Tiguain 5N1 abs coding
mohamed
Egypt
C?ID=211960
Hello , i have been changed the ECU control module and the Coding of ABS has been resetted could you provide me with the correct ABS code
this is the full auto-scan
Saturday,29,February,2020,17:33:23:22511
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
Dealer/Shop Name: Harisa
VIN: WVWZZZ1KZ8M312339   License Plate:
Mileage: 177290km-110162mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 10 15 16 17 19 1C 22 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ1KZ8M312339   Mileage: 177290km-110162miles
Address 01: Engine        Labels: 03C-906-032-BLG.lbl
   Part No SW: 03C 906 032 T    HW: 03C 906 032 C
   Component: MED17.5.1       G   2417
   Revision: 96H07---    Serial number: VWX7Z0G43N88IK
   Coding: 0000075
   Shop #: WSC 00046 000 00000
   VCID: AE104A9C39402A3F85-80FA
005696 - Internal Control Module
               P1640 - 000 - EEPROM Error - MIL ON
                    Fault Status: 11100000
                    Mileage: 177298 km
                    Time: 05:27:45
                    Temperature: 78.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.192 V
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 L    HW: 5N0 614 517 L
   Component: J104    C2 450 V2   0006
   Revision: --H12---    Serial number: 00000001379488
   Coding: 0010000
   Shop #: WSC 00000 785 00200
   VCID: B73E6FF8C61AEBF7D6-80E2
                    Reset counter: 64
                    Mileage: 177298 km
                    Time: 05:29:40
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 166
                    Hex Value: 0x0000
03190 - Incorrect Vehicle Type
                    Reset counter: 64
                    Mileage: 177298 km
                    Time: 05:29:41
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 242
                    Hex Value: 0x0000
03201 - Adaptation Overboost
                    Reset counter: 64
                    Mileage: 177298 km
                    Time: 05:29:41
                    Reset counter: 64
                    Mileage: 177298 km
                    Time: 05:29:41
   Part No SW: 1K0 907 044 CT    HW: 1K0 907 044 CT
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: FBB6B3C8BAB20F9772-80AE
   Revision: 00H54000    Serial number: 00000008740841
   Coding: E58C0FA300041C0047190000140000000009FF475C400124390000000000
   Shop #: WSC 01287 785 00200
   VCID: B3265BE8D26207D7EA-80E6
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 080808  012 0203
   Coding: 00038805
   Shop #: WSC 01287
   Component: RLS     030808 046  0204
   Coding: 00208933
   Shop #: WSC 01287
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 B    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0006
   Revision: --------    Serial number: 22030820104050
   Coding: 100002
   Shop #: WSC 01316 785 00200
   VCID: BA3876CC3508F69F29-80EE
                    Fault Status: 00101101
                    Reset counter: 104
                    Mileage: 177298 km
                    Time: 05:22:18
                    Temperature: 25.0°C
   Component: J234__200 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPF8J0Y/
   Coding: 0012336
   VCID: BB3673C8FA32CF9732-80EE
   Subsystem 1 - Serial number: 6333FTS608831918
   Subsystem 2 - Serial number: 6343FTS640101918
   Subsystem 3 - Serial number: 6353ETS6SFTBUVNP
   Subsystem 4 - Serial number: 6363ETS6IGSCUVNP
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Coding: 0002022
   VCID: 814AC120D85E654728-80D4
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 5N0 920 870 C    HW: 5N0 920 870 C
   Component: KOMBIINSTRUMENT VDD 2422
   Revision: V0004000    Serial number: VWX7Z0G43N88IK
   Coding: 0007104
   Shop #: WSC 01286 386 08256
   VCID: B02C54E423743CCF97-80E4
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 220608F1000883
   Coding: F9A27F060012026002
   VCID: B52265F0DC1619E7C4-80E0
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T3MNP03
   VCID: FDB2BDD0A4A601A74C-80A8
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: CBD62308AA927F1782-809E
   Component: IMMO            VDD 2422
02241 - Engine Control Module; Immobilizer Data not Adapted
                    Mileage: 177298 km
                    Time: 05:31:16
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 177235 km
                    Time: 00:20:27
   Part No SW: 5N0 959 701     HW: 5N0 959 701
   Component: Tuer-SG         006 1205
   Coding: 0000188
   VCID: F2A89EECEDF84EDF21-80A6
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 E
