Trailer not working fault code 00532
alike
Norway
C?ID=282711 (NRRT)
Hi. So i had my car on EU periodic control, and the mechanic gave me feedback that the trailer connection was not working correctly.
I got Touran 2008 model with original vw trailer module:
 Address 69: Trailer       Labels: 1K0-907-383-V2.clb
Control Module Part Number: 1K0 907 383 E    HW: 1K0 907 383 E
  Component and/or Version: Anhaenger     H07 0050
           Software Coding: 0100000100000000
            Work Shop Code: WSC 00000 000 00000
                      VCID: 2F549EB47EEDD1370C-807A
After checking old fault codes i got this:
            011 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10101011
                    Fault Frequency: 15
                    Reset counter: 122
                    Mileage: 127944 km
                    Time: 18:25:17
Milage now is like 228 000 km. i reseted this fault code.
After checking connections on the trailer socket i didnt get any voltages out when testing left/right signal. Something was wrong. So i checked further....
I checked the fuses related to trailer and there was one blown 20A fuse for the F40 trailer detection control unit. I replaced it with a new one and used the 69-trailer 03 output tests to generate volts for each signal and other tests. All of the tests where found to be OK after testing each with output test. However, i dont have trailer and i cant test it to be sure its working. Can i be sure that if these output tests generate 12volts connecting to correct place with mulitmeter, will it also work when connected to any electrically working trailer?
One more thing. I think i get lower volts than the battery itself when testing, showing just 11.46 volts in trailer socket. And also another weird thing, there is constantly 1.76 volts on each output when there is no signal. Can this be sign of some trouble? Some earth leakage or something?
BTW in case there si a need for it, here is my complete auto diag:
Monday,02,March,2020,11:09:54:61597
VCDS Version: 19.6.2.2 (x64)
VIN: WVGZZZ1TZ9W005714   License Plate:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 69
VIN: WVGZZZ1TZ9W005714   Mileage: 228590km-142039miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 RN    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  1989
   Revision: --H08---    Serial number: VWX7Z0H43NE08V
   Coding: 0000072
   Shop #: WSC 00440 218 194275
   VCID: 7CCE79F83F1BFAAFF9-8028
   Revision: 00H11001
   Coding: 0021190
   Shop #: WSC 01324 785 00200
   VCID: 73DC52C41245B5D7A8-8026
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 69E030AC40897F0712-803C
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000008487102
   Coding: 088B8F2100040F0047120C000000000000087B075C000120000000000000
   VCID: 325297C0ADDFFCDF63-8066
   Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 140508 021  0501
   Coding: 00038805
   Shop #: WSC 01324
                    Fault Status: 01101100
                    Reset counter: 87
                    Mileage: 228591 km
                    Voltage: 11.85 V
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 D    HW: 1T0 909 605 D
   Component: 04 AIRBAG VW8   021 0100
   Revision: 02021000    Serial number: 003B9D096S81
   Coding: 0012340
   VCID: 365AABD041B7E0FF4F-8062
   Subsystem 1 - Serial number: 6332QSME67321F29K
   Subsystem 2 - Serial number: 6342QSME624B1A05F
   Subsystem 3 - Serial number: 6352QSME594F1475R
   Subsystem 4 - Serial number: 6362QSME594F793D0
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Component: J0527           752 0101
   Coding: 0000042
   VCID: 7F348EF42E0DE1B7DC-802A
   Part No SW: 1T0 920 864 A    HW: 1T0 920 864 A
   Revision: V0002000    Serial number: VWX7Z0H43NE08V
   Coding: 0007101
   Shop #: WSC 52376 001 1048576
   VCID: 335C92C452C5F5D768-8066
   Part No: 1K0 815 071 T
   Component: Zuheizer        050 2504
   Revision: 00050000    Serial number: 09009839000000
   Coding: 0000011
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 230508F2001595
   Coding: E9801F46000A028002
