Disable Brake Pad Warning Light (Audi A6 - 2014)
MRDAMO666
England
C?ID=380337
Hi there, I have just had my brake pads changed on my Audi A6 2014, 2.0, TDI, (UK vehicle). The brake pad warning light keeps illuminating on the dash, so having done some reading, it is likely to be a broken connection to a sensor. The obvious question, yes, the pads have definitely been changed and are new, so comfortable its the sensor/connection.
How do I disable the Brake Pad Warning Light using the VCDS software?
I have tried to find an exact answer on the forum but no luck unfortunately.
I am very knew to the VCDS software so please feel free to use "Idiots guide" language.....I can see coding strings is going to be part of the answer but am confused how that works.
Any help would be gratefully appreciated
Thanks!
Tuesday,03,March,2020,15:14:27:46541
VIN: WAUZZZ4G3EN182843   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F 62
          72 AC
VIN: WAUZZZ4G3EN182843   Mileage: 73894km-45915miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FE    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8243
   Revision: 85H23---
   Coding: 0A194012242401080000
   Shop #: WSC 56882 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021FE 002007
   ROD: EV_ECM20TDI01104L906021FE_002.rod
   VCID: 6D87C9623D1AA2BF121-8038
19226 - Particulate Trap Bank 1
          P2002 00 [101] - Efficiency Below Threshold
                    Mileage: 73888 km
                    Date: 2020.03.03
                    Time: 13:50:10
                    Engine speed: 1818.50 /min
                    Normed load value: 56.9 %
                    Vehicle speed: 107 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 83 °C
                    Voltage terminal 30: 14.580 V
                    Exhaust mass flow of low-pressure EGR: calculated: 3.012
                    Differential pressure ratio: low-pressure EGR: 31.5 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 38.5 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 38.2 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 64.39 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 51.17 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 38.5 hPa
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 06A09F016005F9809B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2D323E3CD4C507C73-806E
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0551
   Coding: 03B83046000000000000
   VCID: 7AADF23E7CD40507873-802E
   Serial number: 0214000122868001
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 01071400111268
   Coding: 3421090821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 5F9BA3AAC7B6C02F90D-800A
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Revision: 19012002    Serial number: 00000001555361
   Coding: 2600201040349F600481008000001D0C0F9D830827090201000004606100
   VCID: 6D87C9623D9AA2BF121-8038
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140621  H37 0080
   Serial number:         140630055157
   Coding: 0045F7
   Serial number: 22844189
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 23 06 2014  00001518
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 3828C637000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061419000341
   Coding: 08C206
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD5122122465F369-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00JL4UQ
   Coding: 3032343631324E303235554A305234473053
   VCID: 3635260E08CC216723B-8062
   Serial number: 3575HRB405F2M4PG0P3O
   Serial number: 3585HRB40632M4PG408+
   Serial number: 3515JRB405J2SIIA21EK
   Serial number: 3525JRB405L2SIIAA83R
   Serial number: 3554VRB401A52MDSOH85
   Serial number: 3564VRB401A52MDSQ8PG
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140707000312
   Coding: 000014
   VCID: 30391016EA280F57797-8064
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658020714592022
   Coding: 33A40A000B412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3FDB432A27F6E02FF0D-806A
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                    Mileage: 73880 km
                    Date: 2020.03.03
                    Time: 13:37:23
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001466281
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BDDA1E24247D47CF3-8026
   Serial number: 9617223703
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140208000000000006FB
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA720AY5GP
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331F1A1BBE344F045-8066
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 47CB5BCA7FA6A8EF48D-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0025714666
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0339889791
   Coding: 011B062280B900408320080400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Revision: CJ007001    Serial number: 00000000120361
   VCID: 1D67D9A28DBA923FC21-8048
   Component: TSG BF        H03 0507
   VCID: 46D556CE78ACB1E7B3B-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001123019
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070962FD9A62BF521-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140707-0002-088
   Coding: 112196101000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0801
   Coding: 0101000101415B47082B060301020100000000
   VCID: 270BFB4ADFE648EFA8D-8072
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464F30E2668186
   Subsystem 3 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NG9000AH
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49CF5DF269B25E9F5E9-801C
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 141681459
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B03077AC38E6C8F4C5-807E
End----------(Elapsed Time: 01:40, VBatt start/end: 12.1V/12.0V)-----------
0120raptor
North West UK
C?ID=210440
Just connect the two wires together on the relevant front and rear pads. This will stop the light.
NEtech
Denmark
C?ID=56995
Try Coding [09] Byte 17 Bit 2
MRDAMO666
England
C?ID=380337
I want to avoid doing the wire bridging method if possible. Thanks anyway.
MRDAMO666
England
C?ID=380337
Sorry, im a noob, what does that mean in terms of navigating from the VCDS front screen? Thanks
[Select]
[09-Cent. Elect.]
[Coding]
[Long Coding Helper]
That will get you a screen something like this:
In line 3), click on Byte 17. The Byte you have clicked on will will be shown just below ("Byte 6" in the sample screen above).
Bit 2 of that Byte should be labelled: "Brake Pad Wear Sensor (G37) installed".
Remove the check-mark next to it, then exit Long Coding Helper. Then there should be a string in the 'New Coding' field of the previous screen. There, click [Do it!].
MRDAMO666
England
C?ID=380337
[Select]
[09-Cent. Elect.]
[Coding]
‘Uwe’......cracking piece of guidance. Will give it a try in the next couple of says. Thanks muchly!
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Let me get involved: :)
Similar to this, as Niels and Uwe says.
therealfleen
C?ID=378414
Old thread but saved my bacon! Thanks for posting up gents!