   Component: J500__APA-BS KL.096 0401
   Revision: 1AH01251    Serial number: 00080660089202
   Coding: 0000258
   Shop #: WSC 36002 360 89777
   VCID: B62062FCC11012FFCD-80E2
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 64
                    (no units): 4.0
                    Voltage: 12.20 V
                    Reset counter: 64
                    Mileage: 177298 km
                    Time: 05:29:33
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 3
   Component:    KSG PQ35 G2  020 0205
   Coding: 80800A0052830C7F3F04840560084F0BE0FC00
   VCID: 8346CB28C24277573A-80D6
   Part No SW: 5N0 959 702     HW: 5N0 959 702
   Coding: 0000188
   VCID: F3A69BE892E247D72A-80A6
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
   Component: J540 EPB3  VW-09384 0005
   Revision:   H09       Serial number: 00000000176796
   Coding: 0010000
   Shop #: WSC 01324 020 00200
            000 - - - MIL ON
                    Fault Status: 11110000
                    Reset counter: 49
                    Mileage: 177235 km
                    Voltage: 11.50 V
                    Count: 100
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 104
                    Mileage: 177298 km
                    Voltage: 11.90 V
                    Count: 71
                    Hex Value: 0x1251
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 - - - MIL ON
                    Reset counter: 64
                    Mileage: 177298 km
                    Voltage: 11.80 V
                    Count: 98
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3337168
   Coding: 0500040004
   Shop #: WSC 66893 392 00200
   VCID: E582F5B0EC36A967B4-80B0
   Part No SW: 5N0 959 703     HW: 5N0 959 703
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 01287 785 1012552
   VCID: F4A498F497EC40EF33-80A0
   Part No SW: 5N0 959 704     HW: 5N0 959 704
   Coding: 0000144
   VCID: F5A2A5F09C9659E704-80A0
End----------(Elapsed Time: 01:31, VBatt start/end: 12.2V/12.2V)-----------
mohamed
Egypt
C?ID=211960
This is another autoscan after change the coding of engine tobe 172
Tuesday,03,March,2020,14:35:32:22511
   Coding: 0000172
               P1640 - 000 - EEPROM Error - Intermittent
                    Mileage: 177299 km
                    Time: 03:01:52
                    Temperature: 16.0°C
                    Temperature: 19.0°C
                    Voltage: 11.938 V
   Coding: 0010000
                    Reset counter: 64
                    Mileage: 177299 km
                    Time: 03:08:35
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 166
                    Hex Value: 0x0000
                    Reset counter: 64
                    Mileage: 177299 km
                    Time: 03:08:36
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011110
                    Count: 242
                    Hex Value: 0x0000
                    Reset counter: 64
                    Mileage: 177299 km
                    Time: 03:08:36
                    Reset counter: 64
                    Mileage: 177299 km
                    Time: 03:08:36
   Coding: 00038805
   Shop #: WSC 01287
   Coding: 00208933
   Shop #: WSC 01287
   Coding: 100002
   Coding: 0012336
   Coding: 0002022
00576 - Terminal 15
   Coding: 0007104
   Coding: 0000005
            014 - Defective
                    Mileage: 177235 km
                    Time: 00:20:27
   Coding: 0000188
   Coding: 0000258
                    Reset counter: 64
                    (no units): 4.0
                    Voltage: 11.90 V
                    Reset counter: 64
                    (no units): 4.0
                        Not OK
                    (no units): 4
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 64
   Coding: 0000188
   Coding: 0010000
            000 - - - MIL ON
                    Reset counter: 49
                    Mileage: 177235 km
                    Voltage: 11.50 V
                    Count: 100
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 - - - MIL ON
                    Fault Frequency: 8
                    Reset counter: 64
                    Mileage: 177299 km
                    Voltage: 11.70 V
                    Count: 98
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 11110101
                    Reset counter: 64
                    Mileage: 177298 km
                    Voltage: 11.80 V
                    Count: 101
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:32, VBatt start/end: 12.1V/12.0V)-----------
Do you have a scan from before the ECU change?
If not, why not? ;)
