beste ist der komplette Scan.
South Molton, UK
Hallo
The language of this forum is English, please post only in English as most of us do not speak or understand German
... and when posting an Auto-Scan use only the English version of VCDS for the same reason (this can be installed alongside the German version if you have that).
wehnerch
C?ID=332473
Hello do you have a full scan of the T6.1 with LED headlights? I need a special BCM (address 09) headlight area (address 55) with adjustment channels.
The best is the complete scan including adjustment channels.
vastechnics
C?ID=143747
Hello. I can get this no problem. Still need?
wehnerch
C?ID=332473
Yes Please! I still need it.
Thnaks!