   VCID: 3558ACDC5CB1EBE746-8060
   Component: IMMO            VDD 1212
   Part No SW: 1T0 959 701 M    HW: 1T0 959 701 M
   Component: Tuer-SG         008 2007
   Coding: 0000053
   VCID: 41B0C80C18795747EA-8014
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   VCID: 2A628FA0850FB41FDB-807E
   Part No: 1K0 959 433 CP
   Coding: 80C8020C7F2D8405484B036010CC
   VCID: 00360D0853F39E4FA5-8054
   Part No SW: 1T0 959 702 M    HW: 1T0 959 702 M
   Component: Tuer-SG         007 2007
   Coding: 0000053
   VCID: 42B2C7001D7F4C5FF3-8016
Address 56: Radio        Labels: None
   Part No SW: 3TD 035 156     HW: 3TD 035 156
   Component: RadioSK46MID  006 0010
   Coding: 01000424041000
   Shop #: WSC 00078 790 00000
   VCID: 7F348EF4EE0DE1B7DC-802A
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0050
   Revision: 3A002002    Serial number: 00000111882866
End-------------------------(Elapsed Time: 01:09)--------------------------
siLc
Tallinn, Estonia
C?ID=330192
If a trailer-related fuse was blown, you replaced it, cleared the fault in module 69 and the fault didn't come back - then you should be good. I wouldn't worry about the voltage thing unless after connecting a trailer, the fuse blows again. You can check with a trailer simulator.
alike
Norway
C?ID=282711 (NRRT)
I guess i have to check with a real trailer to be sure. If im not lucky and there is something wrong when the mechanic tests it again, it will cost me some more money to go back to the EU control workshop once again.
Simulator? Is this something cheap i can buy? Sounds expensive.
alike
Norway
C?ID=282711 (NRRT)
Thank you all for suggestions.
I tried a trailer today, and this is what happened: There were lights that normally lit up when you connect a trailer. Like sign lights and the red ones that usually lit up when car is started with trailer attached. However, no brake or turning lights worked. I dont know if the fault is with the trailer or the car connection. Also i used a 13p to 7p adapter, and im not sure if its something wrong with that one. I just ordered one of those simulators to be sure.
alike
Norway
C?ID=282711 (NRRT)
I got the simulator and tried it.
All the lights on the simulator shows on without using/testing them, seams like the 1.75volts on all measurements on lights that are not enabled show there is something wrong with the trailer unit or something. When i actually use the lights, ie the brake lights, they do work. However the other lights are sometimes on, or showing yellom instead of green. To be honest i dont quite understand this simulator... i couldnt find any manual on it either.
Not sure what to do next but im considering changing the trailer unit. Then another question comes to mind. What kind of trailer units can i use with this wiring and connection? My model is 1k0 907 383 e. One black and one red connector to it.
Edit: Is for example this model the same as the one i have? Looks exact same. There are several models that look exactly same, but have different ending, instead of E it is either B, D, or F. Is this the revision of the hardware? And can i use backwards, forwards?
Polofan
Denmark
C?ID=270984
Why not try that .
alike
Norway
C?ID=282711 (NRRT)
Ive have bought a used module with same hardware version, but different software version. I measure the same fault with that attached as the former one. But do i need to program the trailer module somehow?
I have measured again with volts... i get 1.63V between earth pin 13 on trailer and pin 5, 7, 4, 1. This is weird!
12Volts between pin 13 and 9.
350 ohms between earth pin 13 and 12 volt pin 9.
Why am i measuring 1.63V between earth and several of the plugs on the trailer when they are not in use? I am stuck and need help with the diagnose.
Edit: I read somewhere that there can be a bulb failure test builtin and sometimes its 2V, 3V and similar. Is this what i have been experiencing?
That would be my guess; the module is supplying a low voltage (maybe even a PWM signal with low duty cycle) to see if there's a bulb on that circuit. What happens of you apply a load?
